Armbian for Amlogic S912
10 hours ago, debianxfce said:
I did try balbes150 test build with kernel 4.9 and with a class 4 tf card. No sign of wifi like it has with kernel 3.14 and a class 10 tf card. I hope you are using a class 10 tf card, my class 4 card causes many performance problems.
Actually I didn't use SD card in that try. I used USB (Slow speed. kind of)
I did tried with the one with kernel 4.9 and that version give a black screen before the initial boot console screen.
Can this device play some java games? or not because no 3d acceleration driver.
What works for me is the samsung evo 32GB class 10 tf card with the kernel 3.14 version installed. It works also with a good quality usb 3.0 adapter.
Minecraft.jar and similar slow games with a rough graphics probably do work. Many simple python games you could try too:
http://pygame.org/project-Super+Mario+Python+Beta-1339-.html
9 hours ago, debianxfce said:
What works for me is the samsung evo 32GB class 10 tf card with the kernel 3.14 version installed. It works also with a good quality usb 3.0 adapter. For testing the kernel 4.9 version more, I did buy a 64GB (the max size that T95Z Plus can use) class 10 tf card.
http://www.ebay.com/itm/Class-10-128GB-64GB-32GB-Micro-SD-Flash-TF-Memory-Card-for-Camera-Mobile-Phone-/371969750227
I'm using one of the fastest USB3.0 Flash Dive in the planet. (250MB/s reading, 190MB/s writing)
I have to find a new SD card memory. Since my 64GB C10 become dead without any known reason
So, This is what I did
First. I extracted dtb file from the working android using this method:
And I found that the 1GB version is the same. didn't change.
but my version (which is 2GB) it has a little bit of a change.
So, I took the new dtb file and run with it.
Unfortunately, no progress has been made. :(
Second, I did "sudo modprobe dhd" and the command give me an error (No such device).
But the wired thing. after this command, I get a notification that tell me eth0 is connected (I never connected it)
So, I write the command "dmesg" to see if there any difference. and this is what I get
[  265.060848] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  265.570698] wifi_platform_bus_enumerate device present 1
[  265.570765] ======== Card detection to detect SDIO card! ========
[  265.610380] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  265.626401] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  265.633674] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  265.635108] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  265.638728] sdio: clk 200000000 SDR mode tuning start
[  265.641012] sdio: rx_tuning_result[1] = 10
[  265.642839] sdio: rx_tuning_result[2] = 10
[  265.644591] sdio: rx_tuning_result[3] = 10
[  265.646387] sdio: rx_tuning_result[4] = 10
[  265.646445] sdio: best_win_start =1, best_win_size =4
[  265.646503] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  265.646595] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  265.658025] sdio: queuing unknown CIS tuple 0x80 (1 bytes)
[  265.658591] sdio: queuing unknown CIS tuple 0x81 (1 bytes)
[  265.659132] sdio: queuing unknown CIS tuple 0x82 (1 bytes)
[  265.659402] sdio: new ultra high speed SDR104 SDIO card at address 0001
[  265.659461] sdio: clock 200000000, 4-bit-bus-width
[  265.662194] [sdio_reinit] finish
[  267.660723] failed to power up DHD generic adapter, 3 retry left
[  267.677073] wifi_platform_set_power = 0
[  267.677100] ======== PULL WL_REG_ON LOW! ========
[  267.677107] wifi_platform_bus_enumerate device present 0
[  267.677112] ======== Card detection to remove SDIO card! ========
[  267.677175] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  267.878010] wifi_platform_set_power = 1
[  267.878021] ======== PULL WL_REG_ON HIGH! ========
[  267.878040] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  268.078076] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  268.580794] wifi_platform_bus_enumerate device present 1
[  268.580855] ======== Card detection to detect SDIO card! ========
[  268.580904] sdio_reset_comm():
[  268.620722] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  268.636681] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  268.643804] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  268.648900] sdio: clk 200000000 SDR mode tuning start
[  268.651360] sdio: rx_tuning_result[1] = 10
[  268.653503] sdio: rx_tuning_result[2] = 10
[  268.655260] sdio: rx_tuning_result[3] = 10
[  268.656983] sdio: rx_tuning_result[4] = 10
[  268.657041] sdio: best_win_start =1, best_win_size =4
[  268.657100] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  268.657169] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  268.657224] [sdio_reinit] finish
[  270.650767] failed to power up DHD generic adapter, 2 retry left
[  270.667459] wifi_platform_set_power = 0
[  270.667530] ======== PULL WL_REG_ON LOW! ========
[  270.667583] wifi_platform_bus_enumerate device present 0
[  270.667625] ======== Card detection to remove SDIO card! ========
