@sfx2000, unfortunately I can't repro any crashes at 1.2GHz (w/the DDR clock at 504MHz)...but after some quick searching it seems that the original FA H5 clock default was 408MHz.
Could you try the attached bootloader?  This version has the DDR clock lowered to 408MHz.
Install it via my instructions above, and make sure the bootloader was written to flash correctly by checking the build date in the console when it boots ("Mar 09 2020 -14:48:34"):
U-Boot SPL 2019.10-armbian (Mar 09 2020 - 14:48:34 +0000)
DRAM: 512 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.2(debug):03ea84c-dirty
NOTICE:  BL31: Built : 14:47:31, Mar  9 2020
NOTICE:  BL31: Detected Allwinner H5 SoC (1718)
NOTICE:  BL31: Found U-Boot DTB at 0x4094d90, model: FriendlyARM NanoPi NEO 2
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
NOTICE:  PMIC: Assuming H5 reference regulator design
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
NOTICE:  PSCI: System suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2019.10-armbian (Mar 09 2020 - 14:48:34 +0000) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: FriendlyARM NanoPi NEO 2
DRAM:  512 MiB
MMC:   mmc@1c0f000: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In:    serial
Out:   serial
Err:   serial
NanoPi NEO2 v1.1 detected
Net:   phy interface7
It'll be interesting to see if this makes a difference...!
linux-u-boot-current-nanopineo2_408_MHz_20.05.0-trunk_arm64.deb
remote this week - can give the board a kick, but no console...
No problem - whenever you get a chance.  If it doesn't work, it'd be helpful to verify that this test bootloader was properly flashed/booted.
@5kft - travel challenges, but finally home...
This is really odd, and I'm thinking maybe this board just doesn't like being overclocked on the 1.3v regulator - even with 408MHz DDR timing...
sfx@nano2:~$ sudo armbianmonitor -m
[sudo] password for sfx:
Stop monitoring using [ctrl]-[c]
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
15:00:33:  816MHz  0.07   4%   2%   1%   0%   0%   0% 29.7°C  0/6
15:00:38:  816MHz  0.06   1%   1%   0%   0%   0%   0% 29.3°C  0/6
15:00:43:  816MHz  0.06   1%   1%   0%   0%   0%   0% 29.3°C  0/6
15:00:48:  816MHz  0.05   1%   1%   0%   0%   0%   0% 29.5°C  0/6
15:00:54: 1200MHz  0.05  57%   0%  56%   0%   0%   0% 46.7°C  0/6
15:01:01: 1200MHz  0.73 100%   0% 100%   0%   0%   0% 48.6°C  0/6
15:01:08: 1200MHz  0.99 100%   0%  99%   0%   0%   0% 49.1°C  0/6
15:01:16: 1200MHz  1.23 100%   0% 100%   0%   0%   0% 49.9°C  0/6
15:01:23: 1200MHz  1.73 100%   0%  99%   0%   0%   0% 49.6°C  0/6
15:01:30: 1200MHz  1.91 100%   0%  99%   0%   0%   0% 52.8°C  0/6
15:01:37: 1200MHz  2.31 100%   0%  99%   0%   0%   0% 51.7°C  0/6
15:01:44: 1200MHz  2.44 100%   0%  99%   0%   0%   0% 50.7°C  0/6
15:01:51: 1200MHz  2.57 100%   0%  99%   0%   0%   0% 55.8°C  0/6
15:01:58: 1200MHz  2.86 100%   0%  99%   0%   0%   0% 56.0°C  0/6
15:02:05: 1200MHz  2.95 100%   0%  99%   0%   0%   0% 59.4°C  0/6
15:02:12: 1200MHz  3.19 100%   0%  99%   0%   0%   0% 60.0°C  0/6
15:02:19: 1200MHz  3.25 100%   0% 100%   0%   0%   0% 60.5°C  0/6
15:02:26: 1200MHz  3.44 100%   0%  99%   0%   0%   0% 61.4°C  0/6
15:02:33: 1200MHz  3.49 100%   0% 100%   0%   0%   0% 61.6°C  0/6
15:02:41: 1200MHz  3.53 100%   0%  99%   0%   0%   0% 62.0°C  0/6
15:02:48: 1200MHz  3.68 100%   0%  99%   0%   0%   0% 62.0°C  0/6
15:02:55: 1200MHz  3.70 100%   0%  99%   0%   0%   0% 62.2°C  0/6
15:03:02: 1200MHz  3.82 100%   0%  99%   0%   0%   0% 59.8°C  0/6
15:03:09: 1200MHz  3.84 100%   0%  99%   0%   0%   0% 59.8°C  0/6
15:03:16: 1200MHz  3.94 100%   0% 100%   0%   0%   0% 58.4°C  0/6
15:03:24: 1200MHz  3.94 100%   0%  99%   0%   0%   0% 58.9°C  0/6
15:03:31: 1200MHz  3.95 100%   0%  99%   0%   0%   0% 58.4°C  0/6
15:03:38: 1200MHz  4.10 100%   0%  99%   0%   0%   0% 58.6°C  0/6
15:03:45: 1200MHz  4.09 100%   0%  99%   0%   0%   0% 58.9°C  0/6
15:03:52: 1200MHz  4.15 100%   0%  99%   0%   0%   0% 59.1°C  0/6
15:03:59: 1200MHz  4.14 100%   0%  99%   0%   0%   0% 59.1°C  0/6
15:04:06: 1200MHz  4.13 100%   0%  99%   0%   0%   0% 59.5°C  0/6
15:04:13: 1200MHz  4.18 100%   0%  99%   0%   0%   0% 62.1°C  0/6
15:04:21: 1200MHz  4.17 100%   0%  99%   0%   0%   0% 62.2°C  0/6
15:04:28: 1200MHz  4.29 100%   0%  99%   0%   0%   0% 63.0°C  0/6
15:04:35: 1200MHz  4.27 100%   0%  99%   0%   0%   0% 63.9°C  0/6
15:04:42: 1200MHz  4.30 100%   0%  99%   0%   0%   0% 63.9°C  0/6
15:04:49: 1200MHz  4.27 100%   0%  99%   0%   0%   0% 64.4°C  0/6
15:04:56: 1200MHz  4.25 100%   0%  99%   0%   0%   0% 65.1°C  0/6
15:05:04: 1200MHz  4.29 100%   0%  99%   0%   0%   0% 65.1°C  0/6
15:05:11: 1200MHz  4.26 100%   0%  99%   0%   0%   0% 65.3°C  0/6
15:05:18: 1200MHz  4.30 100%   0%  99%   0%   0%   0% 65.2°C  0/6
15:05:25: 1200MHz  4.27 100%   0%  99%   0%   0%   0% 65.4°C  0/6
15:05:32: 1200MHz  4.30 100%   0%  99%   0%   0%   0% 65.9°C  0/6
15:05:40: 1200MHz  4.28 100%   0%  99%   0%   0%   0% 66.4°C  0/6
15:05:47: 1200MHz  4.31 100%   0% 100%   0%   0%   0% 67.2°C  0/6
15:05:54: 1200MHz  4.29 100%   0%  99%   0%   0%   0% 66.4°C  0/6
15:06:01: 1200MHz  4.26 100%   0% 100%   0%   0%   0% 68.4°C  0/6
15:06:08: 1200MHz  4.30 100%   0%  99%   0%   0%   0% 69.6°C  0/6
And this crashes the board hard...
Just to make sure...this is a v1.1 board, correct?
Strange...I would imagine that it should have some stability at a higher clockrate and 1.3v CPU VDD...  Luck of the draw...?
Seems like the 1.3v might be the problem...
with the 504MHz DDR timing, and removing the overlays for overclocking, board survives the test...
15:22:52:  648MHz  0.40  10%   5%   4%   0%   0%   0% 32.6°C  0/4
15:22:57:  648MHz  0.37   1%   1%   0%   0%   0%   0% 33.2°C  0/4
15:23:03:  816MHz  0.34   4%   3%   1%   0%   0%   0% 32.6°C  0/4
15:23:08:  648MHz  0.31   3%   1%   1%   0%   0%   0% 33.0°C  0/4
15:23:13:  648MHz  0.28   1%   1%   0%   0%   0%   0% 32.7°C  0/4
15:23:19: 1008MHz  0.26  22%   0%  21%   0%   0%   0% 46.4°C  0/4
15:23:26: 1008MHz  0.56 100%   0%  99%   0%   0%   0% 50.1°C  0/4
15:23:33: 1008MHz  1.16 100%   0%  99%   0%   0%   0% 49.6°C  0/4
15:23:40: 1008MHz  1.39 100%   0%  99%   0%   0%   0% 51.3°C  0/4
15:23:48: 1008MHz  1.87 100%   0% 100%   0%   0%   0% 50.4°C  0/4
15:23:55: 1008MHz  2.04 100%   0% 100%   0%   0%   0% 52.8°C  0/4
15:24:02: 1008MHz  2.19 100%   0%  99%   0%   0%   0% 52.9°C  0/4
15:24:09: 1008MHz  2.55 100%   0%  99%   0%   0%   0% 51.4°C  0/4
15:24:16: 1008MHz  2.66 100%   0%  99%   0%   0%   0% 55.5°C  0/4
15:24:24: 1008MHz  2.94 100%   0%  99%   0%   0%   0% 56.3°C  0/4
15:24:31: 1008MHz  3.03 100%   0% 100%   0%   0%   0% 58.5°C  0/4
15:24:39: 1008MHz  3.25 100%   0%  99%   0%   0%   0% 59.5°C  0/4
15:24:46: 1008MHz  3.31 100%   0% 100%   0%   0%   0% 60.5°C  0/4
15:24:53: 1008MHz  3.49 100%   0%  99%   0%   0%   0% 61.1°C  0/4
15:25:00: 1008MHz  3.53 100%   0%  99%   0%   0%   0% 61.0°C  0/4
15:25:08: 1008MHz  3.68 100%   0%  99%   0%   0%   0% 60.7°C  0/4
15:25:15: 1008MHz  3.70 100%   0% 100%   0%   0%   0% 61.1°C  0/4
15:25:22: 1008MHz  3.82 100%   0%  99%   0%   0%   0% 61.5°C  0/4
15:25:30: 1008MHz  3.84 100%   0%  99%   0%   0%   0% 58.9°C  0/4
15:25:37: 1008MHz  3.85 100%   0%  99%   0%   0%   0% 58.5°C  0/4
15:25:44: 1008MHz  3.95 100%   0%  99%   0%   0%   0% 57.8°C  0/4
15:25:51: 1008MHz  3.95 100%   0%  99%   0%   0%   0% 57.6°C  0/4
15:25:59: 1008MHz  4.03 100%   0%  99%   0%   0%   0% 57.5°C  0/4
15:26:06: 1008MHz  4.03 100%   0%  99%   0%   0%   0% 57.7°C  0/4
15:26:13: 1008MHz  4.10 100%   0%  99%   0%   0%   0% 57.3°C  0/4
15:26:20: 1008MHz  4.09 100%   0%  99%   0%   0%   0% 58.0°C  0/4
15:26:28: 1008MHz  4.15 100%   0%  99%   0%   0%   0% 58.5°C  0/4
15:26:35: 1008MHz  4.14 100%   0%  99%   0%   0%   0% 57.9°C  0/4
15:26:42: 1008MHz  4.13 100%   0%  99%   0%   0%   0% 60.5°C  0/4
15:26:50: 1008MHz  4.18 100%   0%  99%   0%   0%   0% 61.4°C  0/4
15:26:57: 1008MHz  4.17 100%   0% 100%   0%   0%   0% 61.6°C  0/4
15:27:04: 1008MHz  4.22 100%   0%  99%   0%   0%   0% 62.3°C  0/4
15:27:11: 1008MHz  4.20 100%   0%  99%   0%   0%   0% 62.8°C  0/4
15:27:19: 1008MHz  4.24 100%   0%  99%   0%   0%   0% 62.6°C  0/4
15:27:26: 1008MHz  4.22 100%   0%  99%   0%   0%   0% 63.0°C  0/4
15:27:34: 1008MHz  4.26 100%   0%  99%   0%   0%   0% 63.2°C  0/4
15:27:41: 1008MHz  4.24 100%   0% 100%   0%   0%   0% 63.4°C  0/4
15:27:48: 1008MHz  4.28 100%   0% 100%   0%   0%   0% 63.3°C  0/4
15:27:55: 1008MHz  4.25 100%   0%  99%   0%   0%   0% 64.0°C  0/4
15:28:03: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 63.6°C  0/4
15:28:10: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 64.5°C  0/4
15:28:17: 1008MHz  4.25 100%   0%  99%   0%   0%   0% 64.1°C  0/4
15:28:25: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 65.5°C  0/4
15:28:32: 1008MHz  4.26 100%   0%  99%   0%   0%   0% 67.1°C  0/4
15:28:39: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 69.0°C  0/4
15:28:46: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 66.3°C  0/4
15:28:54: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 65.8°C  0/4
15:29:01: 1008MHz  4.28 100%   0% 100%   0%   0%   0% 65.9°C  0/4
15:29:08: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 65.0°C  0/4
15:29:16: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 65.5°C  0/4
15:29:23: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 65.7°C  0/4
15:29:30: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 65.4°C  0/4
15:29:38: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 65.4°C  0/4
15:29:45: 1008MHz  4.29 100%   0% 100%   0%   0%   0% 64.7°C  0/4
15:29:52: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 65.0°C  0/4
15:29:59: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 63.5°C  0/4
15:30:07: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 62.8°C  0/4
15:30:14: 1008MHz  4.31 100%   0% 100%   0%   0%   0% 65.3°C  0/4
15:30:21: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 65.0°C  0/4
