when I used the command "nand-sata-install" ,then i  select The first one, install Armbian from the SD card to the Built in emmc, After step-by-step execution, I will prompt poweroff. Then I remove the SD card and prepare to start from EMMC. However, the following error prompt appears. I cannot enter the system from EMMC normally,Please help me, thank you
TIM-1.0
WTMI-devel-18.12.1-e6bb176
WTMI: system early-init
CPU VDD voltage default value: 1.155V
NOTICE: Booting Trusted Firmware
NOTICE: BL1: v1.5(release):1f8ca7e (Marvell-devel-18.12.2)
NOTICE: BL1: Built : 16:23:10, May 21 2019
NOTICE: BL1: Booting BL2
NOTICE: BL2: v1.5(release):1f8ca7e (Marvell-devel-18.12.2)
NOTICE: BL2: Built : 16:23:11, May 21 2019
NOTICE: BL1: Booting BL31
NOTICE: BL31: v1.5(release):1f8ca7e (Marvell-devel-18.12.2)
NOTICE: BL31: Built : 16:2
U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Feb 20 2019 - 09:45:04 +0100)
Model: Marvell Armada 3720 Community Board ESPRESSOBin
CPU 1000 [MHz]
L2 800 [MHz]
TClock 200 [MHz]
DDR 800 [MHz]
DRAM: 1 GiB
Comphy chip #0:
Comphy-0: USB3 5 Gbps
Comphy-1: PEX0 2.5 Gbps
Comphy-2: SATA0 6 Gbps
SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: ncq led only pmp fbss pio slum part sxs
PCIE-0: Link down
MMC: sdhci@d0000: 0, sdhci@d8000: 1
Loading Environment from SPI Flash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB
OK
Net: eth0: neta@30000 [PRIME]
Hit any key to stop autoboot: 0
starting USB...
USB0: Register 2000104 NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
** Bad device usb 0 **
## Executing script at 06d00000
Wrong image format for "source" command
/boot/
scanning bus for devices...
Device 0: unknown device
** Bad device scsi 0 **
/boot/
** File not found /boot.scr **
/boot/
1119 bytes read in 15 ms (72.3 KiB/s)
240 bytes read in 4 ms (58.6 KiB/s)
Card did not respond to voltage select!
** Bad device mmc 0 **
Bad Linux ARM64 Image magic!
/boot/
Marvell>>
Well, take a close look at your hardware - is the emmc installed?? Just because you bought it doesn't mean you got what you paid for. emmc is an OPTION on the espressobin v5 and v7.
I have a v5 without emmc and it gives an error if I try to install to emmc.
Look under the board - on a v5 with the ethernet ports oriented toward you there should be four chips to the right of center. Is there a place for a fourth one with an outline and no chip? No emmc ...
Espressobin v5 bottom
You should edit the /boot/boot.cmd, change mmc device to 1:1 (eMMC) then:
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
I have the same problem on v7 board. u-boot see's the emmc but it's not there after buster starts.
TIM-1.0
SVC REV: 5, CPU VDD voltage: 1.132V
NOTICE:  BL1: Built : 16:26:25, May 21 2019
NOTICE:  BL2: Built : 16:26:26, May 21 2019
       CPU     1000 [MHz]
       L2      800 [MHz]
       TClock  200 [MHz]
       DDR     800 [MHz]
DRAM:  1 GiB
Comphy chip #0:
PCIE-0: Link down
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB
OK
starting USB...
USB XHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
/boot/
1119 bytes read in 26 ms (42 KiB/s)
240 bytes read in 10 ms (23.4 KiB/s)
18246144 bytes read in 1004 ms (17.3 MiB/s)
8541019 bytes read in 482 ms (16.9 MiB/s)
** File not found /boot/dtb/marvell/armada-3720-community.dtb **
10619 bytes read in 16 ms (647.5 KiB/s)
## Loading init Ramdisk from Legacy Image at 01100000 ...
   Image Name:   uInitrd
   Data Size:    8540955 Bytes = 8.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 06000000
   Booting using the fdt blob at 0x6000000
   Loading Ramdisk to 3ee05000, end 3f62a31b ... OK
   Using Device Tree in place at 0000000006000000, end 000000000600597a
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.6.19-mvebu64 (root@7H1YD42) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architect
ure 9.2-2019.12 (arm-9.10))) #trunk SMP PREEMPT Tue Aug 25 02:23:13 CDT 2020
[    0.000000] Machine model: Globalscale Marvell ESPRESSOBin Board
[    0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '')
[    0.000000] printk: bootconsole [ar3700_uart0] enabled
Loading, please wait...
Starting version 241
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Begin: Will now check root file system ... fsck from util-linux 2.33.1
[/sbin/fsck.ext4 (1) -- /dev/sda1] fsck.ext4 -a -C0 /dev/sda1
/dev/sda1: clean, 39102/455952 files, 361706/1916700 blocks
done.
done.
Welcome to Armbian 20.08.0-trunk Buster!
Marvell>> mmc dev 1
switch to partitions #0, OK
mmc1(part 0) is current device
Marvell>> mmc info
Device: sdhci@d8000
Manufacturer ID: 15
OEM: 100
Bus Speed: 52000000
Mode : MMC High Speed (52MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.3 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 512 KiB ENH