[  270.667781] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  270.868090] wifi_platform_set_power = 1
[  270.868102] ======== PULL WL_REG_ON HIGH! ========
[  270.868121] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  271.068161] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  271.570711] wifi_platform_bus_enumerate device present 1
[  271.570778] ======== Card detection to detect SDIO card! ========
[  271.570827] sdio_reset_comm():
[  271.610664] sdio_read_cis: 1 callbacks suppressed
[  271.610753] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  271.626673] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  271.633692] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  271.635141] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  271.638852] sdio: clk 200000000 SDR mode tuning start
[  271.643293] sdio: rx_tuning_result[1] = 10
[  271.645214] sdio: rx_tuning_result[2] = 10
[  271.647095] sdio: rx_tuning_result[3] = 10
[  271.648971] sdio: rx_tuning_result[4] = 10
[  271.649029] sdio: best_win_start =1, best_win_size =4
[  271.649087] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  271.649159] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  271.649213] [sdio_reinit] finish
[  273.640784] failed to power up DHD generic adapter, 1 retry left
[  273.657455] wifi_platform_set_power = 0
[  273.657525] ======== PULL WL_REG_ON LOW! ========
[  273.657576] wifi_platform_bus_enumerate device present 0
[  273.657619] ======== Card detection to remove SDIO card! ========
[  273.657778] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  273.858087] wifi_platform_set_power = 1
[  273.858109] ======== PULL WL_REG_ON HIGH! ========
[  273.858142] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  274.058181] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  274.560790] wifi_platform_bus_enumerate device present 1
[  274.560858] ======== Card detection to detect SDIO card! ========
[  274.560906] sdio_reset_comm():
[  274.600856] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  274.614839] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  274.620969] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  274.622205] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  274.625417] sdio: clk 200000000 SDR mode tuning start
[  274.626513] sdio: rx_tuning_result[1] = 10
[  274.627475] sdio: rx_tuning_result[2] = 10
[  274.628434] sdio: rx_tuning_result[3] = 10
[  274.629390] sdio: rx_tuning_result[4] = 10
[  274.629412] sdio: best_win_start =1, best_win_size =4
[  274.629436] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  274.629462] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  274.629485] [sdio_reinit] finish
[  276.620757] failed to power up DHD generic adapter, 0 retry left
[  276.637411] wifi_platform_set_power = 0
[  276.637481] ======== PULL WL_REG_ON LOW! ========
[  276.637532] wifi_platform_bus_enumerate device present 0
[  276.637574] ======== Card detection to remove SDIO card! ========
[  276.637729] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  276.837943] failed to power up DHD generic adapter, max retry reached**
[  276.837982] unregister wifi platform drivers
[  276.837988] wifi_platform_bus_enumerate device present 0
[  276.837993] ======== Card detection to remove SDIO card! ========
[  276.838013] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  277.038035] dhd_module_init: Failed to load the driver, try cnt 3
[  277.038060] ======== bcm_wlan_set_plat_data ========
[  277.038064] host_oob_irq: 100
[  277.038068] host_oob_irq_flags=0x414
[  277.038071] dhd_wifi_platform_load: Enter
[  277.038102] Power-up adapter 'DHD generic adapter'
[  277.038106] wifi_platform_set_power = 1
[  277.038110] ======== PULL WL_REG_ON HIGH! ========
[  277.038123] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  277.238154] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  277.740716] wifi_platform_bus_enumerate device present 1
[  277.740779] ======== Card detection to detect SDIO card! ========
[  277.740827] sdio_reset_comm():
[  277.780584] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  277.796622] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  277.803748] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  277.805188] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  277.808913] sdio: clk 200000000 SDR mode tuning start
[  277.811343] sdio: rx_tuning_result[1] = 10
[  277.813213] sdio: rx_tuning_result[2] = 10
[  277.815126] sdio: rx_tuning_result[3] = 10
[  277.816998] sdio: rx_tuning_result[4] = 10
[  277.817054] sdio: best_win_start =1, best_win_size =4
[  277.817112] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  277.817177] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  277.817231] [sdio_reinit] finish
[  279.810803] failed to power up DHD generic adapter, 3 retry left
[  279.827469] wifi_platform_set_power = 0
[  279.827539] ======== PULL WL_REG_ON LOW! ========
[  279.827592] wifi_platform_bus_enumerate device present 0