15:30:29: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 66.5°C  0/4
15:30:36: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 66.9°C  0/4
15:30:43: 1008MHz  4.32 100%   0% 100%   0%   0%   0% 66.9°C  0/4
15:30:51: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 67.7°C  0/4
15:30:59: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 68.4°C  0/4
15:31:07: 1008MHz  4.29 100%   0% 100%   0%   0%   0% 66.9°C  0/4
15:31:14: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 67.0°C  0/4
15:31:21: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 66.0°C  0/4
15:31:28: 1008MHz  4.33 100%   0%  99%   0%   0%   0% 65.1°C  0/4
15:31:36: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 65.1°C  0/4
15:31:43: 1008MHz  4.33 100%   0%  99%   0%   0%   0% 64.8°C  0/4
15:31:50: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 64.1°C  0/4
15:31:57: 1008MHz  4.28 100%   0% 100%   0%   0%   0% 64.0°C  0/4
15:32:05: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 64.4°C  0/4
15:32:12: 1008MHz  4.28 100%   0% 100%   0%   0%   0% 63.5°C  0/4
15:32:19: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 63.8°C  0/4
15:32:27: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 64.1°C  0/4
15:32:34: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 63.6°C  0/4
15:32:41: 1008MHz  4.29 100%   0% 100%   0%   0%   0% 64.1°C  0/4
15:32:48: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 63.5°C  0/4
15:32:56: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 64.4°C  0/4
15:33:03: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 63.8°C  0/4
15:33:10: 1008MHz  4.30 100%   0% 100%   0%   0%   0% 64.2°C  0/4
15:33:18: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 64.1°C  0/4
15:33:25: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 64.1°C  0/4
15:33:33: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 65.8°C  0/4
15:33:40: 1008MHz  4.31 100%   0% 100%   0%   0%   0% 67.3°C  0/4
15:33:47: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 66.5°C  0/4
15:33:55: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 66.3°C  0/4
15:34:02: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 65.4°C  0/4
15:34:09: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 65.2°C  0/4
15:34:17: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 65.7°C  0/4
15:34:24: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 65.4°C  0/4
15:34:31: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 67.5°C  0/4
15:34:38: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 69.8°C  0/4
15:34:45: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 69.4°C  0/4
15:34:53: 1008MHz  4.33 100%   0% 100%   0%   0%   0% 70.1°C  0/4
15:35:00: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 69.4°C  0/4
15:35:07: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 69.2°C  0/4
15:35:15: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 68.3°C  0/4
15:35:22: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 68.6°C  0/4
15:35:29: 1008MHz  4.31 100%   0% 100%   0%   0%   0% 68.9°C  0/4
15:35:37: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 69.0°C  0/4
15:35:45: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 67.9°C  0/4
15:35:52: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 68.6°C  0/4
15:36:00: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 69.0°C  0/4
15:36:07: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 70.2°C  0/4
15:36:14: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 68.1°C  0/4
15:36:21: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 73.3°C  0/4
15:36:29: 1008MHz  4.33 100%   0%  99%   0%   0%   0% 69.1°C  0/4
15:36:36: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 70.2°C  0/4
15:36:43: 1008MHz  4.33 100%   0% 100%   0%   0%   0% 70.6°C  0/4
15:36:51: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 70.6°C  0/4
15:36:58: 1008MHz  4.33 100%   0%  99%   0%   0%   0% 73.6°C  0/4
15:37:05: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 74.7°C  0/4
15:37:13: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 73.7°C  0/4
15:37:20: 1008MHz  4.31 100%   0% 100%   0%   0%   0% 74.5°C  0/4
15:37:27: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 74.2°C  0/4
15:37:34: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 75.8°C  0/4
15:37:42: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 74.2°C  0/4
15:37:49: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 75.0°C  0/4
15:37:56: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 73.4°C  0/4
15:38:03: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 75.5°C  0/4
15:38:11: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 74.5°C  0/4
15:38:18: 1008MHz  4.33 100%   0%  99%   0%   0%   0% 75.0°C  0/4
15:38:25: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 75.3°C  0/4
15:38:32: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 75.6°C  0/4
15:38:40: 1008MHz  4.31 100%   0% 100%   0%   0%   0% 76.0°C  0/4
15:38:47: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 75.9°C  0/4
15:38:54: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 75.6°C  0/4
15:39:01: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 76.0°C  0/4
15:39:09: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 75.6°C  0/4
15:39:16: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 75.9°C  0/4
15:39:24: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 75.9°C  0/4
15:39:31: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 76.5°C  0/4
15:39:38: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 77.5°C  0/4
15:39:45: 1008MHz  4.30 100%   0% 100%   0%   0%   0% 77.2°C  0/4
15:39:52: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 75.5°C  0/4
15:40:00: 1008MHz  4.30 100%   0% 100%   0%   0%   0% 75.0°C  0/4
15:40:07: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 75.6°C  0/4
15:40:14: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 75.2°C  0/4
15:40:21: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 75.3°C  0/4
15:40:28: 1008MHz  4.32 100%   0% 100%   0%   0%   0% 74.5°C  0/4
15:40:36: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 76.0°C  0/4
15:40:43: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 76.2°C  0/4
15:40:50: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 77.1°C  0/4
15:40:57: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 77.2°C  0/4
15:41:05: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 77.2°C  0/4
15:41:12: 1008MHz  4.28 100%   0% 100%   0%   0%   0% 76.6°C  0/4
15:41:19: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 75.0°C  0/4
15:41:26: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 75.0°C  0/4
15:41:34: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 74.5°C  0/4
15:41:41: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 74.7°C  0/4
15:41:48: 1008MHz  4.33 100%   0%  99%   0%   0%   0% 74.7°C  0/4
15:41:55: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 77.6°C  0/4
15:42:03: 1008MHz  4.28 100%   0% 100%   0%   0%   0% 77.5°C  0/4
15:42:10: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 78.4°C  0/4
15:42:17: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 77.1°C  0/4
15:42:24: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 75.0°C  0/4
15:42:32: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 76.8°C  0/4
15:42:39: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 78.2°C  0/4
15:42:46: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 77.5°C  0/4
15:42:53: 1008MHz  4.32 100%   0% 100%   0%   0%   0% 77.9°C  0/4
15:43:01: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 79.1°C  0/4
15:43:08: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 79.8°C  0/4
15:43:15: 1008MHz  4.30 100%   0% 100%   0%   0%   0% 78.8°C  0/4
15:43:22: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 78.2°C  0/4
15:43:30: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 78.4°C  0/4
15:43:37: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 78.5°C  0/4
15:43:44: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 79.1°C  0/4
15:43:52: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 77.5°C  0/4
15:43:59: 1008MHz  4.32 100%   0% 100%   0%   0%   0% 79.1°C  0/4
15:44:06: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 78.7°C  0/4
15:44:14: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 79.0°C  0/4
15:44:21: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 79.5°C  0/4
15:44:28: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 80.1°C  0/4
15:44:35: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 77.6°C  0/4
15:44:43: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 78.2°C  0/4
15:44:50: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 77.8°C  0/4
15:44:57: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 77.8°C  0/4
15:45:05: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 77.1°C  0/4
15:45:12: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 78.4°C  0/4
15:45:19: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 76.2°C  0/4
15:45:26: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 76.3°C  0/4
15:45:34: 1008MHz  4.32 100%   0%  99%   0%   0%   0% 76.2°C  0/4
15:45:41: 1008MHz  4.29 100%   0%  99%   0%   0%   0% 75.6°C  0/4
15:45:48: 1008MHz  4.27 100%   0%  99%   0%   0%   0% 78.7°C  0/4
15:45:56: 1008MHz  4.30 100%   0%  99%   0%   0%   0% 77.9°C  0/4
15:46:03: 1008MHz  4.28 100%   0% 100%   0%   0%   0% 78.1°C  0/4
15:46:10: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 78.7°C  0/4
15:46:18: 1008MHz  4.28 100%   0%  99%   0%   0%   0% 77.6°C  0/4
15:46:25: 1008MHz  4.31 100%   0%  99%   0%   0%   0% 79.8°C  0/4
15:46:32:  816MHz  4.29 100%   0%  99%   0%   0%   0% 79.5°C  0/4
15:46:38:  816MHz  4.00  21%   0%  20%   0%   0%   0% 58.5°C  0/4
15:46:43:  816MHz  3.68   1%   1%   0%   0%   0%   0% 55.8°C  0/4
DDR@504Mhz with CPU@1008 - runs clean on my board with no overlays...
This is a run with byte-unixbench exercising all four cores - as you can observe towards the end, it gets pretty intense...
