toonek Posted November 15, 2019 Posted November 15, 2019 Hello all, I write this topic to be my guide in future reference and maybe some help for other linux noobies like myself. A the beginning my idea was to use AMLogic box to use Octoprint and 3d party software called Klipper for my DIY 3d prinetr. Quick search in google shows that it is doable but there are old topics, posts and old images for s905 processors. At first I had started with newer images from @balbes150 like Armbian_5.98_Aml-g12_Ubuntu_bionic_default_5.3.0_desktop_20191002.img and tried to start WIFI. Like many other before me I tried modprobe wifi_dummy .. etc and nothing good happened - complete linux noob. After trying with numerous images i bought wifi usb dongle with Realtek RTL8188FTV - nothing.... Everywhere there were some whispers - " you need to compile driver " , " you need to compile from source " , " you need to install headers " - DEVILS voice I must say. So i started to digging dipper and with struggle I had managed to enable build-in RTL8189ES and usb dongle. Many thanks to others before me, especially to @balbes150 for great work, and Chris Riley from his YT chanell, and creator of Klipper - KevinOConnor To be honest I`m not completely understand what I`m doing but it is working for some reason :] I`m using Armbian_5.98_Aml-g12_Ubuntu_bionic_default_5.3.0_desktop_20191002.img. This was my steps: 1. After properly installing on sd card and setting user and password I connected to the box with putty - it is more convenient because i had only small BT air mouse/keyboard 2. Then like armbina DOCs says https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver): sudo armbian-config Software -> install kernel headers , you could also already apt get update here exit cd /usr/src/linux-headers-$(uname -r) make scripts 3. I had use guides from this post apt install build-essential libncurses-dev bison flex libssl-dev libelf-dev git clone https://github.com/150balbes/Amlogic_s905-kernel.git cd Amlogic_s905-kernel make oldconfig make prepare make modules_prepare touch Module.symvers I didn`t change utsrelease.h with sudo nano include/generated/utsrelease.h cd .. git clone https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git cd wireless-regdb && cp regulatory.db regulatory.db.p7s /lib/firmware/ cd .. 4. For the USB dongle with RTL8188FTV : git clone https://github.com/kelebek333/rtl8188fu.git cd rtl8188fu we need to change some EXTRA_CFLAGS too and I think it is self explanatory, just add the missing lines, remove #: nano Makefile EXTRA_CFLAGS += -Wno-error=incompatible-pointer-types EXTRA_CFLAGS += -Wno-incompatible-pointer-types EXTRA_CFLAGS += -Wno-vla EXTRA_CFLAGS += -Wno-error=date-time (exit with ctrl+x) And now second difference form post above - we use different image so we have lib/modules/5.3.0-aml-g12 but we can use uname -r make ARCH=arm64 KSRC=../Amlogic_s905-kernel CONFIG_POWER_SAVING=n sudo install -p -m 644 rtl8188fu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless /sbin/depmod -a sudo modprobe rtl8188fu And Voila! now we can use nmtui to activate and config new connection so hit it in terminal: nmtui 5. For RTL8189ES cd ~ git clone https://github.com/pazulin/rtl8189ES_linux.git it has fix for 5.3 kernell cd rtl8189ES_linux change EXTRA_CFLAGS like above nano Makefile EXTRA_CFLAGS += -Wno-error=incompatible-pointer-types EXTRA_CFLAGS += -Wno-incompatible-pointer-types EXTRA_CFLAGS += -Wno-vla EXTRA_CFLAGS += -Wno-error=date-time (exit) make ARCH=arm64 KSRC=../Amlogic_s905-kernel CONFIG_POWER_SAVING=n sudo install -p -m 644 8189es.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless /sbin/depmod -a sudo modprobe 8189es After that nmtui works and no need to add modprobe to autostart etc. 6. For octorpint use: https://community.octoprint.org/t/setting-up-octoprint-on-a-raspberry-pi-running-raspbian/2337 and if you would like to watch nice guide : Then you only need to install Klipper and configure it also from nice guide: cd ~ git clone https://github.com/KevinOConnor/klipper ./klipper/scripts/install-ubuntu-18.04.sh rest on: https://www.klipper3d.org/Installation.html#configuring-klipper
scmsystm Posted March 4, 2020 Posted March 4, 2020 Hello, I have running armbian on S905X tv box and already installed octoprint and klipper, it was running great with my tarantula pro printer. is there any ways to control usb power through octoprint? I dont want my printer screen always turn on when not used.
amirdelta Posted April 6, 2020 Posted April 6, 2020 Hi there, I've a device with similar configuration, and tried to download kernel headers with no success. Is there any other place or option to do the job ? I have a question in my mind for a long long time : why there is not a step by step guide to integrate wifi drivers to armbian versions? where is the botle neck ? I see a lot of people are interested in but hadn't find a way to do this. I want to write a suitable instruction for my device atleast. could you please give me a hand? @toonek @balbes150
balbes150 Posted April 7, 2020 Posted April 7, 2020 On 4/6/2020 at 6:18 PM, amirdelta said: I want to write a suitable instruction for my device atleast. could you please give me a hand? Expand Do you want to write instructions ? Great.
amirdelta Posted April 7, 2020 Posted April 7, 2020 hi yeah! I think there numerous guys outside witch are interested in getting wifi to work(as i said: atleast for 8189es) so if i have had access to source of kernel header, i could have right a visual instruction to. p.s: yesterday i doscovered the latest firmware (20.05.10 )added support for, but i'm at the first place to help if possible. so try me, i wont let you down :-) finally : The latest version is AWESOME !!! really eye catching ! I dont use desktop usually but i cas see a big work behind. so Thank you all for all the hard work. wish you best.
balbes150 Posted April 7, 2020 Posted April 7, 2020 On 4/7/2020 at 1:04 PM, amirdelta said: as i said: atleast for 8189es Expand He is already part of the image and works on Tanix T9S 1
SteeMan Posted April 7, 2020 Posted April 7, 2020 On 4/7/2020 at 1:04 PM, amirdelta said: so if i have had access to source of kernel header, i could have right a visual instruction to. Expand You do have access to the source for these builds: https://github.com/150balbes/Build-Armbian and https://github.com/150balbes/Amlogic_s905-kernel (actually these git trees are usually a few days behind the most recent balbes150's builds as he waits for code changes to stabilize before pushing them back to these github trees) I would recommend you start by pulling the Build-Armbian environment, and building the equivalent of what you currently have installed. You will see that the build system creates the kernel header package as part of the build process. Then you can experiment with improvements and contribute back to the overall community. 1
lifeform Posted May 21, 2020 Posted May 21, 2020 i cannot compile it with 5.7.0 rc6 kernel. could you confirm it? thx