[  279.827635] ======== Card detection to remove SDIO card! ========
[  279.827792] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  280.028153] wifi_platform_set_power = 1
[  280.028167] ======== PULL WL_REG_ON HIGH! ========
[  280.028189] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  280.228233] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  280.730769] wifi_platform_bus_enumerate device present 1
[  280.730831] ======== Card detection to detect SDIO card! ========
[  280.730880] sdio_reset_comm():
[  280.770801] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  280.786919] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  280.793971] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  280.795425] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  280.799129] sdio: clk 200000000 SDR mode tuning start
[  280.801952] sdio: rx_tuning_result[1] = 10
[  280.803822] sdio: rx_tuning_result[2] = 10
[  280.805664] sdio: rx_tuning_result[3] = 10
[  280.807459] sdio: rx_tuning_result[4] = 10
[  280.807515] sdio: best_win_start =1, best_win_size =4
[  280.807574] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  280.807659] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  280.807714] [sdio_reinit] finish
[  282.800777] failed to power up DHD generic adapter, 2 retry left
[  282.817447] wifi_platform_set_power = 0
[  282.817519] ======== PULL WL_REG_ON LOW! ========
[  282.817569] wifi_platform_bus_enumerate device present 0
[  282.817612] ======== Card detection to remove SDIO card! ========
[  282.817768] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  283.018100] wifi_platform_set_power = 1
[  283.018113] ======== PULL WL_REG_ON HIGH! ========
[  283.018132] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  283.218176] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  283.720703] wifi_platform_bus_enumerate device present 1
[  283.720768] ======== Card detection to detect SDIO card! ========
[  283.720817] sdio_reset_comm():
[  283.760749] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  283.776757] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  283.783787] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  283.785195] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  283.788821] sdio: clk 200000000 SDR mode tuning start
[  283.791241] sdio: rx_tuning_result[1] = 10
[  283.792692] sdio: rx_tuning_result[2] = 10
[  283.793364] sdio: rx_tuning_result[3] = 10
[  283.794027] sdio: rx_tuning_result[4] = 10
[  283.794039] sdio: best_win_start =1, best_win_size =4
[  283.794052] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  283.794067] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  283.794082] [sdio_reinit] finish
[  285.790835] failed to power up DHD generic adapter, 1 retry left
[  285.807496] wifi_platform_set_power = 0
[  285.807572] ======== PULL WL_REG_ON LOW! ========
[  285.807624] wifi_platform_bus_enumerate device present 0
[  285.807667] ======== Card detection to remove SDIO card! ========
[  285.807816] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  286.008053] wifi_platform_set_power = 1
[  286.008066] ======== PULL WL_REG_ON HIGH! ========
[  286.008085] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  286.208124] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  286.710781] wifi_platform_bus_enumerate device present 1
[  286.710848] ======== Card detection to detect SDIO card! ========
[  286.710896] sdio_reset_comm():
[  286.750765] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  286.766741] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  286.773791] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  286.775238] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  286.778941] sdio: clk 200000000 SDR mode tuning start
[  286.781783] sdio: rx_tuning_result[1] = 10
[  286.782528] sdio: rx_tuning_result[2] = 10
[  286.783193] sdio: rx_tuning_result[3] = 10
[  286.783992] sdio: rx_tuning_result[4] = 10
[  286.784004] sdio: best_win_start =1, best_win_size =4
[  286.784016] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  286.784034] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  286.784049] [sdio_reinit] finish
[  288.780830] failed to power up DHD generic adapter, 0 retry left
[  288.797504] wifi_platform_set_power = 0
[  288.797574] ======== PULL WL_REG_ON LOW! ========
[  288.797625] wifi_platform_bus_enumerate device present 0
[  288.797669] ======== Card detection to remove SDIO card! ========
[  288.797825] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  288.998266] failed to power up DHD generic adapter, max retry reached**
[  288.998301] unregister wifi platform drivers
[  288.998306] wifi_platform_bus_enumerate device present 0
[  288.998310] ======== Card detection to remove SDIO card! ========
[  288.998330] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  289.198354] dhd_module_init: Failed to load the driver, try cnt 2
[  289.198384] ======== bcm_wlan_set_plat_data ========