16:00:36:  816MHz  0.53  65%   2%  62%   0%   0%   0% 41.8°C  0/4
16:00:41:  480MHz  0.48   1%   1%   0%   0%   0%   0% 41.4°C  0/4
16:00:46:  816MHz  0.44   4%   2%   1%   0%   0%   0% 41.3°C  0/4
16:00:52: 1008MHz  0.73  85%   0%  84%   0%   0%   0% 58.9°C  0/4
16:00:58:  816MHz  0.99  81%   0%  80%   0%   0%   0% 48.3°C  0/4
16:01:05: 1008MHz  1.23  68%   0%  67%   0%   0%   0% 61.3°C  0/4
16:01:10:  816MHz  1.45  95%   0%  94%   0%   0%   0% 60.1°C  0/4
16:01:17: 1008MHz  1.33  53%   0%  52%   0%   0%   0% 61.7°C  0/4
16:01:23: 1008MHz  1.82  99%   0%  99%   0%   0%   0% 62.5°C  0/4
16:01:30: 1008MHz  1.99  47%   0%  45%   0%   0%   0% 61.9°C  0/4
16:01:36: 1008MHz  2.15 100%   0% 100%   0%   0%   0% 63.9°C  0/4
16:01:43: 1008MHz  1.98  48%   1%  47%   0%   0%   0% 61.9°C  0/4
16:01:49: 1008MHz  2.37 100%   0%  99%   0%   0%   0% 63.9°C  0/4
16:01:56: 1008MHz  2.50  48%   1%  47%   0%   0%   0% 62.6°C  0/4
16:02:03: 1008MHz  2.62 100%   0%  99%   0%   0%   0% 64.5°C  0/4
16:02:09: 1008MHz  2.62  49%   1%  47%   0%   0%   0% 62.8°C  0/4
16:02:16: 1008MHz  2.73 100%   0% 100%   0%   0%   0% 63.9°C  0/4
16:02:22: 1008MHz  2.51  48%   1%  47%   0%   0%   0% 62.7°C  0/4
16:02:29: 1008MHz  2.81 100%   0%  99%   0%   0%   0% 65.0°C  0/4
16:02:35: 1008MHz  2.91  49%   1%  47%   0%   0%   0% 62.7°C  0/4
16:02:42: 1008MHz  2.99 100%   0% 100%   0%   0%   0% 65.2°C  0/4
16:02:48: 1008MHz  2.75  47%   1%  46%   0%   0%   0% 62.6°C  0/4
16:02:55: 1008MHz  3.02 100%   0%  99%   0%   0%   0% 65.0°C  0/4
16:03:02: 1008MHz  2.78  48%   1%  46%   0%   0%   0% 60.1°C  0/4
16:03:09: 1008MHz  2.88 100%   0%  99%   0%   0%   0% 62.0°C  0/4
16:03:16: 1008MHz  2.80  58%   0%  57%   0%   0%   0% 57.0°C  0/4
16:03:24: 1008MHz  2.90 100%   0%  99%   0%   0%   0% 61.6°C  0/4
16:03:31: 1008MHz  2.82  58%   0%  57%   0%   0%   0% 58.3°C  0/4
16:03:38: 1008MHz  2.92 100%   0%  99%   0%   0%   0% 59.8°C  0/4
16:03:44:  648MHz  2.84  57%   0%  56%   0%   0%   0% 49.4°C  0/4
16:03:51: 1008MHz  2.93  97%   0%  96%   0%   0%   0% 60.8°C  0/4
16:03:57: 1008MHz  3.02  99%   0%  99%   0%   0%   0% 61.3°C  0/4
16:04:03: 1008MHz  2.77  46%   1%  45%   0%   0%   0% 59.2°C  0/4
16:04:10: 1008MHz  3.04 100%   0%  99%   0%   0%   0% 62.5°C  0/4
16:04:18: 1008MHz  2.79  56%   0%  55%   0%   0%   0% 57.5°C  0/4
16:04:25: 1008MHz  3.05 100%   0%  99%   0%   0%   0% 62.7°C  0/4
16:04:32: 1008MHz  2.81  59%   0%  59%   0%   0%   0% 59.2°C  0/4
16:04:40: 1008MHz  3.06 100%   0%  99%   0%   0%   0% 61.5°C  0/4
16:04:46:  816MHz  2.90  54%   0%  54%   0%   0%   0% 49.2°C  0/4
16:04:52: 1008MHz  2.99  99%   0%  99%   0%   0%   0% 62.1°C  0/4
16:04:58: 1008MHz  3.22  98%   0%  98%   0%   0%   0% 61.9°C  0/4
16:05:05: 1008MHz  3.28  48%   1%  47%   0%   0%   0% 59.8°C  0/4
16:05:12: 1008MHz  3.34 100%   0%  99%   0%   0%   0% 62.0°C  0/4
16:05:19: 1008MHz  3.52  56%   0%  55%   0%   0%   0% 58.6°C  0/4
16:05:27: 1008MHz  3.56 100%   0%  99%   0%   0%   0% 62.2°C  0/4
16:05:33: 1008MHz  3.59  54%   5%  48%   0%   0%   0% 57.0°C  0/4
16:05:38: 1008MHz  3.73  97%  75%  22%   0%   0%   0% 62.9°C  0/4
16:05:43: 1008MHz  3.75  98%  75%  22%   0%   0%   0% 63.8°C  0/4
16:05:49: 1008MHz  3.77  97%  75%  22%   0%   0%   0% 63.2°C  0/4
16:05:54: 1008MHz  3.79  97%  75%  21%   0%   0%   0% 64.2°C  0/4
16:06:00: 1008MHz  3.81  97%  75%  22%   0%   0%   0% 65.5°C  0/4
16:06:05: 1008MHz  3.50  42%  33%   9%   0%   0%   0% 58.0°C  0/4
16:06:11: 1008MHz  3.54  97%  75%  21%   0%   0%   0% 63.2°C  0/4
16:06:16: 1008MHz  3.58  97%  75%  22%   0%   0%   0% 65.0°C  0/4
16:06:21: 1008MHz  3.61  97%  75%  22%   0%   0%   0% 63.9°C  0/4
16:06:27: 1008MHz  3.64  98%  75%  22%   0%   0%   0% 64.8°C  0/4
16:06:32: 1008MHz  3.67  98%  75%  22%   0%   0%   0% 65.7°C  0/4
16:06:37:  816MHz  3.70  45%  34%  10%   0%   0%   0% 51.9°C  0/4
16:06:43: 1008MHz  3.72  95%  73%  21%   0%   0%   0% 64.1°C  0/4
16:06:48: 1008MHz  3.91  98%  75%  22%   0%   0%   0% 65.2°C  0/4
16:06:54: 1008MHz  3.92  97%  76%  21%   0%   0%   0% 65.8°C  0/4
16:06:59: 1008MHz  3.93  97%  74%  23%   0%   0%   0% 65.7°C  0/4
16:07:04: 1008MHz  3.93  97%  75%  22%   0%   0%   0% 65.2°C  0/4
16:07:10:  816MHz  3.62  59%  45%  13%   0%   0%   0% 52.0°C  0/4
16:07:15: 1008MHz  3.33   5%   5%   0%   0%   0%   0% 53.3°C  0/4
16:07:20:  816MHz  3.06  34%  33%   0%   0%   0%   0% 48.9°C  0/4
16:07:25:  816MHz  2.82  40%  37%   2%   0%   0%   0% 49.5°C  0/4
16:07:30: 1008MHz  2.91  88%  85%   2%   0%   0%   0% 64.0°C  0/4
16:07:36: 1008MHz  3.00  99%  97%   2%   0%   0%   0% 65.2°C  0/4
16:07:41: 1008MHz  3.08  99%  96%   3%   0%   0%   0% 66.5°C  0/4
16:07:46: 1008MHz  3.15  99%  97%   2%   0%   0%   0% 66.7°C  0/4
16:07:52: 1008MHz  3.22  99%  96%   2%   0%   0%   0% 66.7°C  0/4
16:07:57:  816MHz  3.28  84%  81%   2%   0%   0%   0% 56.0°C  0/4
16:08:02:  816MHz  3.02   1%   1%   0%   0%   0%   0% 49.5°C  0/4
16:08:07:  816MHz  3.18  41%  39%   0%   0%   1%   0% 50.4°C  0/4
16:08:12:  816MHz  2.92  40%  37%   2%   0%   0%   0% 52.2°C  0/4
16:08:17: 1008MHz  2.69  57%  55%   1%   0%   0%   0% 61.6°C  0/4
16:08:22: 1008MHz  2.79  99%  96%   2%   0%   0%   0% 64.2°C  0/4
16:08:28: 1008MHz  2.89  99%  96%   2%   0%   0%   0% 64.8°C  0/4
16:08:33: 1008MHz  2.98  99%  96%   2%   0%   0%   0% 66.6°C  0/4
16:08:38: 1008MHz  3.21  99%  97%   2%   0%   0%   0% 65.8°C  0/4
16:08:43: 1008MHz  3.27  99%  96%   2%   0%   0%   0% 66.3°C  0/4
16:08:48:  816MHz  3.01  19%  18%   0%   0%   0%   0% 50.5°C  0/4
16:08:54:  816MHz  3.09  40%  38%   0%   0%   0%   0% 60.3°C  0/4
16:09:00: 1008MHz  3.16  34%  32%   1%   0%   0%   0% 62.1°C  0/4
16:09:05: 1008MHz  3.23  43%  42%   1%   0%   0%   0% 61.3°C  0/4
16:09:10: 1008MHz  3.29  99%  97%   2%   0%   0%   0% 64.4°C  0/4
16:09:16: 1008MHz  3.35  99%  96%   3%   0%   0%   0% 65.5°C  0/4
16:09:21: 1008MHz  3.40  99%  96%   2%   0%   0%   0% 65.8°C  0/4
16:09:26: 1008MHz  3.45  99%  96%   2%   0%   0%   0% 66.5°C  0/4
16:09:31: 1008MHz  3.50  99%  97%   2%   0%   0%   0% 67.0°C  0/4
16:09:36:  816MHz  3.21  29%  28%   0%   0%   0%   0% 51.7°C  0/4
16:09:41: 1008MHz  2.96  31%  30%   0%   0%   0%   0% 60.2°C  0/4
16:09:48: 1008MHz  2.72  33%  30%   2%   0%   0%   0% 62.3°C  0/4
16:09:53: 1008MHz  2.50  46%  43%   2%   0%   0%   0% 61.3°C  0/4
16:09:58: 1008MHz  2.81  99%  96%   3%   0%   0%   0% 63.5°C  0/4
16:10:03: 1008MHz  2.90  99%  96%   2%   0%   0%   0% 65.8°C  0/4
16:10:09: 1008MHz  2.99  99%  96%   3%   0%   0%   0% 66.5°C  0/4
16:10:14: 1008MHz  3.07  99%  96%   2%   0%   0%   0% 66.3°C  0/4
16:10:19: 1008MHz  3.15  99%  96%   2%   0%   0%   0% 65.9°C  0/4
16:10:24: 1008MHz  2.89  40%  38%   1%   0%   0%   0% 51.5°C  0/4
16:10:29: 1008MHz  2.66  22%  22%   0%   0%   0%   0% 58.6°C  0/4
16:10:36: 1008MHz  2.45  32%  30%   2%   0%   0%   0% 62.6°C  0/4
16:10:41: 1008MHz  2.25  49%  47%   2%   0%   0%   0% 60.9°C  0/4
16:10:46: 1008MHz  2.39  99%  96%   3%   0%   0%   0% 65.3°C  0/4
16:10:51: 1008MHz  2.52  99%  96%   3%   0%   0%   0% 64.8°C  0/4
16:10:57: 1008MHz  2.64  99%  96%   2%   0%   0%   0% 66.3°C  0/4
16:11:02: 1008MHz  2.75  99%  96%   2%   0%   0%   0% 65.9°C  0/4
16:11:07: 1008MHz  2.85  99%  96%   2%   0%   0%   0% 66.5°C  0/4
16:11:12:  480MHz  2.94  46%  44%   1%   0%   0%   0% 52.0°C  0/4
16:11:17: 1008MHz  2.71  17%  16%   0%   0%   0%   0% 57.6°C  0/4
16:11:22:  816MHz  2.81  24%  22%   0%   0%   1%   0% 49.2°C  0/4
16:11:27: 1008MHz  2.91  40%  36%   3%   0%   0%   0% 49.1°C  0/4
16:11:32: 1008MHz  2.99  98%  94%   3%   0%   0%   0% 64.6°C  0/4
16:11:38: 1008MHz  3.07  99%  96%   3%   0%   0%   0% 65.4°C  0/4
16:11:43: 1008MHz  3.15  99%  96%   2%   0%   0%   0% 66.6°C  0/4
16:11:48: 1008MHz  3.22  99%  96%   3%   0%   0%   0% 66.5°C  0/4
16:11:53: 1008MHz  3.28  99%  96%   2%   0%   0%   0% 66.7°C  0/4
16:11:58:  816MHz  3.34  88%  84%   3%   0%   0%   0% 60.5°C  0/4
16:12:03:  648MHz  2.90   2%   1%   0%   0%   0%   0% 50.2°C  0/4
16:12:08:  816MHz  2.67  41%  39%   0%   0%   1%   0% 50.4°C  0/4
16:12:13: 1008MHz  2.77  39%  38%   0%   0%   0%   0% 62.1°C  0/4
16:12:19: 1008MHz  2.87  42%  41%   1%   0%   0%   0% 64.0°C  0/4
16:12:24: 1008MHz  2.96  99%  97%   1%   0%   0%   0% 66.1°C  0/4
16:12:29: 1008MHz  3.05  99%  97%   1%   0%   0%   0% 67.5°C  0/4
16:12:35: 1008MHz  3.12  99%  97%   2%   0%   0%   0% 67.5°C  0/4
16:12:40: 1008MHz  3.19  99%  97%   2%   0%   0%   0% 67.9°C  0/4
16:12:45: 1008MHz  3.26  99%  97%   2%   0%   0%   0% 68.6°C  0/4
16:12:50:  648MHz  3.00  26%  25%   0%   0%   0%   0% 52.2°C  0/4
16:12:56: 1008MHz  2.76  36%  36%   0%   0%   0%   0% 62.0°C  0/4
16:13:02: 1008MHz  2.54  29%  27%   0%   0%   0%   0% 64.0°C  0/4
16:13:08: 1008MHz  2.33  46%  44%   1%   0%   0%   0% 63.9°C  0/4
16:13:13: 1008MHz  2.47  99%  97%   2%   0%   0%   0% 67.0°C  0/4
16:13:18: 1008MHz  2.59  99%  97%   2%   0%   0%   0% 67.2°C  0/4
16:13:23: 1008MHz  2.88  99%  97%   1%   0%   0%   0% 68.9°C  0/4
16:13:29: 1008MHz  2.97  99%  97%   2%   0%   0%   0% 68.1°C  0/4
16:13:34: 1008MHz  3.05  99%  97%   2%   0%   0%   0% 69.1°C  0/4
16:13:39:  816MHz  2.81  29%  27%   0%   0%   0%   0% 52.1°C  0/4
16:13:45: 1008MHz  2.90  35%  35%   0%   0%   0%   0% 61.7°C  0/4
16:13:51: 1008MHz  2.67  33%  31%   0%   0%   1%   0% 63.0°C  0/4
