OPI stuck after restart Can`t connect to Network
djmcg
Hello
Today my system was suspended after 5 times hit power button OPI was turn oFF
After turn on,  can`t connect to Network by eth0 or any WI FI.
I have no idea whats happen I swap the wire but Led on eth connector in OPI  yellow/green is blinking.
Restart router and is the same
What I should do?
Get a different sd card and try to boot it with a fresh image to make sure the board is not broken.
If it boots the only way to debug this further is to help yourself to an USB-TTL converter to get a serial console to the board.
I burn new image on second SD card internet work properly.
But I need really repair the old image.
I'm attach screen from the armbian config monitor.
Look like problem with firewall network
Pls check
I assume you connected a serial console to get this information?
Anyway as far as I see there is a problem with dns resolution.
Check if /etc/resolv.conf containing valid dns server addresses.
Check if you can ping a known IPv4 address like 141.1.1.1, 8.8.8.8 or 9.9.9.9
Also interesting
https://github.com/armbian/build/blob/f4f33ce2274d77a6d97a5fbda4db279731098a4e/packages/bsp/common/usr/bin/armbianmonitor#L151
It seems like for any reason the script did not stop here as it should...
I`m connect directly to OPI .  (desktop version)
The /etc/resolv.conf  is the same like version where armbian works fine connection.
I have no possible to ping any address
The same
Regarding ifconfig is missing information inet netmask broadcast.
I just type
~sudo ifconfig eth0 (my dedicated IP) netmask 255.255.255.0 up
and works.
But after reboot is still not connect
The cheap and dirty way would be to add ifconfig eth0 (my dedicated IP) netmask 255.255.255.0 up to your /etc/rc.local
The correct way would be to check /etc/network/interfaces as the static ip should have been set there.