[  289.198389] host_oob_irq: 100
[  289.198393] host_oob_irq_flags=0x414
[  289.198396] dhd_wifi_platform_load: Enter
[  289.198429] Power-up adapter 'DHD generic adapter'
[  289.198433] wifi_platform_set_power = 1
[  289.198437] ======== PULL WL_REG_ON HIGH! ========
[  289.198457] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  289.398485] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  289.900717] wifi_platform_bus_enumerate device present 1
[  289.900778] ======== Card detection to detect SDIO card! ========
[  289.900826] sdio_reset_comm():
[  289.941212] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  289.957360] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  289.964421] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  289.965652] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  289.968735] sdio: clk 200000000 SDR mode tuning start
[  289.969485] sdio: rx_tuning_result[1] = 10
[  289.970148] sdio: rx_tuning_result[2] = 10
[  289.971019] sdio: rx_tuning_result[3] = 10
[  289.971719] sdio: rx_tuning_result[4] = 10
[  289.971732] sdio: best_win_start =1, best_win_size =4
[  289.971744] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  289.971760] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  289.971774] [sdio_reinit] finish
[  291.970788] failed to power up DHD generic adapter, 3 retry left
[  291.987480] wifi_platform_set_power = 0
[  291.987551] ======== PULL WL_REG_ON LOW! ========
[  291.987605] wifi_platform_bus_enumerate device present 0
[  291.987649] ======== Card detection to remove SDIO card! ========
[  291.987808] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  292.188146] wifi_platform_set_power = 1
[  292.188159] ======== PULL WL_REG_ON HIGH! ========
[  292.188179] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  292.388215] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  292.890767] wifi_platform_bus_enumerate device present 1
[  292.890829] ======== Card detection to detect SDIO card! ========
[  292.890878] sdio_reset_comm():
[  292.930827] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  292.947272] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  292.954520] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  292.955983] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  292.959704] sdio: clk 200000000 SDR mode tuning start
[  292.962221] sdio: rx_tuning_result[1] = 10
[  292.962737] sdio: rx_tuning_result[2] = 10
[  292.963233] sdio: rx_tuning_result[3] = 10
[  292.963725] sdio: rx_tuning_result[4] = 10
[  292.963737] sdio: best_win_start =1, best_win_size =4
[  292.963749] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  292.963766] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  292.963778] [sdio_reinit] finish
[  294.960770] failed to power up DHD generic adapter, 2 retry left
[  294.977440] wifi_platform_set_power = 0
[  294.977512] ======== PULL WL_REG_ON LOW! ========
[  294.977564] wifi_platform_bus_enumerate device present 0
[  294.977608] ======== Card detection to remove SDIO card! ========
[  294.977762] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  295.178194] wifi_platform_set_power = 1
[  295.178206] ======== PULL WL_REG_ON HIGH! ========
[  295.178225] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  295.378273] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  295.880767] wifi_platform_bus_enumerate device present 1
[  295.880833] ======== Card detection to detect SDIO card! ========
[  295.880883] sdio_reset_comm():
[  295.920786] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  295.936719] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  295.943788] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  295.945280] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  295.949105] sdio: clk 200000000 SDR mode tuning start
[  295.953173] sdio: rx_tuning_result[1] = 10
[  295.955118] sdio: rx_tuning_result[2] = 10
[  295.957042] sdio: rx_tuning_result[3] = 10
[  295.959158] sdio: rx_tuning_result[4] = 10
[  295.959228] sdio: best_win_start =1, best_win_size =4
[  295.959288] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  295.959376] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  295.959433] [sdio_reinit] finish
[  297.950756] failed to power up DHD generic adapter, 1 retry left
[  297.967438] wifi_platform_set_power = 0
[  297.967508] ======== PULL WL_REG_ON LOW! ========
[  297.967561] wifi_platform_bus_enumerate device present 0
[  297.967604] ======== Card detection to remove SDIO card! ========
[  297.967762] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  298.168239] wifi_platform_set_power = 1
[  298.168253] ======== PULL WL_REG_ON HIGH! ========
[  298.168271] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  298.368304] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  298.870707] wifi_platform_bus_enumerate device present 1
[  298.870770] ======== Card detection to detect SDIO card! ========
[  298.870819] sdio_reset_comm():
