andersm Posted April 13, 2020 Posted April 13, 2020 Hi, We've built a network experimentation system using NanoPi R1 modules, but when load testing the system with iperf3, we are seeing the on-board RTL8152 interface enter a state where it does not seem to be responding until the board is power cycled. The system consists of 32 NanoPi modules connected in a torus, with the 1Gig interface connected to its neighbour's 100Mbit interface. An additional USB Ethernet dongle functions as a control interface. The modules are powered from a Ubiquiti PoE switch, using this type of isolated PoE splitter. Eyeballing the switch UI, power consumption per node seems to hover between 2.3W-3.5W, depending on load. We're using the latest Ubuntu-based image, with kernel 5.4.28. Under light loads, the system works fine, but when performing load tests, we're seeing the RTL8152 entering some kind of lock-up state. As can be seen from the system logs, first the netdev watchdog triggers, then the kernel tries to reset the USB device, finally reporting that it is unable to enumerate the device. After encountering this problem, if the node is rebooted, the USB device can still not be enumerated, and will remain unresponsive until it is powercycled. The external USB Ethernet dongle stays working through all of this, so it seems that the USB host controller and subsystem works OK. We haven't seen any issues with the 1Gig interface. Searching the net, I have found reports with similar backtraces, but they seem to be either several years old, or related to the RTL8153 chip, which shares the same driver. In either case, none of them seem to offer any answers as to what's going on, or if there is any fix. Has anyone else seen this? Any ideas if it's a driver or hardware issue? Relevant bit from the kernel log: Spoiler 10707 [ 1063.202413] ------------[ cut here ]------------ 10708 [ 1063.202481] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:448 dev_watchdog+0x213/0x214 10709 [ 1063.202500] NETDEV WATCHDOG: bridgeif1 (r8152): transmit queue 0 timed out 10710 [ 1063.202506] Modules linked in: hsr evdev lima gpu_sched snd_soc_simple_card snd_soc_simple_card_utils zram sun8i_codec_analog sun8i_adda_pr_regmap sun4i_i2s sun4i_gpadc_iio snd_soc_core industrialio snd_pcm_dmaengine snd_pcm r8152 snd_timer snd cdc_ether sun8i_thermal soundcore usbnet sunxi_cedrus(C) v4l2_mem2mem gpio_keys uio_pdrv_genirq uio cpufreq_dt sch_fq_codel usb_f_acm u_serial g_serial libcomposite ip_tables x_tables pwrseq_simple realtek 10711 [ 1063.202605] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G C 5.4.28-sunxi #20.02.7 10712 [ 1063.202610] Hardware name: Allwinner sun8i Family 10713 [ 1063.202640] [<c010da8d>] (unwind_backtrace) from [<c010a0ad>] (show_stack+0x11/0x14) 10714 [ 1063.202661] [<c010a0ad>] (show_stack) from [<c0951bef>] (dump_stack+0x6f/0x7c) 10715 [ 1063.202687] [<c0951bef>] (dump_stack) from [<c011b60b>] (__warn+0xb7/0xb8) 10716 [ 1063.202702] [<c011b60b>] (__warn) from [<c011b8b7>] (warn_slowpath_fmt+0x5f/0x74) 10717 [ 1063.202716] [<c011b8b7>] (warn_slowpath_fmt) from [<c0850083>] (dev_watchdog+0x213/0x214) 10718 [ 1063.202740] [<c0850083>] (dev_watchdog) from [<c017209b>] (call_timer_fn+0x27/0x128) 10719 [ 1063.202752] [<c017209b>] (call_timer_fn) from [<c0172c15>] (run_timer_softirq+0x3f9/0x418) 10720 [ 1063.202763] [<c0172c15>] (run_timer_softirq) from [<c01022f7>] (__do_softirq+0xdf/0x288) 10721 [ 1063.202775] [<c01022f7>] (__do_softirq) from [<c012035f>] (irq_exit+0x7b/0x90) 10722 [ 1063.202792] [<c012035f>] (irq_exit) from [<c016051f>] (__handle_domain_irq+0x47/0x84) 10723 [ 1063.202812] [<c016051f>] (__handle_domain_irq) from [<c05e3c4d>] (gic_handle_irq+0x39/0x6c) 10724 [ 1063.202829] [<c05e3c4d>] (gic_handle_irq) from [<c0101ae5>] (__irq_svc+0x65/0x94) 10725 [ 1063.202841] Exception stack(0xc0f01f20 to 0xc0f01f68) 10726 [ 1063.202855] 1f20: 00000000 0050f000 ef69ff34 c0116341 ffffe000 c0f04f68 c0f04fb0 00000001 10727 [ 1063.202865] 1f40: c0f04f48 00000000 c0ec48f0 c0ff67f6 c0f05028 c0f01f70 c010792f c0107930 10728 [ 1063.202869] 1f60: 400d0033 ffffffff 10729 [ 1063.202886] [<c0101ae5>] (__irq_svc) from [<c0107930>] (arch_cpu_idle+0x28/0x2c) 10730 [ 1063.202900] [<c0107930>] (arch_cpu_idle) from [<c013fa4f>] (do_idle+0x15b/0x1cc) 10731 [ 1063.202912] [<c013fa4f>] (do_idle) from [<c013fcb9>] (cpu_startup_entry+0x19/0x20) 10732 [ 1063.202932] [<c013fcb9>] (cpu_startup_entry) from [<c0e00c6d>] (start_kernel+0x3fb/0x40c) 10733 [ 1063.202948] ---[ end trace 8a7042696d164652 ]--- 10734 [ 1063.202968] r8152 2-1:1.0 bridgeif1: Tx timeout 10735 [ 1064.777084] r8152 2-1:1.0 bridgeif1: Tx status -2 10736 [ 1064.780443] r8152 2-1:1.0 bridgeif1: Tx status -2 10737 [ 1064.783815] r8152 2-1:1.0 bridgeif1: Tx status -2 10738 [ 1064.787064] r8152 2-1:1.0 bridgeif1: Tx status -2 10739 [ 1068.322762] r8152 2-1:1.0 bridgeif1: Tx timeout 10740 [ 1074.211116] r8152 2-1:1.0 bridgeif1: Tx timeout 10741 [ 1079.075375] r8152 2-1:1.0 bridgeif1: Tx timeout 10742 [ 1084.195734] r8152 2-1:1.0 bridgeif1: Tx timeout 10743 [ 1089.315981] r8152 2-1:1.0 bridgeif1: Tx timeout 10744 [ 1095.204340] r8152 2-1:1.0 bridgeif1: Tx timeout 10745 [ 1100.324633] r8152 2-1:1.0 bridgeif1: Tx timeout 10746 [ 1106.212944] r8152 2-1:1.0 bridgeif1: Tx timeout 10747 [ 1111.077223] r8152 2-1:1.0 bridgeif1: Tx timeout 10748 [ 1116.197542] r8152 2-1:1.0 bridgeif1: Tx timeout 10749 [ 1121.317802] r8152 2-1:1.0 bridgeif1: Tx timeout 10750 [ 1127.206158] r8152 2-1:1.0 bridgeif1: Tx timeout 10751 [ 1132.326404] r8152 2-1:1.0 bridgeif1: Tx timeout 10752 [ 1138.214721] r8152 2-1:1.0 bridgeif1: Tx timeout 10753 [ 1143.078976] r8152 2-1:1.0 bridgeif1: Tx timeout 10754 [ 1148.199250] r8152 2-1:1.0 bridgeif1: Tx timeout 10755 [ 1153.319543] r8152 2-1:1.0 bridgeif1: Tx timeout 10756 [ 1159.207853] r8152 2-1:1.0 bridgeif1: Tx timeout 10757 [ 1164.328134] r8152 2-1:1.0 bridgeif1: Tx timeout 10758 [ 1170.216436] r8152 2-1:1.0 bridgeif1: Tx timeout 10759 [ 1175.080678] r8152 2-1:1.0 bridgeif1: Tx timeout 10760 [ 1180.201193] r8152 2-1:1.0 bridgeif1: Tx timeout 10761 [ 1185.321188] r8152 2-1:1.0 bridgeif1: Tx timeout 10762 [ 1191.209491] r8152 2-1:1.0 bridgeif1: Tx timeout 10763 [ 1196.329740] r8152 2-1:1.0 bridgeif1: Tx timeout 10764 [ 1202.218054] r8152 2-1:1.0 bridgeif1: Tx timeout 10765 [ 1207.082286] r8152 2-1:1.0 bridgeif1: Tx timeout 10766 [ 1212.202523] r8152 2-1:1.0 bridgeif1: Tx timeout 10767 [ 1217.322777] r8152 2-1:1.0 bridgeif1: Tx timeout 10768 [ 1223.211058] r8152 2-1:1.0 bridgeif1: Tx timeout 10769 [ 1228.331309] r8152 2-1:1.0 bridgeif1: Tx timeout 10770 [ 1234.219597] r8152 2-1:1.0 bridgeif1: Tx timeout 10771 [ 1239.083829] r8152 2-1:1.0 bridgeif1: Tx timeout 10772 [ 1244.204071] r8152 2-1:1.0 bridgeif1: Tx timeout 