Q1) There is a way to install latest kernel and latest Ubuntu in cubieboard 1
Q2) How to make image file?Please see Reason for reason
Q3) How to install mediatek mt7601u? nand install
Q4) how to install Z-Star Microelectronics Corp. ZC0303 Webcam?This is for camera server
1. If you are referring to Ubuntu Xenial, than you need to build it yourself. We are not providing ready made images yet and can't tell when we will switch Xenial for Trusty. If you are O.K. with Ubuntu Trusty, get it on download page. You can upgrade to Xenial but it's not recommended.
2. Most of how-to's are written, start here: http://www.armbian.com/using-armbian-tools/
3. In ideal world, but sometimes - for this chip can be tricky = reality and that recipe is not working any more. NAND install gives you option to install if you are using kernel that support NAND, 3.4 support it while vanilla versions (4.x) does not support NAND.
4. Ask manufacturer to supply drivers or point to drivers which could be part of the kernel.
-- > add
3. mt7601u works out of the box on 4.4+
Why it show 873mb ram in legency kernel both nand and sd card?.But in vanilla versions Ubuntu server sd card image it show 1001mb ram
I know (4.x) does not support NAND.but there is a way to install it to nand?.If yes then how.Its help
 me not to build drivers.
start wifi usb card.
Chiset: ralink rt5370sta
root@cubieboard:~# ifconfig -a
bond0     Link encap:Ethernet  HWaddr 00:00:00:00:00:00
          BROADCAST MASTER MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth0      Link encap:Ethernet  HWaddr 02:89:07:41:36:ee
          inet addr:192.168.0.105  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::89:7ff:fe41:36ee/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:303 errors:0 dropped:0 overruns:0 frame:0
          TX packets:264 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:33737 (33.7 KB)  TX bytes:34531 (34.5 KB)
          Interrupt:55 Base address:0xb000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
tunl0     Link encap:IPIP Tunnel  HWaddr
          NOARP  MTU:1480  Metric:1
wlx00c41171105d Link encap:Ethernet  HWaddr 00:c4:11:71:10:5d
          BROADCAST MULTICAST  MTU:1500  Metric:1
root@cubieboard:~# ifconfig wlx00c41171105d up
SIOCSIFFLAGS: No such file or directory
root@cubieboard:~# sudo apt-get install firmware-ralink
Reading package lists... Done
Building dependency tree
firmware-ralink is already the newest version (0.36+wheezy.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@cubieboard:~# sudo apt-get install firmware-linux-nonfree
Package firmware-linux-nonfree is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'firmware-linux-nonfree' has no installation candidate
root@cubieboard:~# dmesg
[  141.450044] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
NOT SOLVED
root@cubieboard:~# apt-get install linux-firmware-nonfree
linux-firmware-nonfree is already the newest version (1.14ubuntu3).