[  298.910668] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  298.926646] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  298.933769] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  298.935217] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  298.938910] sdio: clk 200000000 SDR mode tuning start
[  298.941210] sdio: rx_tuning_result[1] = 10
[  298.943102] sdio: rx_tuning_result[2] = 10
[  298.944992] sdio: rx_tuning_result[3] = 10
[  298.946884] sdio: rx_tuning_result[4] = 10
[  298.946941] sdio: best_win_start =1, best_win_size =4
[  298.946999] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  298.947064] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  298.947118] [sdio_reinit] finish
[  300.940787] failed to power up DHD generic adapter, 0 retry left
[  300.957458] wifi_platform_set_power = 0
[  300.957528] ======== PULL WL_REG_ON LOW! ========
[  300.957581] wifi_platform_bus_enumerate device present 0
[  300.957624] ======== Card detection to remove SDIO card! ========
[  300.957780] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  301.158112] failed to power up DHD generic adapter, max retry reached**
[  301.158166] unregister wifi platform drivers
[  301.158178] wifi_platform_bus_enumerate device present 0
[  301.158187] ======== Card detection to remove SDIO card! ========
[  301.158219] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  301.358242] dhd_module_init: Failed to load the driver, try cnt 1
[  301.358265] ======== bcm_wlan_set_plat_data ========
[  301.358269] host_oob_irq: 100
[  301.358272] host_oob_irq_flags=0x414
[  301.358275] dhd_wifi_platform_load: Enter
[  301.358293] Power-up adapter 'DHD generic adapter'
[  301.358296] wifi_platform_set_power = 1
[  301.358300] ======== PULL WL_REG_ON HIGH! ========
[  301.358312] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  301.558340] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  302.060954] wifi_platform_bus_enumerate device present 1
[  302.061017] ======== Card detection to detect SDIO card! ========
[  302.061066] sdio_reset_comm():
[  302.100697] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  302.116611] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  302.123781] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  302.125228] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  302.128944] sdio: clk 200000000 SDR mode tuning start
[  302.131519] sdio: rx_tuning_result[1] = 10
[  302.133673] sdio: rx_tuning_result[2] = 10
[  302.135720] sdio: rx_tuning_result[3] = 10
[  302.137599] sdio: rx_tuning_result[4] = 10
[  302.137654] sdio: best_win_start =1, best_win_size =4
[  302.137713] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  302.137778] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  302.137831] [sdio_reinit] finish
[  304.130761] failed to power up DHD generic adapter, 3 retry left
[  304.147450] wifi_platform_set_power = 0
[  304.147521] ======== PULL WL_REG_ON LOW! ========
[  304.147573] wifi_platform_bus_enumerate device present 0
[  304.147616] ======== Card detection to remove SDIO card! ========
[  304.147772] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  304.348304] wifi_platform_set_power = 1
[  304.348372] ======== PULL WL_REG_ON HIGH! ========
[  304.348490] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  304.548910] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  305.050679] wifi_platform_bus_enumerate device present 1
[  305.050740] ======== Card detection to detect SDIO card! ========
[  305.050790] sdio_reset_comm():
[  305.088747] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  305.102743] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  305.108759] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  305.109983] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  305.113305] sdio: clk 200000000 SDR mode tuning start
[  305.114416] sdio: rx_tuning_result[1] = 10
[  305.115395] sdio: rx_tuning_result[2] = 10
[  305.116371] sdio: rx_tuning_result[3] = 10
[  305.117434] sdio: rx_tuning_result[4] = 10
[  305.117458] sdio: best_win_start =1, best_win_size =4
[  305.117481] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  305.117509] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  305.117532] [sdio_reinit] finish
[  307.110718] failed to power up DHD generic adapter, 2 retry left
[  307.127380] wifi_platform_set_power = 0
[  307.127451] ======== PULL WL_REG_ON LOW! ========
[  307.127503] wifi_platform_bus_enumerate device present 0
[  307.127546] ======== Card detection to remove SDIO card! ========
[  307.127703] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  307.328307] wifi_platform_set_power = 1
[  307.328378] ======== PULL WL_REG_ON HIGH! ========
[  307.328503] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  307.528987] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  308.030716] wifi_platform_bus_enumerate device present 1
[  308.030781] ======== Card detection to detect SDIO card! ========
[  308.030831] sdio_reset_comm():