10773 [ 1249.324313] r8152 2-1:1.0 bridgeif1: Tx timeout 10774 [ 1255.212602] r8152 2-1:1.0 bridgeif1: Tx timeout 10775 [ 1260.332834] r8152 2-1:1.0 bridgeif1: Tx timeout 10776 [ 1266.221110] r8152 2-1:1.0 bridgeif1: Tx timeout 10777 [ 1271.085335] r8152 2-1:1.0 bridgeif1: Tx timeout 10778 [ 1276.205574] r8152 2-1:1.0 bridgeif1: Tx timeout 10779 [ 1281.325815] r8152 2-1:1.0 bridgeif1: Tx timeout 10780 [ 1287.214079] r8152 2-1:1.0 bridgeif1: Tx timeout 10781 [ 1292.334321] r8152 2-1:1.0 bridgeif1: Tx timeout 10782 [ 1298.222578] r8152 2-1:1.0 bridgeif1: Tx timeout 10783 [ 1303.086798] r8152 2-1:1.0 bridgeif1: Tx timeout 10784 [ 1308.207024] r8152 2-1:1.0 bridgeif1: Tx timeout 10785 [ 1313.327255] r8152 2-1:1.0 bridgeif1: Tx timeout 10786 [ 1319.215517] r8152 2-1:1.0 bridgeif1: Tx timeout 10787 [ 1324.335751] r8152 2-1:1.0 bridgeif1: Tx timeout 10788 [ 1330.224002] r8152 2-1:1.0 bridgeif1: Tx timeout 10789 [ 1335.088218] r8152 2-1:1.0 bridgeif1: Tx timeout 10790 [ 1340.208445] r8152 2-1:1.0 bridgeif1: Tx timeout 10791 [ 1345.328670] r8152 2-1:1.0 bridgeif1: Tx timeout 10792 [ 1351.216923] r8152 2-1:1.0 bridgeif1: Tx timeout 10793 [ 1356.337149] r8152 2-1:1.0 bridgeif1: Tx timeout 10794 [ 1362.225400] r8152 2-1:1.0 bridgeif1: Tx timeout 10795 [ 1367.089604] r8152 2-1:1.0 bridgeif1: Tx timeout 10796 [ 1372.209825] r8152 2-1:1.0 bridgeif1: Tx timeout 10797 [ 1377.330044] r8152 2-1:1.0 bridgeif1: Tx timeout 10798 [ 1383.218298] r8152 2-1:1.0 bridgeif1: Tx timeout 10799 [ 1388.338517] r8152 2-1:1.0 bridgeif1: Tx timeout 10800 [ 1394.226765] r8152 2-1:1.0 bridgeif1: Tx timeout 10801 [ 1399.090969] r8152 2-1:1.0 bridgeif1: Tx timeout 10802 [ 1404.211185] r8152 2-1:1.0 bridgeif1: Tx timeout 10803 [ 1409.331406] r8152 2-1:1.0 bridgeif1: Tx timeout 10804 [ 1415.219644] r8152 2-1:1.0 bridgeif1: Tx timeout 10805 [ 1420.339862] r8152 2-1:1.0 bridgeif1: Tx timeout 10806 [ 1426.228097] r8152 2-1:1.0 bridgeif1: Tx timeout 10807 [ 1431.092293] r8152 2-1:1.0 bridgeif1: Tx timeout 10808 [ 1436.212502] r8152 2-1:1.0 bridgeif1: Tx timeout 10809 [ 1441.332714] r8152 2-1:1.0 bridgeif1: Tx timeout 10810 [ 1447.220963] r8152 2-1:1.0 bridgeif1: Tx timeout 10811 [ 1452.341168] r8152 2-1:1.0 bridgeif1: Tx timeout 10812 [ 1458.229403] r8152 2-1:1.0 bridgeif1: Tx timeout 10813 [ 1463.093607] r8152 2-1:1.0 bridgeif1: Tx timeout 10814 [ 1468.213811] r8152 2-1:1.0 bridgeif1: Tx timeout 10815 [ 1473.334015] r8152 2-1:1.0 bridgeif1: Tx timeout 10816 [ 1479.222255] r8152 2-1:1.0 bridgeif1: Tx timeout 10817 [ 1484.342458] r8152 2-1:1.0 bridgeif1: Tx timeout 10818 [ 1490.230695] r8152 2-1:1.0 bridgeif1: Tx timeout 10819 [ 1495.094882] r8152 2-1:1.0 bridgeif1: Tx timeout 10820 [ 1500.215088] r8152 2-1:1.0 bridgeif1: Tx timeout 10821 [ 1505.335292] r8152 2-1:1.0 bridgeif1: Tx timeout 10822 [ 1511.223529] r8152 2-1:1.0 bridgeif1: Tx timeout 10823 [ 1516.343733] r8152 2-1:1.0 bridgeif1: Tx timeout 10824 [ 1522.231964] r8152 2-1:1.0 bridgeif1: Tx timeout 10825 [ 1527.096153] r8152 2-1:1.0 bridgeif1: Tx timeout 10826 [ 1532.216355] r8152 2-1:1.0 bridgeif1: Tx timeout 10827 [ 1537.336553] r8152 2-1:1.0 bridgeif1: Tx timeout 10828 [ 1543.224791] r8152 2-1:1.0 bridgeif1: Tx timeout 10829 [ 1548.344992] r8152 2-1:1.0 bridgeif1: Tx timeout 10830 [ 1554.233216] r8152 2-1:1.0 bridgeif1: Tx timeout 10831 [ 1559.097401] r8152 2-1:1.0 bridgeif1: Tx timeout 10832 [ 1564.217596] r8152 2-1:1.0 bridgeif1: Tx timeout 10833 [ 1569.337793] r8152 2-1:1.0 bridgeif1: Tx timeout 10834 [ 1575.226025] r8152 2-1:1.0 bridgeif1: Tx timeout 10835 [ 1580.154332] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10836 [ 1580.346228] r8152 2-1:1.0 bridgeif1: Tx timeout 10837 [ 1586.234452] r8152 2-1:1.0 bridgeif1: Tx timeout 10838 [ 1590.794665] usb 2-1: device not accepting address 2, error -110 10839 [ 1590.926658] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10840 [ 1591.098639] r8152 2-1:1.0 bridgeif1: Tx timeout 10841 [ 1591.350662] usb 2-1: device not accepting address 2, error -71 10842 [ 1591.690677] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10843 [ 1596.218831] r8152 2-1:1.0 bridgeif1: Tx timeout 10844 [ 1596.858874] usb 2-1: device descriptor read/64, error -110 10845 [ 1601.339028] r8152 2-1:1.0 bridgeif1: Tx timeout 10846 [ 1607.227257] r8152 2-1:1.0 bridgeif1: Tx timeout 10847 [ 1612.347466] r8152 2-1:1.0 bridgeif1: Tx timeout 10848 [ 1612.479473] usb 2-1: device descriptor read/64, error -110 10849 [ 1612.719486] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10850 [ 1613.067489] usb 2-1: device descriptor read/64, error -71 10851 [ 1618.235679] r8152 2-1:1.0 bridgeif1: Tx timeout 10852 [ 1623.099860] r8152 2-1:1.0 bridgeif1: Tx timeout 10853 [ 1628.220058] r8152 2-1:1.0 bridgeif1: Tx timeout 10854 [ 1628.604091] usb 2-1: device descriptor read/64, error -110 10855 [ 1628.716148] r8152 2-1:1.0 bridgeif1: Get ether addr fail 10856 [ 1628.721491] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled 10857 [ 1628.728148] usb 2-1: USB disconnect, device number 2 10858 [ 1628.736033] device bridgeif1 left promiscuous mode 10859 [ 1629.048173] usb 2-1: new high-speed USB device number 3 using ehci-platform 10860 [ 1639.692512] usb 2-1: device not accepting address 3, error -110 10861 [ 1639.824514] usb 2-1: new high-speed USB device number 4 using ehci-platform 10862 [ 1640.248526] usb 2-1: device not accepting address 4, error -71 10863 [ 1640.254411] usb usb2-port1: attempt power cycle 10864 [ 1640.904546] usb 2-1: new high-speed USB device number 5 using ehci-platform 10865 [ 1646.268756] usb 2-1: device descriptor read/64, error -110 10866 [ 1661.885363] usb 2-1: device descriptor read/64, error -110 10867 [ 1662.125384] usb 2-1: new high-speed USB device number 6 using ehci-platform 10868 [ 1662.473360] usb 2-1: device descriptor read/64, error -71 10869 [ 1678.013953] usb 2-1: device descriptor read/64, error -110 10870 [ 1678.126003] usb usb2-port1: unable to enumerate USB device 10871 [ 1678.517957] usb 6-1: new full-speed USB device number 2 using ohci-platform 10872 [ 1694.202558] usb 6-1: device descriptor read/64, error -110 10873 [ 1709.819134] usb 6-1: device descriptor read/64, error -110 10874 [ 1710.119160] usb 6-1: new full-speed USB device number 3 using ohci-platform 10875 [ 1725.691731] usb 6-1: device descriptor read/64, error -110 10876 [ 1741.308300] usb 6-1: device descriptor read/64, error -110 10877 [ 1741.420340] usb usb6-port1: attempt power cycle 10878 [ 1741.924322] usb 6-1: new full-speed USB device number 4 using ohci-platform 10879 [ 1752.592714] usb 6-1: device not accepting address 4, error -110 10880 [ 1752.784726] usb 6-1: new full-speed USB device number 5 using ohci-platform 10881 [ 1763.601125] usb 6-1: device not accepting address 5, error -110 10882 [ 1763.607104] usb usb6-port1: unable to enumerate USB device Full diagnostic dump: Spoiler 9737 ### Activated 1 lzo zram swap devices with 499 MB each 9738 9739 ### Activated Armbian ramlog partition with zstd compression 9740 9741 Wed Apr 8 12:38:57 EEST 2020 | NanoPi R1 | 20.02.1 | armhf | armv7l | 5.4.28-sunxi 9742 9743 ### dmesg: 9744 9745 [ 0.000000] Booting Linux on physical CPU 0x0 9746 [ 0.000000] Linux version 5.4.28-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.02.7 SMP Sat Mar 28 14:32:15 CET 2020 9747 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d 9748 [ 0.000000] CPU: div instructions available: patching division code 9749 [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache 9750 [ 0.000000] OF: fdt: Machine model: FriendlyElec NanoPi-R1 9751 [ 0.000000] Memory policy: Data cache writealloc 9752 [ 0.000000] cma: Reserved 128 MiB at 0x77c00000 9753 [ 0.000000] On node 0 totalpages: 262144 9754 [ 0.000000] Normal zone: 1728 pages used for memmap 9755 [ 0.000000] Normal zone: 0 pages reserved 9756 [ 0.000000] Normal zone: 196608 pages, LIFO batch:63 9757 [ 0.000000] HighMem zone: 65536 pages, LIFO batch:15 9758 [ 0.000000] psci: probing for conduit method from DT. 9759 [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT 9760 [ 0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920 9761 [ 0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096 9762 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 9763 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416 9764 [ 0.000000] Kernel command line: root=UUID=ad129a81-43b8-45fb-8d5e-cb23d637385b rootwait rootfstype=ext4 console=ttyS1,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=44b42d1a-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 9765 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) 9766 [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) 9767 [ 0.000000] allocated 1048576 bytes of page_ext 9768 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off 9769 [ 0.000000] Memory: 881824K/1048576K available (9216K kernel code, 1053K rwdata, 2880K rodata, 1024K init, 316K bss, 35680K reserved, 131072K cma-reserved, 131060K highmem) 9770 [ 0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0 9771 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 9772 [ 0.000000] ftrace: allocating 41301 entries in 81 pages 9773 [ 0.000000] rcu: Hierarchical RCU implementation. 9774 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. 9775 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 9776 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 9777 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 9778 [ 0.000000] GIC: Using split EOI/Deactivate mode 9779 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns 9780 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 9781 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 9782 [ 0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 9783 [ 0.000028] Switching to timer-based delay loop, resolution 41ns 9784 [ 0.000392] Console: colour dummy device 80x30 9785 [ 0.000481] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 9786 [ 0.000501] pid_max: default: 32768 minimum: 301 9787 [ 0.000895] LSM: Security Framework initializing 9788 [ 0.001057] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) 9789 [ 0.001080] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) 9790 [ 0.001222] *** VALIDATE tmpfs *** 9791 [ 0.002383] *** VALIDATE proc *** 9792 [ 0.002899] *** VALIDATE cgroup1 *** 9793 [ 0.002914] *** VALIDATE cgroup2 *** 9794 [ 0.003018] CPU: Testing write buffer coherency: ok 9795 [ 0.003692] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 9796 [ 0.004746] Setting up static identity map for 0x40100000 - 0x40100054 9797 [ 0.004956] rcu: Hierarchical SRCU implementation. 9798 [ 0.005931] smp: Bringing up secondary CPUs ... 9799 [ 0.017149] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 9800 [ 0.028590] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 9801 [ 0.039894] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 9802 [ 0.040074] smp: Brought up 1 node, 4 CPUs 9803 [ 0.040089] SMP: Total of 4 processors activated (192.00 BogoMIPS). 9804 [ 0.040096] CPU: All CPU(s) started in HYP mode. 9805 [ 0.040101] CPU: Virtualization extensions available. 9806 [ 0.041511] devtmpfs: initialized 9807 [ 0.054314] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 9808 [ 0.054759] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 9809 [ 0.054791] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) 9810 [ 0.064019] xor: measuring software checksum speed 9811 [ 0.103995] arm4regs : 598.000 MB/sec 9812 [ 0.144105] 8regs : 416.000 MB/sec 9813 [ 0.184231] 32regs : 393.000 MB/sec 9814 [ 0.224358] neon : 605.000 MB/sec 9815 [ 0.224367] xor: using function: neon (605.000 MB/sec) 9816 [ 0.224481] pinctrl core: initialized pinctrl subsystem 9817 [ 0.226223] NET: Registered protocol family 16 9818 [ 0.229445] DMA: preallocated 256 KiB pool for atomic coherent allocations 9819 [ 0.230499] audit: initializing netlink subsys (disabled) 9820 [ 0.230815] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1 9821 [ 0.231911] cpuidle: using governor ladder 9822 [ 0.231971] cpuidle: using governor menu 9823 [ 0.233069] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. 9824 [ 0.233078] hw-breakpoint: maximum watchpoint size is 8 bytes. 9825 [ 0.357147] raid6: neonx8 gen() 337 MB/s 9826 [ 0.425193] raid6: neonx8 xor() 280 MB/s 9827 [ 0.493410] raid6: neonx4 gen() 346 MB/s 9828 [ 0.561497] raid6: neonx4 xor() 292 MB/s 9829 [ 0.629852] raid6: neonx2 gen() 316 MB/s 9830 [ 0.697852] raid6: neonx2 xor() 278 MB/s 9831 [ 0.766015] raid6: neonx1 gen() 235 MB/s 9832 [ 0.834268] raid6: neonx1 xor() 222 MB/s 9833 [ 0.902682] raid6: int32x8 gen() 127 MB/s 9834 [ 0.970676] raid6: int32x8 xor() 83 MB/s 9835 [ 1.038762] raid6: int32x4 gen() 135 MB/s 9836 [ 1.107006] raid6: int32x4 xor() 93 MB/s 9837 [ 1.175400] raid6: int32x2 gen() 122 MB/s 9838 [ 1.243404] raid6: int32x2 xor() 98 MB/s 9839 [ 1.311892] raid6: int32x1 gen() 95 MB/s 9840 [ 1.379650] raid6: int32x1 xor() 83 MB/s 9841 [ 1.379658] raid6: using algorithm neonx4 gen() 346 MB/s 9842 [ 1.379664] raid6: .... xor() 292 MB/s, rmw enabled 9843 [ 1.379672] raid6: using neon recovery algorithm 9844 [ 1.382191] iommu: Default domain type: Translated 9845 [ 1.382847] SCSI subsystem initialized 9846 [ 1.383202] libata version 3.00 loaded. 