4.4.210-rk3399 kernel headers not available as a package
Hello
I'm trying to install ZFS on the recomended armbian 4.4 bionic image for Nano PI 4 V2 (this is the default kernel) :
uname -a
Linux nanopim4v2 4.4.210-rk3399 #3 SMP Sat Jan 25 14:13:06 CET 2020 aarch64 GNU/Linux
It complains there are no kernel headers to build a module for the 4.4.210 kernel:
sudo apt install zfs-dkms
Building for 4.4.210-rk3399
Module build for kernel 4.4.210-rk3399 was skipped since the
kernel headers for this kernel does not seem to be installed.
● zfs-mount.service - Mount ZFS filesystems
   Loaded: loaded (/lib/systemd/system/zfs-mount.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2020-02-17 13:03:10 UTC; 17ms ago
     Docs: man:zfs(8)
  Process: 13389 ExecStart=/sbin/zfs mount -a (code=exited, status=1/FAILURE)
 Main PID: 13389 (code=exited, status=1/FAILURE)
I've looked into the output of "apt-cache search linux-headers" and there is no package for 4.4.210-rk3399
Also, the armbian-setup tool will install "linux-headers-rk3399 - Linux kernel headers for 4.4.192-rk3399 on arm64"
Is there a way to get the headers for 4.4.210 or prepare them locally ?
I've tried downgrading to 4.4.192 but the board was unstable and after some time the DTB's got messed up and I could no longer boot that image
Repository will be updated with matched headers in few hours from now. If you need this faster, you can build an image with headers and latest kernel https://github.com/armbian/build
All kernels support DKMS but one from rockchip. Not sure if this is the problematic one.
Ok, i will try updating the board this evening (GMT+2)
I thought about building them from scratch but I'll need a new board to test with - the one I have is being used as a NAS and I can't put if offline (my other server is failing)
Best regards,
Alex
