ODroid-N2 RTC not work in linux-image-current-meson64=20.02.8 5.4.28-meson64
Go to solution Solved by iav,
I use image linux-image-current-meson64=20.02.8 5.4.28-meson64, kernel set by apt upgrade
RTC battery connected. Try to perform setup by instruction
seems nwclock can't work:
lsmod|grep rtc
rtc_meson_vrtc         20480  1
ls -l /dev/rt*
lrwxrwxrwx 1 root root      4 Mar 30 18:28 /dev/rtc -> rtc0
crw------- 1 root root 252, 0 Mar 30 18:28 /dev/rtc0
 hwclock
hwclock: select() to /dev/rtc0 to wait for clock tick timed out
root@droid:~# hwclock -w
hwclock: ioctl(RTC_SET_TIME) to /dev/rtc0 to set the time failed: Invalid argument
How to set hardware clock correctly?
Previously I use earlier ubuntu-based armbian kernel 4.* on same device, and hardware clock woks. It brokes after swtching to a new image with new kernel.
Odroid-N2 external RTC is attached on I2C3 which isn't enabled by default.
To enable it, use this overlay source and compile it and load it.
/dts-v1/;
/plugin/;
    compatible = "amlogic,meson-g12b";
    fragment@0 {
        target-path = "/aliases";
        __overlay__ {
            i2c3a = "/soc/bus@ffd00000/i2c@1c000";
    fragment@1 {
        target-path = "/soc/bus@ffd00000/i2c@1c000";
        __overlay__ {
            status = "okay";
            pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>;
            pinctrl-names = "default";
            pcf8563: rtc@51 { /*I2C-bus slave address: read A3h and write A2h*/
		compatible = "nxp,pcf8563";
		reg = <0x51>;
Then, the i2c will appear as well as module for PCF8563 will be loaded, it will be hookup as /dev/rtc1, you can then set the clock and re-read it using :
hwclock -w -f /dev/rtc1
hwclock -f /dev/rtc1
/dts-v1/;
/plugin/;
    fragment@0 {
        __overlay__ {
    fragment@1 {
        __overlay__ {
            status = "okay";
		reg = <0x51>;
Thank you for help.
Could you please point to faq, howto or something like it to read how to "use this overlay source and compile it and load it"? Sorry, I am not "in context" for a while. But I will :)
Install DT compiler from http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_arm64.deb
Then, compile the DTS I've provided and then load it dynamically :
dtc -@ -I dts -O dtb -o odroid-n2-ic2@1c000.dtbo odroid-n2-ic2@1c000.dts
mkdir /sys/kernel/config/device-tree/overlays/i2c3a
cat odroid-n2-ic2@1c000.dtbo > /sys/kernel/config/device-tree/overlays/i2c3a/dtbo
It works!
Thank you!
Do you think I have to ask armbian kernel builders to include your code into kernel image?
I'm one of the main Armbian devs, so, yes, I will add the DT overlay in builds in the near future ...
What kernel  I have to install to got it work?
linux-image-current, -dev, -legacy, other sources?
I've not done the commit yet, "time is the missing ingredient" ...
But feel free to compile above DT overlay !
yes, I did it already... but I not understand how to avoid manual path creation and dt copying with manual hwclock run. To let it work as it should — set system clock at a boot time.
Hi martinayotte,
thanks for providing quick fix via device tree overlay. Also i am very happy to see we got Armbian and a much more recent kernel running on HK Odroid N2! Thx for all your hard work!
Do we lack full support for overlays atm? Even if we do as described for allwiner based boards?
'Cause i tried to use "user_overlays" and "overlay" options in "ArmbianEnv.txt" as described here:
https://docs.armbian.com/Hardware_Allwinner_overlays/
but couldn't get it to work.
Just wanna know if i am missing something/ doing it wrong or It's known/intended
/boot/armbianEnv.txt
verbosity=1
user_overlays=odroid-n2-ic2@1c000
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u <= AutoAdded so file seems to be found
adding the entries and copying the files myself didn't change anything.
adding useroverlay via armbian-add-overlay  => Overlays are supported only on A10... => Removing the allwiner sanity check from
/usr/sbin/armbian-add-overlay line 38-41
edits armbianEnv.txt correctly by adding "user_overlays" option and copying the files to "/boot/overlay-user/" which seems be the desired location. But no pcf8563 modules are loaded after boot.
I also tried adding the dtbo to /boot/dtb/overlay /boot/dtb/amlogic/overlays and so on.
Your mentioned example rc.local works fine instead.
cat /root/odroid-n2-ic2@1c000.dtbo > /sys/kernel/config/device-tree/overlays/i2c3a/dtbo
systemctl stop ntp
ntpd -qg
systemctl start ntp
hwclock --systohc -f /dev/rtc1
TIA
@martinayotte pleeease.
so long present, but not in armbian trunk.
@chewitt have same patches too, but not push.