9847 [ 1.383716] usbcore: registered new interface driver usbfs 9848 [ 1.383800] usbcore: registered new interface driver hub 9849 [ 1.383946] usbcore: registered new device driver usb 9850 [ 1.384335] mc: Linux media interface: v0.10 9851 [ 1.384407] videodev: Linux video capture interface: v2.00 9852 [ 1.384628] pps_core: LinuxPPS API ver. 1 registered 9853 [ 1.384635] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 9854 [ 1.384667] PTP clock support registered 9855 [ 1.387725] clocksource: Switched to clocksource arch_sys_counter 9856 [ 3.133124] *** VALIDATE bpf *** 9857 [ 3.133582] VFS: Disk quotas dquot_6.6.0 9858 [ 3.133713] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) 9859 [ 3.133885] *** VALIDATE ramfs *** 9860 [ 3.148726] thermal_sys: Registered thermal governor 'fair_share' 9861 [ 3.148737] thermal_sys: Registered thermal governor 'bang_bang' 9862 [ 3.148748] thermal_sys: Registered thermal governor 'step_wise' 9863 [ 3.148756] thermal_sys: Registered thermal governor 'power_allocator' 9864 [ 3.149628] NET: Registered protocol family 2 9865 [ 3.150862] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) 9866 [ 3.150920] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) 9867 [ 3.151061] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) 9868 [ 3.151294] TCP: Hash tables configured (established 8192 bind 8192) 9869 [ 3.151495] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) 9870 [ 3.151586] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) 9871 [ 3.152082] NET: Registered protocol family 1 9872 [ 3.153007] RPC: Registered named UNIX socket transport module. 9873 [ 3.153014] RPC: Registered udp transport module. 9874 [ 3.153021] RPC: Registered tcp transport module. 9875 [ 3.153027] RPC: Registered tcp NFSv4.1 backchannel transport module. 9876 [ 3.153486] Trying to unpack rootfs image as initramfs... 9877 [ 4.200819] Freeing initrd memory: 8472K 9878 [ 4.203262] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available 9879 [ 4.205582] Initialise system trusted keyrings 9880 [ 4.205976] workingset: timestamp_bits=14 max_order=18 bucket_order=4 9881 [ 4.219268] zbud: loaded 9882 [ 4.223855] NFS: Registering the id_resolver key type 9883 [ 4.223901] Key type id_resolver registered 9884 [ 4.223908] Key type id_legacy registered 9885 [ 4.223930] nfs4filelayout_init: NFSv4 File Layout Driver Registering... 9886 [ 4.223939] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). 9887 [ 4.226607] JFS: nTxBlock = 7979, nTxLock = 63835 9888 [ 4.240999] SGI XFS with ACLs, security attributes, realtime, no debug enabled 9889 [ 4.334388] Key type asymmetric registered 9890 [ 4.334405] Asymmetric key parser 'x509' registered 9891 [ 4.334535] bounce: pool size: 64 pages 9892 [ 4.334639] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) 9893 [ 4.334994] io scheduler mq-deadline registered 9894 [ 4.335004] io scheduler kyber registered 9895 [ 4.335126] io scheduler bfq registered 9896 [ 4.346772] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver 9897 [ 4.349827] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver 9898 [ 4.361882] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 9899 [ 4.366244] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator 9900 [ 4.387224] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A 9901 [ 4.388078] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator 9902 [ 4.408922] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 43, base_baud = 1500000) is a U6_16550A 9903 [ 4.409022] printk: console [ttyS1] enabled 9904 [ 4.421298] brd: module loaded 9905 [ 4.433186] loop: module loaded 9906 [ 4.436322] libphy: Fixed MDIO Bus: probed 9907 [ 4.437616] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator 9908 [ 4.437933] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found 9909 [ 4.437948] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found 9910 [ 4.438144] dwmac-sun8i 1c30000.ethernet: PTP uses main clock 9911 [ 4.440164] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 9912 [ 4.440173] ehci-platform: EHCI generic platform driver 9913 [ 4.440474] ehci-platform 1c1a000.usb: EHCI Host Controller 9914 [ 4.440524] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 9915 [ 4.441076] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000 9916 [ 4.455717] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 9917 [ 4.456238] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 9918 [ 4.456255] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 9919 [ 4.456268] usb usb1: Product: EHCI Host Controller 9920 [ 4.456281] usb usb1: Manufacturer: Linux 5.4.28-sunxi ehci_hcd 9921 [ 4.456292] usb usb1: SerialNumber: 1c1a000.usb 9922 [ 4.457313] hub 1-0:1.0: USB hub found 9923 [ 4.457411] hub 1-0:1.0: 1 port detected 9924 [ 4.458427] ehci-platform 1c1b000.usb: EHCI Host Controller 9925 [ 4.458469] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2 9926 [ 4.458779] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000 9927 [ 4.471715] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 9928 [ 4.472183] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 9929 [ 4.472199] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 9930 [ 4.472212] usb usb2: Product: EHCI Host Controller 9931 [ 4.472224] usb usb2: Manufacturer: Linux 5.4.28-sunxi ehci_hcd 9932 [ 4.472236] usb usb2: SerialNumber: 1c1b000.usb 9933 [ 4.473114] hub 2-0:1.0: USB hub found 9934 [ 4.473213] hub 2-0:1.0: 1 port detected 9935 [ 4.474210] ehci-platform 1c1c000.usb: EHCI Host Controller 9936 [ 4.474251] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3 9937 [ 4.474533] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000 9938 [ 4.487715] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 9939 [ 4.488134] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 9940 [ 4.488151] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 9941 [ 4.488163] usb usb3: Product: EHCI Host Controller 9942 [ 4.488175] usb usb3: Manufacturer: Linux 5.4.28-sunxi ehci_hcd 9943 [ 4.488187] usb usb3: SerialNumber: 1c1c000.usb 9944 [ 4.489091] hub 3-0:1.0: USB hub found 9945 [ 4.489178] hub 3-0:1.0: 1 port detected 9946 [ 4.490072] ehci-platform 1c1d000.usb: EHCI Host Controller 9947 [ 4.490113] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4 9948 [ 4.490409] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000 9949 [ 4.503716] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 9950 [ 4.504153] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 9951 [ 4.504169] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 9952 [ 4.504182] usb usb4: Product: EHCI Host Controller 9953 [ 4.504194] usb usb4: Manufacturer: Linux 5.4.28-sunxi ehci_hcd 9954 [ 4.504205] usb usb4: SerialNumber: 1c1d000.usb 9955 [ 4.505064] hub 4-0:1.0: USB hub found 9956 [ 4.505163] hub 4-0:1.0: 1 port detected 9957 [ 4.506054] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 9958 [ 4.506090] ohci-platform: OHCI generic platform driver 9959 [ 4.506432] ohci-platform 1c1a400.usb: Generic Platform OHCI controller 