perfstr Posted December 17, 2019 Posted December 17, 2019 Hello, I've just found a topic about removing Allwinner legacy. I work with Orange Pi PC Plus board, H3 CPU. Do I understand correctly that the option to build system based on old v.3.4 kernel will be removed? Once I experienced a problem with system shutdown using newer kernel - got System halted message. This is why I decided to continue with legacy kernel. Please advise.
Igor Posted December 17, 2019 Posted December 17, 2019 48 minutes ago, perfstr said: will be removed? It was already removed from the build system. You still can run, download (from "OLD") and build old images (with some errors) by changing LIB_TAG=v19.08 but you are on your own. Nobody maintains that branch and Jessie repository has been dropped. 48 minutes ago, perfstr said: experienced a problem Problems will eventually be fixed. Perhaps this already is in 5.3.y ... ? Have faith.
