Hello everybody,
I'd like build the module for my usb dongle with rtl8821cu. Im using the 4.4.154 version on rk3328 tvboxes. I need the kernel sources. Is the a repo on github for this build? Thanks and excuse me for my English
I have same problems during the installation with armbian-config. Anyway I have downloaded the kernel source, Renegade option in compile.sh, and Im using insmod and the 8821cu.ko is loaded. But the kernel freeze with nulla pointer in rtw_os_ndev_register. May Be there Is a bug in halmac routines. Iam already using the driver on x86 Ubuntu 1604 and It works well. Im using old version 4.4.154 on rk3228
Build image and try:
https://github.com/armbian/build/pull/1690
I don't have this hardware but it doesn't crash on loading:
[  119.107213] RTW: module init start
[  119.107222] RTW: rtl8821cu v5.4.1_28754.20180921_COEX20180712-3232
[  119.107225] RTW: build time: Dec 23 2019 21:19:20
[  119.107228] RTW: rtl8821cu BT-Coex version = COEX20180712-3232
[  119.107378] usbcore: registered new interface driver rtl8821cu
[  119.107382] RTW: module init ret=0
Running on Olimex Lime A64 http://ix.io/25kb
Yes the module is ready. But as soon as the usb is ready it freezes. There are many problems in rtl8821c_read_efuse function. Im just detecting the problem, maybe there is a problem with country code.
I started using armbian yesterday, I am really having fun. So I share my driver experience for rtl8821CU...
To get my CUDY  WU650   to work, I had to download   rtl8821CU_rtl8731AU_WiFi_linux_v5.8.1.7_37266.20200929_COEX20200616-4141.tar.gz
from the Cudy support page ( www.cudy.com/download ).  I followed their documentation, but got errors: No such file or directory for /lib/modules/5.10.21-meson64/build.
So I installed the kernel headers (linux-headers-current-meson64_21.02.3_arm64.deb)  and
dtb ( not sure if that is needed - linux-dtb-current-meson64)   using synaptic.
The make script from cudy  tries to use   arch/aarch64/Makefile, but fails:      No rule to make target 'arch/aarch64/Makefile'.  Stop.
So I copied   /lib/modules/5.10.21-meson64/build/arch/arm64  to  /lib/modules/5.10.21-meson64/build/arch/aarch64.
sudo make
sudo make install
sudo modprobe -r 8821cu
then worked  perfectly...
pls enjoy...
   cic_as