9960 [ 4.506473] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 5 9961 [ 4.506750] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400 9962 [ 4.568141] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04 9963 [ 4.568157] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 9964 [ 4.568170] usb usb5: Product: Generic Platform OHCI controller 9965 [ 4.568182] usb usb5: Manufacturer: Linux 5.4.28-sunxi ohci_hcd 9966 [ 4.568194] usb usb5: SerialNumber: 1c1a400.usb 9967 [ 4.569090] hub 5-0:1.0: USB hub found 9968 [ 4.569176] hub 5-0:1.0: 1 port detected 9969 [ 4.570083] ohci-platform 1c1b400.usb: Generic Platform OHCI controller 9970 [ 4.570122] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 9971 [ 4.570354] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400 9972 [ 4.632147] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04 9973 [ 4.632164] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 9974 [ 4.632177] usb usb6: Product: Generic Platform OHCI controller 9975 [ 4.632190] usb usb6: Manufacturer: Linux 5.4.28-sunxi ohci_hcd 9976 [ 4.632201] usb usb6: SerialNumber: 1c1b400.usb 9977 [ 4.633144] hub 6-0:1.0: USB hub found 9978 [ 4.633236] hub 6-0:1.0: 1 port detected 9979 [ 4.634144] ohci-platform 1c1c400.usb: Generic Platform OHCI controller 9980 [ 4.634186] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 9981 [ 4.634425] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400 9982 [ 4.696133] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04 9983 [ 4.696150] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 9984 [ 4.696163] usb usb7: Product: Generic Platform OHCI controller 9985 [ 4.696175] usb usb7: Manufacturer: Linux 5.4.28-sunxi ohci_hcd 9986 [ 4.696187] usb usb7: SerialNumber: 1c1c400.usb 9987 [ 4.697067] hub 7-0:1.0: USB hub found 9988 [ 4.697153] hub 7-0:1.0: 1 port detected 9989 [ 4.698090] ohci-platform 1c1d400.usb: Generic Platform OHCI controller 9990 [ 4.698131] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 9991 [ 4.698360] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400 9992 [ 4.760145] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04 9993 [ 4.760163] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 9994 [ 4.760176] usb usb8: Product: Generic Platform OHCI controller 9995 [ 4.760188] usb usb8: Manufacturer: Linux 5.4.28-sunxi ohci_hcd 9996 [ 4.760199] usb usb8: SerialNumber: 1c1d400.usb 9997 [ 4.761089] hub 8-0:1.0: USB hub found 9998 [ 4.761187] hub 8-0:1.0: 1 port detected 9999 [ 4.763119] usbcore: registered new interface driver usb-storage 10000 [ 4.763790] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator 10001 [ 4.767475] sun6i-rtc 1f00000.rtc: registered as rtc0 10002 [ 4.767490] sun6i-rtc 1f00000.rtc: RTC enabled 10003 [ 4.768068] i2c /dev entries driver 10004 [ 4.771889] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) 10005 [ 4.773046] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator 10006 [ 4.774277] sunxi-mmc 1c0f000.mmc: Got CD GPIO 10007 [ 4.799846] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB 10008 [ 4.801990] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator 10009 [ 4.811751] usb 2-1: new high-speed USB device number 2 using ehci-platform 10010 [ 4.828512] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB 10011 [ 4.829436] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator 10012 [ 4.831112] ledtrig-cpu: registered to indicate activity on CPUs 10013 [ 4.831247] hidraw: raw HID events driver (C) Jiri Kosina 10014 [ 4.831544] usbcore: registered new interface driver usbhid 10015 [ 4.831551] usbhid: USB HID core driver 10016 [ 4.835038] Initializing XFRM netlink socket 10017 [ 4.836219] NET: Registered protocol family 10 10018 [ 4.839796] usb 4-1: new high-speed USB device number 2 using ehci-platform 10019 [ 4.845736] usb 2-1: New USB device found, idVendor=0bda, idProduct=8152, bcdDevice=20.00 10020 [ 4.845756] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 10021 [ 4.845770] usb 2-1: Product: USB 10/100 LAN 10022 [ 4.845782] usb 2-1: Manufacturer: Realtek 10023 [ 4.845794] usb 2-1: SerialNumber: 000000000000 10024 [ 4.869877] usb 4-1: New USB device found, idVendor=2357, idProduct=0602, bcdDevice=20.00 10025 [ 4.869900] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 10026 [ 4.869913] usb 4-1: Product: USB 10/100 LAN 10027 [ 4.869926] usb 4-1: Manufacturer: TP-LINK 10028 [ 4.869938] usb 4-1: SerialNumber: D03745448C04 10029 [ 4.890478] Segment Routing with IPv6 10030 [ 4.890663] NET: Registered protocol family 17 10031 [ 4.890718] NET: Registered protocol family 15 10032 [ 4.890835] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. 10033 [ 4.891211] 8021q: 802.1Q VLAN Support v1.8 10034 [ 4.891332] Key type dns_resolver registered 10035 [ 4.892274] Registering SWP/SWPB emulation handler 10036 [ 4.892794] registered taskstats version 1 10037 [ 4.892802] Loading compiled-in X.509 certificates 10038 [ 4.892978] zswap: loaded using pool lzo/zbud 10039 [ 4.893515] Key type ._fscrypt registered 10040 [ 4.893524] Key type .fscrypt registered 10041 [ 4.898880] Btrfs loaded, crc32c=crc32c-generic 10042 [ 4.924602] Key type encrypted registered 10043 [ 4.945499] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator 10044 [ 4.948059] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found 10045 [ 4.948077] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found 10046 [ 4.948263] dwmac-sun8i 1c30000.ethernet: PTP uses main clock 10047 [ 4.948468] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator 10048 [ 4.975850] mmc1: new DDR MMC card at address 0001 10049 [ 4.977351] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB 10050 [ 4.978143] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB 10051 [ 4.978927] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB 10052 [ 4.982195] mmcblk1: p1 p2 p3 10053 [ 5.056129] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000) 10054 [ 5.056179] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported 10055 [ 5.056192] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported 10056 [ 5.056204] dwmac-sun8i 1c30000.ethernet: COE Type 2 10057 [ 5.056215] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported 10058 [ 5.056228] dwmac-sun8i 1c30000.ethernet: Normal descriptors 10059 [ 5.056239] dwmac-sun8i 1c30000.ethernet: Chain mode enabled 10060 [ 5.056569] libphy: stmmac: probed 10061 [ 5.057951] dwmac-sun8i 1c30000.ethernet: Found internal PHY node 10062 [ 5.058150] libphy: mdio_mux: probed 10063 [ 5.058190] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY 10064 [ 5.058207] dwmac-sun8i 1c30000.ethernet: Powering internal PHY 10065 [ 5.066973] ac200: Unknown symbol ac200_reg_mod (err -2) 10066 [ 5.067021] ac200: Unknown symbol