[  308.070710] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  308.086758] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  308.093946] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  308.095406] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  308.099131] sdio: clk 200000000 SDR mode tuning start
[  308.101604] sdio: rx_tuning_result[1] = 10
[  308.102812] sdio: rx_tuning_result[2] = 10
[  308.103498] sdio: rx_tuning_result[3] = 10
[  308.104175] sdio: rx_tuning_result[4] = 10
[  308.104188] sdio: best_win_start =1, best_win_size =4
[  308.104201] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  308.104217] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  308.104230] [sdio_reinit] finish
[  310.100806] failed to power up DHD generic adapter, 1 retry left
[  310.117478] wifi_platform_set_power = 0
[  310.117549] ======== PULL WL_REG_ON LOW! ========
[  310.117601] wifi_platform_bus_enumerate device present 0
[  310.117644] ======== Card detection to remove SDIO card! ========
[  310.117798] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  310.318232] wifi_platform_set_power = 1
[  310.318245] ======== PULL WL_REG_ON HIGH! ========
[  310.318265] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  310.518296] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Enable! 240
[  311.020693] wifi_platform_bus_enumerate device present 1
[  311.020755] ======== Card detection to detect SDIO card! ========
[  311.020804] sdio_reset_comm():
[  311.060672] sdio: queuing unknown CIS tuple 0x01 (3 bytes)
[  311.075005] sdio: queuing unknown CIS tuple 0x1a (5 bytes)
[  311.081053] sdio: queuing unknown CIS tuple 0x1b (8 bytes)
[  311.082290] sdio: queuing unknown CIS tuple 0x14 (0 bytes)
[  311.085522] sdio: clk 200000000 SDR mode tuning start
[  311.086624] sdio: rx_tuning_result[1] = 10
[  311.087603] sdio: rx_tuning_result[2] = 10
[  311.088576] sdio: rx_tuning_result[3] = 10
[  311.089548] sdio: rx_tuning_result[4] = 10
[  311.089570] sdio: best_win_start =1, best_win_size =4
[  311.089594] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x32000
[  311.089632] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x32000
[  311.089654] [sdio_reinit] finish
[  313.080841] failed to power up DHD generic adapter, 0 retry left
[  313.097519] wifi_platform_set_power = 0
[  313.097590] ======== PULL WL_REG_ON LOW! ========
[  313.097642] wifi_platform_bus_enumerate device present 0
[  313.097685] ======== Card detection to remove SDIO card! ========
[  313.097842] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  313.298179] failed to power up DHD generic adapter, max retry reached**
[  313.298219] unregister wifi platform drivers
[  313.298225] wifi_platform_bus_enumerate device present 0
[  313.298230] ======== Card detection to remove SDIO card! ========
[  313.298251] aml_wifi wifi.33: [extern_wifi_set_enable] WIFI  Disable! 240
[  313.498271] dhd_module_init: Failed to load the driver, try cnt 0
[  313.498294] dhd_module_init: Failed to load driver max retry reached**
[  313.498298] dhd_module_init: Exit err=-19
[  322.156974] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
  Reveal hidden contents
The dtb file must match your hardware and kernel exactly. You can see example source code in linux kernel source directory: linux/arch/arm64/boot/dts/amlogic/.  You did write that you tested my method: https://forum.armbian.com/index.php?/topic/3401-sunvell-t95z-plus-booting-armbian-from-sd-card/#comment-33682
First step is see the wlan0 device with dmesg. Adding wifi_dummy to /etc/modules made that. Then with the ethernet cable update Armbian to Debian testing, install wicd and remove networkmanager package and systemd networking.service.  Maybe our S912 tvboxes do differ so much that my method does not work. With balbes150 kernel 3.14 everything works. balbes150 4.9 kernel does not have audio driver and network does not work.
I can not see in your dmesg that if the firmware for wifi is found or not. Maybe you do need to install the correct firmware. Firmware can have many files, all of them you should put in /lib/firmware/bcrm.
I tried to install on mecool bb2 pro s912:
Armbian_5.27_S9xxx_Ubuntu_xenial_3.14.29_mate_KODI_20170623.img.xz
The installation did not start with gxm_q200_3g.dtb (dtb.img). It was only after deleting the dtb.img file that the installation went through correctly.
Wifi works after "sudo modprobe dhd"
Unfortunately launching KODI causes artifacts.
Does KODI have any chance of running under ubuntu on my device without hardware acceleration?
( OpenElec works very well )
Kodi is a user interface that can use ( http://kodi.wiki/view/external_players ) other Linux software to play videos and music ( https://packages.debian.org/testing/video/). If the other  video players do not work, then Kodi does not work either. Chromium browser uses all cpu cores to play youtube videos correctly so a light change is that some other player can too. Armbian desktop mp4 files do not work with the default player.
