Guest swamper Posted June 7, 2016 Posted June 7, 2016 Hi folks, I flashed the Armbian Jessie server image to sd. Then I ran update and upgrade after the system booted. I installed xorg and MATE desktop. No problems anywhere. I did not install a display manager as I want to login from tty. I basically performed the exact same install I have done for 15 years(since Gnome2). And a problem I haven't seen in 10 years or more rears it's ugly head as I type in "startx". MATE desktop boots up and I have no mouse or keyboard... I hit ctrl-alt-del and I have keyboard in the shutdown prompt. lsmod meson_ir 2943 0 joydev 10384 0 spidev 5785 0 spi_gpio 5970 0 spi_bitbang 3653 1 spi_gpio w1_gpio 3246 0 wire 21783 1 w1_gpio bonding 103653 0 fuse 80499 1 autofs4 25155 2 btrfs 864768 0 xor 7330 1 btrfs raid6_pq 85616 1 btrfs No evdev? All the xserver drivers are installed. I don't know if it's just the kernel module or where exactly to go here. Mouse and keyboard are on a usb hub too so it's not a power issue. If it was x86 I'd figure out how to hammer this out but with arm64 and it being so new it could just not be supported yet or be a bug I am unaware of. It could even be MATE I suppose as the issue only exists in GUI. Figure folks that do this every day are better equipped than me to figure this out... lsusb Bus 001 Device 008: ID 045e:0736 Microsoft Corp. Sidewinder X5 Mouse Bus 001 Device 007: ID 045e:00b0 Microsoft Corp. Digital Media Pro Keyboard Bus 001 Device 006: ID 0409:0059 NEC Corp. HighSpeed Hub Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub I am aware there are some .ini files and scripts that are being used at boot but have not tampered with any of them as I am unsure where to go with what... Not finding enough info on the C2 with other folks having this problem. Arm64 is new territory for me as I just got this Odroid C2 and this is the first attempt. If I need to roll my own kernel that will be fine. Figured asking would do better than banging my head against the wall for the next week. Any thoughts? Thanks
Igor Posted June 8, 2016 Posted June 8, 2016 amd64 is new territory for everybody. Package base is few months old and it's not complete. Since it's not broadly tested, problems could exists in this level too. Furthermore C2 kernel is more or less development, it's very buggy ... many things can go wrong. Server to desktop upgrades should work, best with Jessie, yes. it's working fine on most boards but was never tested on C2. BTW: we have mouse on our desktop build.
swamper Posted June 8, 2016 Posted June 8, 2016 I figured I was in a grey area still. I can do what I need to do from tty. I really don't want a display manager booting in a gui. This C2 was bought for a server job to run docker. It's just nice to have access to a gui every now and then when you need it. I rolled up an ubuntu 16.04 image last night and will try it out today too. I don't mind buggy as long as some functionality remains... Thanks Igor