16:13:56: 1008MHz  2.46  42%  41%   0%   0%   0%   0% 62.9°C  0/4
16:14:02: 1008MHz  2.58  99%  97%   1%   0%   0%   0% 65.8°C  0/4
16:14:07: 1008MHz  2.69  99%  97%   1%   0%   0%   0% 67.7°C  0/4
16:14:12: 1008MHz  2.80  99%  97%   1%   0%   0%   0% 67.2°C  0/4
16:14:17: 1008MHz  2.90  99%  97%   1%   0%   0%   0% 68.9°C  0/4
16:14:23: 1008MHz  2.98  99%  98%   1%   0%   0%   0% 67.7°C  0/4
16:14:29: 1008MHz  3.07  48%  45%   2%   0%   0%   0% 65.5°C  0/4
16:14:37: 1008MHz  3.28 100%  88%  10%   0%   0%   0% 68.5°C  0/4
16:14:44: 1008MHz  3.02  58%  52%   6%   0%   0%   0% 67.2°C  0/4
16:14:51: 1008MHz  3.25 100%  89%  10%   0%   0%   0% 68.5°C  0/4
16:14:57: 1008MHz  2.98  49%  44%   5%   0%   0%   0% 66.7°C  0/4
16:15:04: 1008MHz  3.07 100%  89%  10%   0%   0%   0% 67.9°C  0/4
16:15:10: 1008MHz  3.28  50%  44%   5%   0%   0%   0% 66.5°C  0/4
16:15:17: 1008MHz  3.34 100%  89%  10%   0%   0%   0% 69.1°C  0/4
16:15:23: 1008MHz  3.07  48%  42%   5%   0%   0%   0% 66.9°C  0/4
16:15:30: 1008MHz  3.29 100%  89%  10%   0%   0%   0% 67.9°C  0/4
16:15:36: 1008MHz  3.35  47%  42%   5%   0%   0%   0% 67.5°C  0/4
16:15:43: 1008MHz  3.40 100%  89%  10%   0%   0%   0% 69.5°C  0/4
16:15:50: 1008MHz  3.13  48%  43%   4%   0%   0%   0% 67.0°C  0/4
16:15:56: 1008MHz  3.34 100%  88%  11%   0%   0%   0% 67.7°C  0/4
16:16:03: 1008MHz  3.07  47%  42%   5%   0%   0%   0% 67.0°C  0/4
16:16:09: 1008MHz  3.29 100%  88%  11%   0%   0%   0% 68.4°C  0/4
16:16:16: 1008MHz  3.34  48%  43%   5%   0%   0%   0% 66.6°C  0/4
16:16:22: 1008MHz  3.40 100%  89%  10%   0%   0%   0% 69.0°C  0/4
16:16:29: 1008MHz  3.12  49%  43%   5%   0%   0%   0% 67.7°C  0/4
16:16:35: 1008MHz  3.33 100%  89%  10%   0%   0%   0% 69.6°C  0/4
16:16:41: 1008MHz  3.07  26%  23%   1%   0%   0%   0% 64.5°C  0/4
16:16:46: 1008MHz  3.22  54%  51%   2%   0%   0%   0% 65.5°C  0/4
16:16:51:  816MHz  3.28  31%  29%   2%   0%   0%   0% 52.9°C  0/4
16:16:56: 1008MHz  3.34  44%  42%   2%   0%   0%   0% 63.6°C  0/4
16:17:01: 1008MHz  3.39  54%  50%   3%   0%   0%   0% 65.0°C  0/4
16:17:06: 1008MHz  3.12  22%  20%   1%   0%   0%   0% 61.1°C  0/4
16:17:11: 1008MHz  3.27  54%  51%   2%   0%   0%   0% 65.8°C  0/4
16:17:16:  816MHz  3.41  39%  37%   2%   0%   0%   0% 53.0°C  0/4
16:17:21: 1008MHz  3.54  36%  34%   2%   0%   0%   0% 64.4°C  0/4
16:17:26: 1008MHz  3.58  54%  51%   3%   0%   0%   0% 65.9°C  0/4
16:17:31: 1008MHz  3.29  22%  20%   1%   0%   0%   0% 53.4°C  0/4
16:17:37: 1008MHz  3.35  54%  51%   2%   0%   0%   0% 64.6°C  0/4
16:17:42:  816MHz  3.32  48%  45%   3%   0%   0%   0% 56.0°C  0/4
16:17:47: 1008MHz  3.05  28%  26%   1%   0%   0%   0% 64.1°C  0/4
16:17:52: 1008MHz  3.13  54%  51%   3%   0%   0%   0% 65.2°C  0/4
16:17:57:  816MHz  3.28  25%  23%   1%   0%   0%   0% 52.2°C  0/4
16:18:02: 1008MHz  3.50  51%  48%   2%   0%   0%   0% 64.6°C  0/4
16:18:07: 1008MHz  3.62  53%  50%   3%   0%   0%   0% 66.0°C  0/4
16:18:12: 1008MHz  3.33  22%  20%   1%   0%   0%   0% 62.8°C  0/4
16:18:17: 1008MHz  3.54  54%  51%   2%   0%   0%   0% 64.7°C  0/4
16:18:22:  816MHz  3.58  33%  31%   1%   0%   0%   0% 52.3°C  0/4
16:18:27: 1008MHz  3.61  43%  40%   2%   0%   0%   0% 64.4°C  0/4
16:18:32: 1008MHz  3.64  54%  51%   2%   0%   0%   0% 64.5°C  0/4
16:18:38: 1008MHz  3.35  22%  20%   1%   0%   0%   0% 62.3°C  0/4
16:18:43: 1008MHz  3.48  54%  50%   3%   0%   0%   0% 65.1°C  0/4
16:18:48:  816MHz  3.61  41%  38%   2%   0%   0%   0% 54.0°C  0/4
16:18:53: 1008MHz  3.32  54%  52%   1%   0%   0%   0% 61.6°C  0/4
16:18:58: 1008MHz  3.53  85%  82%   2%   0%   0%   0% 62.2°C  0/4
16:19:03:  960MHz  3.57  85%  82%   2%   0%   0%   0% 62.5°C  0/4
16:19:09: 1008MHz  3.68  85%  81%   2%   0%   0%   0% 63.0°C  0/4
16:19:14: 1008MHz  3.97  84%  80%   3%   0%   0%   0% 62.9°C  0/4
16:19:19: 1008MHz  3.97  85%  82%   2%   0%   0%   0% 61.7°C  0/4
16:19:24: 1008MHz  4.21  35%  33%   1%   0%   0%   0% 60.2°C  0/4
16:19:29: 1008MHz  4.20  85%  81%   2%   0%   0%   0% 61.9°C  0/4
16:19:34: 1008MHz  4.18  85%  81%   3%   0%   0%   0% 62.5°C  0/4
16:19:40: 1008MHz  4.25  85%  81%   2%   0%   0%   0% 62.9°C  0/4
16:19:45: 1008MHz  4.23  85%  82%   2%   0%   0%   0% 63.5°C  0/4
16:19:50: 1008MHz  4.37  85%  82%   2%   0%   0%   0% 63.8°C  0/4
16:19:55:  816MHz  4.02  44%  41%   1%   0%   0%   0% 51.7°C  0/4
16:20:00: 1008MHz  4.02  77%  73%   2%   0%   0%   0% 62.3°C  0/4
16:20:06: 1008MHz  4.02  85%  81%   2%   0%   0%   0% 62.6°C  0/4
16:20:11: 1008MHz  4.01  85%  81%   3%   0%   0%   0% 63.4°C  0/4
16:20:16: 1008MHz  3.93  85%  82%   2%   0%   0%   0% 64.2°C  0/4
16:20:21: 1008MHz  3.94  85%  80%   3%   0%   0%   0% 63.9°C  0/4
16:20:26:  816MHz  4.02  77%  73%   3%   0%   0%   0% 59.6°C  0/4
16:20:33: 1008MHz  3.70  55%  38%  17%   0%   0%   0% 65.1°C  0/4
16:20:39: 1008MHz  3.83 100%  68%  31%   0%   0%   0% 67.3°C  0/4
16:20:46: 1008MHz  3.84  47%  32%  14%   0%   0%   0% 64.8°C  0/4
16:20:52: 1008MHz  3.85 100%  67%  32%   0%   0%   0% 67.1°C  0/4
16:20:59: 1008MHz  3.55  48%  33%  15%   0%   0%   0% 65.4°C  0/4
16:21:05: 1008MHz  3.69 100%  68%  31%   0%   0%   0% 67.0°C  0/4
16:21:12: 1008MHz  3.71  48%  32%  15%   0%   0%   0% 65.5°C  0/4
16:21:18: 1008MHz  3.74 100%  67%  32%   0%   0%   0% 67.6°C  0/4
16:21:25: 1008MHz  3.44  49%  34%  14%   0%   0%   0% 65.8°C  0/4
16:21:31: 1008MHz  3.60 100%  67%  32%   0%   0%   0% 67.6°C  0/4
16:21:38: 1008MHz  3.31  48%  33%  14%   0%   0%   0% 66.0°C  0/4
16:21:44: 1008MHz  3.49 100%  68%  31%   0%   0%   0% 66.4°C  0/4
16:21:51: 1008MHz  3.53  48%  33%  14%   0%   0%   0% 66.1°C  0/4
16:21:57: 1008MHz  3.57 100%  68%  31%   0%   0%   0% 67.0°C  0/4
16:22:04: 1008MHz  3.28  49%  33%  15%   0%   0%   0% 64.8°C  0/4
16:22:11: 1008MHz  3.47 100%  68%  31%   0%   0%   0% 67.5°C  0/4
16:22:17: 1008MHz  3.51  47%  33%  14%   0%   0%   0% 66.0°C  0/4
16:22:24: 1008MHz  3.55 100%  68%  32%   0%   0%   0% 67.3°C  0/4
16:22:30: 1008MHz  3.84  48%  33%  14%   0%   0%   0% 66.9°C  0/4
16:22:37: 1008MHz  3.85 100%  67%  32%   0%   0%   0% 67.7°C  0/4
16:22:42: 1008MHz  3.54  40%  23%  16%   0%   0%   0% 63.4°C  0/4
16:22:47: 1008MHz  3.66  98%  56%  41%   0%   0%   0% 66.0°C  0/4
16:22:52: 1008MHz  3.77  98%  58%  40%   0%   0%   0% 65.5°C  0/4
16:22:58:  816MHz  4.19  98%  56%  40%   0%   0%   0% 65.2°C  0/4
16:23:03: 1008MHz  4.33  98%  56%  41%   0%   0%   0% 65.5°C  0/4
16:23:08: 1008MHz  4.39  98%  56%  41%   0%   0%   0% 66.5°C  0/4
16:23:14: 1008MHz  4.60  98%  57%  40%   0%   0%   0% 66.0°C  0/4
16:23:19:  960MHz  4.81  98%  56%  41%   0%   0%   0% 65.3°C  0/4
16:23:24: 1008MHz  4.99  98%  56%  41%   0%   0%   0% 66.0°C  0/4
16:23:30: 1008MHz  5.23  98%  58%  39%   0%   0%   0% 67.0°C  0/4
16:23:35: 1008MHz  5.21  98%  56%  42%   0%   0%   0% 67.6°C  0/4
16:23:40:  648MHz  5.43  98%  56%  41%   0%   0%   0% 66.6°C  0/4
16:23:45: 1008MHz  5.48  41%  24%  17%   0%   0%   0% 64.2°C  0/4
16:23:50:  960MHz  5.44  98%  56%  40%   0%   0%   0% 65.7°C  0/4
16:23:56: 1008MHz  5.49  98%  55%  42%   0%   0%   0% 65.8°C  0/4
16:24:01:  960MHz  5.69  98%  57%  40%   0%   0%   0% 66.3°C  0/4
16:24:06:  816MHz  5.79  98%  56%  41%   0%   0%   0% 67.0°C  0/4
16:24:12: 1008MHz  5.89  98%  57%  40%   0%   0%   0% 66.6°C  0/4
16:24:17: 1008MHz  5.74  98%  55%  42%   0%   0%   0% 66.9°C  0/4
16:24:22: 1008MHz  5.84  98%  57%  40%   0%   0%   0% 66.3°C  0/4
16:24:27: 1008MHz  5.85  98%  57%  40%   0%   0%   0% 67.1°C  0/4
16:24:33:  960MHz  5.95  98%  56%  41%   0%   0%   0% 67.3°C  0/4
16:24:38: 1008MHz  6.03  98%  57%  41%   0%   0%   0% 67.6°C  0/4
16:24:43:  816MHz  5.87  98%  57%  40%   0%   0%   0% 67.5°C  0/4
16:24:48: 1008MHz  5.40  41%  23%  17%   0%   0%   0% 64.6°C  0/4
16:24:54:  960MHz  5.45  98%  57%  40%   0%   0%   0% 66.3°C  0/4
16:24:59: 1008MHz  5.49  98%  58%  40%   0%   0%   0% 66.0°C  0/4
16:25:04: 1008MHz  5.64  98%  56%  41%   0%   0%   0% 67.0°C  0/4
16:25:09:  816MHz  5.90  98%  56%  41%   0%   0%   0% 67.5°C  0/4
16:25:15: 1008MHz  5.83  98%  56%  41%   0%   0%   0% 66.3°C  0/4
16:25:20: 1008MHz  6.01  98%  56%  41%   0%   0%   0% 67.9°C  0/4
16:25:25:  960MHz  5.93  98%  57%  40%   0%   0%   0% 67.5°C  0/4
16:25:31: 1008MHz  5.85  98%  56%  41%   0%   0%   0% 67.2°C  0/4
16:25:36: 1008MHz  5.86  98%  57%  41%   0%   0%   0% 67.2°C  0/4
16:25:41: 1008MHz  5.71  98%  58%  39%   0%   0%   0% 66.9°C  0/4
16:25:46:  816MHz  5.90  97%  56%  40%   0%   0%   0% 67.6°C  0/4
16:25:54:  816MHz  5.42  54%  29%  24%   0%   0%   0% 66.7°C  0/4
16:26:03: 1008MHz  9.78 100%  53%  46%   0%   0%   0% 67.8°C  0/4
16:26:11: 1008MHz 13.35 100%  54%  45%   0%   0%   0% 68.8°C  0/4
16:26:20: 1008MHz 15.41 100%  54%  45%   0%   0%   0% 69.6°C  0/4
16:26:27: 1008MHz 17.16 100%  53%  46%   0%   0%   0% 69.7°C  0/4
16:26:34:  816MHz 18.99  99%  53%  45%   0%   0%   0% 69.5°C  0/4
16:26:44: 1008MHz 21.69 100%  54%  45%   0%   0%   0% 73.3°C  0/4
16:26:52:  816MHz 21.27  77%  42%  34%   0%   0%   0% 55.0°C  0/4
16:27:00: 1008MHz 20.68  89%  47%  41%   0%   0%   0% 70.3°C  0/4
16:27:08: 1008MHz 19.60 100%  53%  46%   0%   0%   0% 69.7°C  0/4
16:27:20:  816MHz 18.66  99%  54%  45%   0%   0%   0% 70.2°C  0/4
16:27:30: 1008MHz 18.00 100%  54%  45%   0%   0%   0% 69.8°C  0/4
16:27:37: 1008MHz 20.08 100%  54%  45%   0%   0%   0% 69.6°C  0/4