ac200_reg_write (err -2) 10067 [ 5.068950] libphy: mdio_mux: probed 10068 [ 5.068997] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY 10069 [ 5.084751] mmc0: host does not support reading read-only switch, assuming write-enable 10070 [ 5.086961] mmc0: new high speed SDHC card at address 0001 10071 [ 5.090416] mmcblk0: mmc0:0001 0008G 7.54 GiB 10072 [ 5.094310] mmcblk0: p1 10073 [ 5.095273] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:10 UTC (10) 10074 [ 5.095609] of_cfs_init 10075 [ 5.095907] of_cfs_init: OK 10076 [ 5.103917] Freeing unused kernel memory: 1024K 10077 [ 5.124178] Run /init as init process 10078 [ 5.942561] random: fast init done 10079 [ 5.990978] dwmac-sun8i 1c30000.ethernet bridgeif0: renamed from eth0 10080 [ 6.029161] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq 10081 [ 6.059137] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB 10082 [ 6.086065] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) 10083 [ 6.087740] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) 10084 [ 6.089392] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) 10085 [ 6.092396] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) 10086 [ 6.096055] mmc2: queuing unknown CIS tuple 0x81 (9 bytes) 10087 [ 6.208707] mmc2: new high speed SDIO card at address 0001 10088 [ 6.875339] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 10089 [ 7.726185] systemd[1]: System time before build time, advancing clock. 10090 [ 7.788801] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 10091 [ 7.789668] systemd[1]: Detected architecture arm. 10092 [ 7.853242] systemd[1]: Set hostname to <N17.local>. 10093 [ 8.688486] random: systemd: uninitialized urandom read (16 bytes read) 10094 [ 8.688642] systemd[1]: Reached target Remote File Systems. 10095 [ 8.699992] random: systemd: uninitialized urandom read (16 bytes read) 10096 [ 8.700105] systemd[1]: Reached target Swap. 10097 [ 8.711983] random: systemd: uninitialized urandom read (16 bytes read) 10098 [ 8.712446] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. 10099 [ 8.733922] systemd[1]: Created slice System Slice. 10100 [ 8.749635] systemd[1]: Created slice system-serial\x2dgetty.slice. 10101 [ 8.760541] systemd[1]: Listening on fsck to fsckd communication Socket. 10102 [ 8.772547] systemd[1]: Listening on Journal Socket (/dev/log). 10103 [ 9.047228] g_serial gadget: Gadget Serial v2.4 10104 [ 9.047251] g_serial gadget: g_serial ready 10105 [ 9.180913] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 10106 [ 9.668554] systemd-journald[299]: Received request to flush runtime journal from PID 1 10107 [ 10.260184] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator 10108 [ 10.260220] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) 10109 [ 10.260392] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator 10110 [ 10.260408] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000) 10111 [ 10.260622] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator 10112 [ 10.260639] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000) 10113 [ 10.260926] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator 10114 [ 10.260950] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000) 10115 [ 10.331033] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0 10116 [ 10.488093] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. 10117 [ 10.500889] cedrus 1c0e000.video-codec: Device registered as /dev/video0 10118 [ 10.579370] cdc_ether 4-1:2.0 eth0: register 'cdc_ether' at usb-1c1d000.usb-1, CDC Ethernet Device, d0:37:45:44:8c:04 10119 [ 10.579628] usbcore: registered new interface driver cdc_ether 10120 [ 10.594947] usbcore: registered new interface driver r8152 10121 [ 10.708356] zram: Added device: zram0 10122 [ 10.709699] zram: Added device: zram1 10123 [ 10.710554] zram: Added device: zram2 10124 [ 10.731857] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10125 [ 10.764074] lima 1c40000.gpu: IRQ ppmmu2 not found 10126 [ 10.769039] lima 1c40000.gpu: IRQ ppmmu3 not found 10127 [ 10.773943] lima 1c40000.gpu: gp - mali400 version major 1 minor 1 10128 [ 10.774066] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 10129 [ 10.774127] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 10130 [ 10.774169] lima 1c40000.gpu: IRQ pp2 not found 10131 [ 10.778808] lima 1c40000.gpu: IRQ pp3 not found 10132 [ 10.783468] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus 10133 [ 10.791363] r8152 2-1:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00 10134 [ 10.800592] r8152 2-1:1.0 (unnamed net_device) (uninitialized): Random ether addr 6e:15:02:38:93:e7 10135 [ 10.831179] lima 1c40000.gpu: bus rate = 200000000 10136 [ 10.831199] lima 1c40000.gpu: mod rate = 384000000 10137 [ 10.835320] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 0 10138 [ 10.837711] r8152 2-1:1.0 eth1: v1.10.11 10139 [ 10.847392] zram1: detected capacity change from 0 to 523464704 10140 [ 11.159465] cdc_ether 4-1:2.0 ethext: renamed from eth0 10141 [ 11.266422] r8152 2-1:1.0 bridgeif1: renamed from eth1 10142 [ 11.563092] dwmac-sun8i 1c30000.ethernet bridgeif0: PHY [0.2:07] driver [RTL8211E Gigabit Ethernet] 10143 [ 11.564715] dwmac-sun8i 1c30000.ethernet bridgeif0: No Safety Features support found 10144 [ 11.564734] dwmac-sun8i 1c30000.ethernet bridgeif0: No MAC Management Counters available 10145 [ 11.564747] dwmac-sun8i 1c30000.ethernet bridgeif0: PTP not supported by HW 10146 [ 11.564766] dwmac-sun8i 1c30000.ethernet bridgeif0: configuring for phy/rgmii link mode 10147 [ 11.971902] Adding 511192k swap on /dev/zram1. Priority:5 extents:1 across:511192k SSFS 10148 [ 12.150488] zram0: detected capacity change from 0 to 52428800 10149 [ 12.266235] device bridgeif0 entered promiscuous mode 10150 [ 12.291896] device bridgeif1 entered promiscuous mode 10151 [ 12.446651] br0: Slave A (bridgeif0) is not up; please bring it up to get a fully working HSR network 10152 [ 12.446976] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready 10153 [ 12.496994] random: crng init done 10154 [ 12.497016] random: 7 urandom warning(s) missed due to ratelimiting 10155 [ 12.670378] IPv6: ADDRCONF(NETDEV_CHANGE): bridgeif1: link becomes ready 10156 [ 12.671028] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled 10157 [ 12.673230] r8152 2-1:1.0 bridgeif1: carrier on 10158 [ 12.675782] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled 10159 [ 12.874553] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 10160 [ 12.874606] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 10161 [ 14.648321] dwmac-sun8i 1c30000.ethernet bridgeif0: Link is Up - 100Mbps/Full - flow control off 10162 [ 14.648373] IPv6: ADDRCONF(NETDEV_CHANGE): bridgeif0: link becomes ready 10163 10164 ### armbian-release: 10165 