scaevola Posted April 6, 2020 Posted April 6, 2020 Hi, I use OrangePi PC as my home samba server, as well as dlna server. It works from hdd, since I made a command nand-sata-install. I want to change the disc for a bigger one, how can I do this? If I will make rsync with all hdd will it be enough?
Igor Posted April 6, 2020 Posted April 6, 2020 Change UUID in /boot/armbianEnv.txt and /etc/fstab to the one from a new disk after you transfer your data.
