thanh_tan Posted February 21, 2020 Share Posted February 21, 2020 Hello, I tried to install as instruction in this link https://github.com/stdevPavelmc/armbian-hostpot-bridge to convert my orange pi zero to a hotspot bridge, connected to LAN and wifi to my home under Pi-Hole application to block ads Howeverm after i call up the bridge ifup br0 the network is not running, i cannot connect to the PI again. Pi-Hole installed on the LAN interface. The content of the interfaces file # loopback interface auto lo iface lo inet loopback # wireless wlan0 allow-hotplug wlan0 iface wlan0 inet manual # eth0 connected to the ISP router allow-hotplug eth0 iface eth0 inet manual # Setup bridge allow-hotplug br0 iface br0 inet dhcp bridge_ports wlan0 eth0 Please help me Link to comment Share on other sites More sharing options...
Werner Posted February 21, 2020 Share Posted February 21, 2020 It is always handy to have USB-TTL adapter laying around to access SBCs serial console for debugging indipended from network access. Also the manual seem to work for Debian Stretch and has not been updated since then. You are probably using Buster or Bionic since Stretch is EOS. Besides the fact that it does not work properly on software side I'd also consider using a SBC with known-to-be-stable wireless onboard or use an USB wireless adapter. OPi Zero wireless is quite crappy and unstable. There are some new drivers in recent images but no idea if these fix those issues. Link to comment Share on other sites More sharing options...
