Hi all, has anyone managed to get wifi working on the Buster image for M4 v 1 ? Works perfectly with Bionic but I couln't connect at all on the Buster image ( eth0 on physical cable was fine ), using armbian-config lists available networks but is unable to connect ( which is what the error message is )
1 hour ago, martinayotte said:
Maybe you should try the firmware I've provided during v2 testing here :
I think I did try that Martin