16:27:49: 1008MHz 23.09 100%  53%  45%   0%   0%   0% 69.8°C  0/4
16:27:55:  816MHz 22.56  68%  37%  31%   0%   0%   0% 57.1°C  0/4
16:28:02: 1008MHz 23.00  89%  48%  41%   0%   0%   0% 69.1°C  0/4
16:28:15: 1008MHz 24.07 100%  53%  46%   0%   0%   0% 70.2°C  0/4
16:28:26: 1008MHz 26.41  99%  54%  45%   0%   0%   0% 70.3°C  0/4
16:28:37: 1008MHz 28.21 100%  53%  46%   0%   0%   0% 70.0°C  0/4
16:28:47: 1008MHz 29.06 100%  54%  45%   0%   0%   0% 73.3°C  0/4
16:28:56: 1008MHz 29.36  99%  54%  45%   0%   0%   0% 70.1°C  0/4
Performance is ok, all considered...
Benchmark Run: Sun Mar 15 2020 16:00:44 - 16:28:56
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables       19276204.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3620.2 MWIPS (9.9 s, 7 samples)
Execl Throughput                               2280.0 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        240254.9 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           70006.3 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        596287.3 KBps  (30.0 s, 2 samples)
Pipe Throughput                             1171639.6 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 103500.5 lps   (10.0 s, 7 samples)
Process Creation                               4408.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   3769.6 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    526.5 lpm   (60.2 s, 2 samples)
System Call Overhead                        1975720.5 lps   (10.0 s, 7 samples)
System Benchmarks Index Values               BASELINE       RESULT    INDEX
Dhrystone 2 using register variables         116700.0   19276204.8   1651.8
Double-Precision Whetstone                       55.0       3620.2    658.2
Execl Throughput                                 43.0       2280.0    530.2
File Copy 1024 bufsize 2000 maxblocks          3960.0     240254.9    606.7
File Copy 256 bufsize 500 maxblocks            1655.0      70006.3    423.0
File Copy 4096 bufsize 8000 maxblocks          5800.0     596287.3   1028.1
Pipe Throughput                               12440.0    1171639.6    941.8
Pipe-based Context Switching                   4000.0     103500.5    258.8
Process Creation                                126.0       4408.1    349.9
Shell Scripts (1 concurrent)                     42.4       3769.6    889.1
Shell Scripts (8 concurrent)                      6.0        526.5    877.5
System Call Overhead                          15000.0    1975720.5   1317.1
System Benchmarks Index Score                                         697.8
@sfx2000 Well, considering where this all started, it is great to see it stable at least :)  If you're interested, we could try clocking the CPU at 1.1GHz at 1.3v.  Let me know and I could create a test overlay.
Could probably try the 1.2GHz 1.3 overlay, and use cpufreq-util to limit max freq to 1100...
Ok, this is interesting... limiting cpu maxspeed to 1104MHz, with DDR at 504MHz, the board both survives the test, and also...
Hits the DVFS OPP's, and starts throttling to keep itself cool once it gets above 80C
18:56:40:  816MHz  0.20   6%   3%   2%   0%   0%   0% 33.8°C  0/6
18:56:45:  816MHz  0.18   1%   1%   0%   0%   0%   0% 32.6°C  0/6
18:56:50:  816MHz  0.17   1%   1%   0%   0%   0%   0% 33.0°C  0/6
18:56:55:  816MHz  0.15   1%   1%   0%   0%   0%   0% 32.7°C  0/6
18:57:01: 1104MHz  0.46  93%   0%  93%   0%   0%   0% 51.5°C  0/6
18:57:08: 1104MHz  0.74 100%   0%  99%   0%   0%   0% 51.4°C  0/6
18:57:15: 1104MHz  1.00 100%   0%  99%   0%   0%   0% 52.3°C  0/6
18:57:22: 1104MHz  1.54 100%   0% 100%   0%   0%   0% 52.9°C  0/6
18:57:29: 1104MHz  1.74 100%   0%  99%   0%   0%   0% 52.3°C  0/6
18:57:36: 1104MHz  2.16 100%   0%  99%   0%   0%   0% 54.7°C  0/6
18:57:43: 1104MHz  2.31 100%   0% 100%   0%   0%   0% 53.6°C  0/6
18:57:50: 1104MHz  2.44 100%   0%  99%   0%   0%   0% 55.5°C  0/6
18:57:57: 1104MHz  2.76 100%   0%  99%   0%   0%   0% 57.8°C  0/6
18:58:04: 1104MHz  2.86 100%   0% 100%   0%   0%   0% 58.5°C  0/6
18:58:11: 1104MHz  3.11 100%   0%  99%   0%   0%   0% 60.2°C  0/6
18:58:18: 1104MHz  3.18 100%   0% 100%   0%   0%   0% 61.7°C  0/6
18:58:25: 1104MHz  3.24 100%   0%  99%   0%   0%   0% 62.7°C  0/6
18:58:32: 1104MHz  3.43 100%   0% 100%   0%   0%   0% 63.0°C  0/6
18:58:39: 1104MHz  3.48 100%   0%  99%   0%   0%   0% 64.0°C  0/6
18:58:46: 1104MHz  3.63 100%   0%  99%   0%   0%   0% 63.9°C  0/6
18:58:53: 1104MHz  3.66 100%   0%  99%   0%   0%   0% 63.3°C  0/6
18:59:00: 1104MHz  3.69 100%   0% 100%   0%   0%   0% 63.6°C  0/6
18:59:07: 1104MHz  3.81 100%   0%  99%   0%   0%   0% 62.1°C  0/6
18:59:14: 1104MHz  3.83 100%   0%  99%   0%   0%   0% 60.7°C  0/6
18:59:21: 1104MHz  3.93 100%   0% 100%   0%   0%   0% 60.9°C  0/6
18:59:28: 1104MHz  3.93 100%   0%  99%   0%   0%   0% 59.8°C  0/6
18:59:35: 1104MHz  3.94 100%   0%  99%   0%   0%   0% 61.0°C  0/6
18:59:42: 1104MHz  4.02 100%   0%  99%   0%   0%   0% 60.2°C  0/6
18:59:49: 1104MHz  4.02 100%   0% 100%   0%   0%   0% 60.5°C  0/6
18:59:56: 1104MHz  4.09 100%   0%  99%   0%   0%   0% 61.1°C  0/6
19:00:03: 1104MHz  4.08 100%   0%  99%   0%   0%   0% 60.4°C  0/6
19:00:10: 1104MHz  4.08 100%   0% 100%   0%   0%   0% 61.4°C  0/6
19:00:17: 1104MHz  4.14 100%   0%  99%   0%   0%   0% 64.4°C  0/6
19:00:24: 1104MHz  4.13 100%   0%  99%   0%   0%   0% 64.5°C  0/6
19:00:31: 1104MHz  4.18 100%   0% 100%   0%   0%   0% 65.4°C  0/6
19:00:38: 1104MHz  4.17 100%   0% 100%   0%   0%   0% 64.4°C  0/6
19:00:46: 1104MHz  4.15 100%   0%  99%   0%   0%   0% 65.2°C  0/6
19:00:53: 1104MHz  4.20 100%   0%  99%   0%   0%   0% 65.8°C  0/6
19:01:00: 1104MHz  4.19 100%   0%  99%   0%   0%   0% 65.4°C  0/6
19:01:07: 1104MHz  4.23 100%   0%  99%   0%   0%   0% 66.3°C  0/6
19:01:14: 1104MHz  4.21 100%   0% 100%   0%   0%   0% 66.9°C  0/6
19:01:21: 1104MHz  4.25 100%   0%  99%   0%   0%   0% 67.0°C  0/6
19:01:28: 1104MHz  4.23 100%   0%  99%   0%   0%   0% 66.7°C  0/6
19:01:35: 1104MHz  4.21 100%   0%  99%   0%   0%   0% 67.3°C  0/6
19:01:42: 1104MHz  4.25 100%   0% 100%   0%   0%   0% 67.2°C  0/6
19:01:49: 1104MHz  4.23 100%   0%  99%   0%   0%   0% 67.3°C  0/6
19:01:56: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 67.6°C  0/6
19:02:03: 1104MHz  4.25 100%   0%  99%   0%   0%   0% 68.9°C  0/6
19:02:10: 1104MHz  4.23 100%   0%  99%   0%   0%   0% 73.3°C  0/6
19:02:17: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 74.2°C  0/6
19:02:24: 1104MHz  4.25 100%   0%  99%   0%   0%   0% 69.8°C  0/6
19:02:31: 1104MHz  4.28 100%   0% 100%   0%   0%   0% 69.0°C  0/6
19:02:38: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 68.8°C  0/6
19:02:45: 1104MHz  4.24 100%   0%  99%   0%   0%   0% 69.1°C  0/6
19:02:52: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 69.1°C  0/6
19:02:59: 1104MHz  4.25 100%   0%  99%   0%   0%   0% 69.5°C  0/6
19:03:06: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 69.6°C  0/6
19:03:13: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 70.1°C  0/6
19:03:21: 1104MHz  4.24 100%   0%  99%   0%   0%   0% 68.3°C  0/6
19:03:28: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 68.2°C  0/6
19:03:35: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 66.7°C  0/6
19:03:42: 1104MHz  4.29 100%   0% 100%   0%   0%   0% 66.7°C  0/6
19:03:49: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 66.7°C  0/6
19:03:56: 1104MHz  4.25 100%   0%  99%   0%   0%   0% 69.4°C  0/6
19:04:03: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 69.5°C  0/6
19:04:10: 1104MHz  4.26 100%   0% 100%   0%   0%   0% 70.2°C  0/6
19:04:17: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 73.4°C  0/6
19:04:24: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 73.6°C  0/6
19:04:32: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 75.2°C  0/6
19:04:40: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 75.5°C  0/6
19:04:47: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 70.3°C  0/6
19:04:55: 1104MHz  4.28 100%   0% 100%   0%   0%   0% 69.6°C  0/6
19:05:02: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 69.5°C  0/6
19:05:09: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 68.4°C  0/6
19:05:16: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 68.2°C  0/6
19:05:23: 1104MHz  4.30 100%   0% 100%   0%   0%   0% 67.8°C  0/6
19:05:30: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 67.9°C  0/6
19:05:37: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 68.1°C  0/6
19:05:44: 1104MHz  4.28 100%   0% 100%   0%   0%   0% 67.8°C  0/6
19:05:51: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 67.3°C  0/6
19:05:58: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 67.5°C  0/6
19:06:06: 1104MHz  4.26 100%   0% 100%   0%   0%   0% 67.8°C  0/6
19:06:13: 1104MHz  4.30 100%   0% 100%   0%   0%   0% 68.1°C  0/6
19:06:20: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 67.9°C  0/6
19:06:27: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 67.9°C  0/6
19:06:35: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 68.2°C  0/6
19:06:42: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 68.8°C  0/6
19:06:49: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 68.2°C  0/6
19:06:56: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 67.9°C  0/6
19:07:04: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 68.2°C  0/6
