maybe_diereses Posted January 28, 2020 Posted January 28, 2020 (edited) Hello! Really appreciating armbian having good notes on how to get up and running on a specific device. Thanks! I have these wifi cards, RTL8821AE. If I `apt install hostapd` I can get hostapd to start up. If I use `hostapd-realtek` it doesn't. Some of the armbian docs say look for and try '/usr/sbin/hostapd-rt', but I can't figure out how to get that; Maybe that note is out of date? It starts up, but doesn't seem to work. I have wlp0s0 in a bridge with the LAN ports. It seems like I'm able to associate to my SSID, but nothing's going across the bridge. No DHCP is happening, etc. I'm just trying to make a access point right now. The gateway/dhcp service is a different box. Am I just forgetting a little linux config, or is there probably something wrong with the driver? Here's a bunch of output from hostapd -d. Spoiler nl80211: TX queue param set: queue=2 aifs=3 cw_min=15 cw_max=63 burst_time=0 --> res=0 nl80211: TX queue param set: queue=3 aifs=7 cw_min=15 cw_max=1023 burst_time=0 --> res=0 wlp0s0: interface state COUNTRY_UPDATE->ENABLED wlp0s0: AP-ENABLED wlp0s0: Setup of interface done. ctrl_iface not configured! RTM_NEWLINK: ifi_index=8 ifname=wlp0s0 operstate=2 linkmode=0 master=6 ifi_family=0 ifi_flags=0x1003 ([UP]) RTM_NEWLINK: ifi_index=8 ifname=wlp0s0 operstate=2 linkmode=0 master=6 ifi_family=0 ifi_flags=0x1003 ([UP]) RTM_NEWLINK: ifi_index=8 ifname=wlp0s0 master=6 operstate=2 ifi_family=7 ifi_flags=0x1003 ([UP]) nl80211: Add ifindex 6 for bridge br0 nl80211: Add own interface ifindex 6 (ifidx_reason 8) nl80211: ifindex 6 already in the list RTM_NEWLINK: ifi_index=8 ifname=wlp0s0 master=6 operstate=6 ifi_family=7 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP]) nl80211: Add ifindex 6 for bridge br0 nl80211: Add own interface ifindex 6 (ifidx_reason 8) nl80211: ifindex 6 already in the list RTM_NEWLINK: ifi_index=8 ifname=wlp0s0 master=6 operstate=6 ifi_family=7 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP]) nl80211: Add ifindex 6 for bridge br0 nl80211: Add own interface ifindex 6 (ifidx_reason 8) nl80211: ifindex 6 already in the list RTM_NEWLINK: ifi_index=8 ifname=wlp0s0 operstate=6 linkmode=0 master=6 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP]) ^CSignal 2 received - terminating hostapd_interface_deinit_free(0x5576b29ba0) hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1 hostapd_interface_deinit(0x5576b29ba0) wlp0s0: interface state ENABLED->DISABLED hostapd_bss_deinit: deinit bss wlp0s0 wlp0s0: Deauthenticate all stations nl80211: send_mlme - da= ff:ff:ff:ff:ff:ff noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0xc0 (WLAN_FC_STYPE_DEAUTH) nlmode=3 nl80211: send_mlme -> send_frame nl80211: send_frame - Use bss->freq=2432 nl80211: send_frame -> send_frame_cmd wlp0s0: AP-DISABLED hostapd_cleanup(hapd=0x5576b2aed0 (wlp0s0)) wlp0s0: CTRL-EVENT-TERMINATING hostapd_free_hapd_data(wlp0s0) hostapd_interface_deinit_free: driver=0x55703d8ca8 drv_priv=0x5576b2ef10 -> hapd_deinit nl80211: deinit ifname=wlp0s0 disabled_11b_rates=0 nl80211: Remove monitor interface: refcount=0 nl80211: Remove beacon (ifindex=8) netlink: Operstate: ifindex=8 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP) nl80211: Set mode ifindex 8 iftype 2 (STATION) nl80211: Teardown AP(wlp0s0) - device_ap_sme=0 use_monitor=0 nl80211: Unsubscribe mgmt frames handle 0x888888ddfe3a5b69 (AP teardown) hostapd_interface_free(0x5576b29ba0) hostapd_interface_free: free hapd 0x5576b2aed0 