I am starting Rock64 again after a long layoff.
I'm a bit rusty, please forgive any forgetfulness.
I tried downloading the Rock64 desktop image, but it was 404.
I downloaded Armbian_19.11.6_Rock64_bionic_legacy_4.4.207_desktop.7z
Unzipped it, and used etcher to write it to the micro-SD card.
Booted up, but didn't get to a graphical desktop.
Created a new user OK.
I did # apt update, # apt upgrade, # reboot now.
Still no graphical desktop.
I did # apt install lxde lxdm. (this used to work OK).
As expected, the installer asked  if i wanted to use lxdm as the display manager. Yes.
$ sudo armbian-config
Updated the timezone OK.
Did Enable Desktop OK, but this didn't get me to lxde.
Did Enable autologin.
Reboot got me to LXDE.
So far so good.
But the USB keyboard and mouse don't work. Tried numerous mice and USB sockets.
ALT+f1 now doesn't get back to command line so I am stuck.
Have I forgotten something?
Support for Rock64 is still not matured while maker is already on their future products ... there are three (3) HW board revisions which only raises support expenses.
:) No problem about that.
You found a bug which was fixed while typing this.
I tested the exact same image on my Rock64 Revision 3. No problems.
First login:
"Desktop environment will not be enabled if you abort the new user creation"
We want to keep system clean, so there are no users on the system beside system ones and running desktop under root is not a good idea. Some applications will also not work. If you skipped our scripts and created new user manually ... there will be no desktop and you are on your own to get it up.
My mouse and keyboard works straight up. Even over KVM ... but USB troubles are known. Try other port.
I have a similar problem. The keyboard does not work. Mouse and desktop work normally.
Different keyboards and different usb inputs
 Armbian 20.11.6 Buster with Linux 5.9.14-rockchip64
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 1a2c:0042 China Resource Semico Co., Ltd
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Sorry wrong armbian image... I have rockpi4b image  not rockpi4c. Only one USB port is powered. Next time will be better :)