Hello everyone
Does anyone have or knows which version of dtb works with the Beelink GT1 A912 AP6255
tried Armbian_5.27_S9xxx_Ubuntu_xenial_3.14.29_mate_20170619 and dtb in folder for
beelink_gt1_g2
gxm_q201_2g
vega_s96
Only with vega_s96 have working ethernet but no wifi
1 hour ago, ad_lopta said:
Hello everyone
beelink_gt1_g2
gxm_q201_2g
vega_s96
vega_s96.dtb does work with Sunvell T95Z Plus. and Jessie Xfce. Copy it to as BOOT/ dtb.img. With ap6255 wifi use the dhd driver, modprobe dhd and install correct firmware from the Armbian firmware package. With recent systemd, you might have systemd syscall 279 kernel tainted messages in dmesg. Add audit=0 to the kernel command line by editing the .cmd file and using mkimage tool to make the u-boot binary. mkimage -T script -C none -n 's905 autoscript' -d s905_autoscript.cmd s905_autoscript
Thanks debianxfce
I tried again with gxm_q201_2g. At first it does not work wifi but when i try dhd driver then it works
perfect
Update images kernel 3.14.29. (20170701)
Changes - added driver for qca9377. Its use is similar to the module "dhd" and "wifi_dummy". To check loaded, with the command "modprobe qca9377" if a WiFi network will work with it, write its startup in /etc/modules.
I checked on the model Tronsmart S96 (s912) - with this module the WiFi and BT working. By the way, I didn't even need to manually copy the dtb file, the system could earn with regular dtb from the internal memory. I wonder how on other models, to run these images without manually adding the dtb file.
WOW. I really appreciate you and your efforts to support this OS on Amlogic based devices. :o
Even downloaded the 20170701 release before you write this post.
Thank you very much. From this forum and the other 2 forums
OK. Let's try it right now.
UPDATE: Now the WiFi Works! (Beelink GT1 S912/G912)
By the way. I like the new first boot method, which makes the device restart it self. and the new login screen, which make me able to login as a root user
Thank you balbes150, I have completely changed my mind regarding the use I will make of my S912 boards (make one or multiple Indi servers), I will test your new images on the H96pro+ today or tomorrow.
Additional question: do you know how I can use the serial port (is there one or two ?) on this board ?
Thank you very much for your help
I hope we will get better driver support for Linux after the release of Khadas VIM2 (Developing board based on Amlogic S912)
Can we use Android Mali drivers with libhybris? or that is not supported now?
By default (not copying the dtb file as dtb.img at the root of the BOOT partition) wifi does not work on H96 pro + (apparently fnlink 8223a-sr). Neither does sound, however bluetooth works well.
A weird thing is that cat /proc/cpuinfo allows to see all 8 cores, however gnome-system-monitor for ubuntu mates only shows 2 cores.
After multiple edit, nevermind, everything is up and running thanks to the wifi_dummy added to /etc/modules. However I did not checked if both 2.4 and 5GHz channels are working, but I see no reason for this to fail.
Thank you balbes150, this is truly awesome
23 hours ago, gnthibault said:
Has someone been able to use the remote controller under armbian yet ? what would it require ?
Thank you in advance for your help.
I can see with the dmesg command that I have pressed LG 26LG3000 remote controller. Using my custom balbes150 armbian 3.14.29 kernel and Debian testing Xfce.
https://www.youtube.com/watch?v=UsNzZn-luc0
[ 1565.352988] remote: scancode is 0x0008,invalid key is 0x0000.
[ 1565.690377] remote: scancode is 0x0008,invalid key is 0x0000.
I have enabled AMlogic remote controller in the kernel, but I am not using Sunvell T95Z Plus infrared remote controller, because I have a mini wireless keyboard/touchpad with 2.4Ghz usb adapter and it works ok, except it must be close (less than 50 cm)  to the tvbox and have direct view to the usb adapter.
2 hours ago, balbes150 said:
Test Assembly for s912.
https://yadi.sk/d/HWf1_w123KhtER
libreelec newes version for s912
Currently missing, I am also waiting for this version.
Wait for the S912 open source Linux GPU accelerated driver can be long or never happen. Vim 2 board is not even in sale yet and open source community or Shenzhen Wesion do not have resources and skills. Arm should do the driver. The development of the Nouveau driver is slow and it performs poorly compared to the nvidia proprietary driver.
http://www.cnx-software.com/2017/07/02/the-first-amlogic-s912-development-board-is-coming-soon-with-khadas-vim2/
Librelec uses some hack to make the android gpu driver to work with 905.
I don't know if this is related to S912, but I can't use vncserver on the latest ubuntu image,
Is there a tutorial somwhere that explains how to get anything else than a grey screen when connecting to armbian through vncserver ?
Hi all, I have big problem with H96 Pro+ after Armbian Installation.