hostapd_cleanup_iface(0x5576b29ba0) hostapd_cleanup_iface_partial(0x5576b29ba0) hostapd_cleanup_iface: free iface=0x5576b29ba0 and the hostapd config Spoiler ssid=ARMBIAN interface=wlp0s0 bridge=br0 hw_mode=g channel=5 #driver=nl80211 ignore_broadcast_ssid=0 logger_syslog=0 logger_syslog_level=0 wmm_enabled=1 wpa=2 preamble=1 wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27 wpa_passphrase=12345678 wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP auth_algs=1 macaddr_acl=0 noscan=1 ### IEEE 802.11n #ieee80211n=1 #ht_capab= country_code=US #ieee80211d=1 ### IEEE 802.11n ### IEEE 802.11a #hw_mode=a ### IEEE 802.11a ### IEEE 802.11ac #ieee80211ac=1 #vht_capab=[MAX-MPDU-11454][SHORT-GI-80][TX-STBC-2BY1][RX-STBC-1][MAX-A-MPDU-LEN-EXP3] #vht_oper_chwidth=1 #vht_oper_centr_freq_seg0_idx=42 ### IEEE 802.11ac # controlling enabled ctrl_interface=/var/run/hostapd ctrl_interface_group=0 Edited January 28, 2020 by maybe_diereses
TRS-80 Posted January 28, 2020 Posted January 28, 2020 In Debian, I think you might need to install firmware-realtek package, which is in non-free (you will need to add that to your sources.list if not already there). See: https://wiki.debian.org/rtl819x Please remember to report back if that works or not.
maybe_diereses Posted January 28, 2020 Author Posted January 28, 2020 Thanks! I must have installed that at some point already. Quote apt list firmware-realtek Listing... Done firmware-realtek/stable,stable,now 20190114-2 all [installed] Here's when I try with hostapd-realtek Spoiler root@espressobin:~# hostapd -d /etc/hostapd.conf random: Trying to read entropy from /dev/random Configuration file: /etc/hostapd.conf ctrl_interface_group=0 drv->ifindex=8 Configure bridge br0 for EAPOL traffic. ioctl[SIOCSIWMODE]: Invalid argument Could not set interface to mode(3)! Could not set interface to master mode! rtl871xdrv driver initialization failed. hostapd_interface_deinit_free(0x5575ac98d0) hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1 hostapd_interface_deinit(0x5575ac98d0) wlp0s0: interface state UNINITIALIZED->DISABLED hostapd_bss_deinit: deinit bss wlp0s0 wlp0s0: AP-DISABLED hostapd_cleanup(hapd=0x5575acac30 (wlp0s0)) hostapd_free_hapd_data: Interface wlp0s0 wasn't started hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit hostapd_interface_free(0x5575ac98d0) hostapd_interface_free: free hapd 0x5575acac30 hostapd_cleanup_iface(0x5575ac98d0) hostapd_cleanup_iface_partial(0x5575ac98d0) hostapd_cleanup_iface: free iface=0x5575ac98d0 this is with the same hostapd.conf. Not sure exactly how the driver is supposed to be specified. It being commented out and using `hostapd` not `hostapd-realtek` is the closest to working so far.
Igor Posted January 28, 2020 Posted January 28, 2020 5 hours ago, maybe_diereses said: If I `apt install hostapd` I can get hostapd to start up. If I use `hostapd-realtek` it doesn't. That's expected. Realtek version is for some old driver implementation and its probably deprecated. What you have to try is this: Spoiler But also its possible that driver does not support AP at all. I am not familiar if the one you use works in AP mode or not.
maybe_diereses Posted January 28, 2020 Author Posted January 28, 2020 That process seems to have succeeded, but I'm not getting dhcp when I join. :/ iw says this thing has AP mode.
maybe_diereses Posted January 29, 2020 Author Posted January 29, 2020 Weird, it's working now. It's taking 5 or 10 minutes for my phone to get dhcp via it and perf is really bad. I dunno