19:07:11: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 68.1°C  0/6
19:07:18: 1104MHz  4.30 100%   0% 100%   0%   0%   0% 70.4°C  0/6
19:07:25: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 70.6°C  0/6
19:07:32: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 70.0°C  0/6
19:07:40: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 70.3°C  0/6
19:07:47: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 69.5°C  0/6
19:07:54: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 69.0°C  0/6
19:08:01: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 69.2°C  0/6
19:08:08: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 69.1°C  0/6
19:08:15: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 76.5°C  0/6
19:08:23: 1104MHz  4.38 100%   0%  99%   0%   0%   0% 76.9°C  0/6
19:08:30: 1104MHz  4.35 100%   0% 100%   0%   0%   0% 77.2°C  0/6
19:08:37: 1104MHz  4.37 100%   0%  99%   0%   0%   0% 76.5°C  0/6
19:08:44: 1104MHz  4.34 100%   0%  99%   0%   0%   0% 77.6°C  0/6
19:08:51: 1104MHz  4.37 100%   0%  99%   0%   0%   0% 77.5°C  0/6
19:08:58: 1104MHz  4.34 100%   0% 100%   0%   0%   0% 76.5°C  0/6
19:09:05: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 76.8°C  0/6
19:09:13: 1104MHz  4.41 100%   0%  99%   0%   0%   0% 78.1°C  0/6
19:09:21: 1104MHz  4.38 100%   0%  99%   0%   0%   0% 77.4°C  0/6
19:09:28: 1104MHz  4.39 100%   0% 100%   0%   0%   0% 75.3°C  0/6
19:09:35: 1104MHz  4.36 100%   0%  99%   0%   0%   0% 76.8°C  0/6
19:09:43: 1104MHz  4.45 100%   0%  99%   0%   0%   0% 78.2°C  0/6
19:09:50: 1104MHz  4.42 100%   0%  99%   0%   0%   0% 78.4°C  0/6
19:09:57: 1104MHz  4.43 100%   0%  99%   0%   0%   0% 78.1°C  0/6
19:10:04: 1104MHz  4.39 100%   0%  99%   0%   0%   0% 79.0°C  0/6
19:10:12: 1104MHz  4.40 100%   0% 100%   0%   0%   0% 79.5°C  0/6
19:10:19: 1104MHz  4.37 100%   0%  99%   0%   0%   0% 79.4°C  0/6
19:10:26: 1104MHz  4.39 100%   0%  99%   0%   0%   0% 79.5°C  3/6
19:10:34: 1104MHz  4.36 100%   0%  99%   0%   0%   0% 79.0°C  0/6
19:10:41:  960MHz  4.33 100%   0%  99%   0%   0%   0% 80.0°C  3/6
19:10:48: 1104MHz  4.35 100%   0%  99%   0%   0%   0% 80.7°C  0/6
19:10:56: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 80.3°C  0/6
19:11:03: 1104MHz  4.35 100%   0%  99%   0%   0%   0% 80.5°C  0/6
19:11:10: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 79.5°C  0/6
19:11:18: 1104MHz  4.34 100%   0%  99%   0%   0%   0% 78.7°C  0/6
19:11:25: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 78.8°C  0/6
19:11:32: 1104MHz  4.34 100%   0%  99%   0%   0%   0% 80.1°C  0/6
19:11:40:  960MHz  4.31 100%   0%  99%   0%   0%   0% 80.3°C  0/6
19:11:47: 1104MHz  4.34 100%   0%  99%   0%   0%   0% 79.7°C  0/6
19:11:54:  960MHz  4.31 100%   0% 100%   0%   0%   0% 79.1°C  0/6
19:12:01: 1104MHz  4.34 100%   0%  99%   0%   0%   0% 80.1°C  0/6
19:12:09: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 78.8°C  0/6
19:12:16:  960MHz  4.29 100%   0%  99%   0%   0%   0% 80.5°C  0/6
19:12:23: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 80.3°C  3/6
19:12:31:  960MHz  4.29 100%   0%  99%   0%   0%   0% 80.4°C  3/6
19:12:39: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 79.4°C  3/6
19:12:46: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 79.7°C  3/6
19:12:53:  960MHz  4.32 100%   0%  99%   0%   0%   0% 80.1°C  0/6
19:13:01:  960MHz  4.30 100%   0%  99%   0%   0%   0% 80.1°C  0/6
19:13:08: 1104MHz  4.33 100%   0%  99%   0%   0%   0% 79.8°C  3/6
19:13:16: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 79.5°C  3/6
19:13:23: 1104MHz  4.33 100%   0%  99%   0%   0%   0% 81.1°C  3/6
19:13:30: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 80.7°C  3/6
19:13:37: 1104MHz  4.33 100%   0%  99%   0%   0%   0% 79.2°C  0/6
19:13:44: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 79.4°C  0/6
19:13:52: 1104MHz  4.33 100%   0% 100%   0%   0%   0% 79.4°C  0/6
19:13:59: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 79.2°C  0/6
19:14:06: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 79.8°C  0/6
19:14:13: 1104MHz  4.38 100%   0%  99%   0%   0%   0% 81.6°C  0/6
19:14:20:  960MHz  4.35 100%   0%  99%   0%   0%   0% 81.0°C  3/6
19:14:28: 1104MHz  4.37 100%   0%  99%   0%   0%   0% 80.8°C  3/6
19:14:35:  960MHz  4.34 100%   0%  99%   0%   0%   0% 79.8°C  3/6
19:14:43:  960MHz  4.36 100%   0%  99%   0%   0%   0% 80.8°C  3/6
19:14:50:  960MHz  4.33 100%   0%  99%   0%   0%   0% 80.1°C  0/6
19:14:58: 1104MHz  4.36 100%   0%  99%   0%   0%   0% 79.1°C  0/6
19:15:05: 1104MHz  4.33 100%   0%  99%   0%   0%   0% 79.2°C  0/6
19:15:13: 1104MHz  4.35 100%   0%  99%   0%   0%   0% 79.2°C  0/6
19:15:20: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 79.0°C  0/6
19:15:27: 1104MHz  4.35 100%   0%  99%   0%   0%   0% 79.5°C  0/6
19:15:35:  960MHz  4.32 100%   0%  99%   0%   0%   0% 80.1°C  3/6
19:15:42:  960MHz  4.34 100%   0%  99%   0%   0%   0% 81.1°C  3/6
19:15:49:  960MHz  4.32 100%   0%  99%   0%   0%   0% 81.1°C  3/6
19:15:57:  960MHz  4.34 100%   0%  99%   0%   0%   0% 79.8°C  3/6
19:16:04: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 78.8°C  0/6
19:16:11: 1104MHz  4.29 100%   0% 100%   0%   0%   0% 79.1°C  0/6
19:16:18:  960MHz  4.32 100%   0%  99%   0%   0%   0% 80.3°C  3/6
19:16:26:  960MHz  4.29 100%   0%  99%   0%   0%   0% 82.0°C  3/6
19:16:33:  960MHz  4.32 100%   0%  99%   0%   0%   0% 81.3°C  3/6
19:16:40:  960MHz  4.29 100%   0% 100%   0%   0%   0% 81.3°C  3/6
19:16:48:  960MHz  4.32 100%   0%  99%   0%   0%   0% 80.8°C  3/6
19:16:55:  960MHz  4.30 100%   0%  99%   0%   0%   0% 81.1°C  3/6
19:17:02:  960MHz  4.33 100%   0%  99%   0%   0%   0% 80.8°C  3/6
19:17:10:  960MHz  4.30 100%   0% 100%   0%   0%   0% 81.4°C  3/6
19:17:17:  960MHz  4.33 100%   0%  99%   0%   0%   0% 81.7°C  3/6
19:17:24:  960MHz  4.30 100%   0%  99%   0%   0%   0% 81.9°C  3/6
19:17:32:  960MHz  4.33 100%   0% 100%   0%   0%   0% 81.1°C  3/6
19:17:39:  960MHz  4.31 100%   0%  99%   0%   0%   0% 81.9°C  3/6
19:17:47:  960MHz  4.28 100%   0%  99%   0%   0%   0% 81.4°C  3/6
19:17:54:  960MHz  4.31 100%   0%  99%   0%   0%   0% 81.9°C  3/6
19:18:02:  960MHz  4.29 100%   0%  99%   0%   0%   0% 82.1°C  3/6
19:18:09:  960MHz  4.32 100%   0%  99%   0%   0%   0% 82.7°C  3/6
19:18:16:  960MHz  4.29 100%   0%  99%   0%   0%   0% 81.4°C  3/6
19:18:23:  960MHz  4.32 100%   0%  99%   0%   0%   0% 80.8°C  3/6
19:18:31:  960MHz  4.29 100%   0%  99%   0%   0%   0% 80.5°C  3/6
19:18:38:  960MHz  4.32 100%   0% 100%   0%   0%   0% 82.9°C  3/6
19:18:46:  960MHz  4.30 100%   0%  99%   0%   0%   0% 82.6°C  3/6
19:18:53:  960MHz  4.32 100%   0%  99%   0%   0%   0% 81.0°C  0/6
19:19:00: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 79.5°C  3/6
19:19:08: 1104MHz  4.33 100%   0%  99%   0%   0%   0% 79.7°C  3/6
19:19:15: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 79.8°C  3/6
19:19:22: 1104MHz  4.33 100%   0%  99%   0%   0%   0% 79.5°C  3/6
19:19:29:  960MHz  4.30 100%   0%  99%   0%   0%   0% 81.6°C  3/6
19:19:36:  960MHz  4.28 100%   0%  99%   0%   0%   0% 81.0°C  3/6
19:19:43:  960MHz  4.31 100%   0% 100%   0%   0%   0% 81.1°C  3/6
19:19:50:  960MHz  4.28 100%   0%  99%   0%   0%   0% 80.5°C  3/6
19:19:58:  960MHz  4.31 100%   0% 100%   0%   0%   0% 81.3°C  3/6
19:20:05:  960MHz  4.29 100%   0%  99%   0%   0%   0% 82.3°C  3/6
19:20:12:  960MHz  4.32 100%   0%  99%   0%   0%   0% 82.6°C  3/6
19:20:18:  816MHz  3.97  23%   0%  22%   0%   0%   0% 60.5°C  0/6
19:20:23:  816MHz  3.65   1%   1%   0%   0%   0%   0% 58.4°C  0/6
19:20:28:  816MHz  3.36   1%   1%   0%   0%   0%   0% 56.7°C  0/6
19:20:33:  816MHz  3.09   1%   1%   0%   0%   0%   0% 55.9°C  0/6
19:20:38:  816MHz  2.84   1%   1%   0%   0%   0%   0% 55.2°C  0/6
19:20:44:  816MHz  2.61   1%   1%   0%   0%   0%   0% 54.6°C  0/6
19:20:49:  816MHz  2.41   1%   1%   0%   0%   0%   0% 55.0°C  0/6
19:20:54:  816MHz  2.21   1%   1%   0%   0%   0%   0% 54.7°C  0/6
19:20:59:  816MHz  2.04   1%   1%   0%   0%   0%   0% 54.0°C  0/6
19:21:04:  816MHz  1.87   1%   1%   0%   0%   0%   0% 53.6°C  0/6
19:21:09:  816MHz  1.72   1%   1%   0%   0%   0%   0% 53.4°C  0/6
19:21:14:  816MHz  1.58   1%   1%   0%   0%   0%   0% 53.3°C  0/6
19:21:19:  816MHz  1.46   1%   1%   0%   0%   0%   0% 52.8°C  0/6
19:21:24:  816MHz  1.34   1%   1%   0%   0%   0%   0% 52.8°C  0/6
19:21:29:  816MHz  1.23   1%   0%   0%   0%   0%   0% 52.9°C  0/6
19:21:35:  816MHz  1.13   1%   0%   0%   0%   0%   0% 52.6°C  0/6
19:21:40:  816MHz  1.04   1%   1%   0%   0%   0%   0% 52.3°C  0/6
19:21:45:  816MHz  0.96   1%   1%   0%   0%   0%   0% 52.3°C  0/6
19:21:50:  816MHz  0.88   1%   0%   0%   0%   0%   0% 52.2°C  0/6
19:21:55:  816MHz  0.81   1%   1%   0%   0%   0%   0% 52.3°C  0/6
19:22:00:  816MHz  0.75   1%   1%   0%   0%   0%   0% 52.9°C  0/6
19:22:05:  816MHz  0.69   1%   0%   0%   0%   0%   0% 52.0°C  0/6
19:22:10:  816MHz  0.63   1%   0%   0%   0%   0%   0% 51.6°C  0/6
19:22:15:  816MHz  0.58   1%   1%   0%   0%   0%   0% 51.4°C  0/6
19:22:20:  816MHz  0.53   1%   1%   0%   0%   0%   0% 51.1°C  0/6
19:22:26:  816MHz  0.60   1%   1%   0%   0%   0%   0% 51.3°C  0/6^C
Interesting - this is the first time I've seen the board actually try to save itself rather than run willingly off the cliff and crash hard.