I made an Armbian SDCard and booted up to the BOX and after some testing, I decided to use "nand-sata-install" command.
After it was done, I reboot the Box but it doesn't boot. (No Signal on HDMI / Not recognized on PC usb port).
The power led blinks between red and blue continuously.
What can I do to recover it ? Can someone help me please ?
Thank you.
Thank you.
Why on earth did you that. From class 10 microsd card Debian testing Xfce runs fine. When you look at that script, you see sunxi comments often. Armbian does not support S912, so all emmc scripts are dangerous. Balbes150 s905_install.sh script looks much safer and probably works after editing or without.  Take a look of the nand-sata-install script if it has overwritten bootloader, if it is then things are more difficult.  Contact the manufacturer to get original firmware and instructions to flash it.
has anyone been able to get ZFS to work on an S912 armbian?
How can I get ethernet to work with OpenSUSE or Archlinux? (would ZFS work on those?)
Does anyone know if ZFS works on other S9xx boxes?
Hey guys
So I tried some distros from balbes150 on my beelink GT1 A912 (2GB + 32GB)
  • Armbian_5.27_S9xxx_Ubuntu_xenial_3.14.29_mate_20170705.img.xz << Boots correctly, lan, wifi (wifi_dummy), BT, audio, hdmi, usbs, all work "correctly" (I dont know what else should I check but this is what I got), video playback lags and even freezes the box (sometimes), however on chromium it played some videos correctly but lags a lot!
  • S9xxx_ArchLinux_20170617_3_14_29.img.xz << Boots correctly, I tried lan and wifi (which works apparently after installing iw wpa_supplicant and dialog for wifi-menu), I didnt continue any further because installing a gui got me into a black screen (could only get through ssh)
  • Armbian_5.27_S905X-S912_Ubuntu_xenial_4.9.26+_mate_20170519.img.xz AND Armbian_5.27_S9xxx_Ubuntu_xenial_4.12.0+_mate_20170711.img.xz as well as S905X_S912_ArchLinux_20170519_4_9_26.img.xz << DID NOT BOOT, for some reason, I see my drive's LED blinking when I start the box, after that, the beelink logo disappears and I stay with a black screen. I tried putting beelink_gt1_g2.dtb / vega_s96 as dtb.img and in dtb folders but same results. Can someone explain why or show me how to workaround this?
  • LibreElec 8.0.2e << everything works oob but a bit sluggish
I use an external USB3.0 160GB HDD drive (I swapped the internal HDD with another one), and the image is written (img.xz) with gnome-disk-utility.
Just for information: I just found out that I can boot directly to any USB drive (ofc with the correct OS/files) without the toothpick method just by inserting the USB disk before plugging the power cord, the box should load the content of the USB automatically. I dont know if this happens for others but it's good to know.
It always works with the instruction from below link
http://www.wolffhaven45.com/blog/linux/x11vnc-server-installation-ubuntu-16-04-xenial-xerus/
On 16/07/2017 at 0:09 AM, midi-sama said:
Hey guys
There is no gpu accelerated graphics for 912 in Linux drivers. Chromium uses all cpu cores for software rendering and that is why it works. Balbes 4.9 kernel does not have audio so it is unusable. Not worth to use or explain why it does not work. It must  take a long time with 160GB drive when the armbian expands the image at first boot. Many new boxes do have multiboot features, so toothpick is for some older boxes.
Could someone explain how to install ubuntu on the built in eMMC memory?
I have tried both the mate and server 16.04 images from the freaktab thread, on sd card. And they work (except wifi)
But I'd like to run the OS directly from the built in memory. I don't care about overwriting Android
Take a look of this script: https://github.com/150balbes/lib/blob/master/scripts/amlogic/905_install.sh
ycomp: when your are logged as root, just run the install script in /home/root as suggested by debianxfce.
My question is related to vnc, I always get grey window when connecting to the tightvnc server. I use the latest 3.14 Ubuntu Mate (16.04) desktop image, but I am not connecting my box to a display. Can someone give me an example of xstartup file that works ? What bothers me for the moment is that log does not show error, bu still nothing but a grey screen ...
Edit, here is the solution (yaaayyy!):
Setup password with
vncpasswd /etc/vnc/vncpasswd
Then add the following lines to /etc/lightdm/lightdm.conf :
[VNCServer]
enabled=true
command=/usr/bin/Xvnc -rfbauth /etc/vnc/vncpasswd
port=5900
width=1280
height=1024
depth=24