10166 # PLEASE DO NOT EDIT THIS FILE 10167 BOARD=nanopi-r1 10168 BOARD_NAME="NanoPi R1" 10169 BOARDFAMILY=sun8i 10170 BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin 10171 BUILD_REPOSITORY_COMMIT=3e533c9 10172 DISTRIBUTION_CODENAME=bionic 10173 DISTRIBUTION_STATUS=supported 10174 VERSION=20.02.1 10175 LINUXFAMILY=sunxi 10176 BRANCH=current 10177 ARCH=arm 10178 IMAGE_TYPE=stable 10179 BOARD_TYPE=conf 10180 INITRD_ARCH=arm 10181 KERNEL_IMAGE_TYPE=Image 10182 10183 ### boot environment: 10184 10185 verbosity=1 10186 logo=disabled 10187 console=serial 10188 disp_mode=1920x1080p60 10189 overlay_prefix=sun8i-h3 10190 overlays=usbhost0 usbhost1 uart1 10191 rootdev=UUID=ad129a81-43b8-45fb-8d5e-cb23d637385b 10192 rootfstype=ext4 10193 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 10194 10195 ### lsusb: 10196 10197 Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 10198 Bus 004 Device 002: ID 2357:0602 10199 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10200 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 10201 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10202 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 10203 Bus 002 Device 002: ID 0bda:8152 Realtek Semiconductor Corp. 10204 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10205 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 10206 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10207 10208 ### lscpu: 10209 10210 Architecture: armv7l 10211 Byte Order: Little Endian 10212 CPU(s): 4 10213 On-line CPU(s) list: 0-3 10214 Thread(s) per core: 1 10215 Core(s) per socket: 4 10216 Socket(s): 1 10217 Vendor ID: ARM 10218 Model: 5 10219 Model name: Cortex-A7 10220 Stepping: r0p5 10221 CPU max MHz: 1008.0000 10222 CPU min MHz: 480.0000 10223 BogoMIPS: 100.80 10224 Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 10225 10226 ### cpuinfo: 10227 10228 processor : 0 10229 model name : ARMv7 Processor rev 5 (v7l) 10230 BogoMIPS : 100.80 10231 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 10232 CPU implementer : 0x41 10233 CPU architecture: 7 10234 CPU variant : 0x0 10235 CPU part : 0xc07 10236 CPU revision : 5 10237 10238 processor : 1 10239 model name : ARMv7 Processor rev 5 (v7l) 10240 BogoMIPS : 100.80 10241 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 10242 CPU implementer : 0x41 10243 CPU architecture: 7 10244 CPU variant : 0x0 10245 CPU part : 0xc07 10246 CPU revision : 5 10247 10248 processor : 2 10249 model name : ARMv7 Processor rev 5 (v7l) 10250 BogoMIPS : 100.80 10251 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 10252 CPU implementer : 0x41 10253 CPU architecture: 7 10254 CPU variant : 0x0 10255 CPU part : 0xc07 10256 CPU revision : 5 10257 10258 processor : 3 10259 model name : ARMv7 Processor rev 5 (v7l) 10260 BogoMIPS : 100.80 10261 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 10262 CPU implementer : 0x41 10263 CPU architecture: 7 10264 CPU variant : 0x0 10265 CPU part : 0xc07 10266 CPU revision : 5 10267 10268 Hardware : Allwinner sun8i Family 10269 Revision : 0000 10270 Serial : 02c00181d27f68b2 10271 10272 ### meminfo: 10273 10274 MemTotal: 1022392 kB 10275 MemFree: 872560 kB 10276 MemAvailable: 934480 kB 10277 Buffers: 9840 kB 10278 Cached: 62304 kB 10279 SwapCached: 0 kB 10280 Active: 49064 kB 10281 Inactive: 43700 kB 10282 Active(anon): 20888 kB 10283 Inactive(anon): 2828 kB 10284 Active(file): 28176 kB 10285 Inactive(file): 40872 kB 10286 Unevictable: 0 kB 10287 Mlocked: 0 kB 10288 HighTotal: 262132 kB 10289 HighFree: 162276 kB 10290 LowTotal: 760260 kB 10291 LowFree: 710284 kB 10292 SwapTotal: 511192 kB 10293 SwapFree: 511192 kB 10294 Dirty: 15940 kB 10295 Writeback: 1000 kB 10296 AnonPages: 20724 kB 10297 Mapped: 18452 kB 10298 Shmem: 3032 kB 10299 KReclaimable: 12044 kB 10300 Slab: 29992 kB 10301 SReclaimable: 12044 kB 10302 SUnreclaim: 17948 kB 10303 KernelStack: 1128 kB 10304 PageTables: 896 kB 10305 NFS_Unstable: 0 kB 10306 Bounce: 0 kB 10307 WritebackTmp: 0 kB 10308 CommitLimit: 1022388 kB 10309 Committed_AS: 139184 kB 10310 VmallocTotal: 245760 kB 10311 VmallocUsed: 14568 kB 10312 VmallocChunk: 0 kB 10313 Percpu: 464 kB 10314 CmaTotal: 131072 kB 10315 CmaFree: 130720 kB 10316 10317 ### virtual memory: 10318 10319 vm.admin_reserve_kbytes = 8192 10320 vm.block_dump = 0 10321 vm.compact_unevictable_allowed = 1 10322 vm.dirty_background_bytes = 0 10323 vm.dirty_background_ratio = 10 10324 vm.dirty_bytes = 0 10325 vm.dirty_expire_centisecs = 3000 10326 vm.dirty_ratio = 20 10327 vm.dirtytime_expire_seconds = 43200 10328 vm.dirty_writeback_centisecs = 500 10329 vm.extfrag_threshold = 500 10330 vm.highmem_is_dirtyable = 0 10331 vm.laptop_mode = 0 10332 vm.legacy_va_layout = 0 10333 vm.lowmem_reserve_ratio = 32 0 0 10334 vm.max_map_count = 65530 10335 vm.min_free_kbytes = 3465 10336 vm.mmap_min_addr = 32768 10337 vm.mmap_rnd_bits = 8 10338 vm.oom_dump_tasks = 1 10339 vm.oom_kill_allocating_task = 0 10340 vm.overcommit_kbytes = 0 10341 vm.overcommit_memory = 0 10342 vm.overcommit_ratio = 50 10343 vm.page-cluster = 0 10344 vm.panic_on_oom = 0 10345 vm.percpu_pagelist_fraction = 0 10346 vm.stat_interval = 1 10347 vm.swappiness = 100 10348 vm.user_reserve_kbytes = 31523 10349 vm.vfs_cache_pressure = 100 10350 vm.watermark_boost_factor = 15000 10351 vm.watermark_scale_factor = 10 10352 10353 ### ip addr: 10354 10355 default via XXX.XXX.1.1 dev ethext 10356 default dev br0 scope link metric 1005 10357 XXX.XXX.0.0/16 dev br0 proto kernel scope link src XXX.XXX.9.189 10358 XXX.XXX.0.0/16 dev ethext scope link metric 1000 10359 XXX.XXX.1.0/24 dev ethext proto kernel scope link src XXX.XXX.1.60 10360 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 10361 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 10362 inet XXX.XXX.0.1/8 scope host lo 10363 valid_lft forever preferred_lft forever 10364 inet6 ::1/128 scope host 10365 valid_lft forever preferred_lft forever 10366 2: bridgeif0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000 10367 link/ether 12:81:d2:7f:68:b2 brd ff:ff:ff:ff:ff:ff 10368 inet6 fe80::1081:d2ff:fe7f:68b2/64 scope link 10369 valid_lft forever preferred_lft forever 10370 3: ethext: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000 10371 link/ether d0:37:45:44:8c:04 brd ff:ff:ff:ff:ff:ff 10372 inet XXX.XXX.1.60/24 brd XXX.XXX.1.255 scope global ethext 10373 valid_lft forever preferred_lft forever 10374 inet6 fe80::d237:45ff:fe44:8c04/64 scope link 10375 valid_lft forever preferred_lft forever 10376 4: bridgeif1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 10377 link/ether 6e:15:02:38:93:e7 brd ff:ff:ff:ff:ff:ff 10378 inet6 fe80::6c15:2ff:fe38:93e7/64 scope link 10379 valid_lft forever preferred_lft forever 10380 5: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1494 