Seems kind of interesting
getting more interesting...
https://www.kernel.org/doc/Documentation/cpu-freq/governors.txt
Default these days is schedutil - and this is perhaps a good thing, but it does make folks reconsider min-max, and dvfs curves (OPP's)....
Here's a run where I changed the governor from schedutil to performance - here one can see that we're clearly hitting curves and downclocking to keep the chip cool to some degree...
19:40:32: 1104MHz  0.01   3%   1%   1%   0%   0%   0% 41.3°C  0/6
19:40:37: 1104MHz  0.01   0%   0%   0%   0%   0%   0% 40.5°C  0/6
19:40:42: 1104MHz  0.01   0%   0%   0%   0%   0%   0% 40.4°C  0/6
19:40:47: 1104MHz  0.01   0%   0%   0%   0%   0%   0% 40.7°C  0/6
19:40:53: 1104MHz  0.01  30%   0%  30%   0%   0%   0% 54.1°C  0/6
19:41:00: 1104MHz  0.33 100%   0%  99%   0%   0%   0% 57.3°C  0/6
19:41:07: 1104MHz  0.96 100%   0%  99%   0%   0%   0% 57.2°C  0/6
19:41:14: 1104MHz  1.21 100%   0%  99%   0%   0%   0% 58.4°C  0/6
19:41:21: 1104MHz  1.43 100%   0% 100%   0%   0%   0% 58.2°C  0/6
19:41:28: 1104MHz  1.90 100%   0%  99%   0%   0%   0% 60.2°C  0/6
19:41:35: 1104MHz  2.07 100%   0% 100%   0%   0%   0% 60.2°C  0/6
19:41:42: 1104MHz  2.45 100%   0% 100%   0%   0%   0% 59.5°C  0/6
19:41:49: 1104MHz  2.57 100%   0%  99%   0%   0%   0% 62.6°C  0/6
19:41:56: 1104MHz  2.69 100%   0%  99%   0%   0%   0% 64.4°C  0/6
19:42:03: 1104MHz  2.96 100%   0% 100%   0%   0%   0% 65.0°C  0/6
19:42:10: 1104MHz  3.05 100%   0%  99%   0%   0%   0% 67.0°C  0/6
19:42:17: 1104MHz  3.12 100%   0%  99%   0%   0%   0% 67.6°C  0/6
19:42:24: 1104MHz  3.33 100%   0% 100%   0%   0%   0% 68.5°C  0/6
19:42:31: 1104MHz  3.39 100%   0% 100%   0%   0%   0% 68.2°C  0/6
19:42:38: 1104MHz  3.55 100%   0%  99%   0%   0%   0% 69.1°C  0/6
19:42:45: 1104MHz  3.59 100%   0%  99%   0%   0%   0% 68.1°C  0/6
19:42:52: 1104MHz  3.62 100%   0%  99%   0%   0%   0% 68.6°C  0/6
19:42:59: 1104MHz  3.75 100%   0%  99%   0%   0%   0% 67.8°C  0/6
19:43:06: 1104MHz  3.77 100%   0% 100%   0%   0%   0% 66.5°C  0/6
19:43:13: 1104MHz  3.88 100%   0%  99%   0%   0%   0% 66.0°C  0/6
19:43:20: 1104MHz  3.89 100%   0%  99%   0%   0%   0% 65.2°C  0/6
19:43:27: 1104MHz  3.90 100%   0%  99%   0%   0%   0% 65.0°C  0/6
19:43:34: 1104MHz  3.99 100%   0% 100%   0%   0%   0% 65.9°C  0/6
19:43:41: 1104MHz  3.99 100%   0% 100%   0%   0%   0% 65.8°C  0/6
19:43:48: 1104MHz  4.07 100%   0%  99%   0%   0%   0% 65.9°C  0/6
19:43:55: 1104MHz  4.06 100%   0%  99%   0%   0%   0% 65.2°C  0/6
19:44:02: 1104MHz  4.06 100%   0%  99%   0%   0%   0% 66.0°C  0/6
19:44:09: 1104MHz  4.12 100%   0% 100%   0%   0%   0% 66.5°C  0/6
19:44:16: 1104MHz  4.11 100%   0% 100%   0%   0%   0% 68.4°C  0/6
19:44:23: 1104MHz  4.17 100%   0%  99%   0%   0%   0% 69.5°C  0/6
19:44:30: 1104MHz  4.15 100%   0%  99%   0%   0%   0% 69.4°C  0/6
19:44:37: 1104MHz  4.14 100%   0% 100%   0%   0%   0% 70.3°C  0/6
19:44:44: 1104MHz  4.19 100%   0%  99%   0%   0%   0% 70.0°C  0/6
19:44:51: 1104MHz  4.18 100%   0%  99%   0%   0%   0% 70.0°C  0/6
19:44:58: 1104MHz  4.22 100%   0%  99%   0%   0%   0% 70.2°C  0/6
19:45:05: 1104MHz  4.21 100%   0%  99%   0%   0%   0% 73.4°C  0/6
19:45:12: 1104MHz  4.19 100%   0% 100%   0%   0%   0% 73.6°C  0/6
19:45:19: 1104MHz  4.23 100%   0% 100%   0%   0%   0% 74.0°C  0/6
19:45:26: 1104MHz  4.21 100%   0%  99%   0%   0%   0% 74.2°C  0/6
19:45:34: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 74.2°C  0/6
19:45:41: 1104MHz  4.23 100%   0%  99%   0%   0%   0% 74.0°C  0/6
19:45:48: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 75.0°C  0/6
19:45:55: 1104MHz  4.25 100%   0% 100%   0%   0%   0% 75.8°C  0/6
19:46:02: 1104MHz  4.23 100%   0%  99%   0%   0%   0% 76.9°C  0/6
19:46:09: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 78.8°C  0/6
19:46:16: 1104MHz  4.25 100%   0%  99%   0%   0%   0% 79.0°C  0/6
19:46:23: 1104MHz  4.28 100%   0% 100%   0%   0%   0% 76.5°C  0/6
19:46:30: 1104MHz  4.26 100%   0% 100%   0%   0%   0% 76.3°C  0/6
19:46:37: 1104MHz  4.24 100%   0%  99%   0%   0%   0% 76.2°C  0/6
19:46:44: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 76.6°C  0/6
19:46:51: 1104MHz  4.25 100%   0%  99%   0%   0%   0% 76.3°C  0/6
19:46:58: 1104MHz  4.29 100%   0% 100%   0%   0%   0% 76.6°C  0/6
19:47:05: 1104MHz  4.26 100%   0% 100%   0%   0%   0% 77.1°C  0/6
19:47:12: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 76.2°C  0/6
19:47:19: 1104MHz  4.28 100%   0% 100%   0%   0%   0% 75.6°C  0/6
19:47:27: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 75.6°C  0/6
19:47:34: 1104MHz  4.29 100%   0% 100%   0%   0%   0% 74.2°C  0/6
19:47:41: 1104MHz  4.27 100%   0% 100%   0%   0%   0% 73.3°C  0/6
19:47:48: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 75.9°C  0/6
19:47:55: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 76.6°C  0/6
19:48:02: 1104MHz  4.25 100%   0%  99%   0%   0%   0% 77.5°C  0/6
19:48:09: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 77.9°C  0/6
19:48:16: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 78.1°C  0/6
19:48:25:  960MHz  4.30 100%   0%  99%   0%   0%   0% 79.1°C  0/6
19:48:33: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 79.1°C  0/6
19:48:40:  960MHz  4.30 100%   0%  99%   0%   0%   0% 77.2°C  0/6
19:48:47: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 77.4°C  0/6
19:48:54: 1104MHz  4.31 100%   0% 100%   0%   0%   0% 76.8°C  0/6
19:49:01: 1104MHz  4.29 100%   0% 100%   0%   0%   0% 75.9°C  0/6
19:49:09: 1104MHz  4.32 100%   0%  99%   0%   0%   0% 75.6°C  0/6
19:49:16: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 75.5°C  0/6
19:49:23: 1104MHz  4.32 100%   0% 100%   0%   0%   0% 75.5°C  0/6
19:49:30: 1104MHz  4.29 100%   0% 100%   0%   0%   0% 74.2°C  0/6
19:49:37: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 74.3°C  0/6
19:49:44: 1104MHz  4.30 100%   0% 100%   0%   0%   0% 74.6°C  0/6
19:49:51: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 74.0°C  0/6
19:49:58: 1104MHz  4.31 100%   0% 100%   0%   0%   0% 74.9°C  0/6
19:50:06: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 74.9°C  0/6
19:50:13: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 74.0°C  0/6
19:50:20: 1104MHz  4.29 100%   0% 100%   0%   0%   0% 75.5°C  0/6
19:50:27: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 74.0°C  0/6
19:50:34: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 73.9°C  0/6
19:50:41: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 76.0°C  0/6
19:50:49: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 74.9°C  0/6
19:50:56: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 74.9°C  0/6
19:51:03: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 74.7°C  0/6
19:51:11: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 77.4°C  0/6
19:51:18: 1104MHz  4.32 100%   0% 100%   0%   0%   0% 77.6°C  0/6
19:51:25: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 77.9°C  0/6
19:51:32: 1104MHz  4.27 100%   0%  99%   0%   0%   0% 77.6°C  0/6
19:51:39: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 76.9°C  0/6
19:51:46: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 76.6°C  0/6
19:51:53: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 75.9°C  0/6
19:52:01: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 75.5°C  0/6
19:52:08: 1104MHz  4.26 100%   0%  99%   0%   0%   0% 79.0°C  0/6
19:52:15: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 79.7°C  3/6
19:52:22:  960MHz  4.27 100%   0%  99%   0%   0%   0% 79.4°C  3/6
19:52:30: 1104MHz  4.30 100%   0%  99%   0%   0%   0% 80.0°C  0/6
19:52:37: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 79.7°C  3/6
19:52:44: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 80.4°C  0/6
19:52:52: 1104MHz  4.28 100%   0%  99%   0%   0%   0% 80.3°C  3/6
19:52:59: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 80.3°C  0/6
