Andre1000 Posted February 6, 2020 Posted February 6, 2020 Hello, I will use the integrated CAN-Controller with the actual version of Armbian Bionic (or Buster) on the BananaPi-M1 Actually it is not possible to activate the CAN-Bus. I had activate the CAN in the armbian-config. After a reboot I the CAN0 is not integrate in the list from "ifconfig -a". What are the steps to activate the CAN-Bus on the BananaPi M1. Many thanks, André
Igor Posted February 6, 2020 Posted February 6, 2020 Providing logs with armbianmonitor -u significantly raises chances that issue is getting addressed. What do you have here: lsmod | grep can
Andre1000 Posted February 7, 2020 Author Posted February 7, 2020 Hello, with "lsmod | grep can" I have no result. The log file is attached. André armbian-hardware-monitor.log
Igor Posted February 7, 2020 Posted February 7, 2020 It seems you did the right things ... Module is enabled and it should be loaded after overlay is enabled. Try loading it manually perhaps? https://github.com/armbian/build/blob/master/config/kernel/linux-sunxi-current.config#L1540 ATM low of ideas why this doesn't work. Try legacy kernel - where people indeed reported success: armbian-config -> system -> alternative kernels and pick one with 4.19.y
Andre1000 Posted February 8, 2020 Author Posted February 8, 2020 Thank you Igor, now the CAN-bus is available. André
Igor Posted February 8, 2020 Posted February 8, 2020 1 hour ago, Andre1000 said: now the CAN-bus is available. 4.19.y or just loading a module?
wollik Posted May 11, 2020 Posted May 11, 2020 On 2/6/2020 at 11:31 PM, Andre1000 said: Hello, I will use the integrated CAN-Controller with the actual version of Armbian Bionic (or Buster) on the BananaPi-M1 Actually it is not possible to activate the CAN-Bus. I had activate the CAN in the armbian-config. After a reboot I the CAN0 is not integrate in the list from "ifconfig -a". What are the steps to activate the CAN-Bus on the BananaPi M1. Many thanks, André Hi Andre1000, please can you share the diagram of the CAN interface you are using with the bananapi ?
