My cursor in console (not desktop environment) disappeared after apt upgrade from a clean install.
Device : orange pi pc
Version: ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i
I also changed led triggers red one to mmc0 and green to timer. I run apt list>aptlist.txt and attach result to post. it changed a lot i install further packages.
aptlist.txt
I found this fix, credit to youka
http://forum.odroid.com/viewtopic.php?f=117&t=11758
Re: fbcon cursor
icon_post_target_unread.gifby youka Â» Fri Mar 27, 2015 10:57 pm
Anyway, all that aside...There's a nice work-around in the link Holzhaus provided...
CODE: SELECT ALL infocmp >> terminfo.txt
sed -i.bak -e 's/?0c/?112c/g' -e 's/?8c/?48;0;64c/g' terminfo.txt
tic terminfo.txt
tput cnorm
Then just re-run "tput cnorm" each time you log in. This should be good enough for now. At least now I can edit text files without being completely lost icon_e_biggrin.gif
To display grey-block cursor in console i used this script:
  # delete console settings for current user
  rm -rf ~/.terminfo
  # delete console settings for root
  sudo rm -rf /etc/terminfo/*
  cd /tmp
  # copy default console settings to a file
  infocmp -A /lib/terminfo linux > terminfo
  # replace 'bad' cursor params (cnorm and cvvis) with new (man terminfo)
  sed -i -e 's/?0c/?16;0;240c/g' -e 's/?8c/?16;0;240c/g' terminfo
  # compile the edited terminfo
  sudo tic terminfo
last command launched as root, puts compiled data in /etc/terminfo
since ~/.terminfo is removed, parameters will be read from /etc/terminfo (for current user and root)
now create script in /etc/profile.d with one line:
tput cnorm
now cursor should be anywhere at anytime except login prompt.
I use the solution posted by markbirss.
It works.
I just wanted to add that you should enter those commands as a super user, otherwise the cursor will disappear when you open vim as a super user. This happened to me on a previous install and I was using a workaround to edit read-only files. Today, in a fresh install, I entered those commands as a super user and I'm not having that problem anymore.
