Scaccomatto Posted January 7, 2020 Posted January 7, 2020 Hi everyone, I installed the latest version of armbian available today for cubietruck. The volume coming out of the 3.5mm jack is really low. I checked on pulseaudio and the volume is set to maximum. I'm from another distro and didn't have this problem with audio before. Could someone help me? There are other people that have the same issue? Thanks in advance.
Igor Posted January 7, 2020 Posted January 7, 2020 3 hours ago, Scaccomatto said: Could someone help me? I don't know about this problem, but prooviding logs with armbianmonitor -u significantly raises chances that issue is getting addressed. And which kernel have you used before when things worked. Which distribution is not relevant information.
voka Posted January 9, 2020 Posted January 9, 2020 (edited) I have the same problem. Logs: http://ix.io/26UV Edited January 9, 2020 by voka
Harald Posted January 14, 2020 Posted January 14, 2020 (edited) Me too, Using the USB-audio everything is fine. Using line the sound volume is very very low. I changed last week from the armbian of 2015/2016 to the latest version. Edited January 14, 2020 by Harald http://ix.io/271X
Harald Posted February 21, 2020 Posted February 21, 2020 Push: Has no one else this problems and is there no solution? I tried to use onboard bluetooth instead line, but that also don't work.