19:53:06:  960MHz  4.29 100%   0%  99%   0%   0%   0% 82.0°C  3/6
19:53:15:  960MHz  4.32 100%   0%  99%   0%   0%   0% 79.8°C  3/6
19:53:23: 1104MHz  4.29 100%   0%  99%   0%   0%   0% 79.5°C  3/6
19:53:31:  960MHz  4.32 100%   0%  99%   0%   0%   0% 81.1°C  0/6
19:53:38:  960MHz  4.35 100%   0%  99%   0%   0%   0% 79.4°C  3/6
19:53:46:  960MHz  4.32 100%   0%  99%   0%   0%   0% 81.3°C  3/6
19:53:54:  960MHz  4.34 100%   0%  99%   0%   0%   0% 79.5°C  3/6
19:54:01:  960MHz  4.31 100%   0%  99%   0%   0%   0% 80.5°C  3/6
19:54:09:  960MHz  4.34 100%   0%  99%   0%   0%   0% 80.4°C  3/6
19:54:16: 1104MHz  4.31 100%   0%  99%   0%   0%   0% 81.4°C  3/6
19:54:24:  960MHz  4.34 100%   0% 100%   0%   0%   0% 80.8°C  3/6
19:54:32:  960MHz  4.31 100%   0%  99%   0%   0%   0% 81.4°C  3/6
19:54:39:  960MHz  4.34 100%   0%  99%   0%   0%   0% 82.6°C  3/6
19:54:47:  960MHz  4.31 100%   0%  99%   0%   0%   0% 81.9°C  3/6
19:54:54:  960MHz  4.34 100%   0%  99%   0%   0%   0% 82.1°C  3/6
19:55:02:  960MHz  4.31 100%   0%  99%   0%   0%   0% 80.7°C  3/6
19:55:09:  960MHz  4.33 100%   0%  99%   0%   0%   0% 82.6°C  3/6
19:55:17:  960MHz  4.31 100%   0% 100%   0%   0%   0% 81.3°C  3/6
19:55:24:  960MHz  4.33 100%   0%  99%   0%   0%   0% 82.9°C  3/6
19:55:32:  960MHz  4.31 100%   0%  99%   0%   0%   0% 81.9°C  3/6
19:55:39:  960MHz  4.33 100%   0% 100%   0%   0%   0% 82.4°C  3/6
19:55:47:  960MHz  4.31 100%   0%  99%   0%   0%   0% 82.6°C  3/6
19:55:54:  960MHz  4.33 100%   0%  99%   0%   0%   0% 82.4°C  3/6
19:56:02:  960MHz  4.31 100%   0%  99%   0%   0%   0% 81.4°C  3/6
19:56:10:  960MHz  4.33 100%   0% 100%   0%   0%   0% 83.2°C  3/6
19:56:17:  960MHz  4.31 100%   0%  99%   0%   0%   0% 83.3°C  3/6
19:56:25:  960MHz  4.33 100%   0%  99%   0%   0%   0% 82.9°C  3/6
19:56:32:  960MHz  4.31 100%   0%  99%   0%   0%   0% 83.0°C  3/6
19:56:40:  960MHz  4.33 100%   0% 100%   0%   0%   0% 83.2°C  3/6
19:56:48:  960MHz  4.30 100%   0%  99%   0%   0%   0% 83.5°C  3/6
19:56:55:  960MHz  4.33 100%   0%  99%   0%   0%   0% 83.0°C  3/6
19:57:03:  960MHz  4.30 100%   0%  99%   0%   0%   0% 83.3°C  3/6
19:57:11:  960MHz  4.33 100%   0%  99%   0%   0%   0% 84.0°C  3/6
19:57:18:  960MHz  4.30 100%   0% 100%   0%   0%   0% 83.6°C  3/6
19:57:26:  960MHz  4.33 100%   0%  99%   0%   0%   0% 84.5°C  3/6
19:57:33:  960MHz  4.30 100%   0%  99%   0%   0%   0% 81.7°C  3/6
19:57:41:  960MHz  4.33 100%   0% 100%   0%   0%   0% 83.3°C  3/6
19:57:48:  960MHz  4.30 100%   0%  99%   0%   0%   0% 81.4°C  3/6
19:57:56:  960MHz  4.33 100%   0% 100%   0%   0%   0% 82.4°C  3/6
19:58:03:  960MHz  4.36 100%   0%  99%   0%   0%   0% 82.1°C  3/6
19:58:11:  960MHz  4.33 100%   0%  99%   0%   0%   0% 83.3°C  3/6
19:58:19:  960MHz  4.35 100%   0%  99%   0%   0%   0% 83.2°C  3/6
19:58:26:  960MHz  4.33 100%   0%  99%   0%   0%   0% 84.0°C  3/6
19:58:34:  960MHz  4.35 100%   0% 100%   0%   0%   0% 82.9°C  3/6
19:58:41:  960MHz  4.32 100%   0% 100%   0%   0%   0% 83.9°C  3/6
19:58:49:  960MHz  4.34 100%   0%  99%   0%   0%   0% 82.1°C  3/6
19:58:57:  960MHz  4.32 100%   0%  99%   0%   0%   0% 81.6°C  3/6
19:59:04:  960MHz  4.34 100%   0%  99%   0%   0%   0% 81.4°C  3/6
19:59:12:  960MHz  4.31 100%   0%  99%   0%   0%   0% 80.7°C  3/6
19:59:20:  960MHz  4.34 100%   0%  99%   0%   0%   0% 82.4°C  3/6
19:59:28:  960MHz  4.31 100%   0%  99%   0%   0%   0% 82.1°C  3/6
19:59:35:  960MHz  4.34 100%   0% 100%   0%   0%   0% 83.6°C  3/6
19:59:43:  960MHz  4.31 100%   0%  99%   0%   0%   0% 84.5°C  3/6
19:59:50:  960MHz  4.34 100%   0% 100%   0%   0%   0% 82.7°C  3/6
19:59:58:  960MHz  4.31 100%   0%  99%   0%   0%   0% 82.6°C  3/6
20:00:05:  960MHz  4.34 100%   0%  99%   0%   0%   0% 81.1°C  3/6
20:00:12:  960MHz  4.31 100%   0%  99%   0%   0%   0% 83.6°C  3/6
20:00:20:  960MHz  4.33 100%   0%  99%   0%   0%   0% 83.5°C  3/6
20:00:27:  960MHz  4.31 100%   0%  99%   0%   0%   0% 84.0°C  3/6
20:00:35:  960MHz  4.33 100%   0% 100%   0%   0%   0% 84.3°C  3/6
20:00:42:  960MHz  4.31 100%   0%  99%   0%   0%   0% 84.6°C  3/6
20:00:50:  960MHz  4.33 100%   0%  99%   0%   0%   0% 85.2°C  3/6
20:00:57:  960MHz  4.31 100%   0%  99%   0%   0%   0% 84.8°C  3/6
20:01:05:  960MHz  4.33 100%   0%  99%   0%   0%   0% 85.3°C  3/6
20:01:12:  960MHz  4.31 100%   0%  99%   0%   0%   0% 85.6°C  3/6
20:01:20:  960MHz  4.33 100%   0%  99%   0%   0%   0% 85.5°C  3/6
20:01:27:  960MHz  4.31 100%   0%  99%   0%   0%   0% 85.3°C  3/6
20:01:35:  960MHz  4.33 100%   0% 100%   0%   0%   0% 85.8°C  3/6
20:01:42:  960MHz  4.31 100%   0%  99%   0%   0%   0% 85.2°C  3/6
20:01:50:  960MHz  4.33 100%   0%  99%   0%   0%   0% 85.6°C  3/6
20:01:57:  960MHz  4.30 100%   0%  99%   0%   0%   0% 86.1°C  3/6
20:02:05:  960MHz  4.33 100%   0%  99%   0%   0%   0% 86.2°C  3/6
20:02:12:  960MHz  4.30 100%   0%  99%   0%   0%   0% 85.5°C  3/6
20:02:19:  960MHz  4.33 100%   0%  99%   0%   0%   0% 84.5°C  3/6
20:02:27:  960MHz  4.30 100%   0%  99%   0%   0%   0% 84.3°C  3/6
20:02:35:  960MHz  4.33 100%   0%  99%   0%   0%   0% 85.2°C  3/6
20:02:42:  960MHz  4.30 100%   0%  99%   0%   0%   0% 84.9°C  3/6
20:02:49:  960MHz  4.33 100%   0%  99%   0%   0%   0% 83.9°C  3/6
20:02:57:  960MHz  4.30 100%   0%  99%   0%   0%   0% 82.7°C  3/6
20:03:04:  960MHz  4.33 100%   0%  99%   0%   0%   0% 83.3°C  3/6
20:03:12:  960MHz  4.30 100%   0%  99%   0%   0%   0% 82.0°C  3/6
20:03:19:  960MHz  4.33 100%   0%  99%   0%   0%   0% 84.5°C  3/6
20:03:26:  960MHz  4.30 100%   0%  99%   0%   0%   0% 84.9°C  3/6
20:03:34:  960MHz  4.33 100%   0%  99%   0%   0%   0% 84.2°C  3/6
20:03:41:  960MHz  4.30 100%   0%  99%   0%   0%   0% 83.9°C  3/6
20:03:48:  960MHz  4.28 100%   0%  99%   0%   0%   0% 83.9°C  3/6
20:03:56:  960MHz  4.31 100%   0%  99%   0%   0%   0% 84.8°C  3/6
20:04:03:  960MHz  4.29 100%   0%  99%   0%   0%   0% 85.5°C  3/6
20:04:09:  960MHz  4.32 100%   0%  99%   0%   0%   0% 86.4°C  3/6
20:04:14: 1104MHz  3.97   1%   0%   1%   0%   0%   0% 67.1°C  0/6
20:04:19: 1104MHz  3.65   0%   0%   0%   0%   0%   0% 64.4°C  0/6^C
Since this is a different code path in the overall scheme of things - schedutil makes this a good problem to solve.
Another takeaway is that Cortex-A53 at 40nm, which is what the H5 is built on - has limits - 1104 cores/504 ddr - would be interesting to see how this plays out with mali450 timing on gpu intense apps - nanopi neo2, this is obviously not possible.
On another project - a53 at 40nm - it has limits, and there we did limit things to 1GHz, and DDR2 to 800 (ddr400), but that was not Allwinner H5 - all in the name of stability...
Yes, it's working just as it should :thumbup:
Interesting...this reminds me of a post from my OrangePi overclocking thread:  https://forum.armbian.com/topic/6866-orange-pi-zero-plus2-h5-hardware-oddity-in-vdd_cpux-power-circuit/?do=findComment&comment=52485, where @Da Xue notes:
Allwinner only certifies the H3 to operate at 1008MHz @1.2V and H5 to operate at 1008MHz @ 1.1V with DDR clocks up to 672MHz. Designs and software support for adjustable voltage and higher clock rates must be validated by the third party that chooses to implementing such features.
Agreed
Agreed as well!
Noted - and contributed findings to that thread - with credits to you and @lanefu for the assist.
power of the armbian community to sort problems - that's what make this forum great
@5kft
Saw the uboot update pushed out - folks can blame me for the performance hit perhaps as part of this thread.
@Igor
Which one was released - 408MHz was stable under testing...
sfx@blaster:~/nano2_uboots$ ll
total 544
-rw-r--r-- 1 sfx sfx 275264 Jun 17 20:08 linux-u-boot-current-nanopineo2_20.05.0-trunk_arm64.deb
-rw-r--r-- 1 sfx sfx 275372 Jun 17 20:08 linux-u-boot-current-nanopineo2_408_MHz_20.05.0-trunk_arm64.deb
Best regards...
Up to my knees with other stuff standing on my head - which means means the inverse ;)
