How can I use S-TWI PL0/PL1 - i2C (orangepiZeroPlus2? (Do I need a pinctrl config?)
Hello, I have spend a lot of time trying to make it work I2C PL0/PL1 of orangepi zero plus 2 H5.
I change sunxi-h3-h5.dtsi to status="okay" and i can not to see i2c PL0/PL1 only I can see others i2c. Can anybody help me to understand what I am doing bad?
    r_i2c: i2c@1f02400 {
            compatible = "allwinner,sun6i-a31-i2c";
            reg = <0x01f02400 0x400>;
            interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>;
            pinctrl-names = "default";
            pinctrl-0 = <&r_i2c_pins>;
            clocks = <&r_ccu CLK_APB0_I2C>;
            resets = <&r_ccu RST_APB0_I2C>;
            status = "okay";
            #address-cells = <1>;
            #size-cells = <0>;
r_pio: pinctrl@1f02c00 {
            compatible = "allwinner,sun8i-h3-r-pinctrl";
            reg = <0x01f02c00 0x400>;
            interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>;
            clocks = <&r_ccu CLK_APB0_PIO>, <&osc24M>, <&rtc 0>;
            clock-names = "apb", "hosc", "losc";
            gpio-controller;
            #gpio-cells = <3>;
            interrupt-controller;
            #interrupt-cells = <3>;
            r_ir_rx_pin: r-ir-rx-pin {
                pins = "PL11";
                function = "s_cir_rx";
            r_i2c_pins: r-i2c-pins {
                pins = "PL0", "PL1";
                function = "s_i2c";
Edited by TRS-80
put in code and spoiler block
I gave it a try and I got /dev/i2c-2 added to my previous setup, although I didn't plug any devices on it yet ...
root@orangepizeroplus2:~# i2cdetect -l
i2c-1	i2c       	DesignWare HDMI                 	I2C adapter
i2c-2	i2c       	mv64xxx_i2c adapter             	I2C adapter
i2c-0	i2c       	mv64xxx_i2c adapter             	I2C adapter
Thanks martinayotte.
I try to see i2c-1 but nothing is shown even when I change connections between i2c ports (0<>1). May be it's a problem related to pinmux?. Thanks for your help
# i2cdetect -l
i2c-1    i2c           mv64xxx_i2c adapter                 I2C adapter
# i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- 0a 0b -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
# i2cdetect -y 1
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