qdisc noqueue state UP group default qlen 1000 10381 link/ether 12:81:d2:7f:68:b2 brd ff:ff:ff:ff:ff:ff 10382 inet XXX.XXX.9.189/16 brd XXX.XXX.255.255 scope link br0:avahi 10383 valid_lft forever preferred_lft forever 10384 inet6 fe80::1081:d2ff:fe7f:68b2/64 scope link 10385 valid_lft forever preferred_lft forever 10386 10387 ### partitions: 10388 10389 major minor #blocks name 10390 10391 179 0 7634944 mmcblk1 10392 179 1 40960 mmcblk1p1 10393 179 2 1221632 mmcblk1p2 10394 179 3 6347776 mmcblk1p3 10395 179 24 7901184 mmcblk0 10396 179 25 7739056 mmcblk0p1 10397 254 0 51200 zram0 10398 254 1 511196 zram1 10399 10400 ### df: 10401 10402 udev 431M 0 431M 0% /dev 10403 tmpfs 100M 3.0M 97M 3% /run 10404 /dev/mmcblk0p1 7.3G 938M 6.3G 13% / 10405 tmpfs 500M 0 500M 0% /dev/shm 10406 tmpfs 5.0M 0 5.0M 0% /run/lock 10407 tmpfs 500M 0 500M 0% /sys/fs/cgroup 10408 tmpfs 500M 4.0K 500M 1% /tmp 10409 /dev/zram0 49M 18M 28M 39% /var/log 10410 10411 ### lsblk: 10412 10413 NAME FSTYPE SIZE MOUNTPOINT UUID 10414 mmcblk1 7.3G 10415 ├─mmcblk1p1 vfat 40M D45E-0C11 10416 ├─mmcblk1p2 ext4 1.2G ff313567-e9f1-5a5d-9895-3ba130b4a864 10417 └─mmcblk1p3 ext4 6.1G 269e9152-5cb6-035b-9c34-e1ed87cca310 10418 mmcblk1boot0 4M 10419 mmcblk1boot1 4M 10420 mmcblk0 7.5G 10421 └─mmcblk0p1 ext4 7.4G / ad129a81-43b8-45fb-8d5e-cb23d637385b 10422 zram0 50M /var/log 10423 10424 ### zramctl: 10425 10426 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 10427 /dev/zram1 lzo 499.2M 4K 76B 4K 4 [SWAP] 10428 /dev/zram0 50M 13.4M 2.8M 3.2M 4 /var/log 10429 10430 ### mtab: 10431 10432 /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 10433 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 10434 /dev/zram0 /var/log ext4 rw,relatime,discard 0 0 10435 10436 ### mmc1:0001 info: 10437 10438 manfid: 0x000015 10439 cid: 15010038475446345206d2ffc66676f3 10440 fwrev: 0x0600000000000000 10441 rca: 0x0001 10442 csd: d02701320f5903fff6dbffef8e40400d 10443 life_time: 0x01 0x01 10444 ocr: 0x00200000 10445 type: MMC 10446 enhanced_area_offset: 18446744073709551594 10447 date: 07/2019 10448 hwrev: 0x0 10449 prv: 0x6 10450 dsr: 0x404 10451 ffu_capable: 1 10452 serial: 0xd2ffc666 10453 raw_rpmb_size_mult: 0x4 10454 erase_size: 524288 10455 pre_eol_info: 0x01 10456 rel_sectors: 0x1 10457 cmdq_en: 0 10458 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block 10459 enhanced_area_size: 4294967274 10460 oemid: 0x0100 10461 rev: 0x8 10462 preferred_erase_size: 4194304 10463 name: 8GTF4R 10464 10465 ### mmc0:0001 info: 10466 10467 manfid: 0x00005d 10468 cid: 5d5342303030384711c503078701389f 10469 fwrev: 0x1 10470 rca: 0x0001 10471 csd: 400e00325b5900003c477f800a4000db 10472 ocr: 0x00200000 10473 type: SD 10474 date: 08/2019 10475 hwrev: 0x1 10476 dsr: 0x404 10477 serial: 0xc5030787 10478 erase_size: 512 10479 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=0008G MODALIAS=mmc:block 10480 ssr: 0000000003000000040590000105190000000000000000000001000a00ab00ab64640000027e8e6500000000003f0000000019bd0008002e000000641601252a 10481 scr: 02b5800300000000 10482 oemid: 0x5342 10483 preferred_erase_size: 4194304 10484 name: 0008G 10485 10486 ### Boot system health: 10487 10488 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 10489 12:39:02: 1008MHz 0.83 62% 36% 22% 0% 2% 0% 34.4°C 0/4 10490 12:39:02: 480MHz 0.83 9% 7% 0% 0% 0% 0% 33.3°C 0/4 10491 12:39:03: 1008MHz 0.84 8% 6% 0% 2% 0% 0% 32.6°C 0/4 10492 12:39:03: 1008MHz 0.84 6% 4% 0% 2% 0% 0% 32.6°C 0/4 10493 12:39:03: 1008MHz 0.84 7% 5% 0% 1% 0% 0% 32.2°C 0/4 10494 10495 ### lsusb: 10496 10497 Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 10498 Bus 004 Device 002: ID 2357:0602 10499 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10500 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 10501 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10502 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 10503 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10504 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 10505 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10506 10507 /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 10508 /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 10509 /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 10510 /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 10511 /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 10512 |__ Port 1: Dev 2, If 0, Class=Communications, Driver=cdc_ether, 480M 10513 |__ Port 1: Dev 2, If 1, Class=CDC Data, Driver=cdc_ether, 480M 10514 /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 10515 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 10516 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 10517 10518 ### Group membership of esmi : esmi tty disk dialout sudo audio video plugdev games users systemd-journal input netdev ssh 10519 10520 ### Installed packages: 10521 10522 ii armbian-config 20.02.9 all Armbian configuration utility 10523 ii armbian-firmware 20.02.4 all Linux firmware 10524 ii hostapd 3:2.7-99~armbian5.86+1 armhf IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator 10525 ii linux-base 4.5ubuntu1.1 all Linux image base package 10526 ii linux-bionic-root-current-nanopi-r1 20.02.1 armhf Armbian tweaks for bionic on nanopi-r1 (current branch) 10527 ii linux-dtb-current-sunxi 20.02.7 armhf Linux DTB, version 5.4.28-sunxi 10528 ii linux-image-current-sunxi 20.02.7 armhf Linux kernel, version 5.4.28-sunxi 10529 ii linux-libc-dev:armhf 4.15.0-91.92 armhf Linux Kernel Headers for development 10530 ii linux-u-boot-nanopi-r1-current 20.02.1 armhf Uboot loader 2019.10 10531 ii sunxi-tools 1.4.2-2~armbian5.86+1 armhf tools for working with Allwinner (sunxi) ARM processors 10532 10533 ### Loaded modules: 10534 10535 Module Size Used by 10536 hsr 28672 0 10537 evdev 20480 0 10538 lima 36864 0 10539 gpu_sched 24576 1 lima 10540 snd_soc_simple_card 16384 0 10541 snd_soc_simple_card_utils 16384 1 snd_soc_simple_card 10542 zram 24576 2 10543 sun8i_codec_analog 24576 0 10544 sun8i_adda_pr_regmap 16384 1 sun8i_codec_analog 10545 sun4i_i2s 24576 0 10546 sun4i_gpadc_iio 16384 0 10547 snd_soc_core 118784 4 sun4i_i2s,sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_simple_card 10548 industrialio 49152 1 sun4i_gpadc_iio 10549 snd_pcm_dmaengine 16384 1 snd_soc_core 10550 snd_pcm 65536 3 sun4i_i2s,snd_pcm_dmaengine,snd_soc_core 10551 r8152 53248 0 10552 snd_timer 24576 1 snd_pcm 10553 snd 45056 3 snd_timer,snd_soc_core,snd_pcm 10554 cdc_ether 16384 0 10555 sun8i_thermal 16384 0 10556 soundcore 16384 1 snd 10557 usbnet 24576 1 cdc_ether 10558 sunxi_cedrus 32768 0 10559 v4l2_mem2mem 20480 1 sunxi_cedrus 10560 gpio_keys 20480 0 10561 uio_pdrv_genirq 16384 0 10562 uio 16384 1 uio_pdrv_genirq 10563 cpufreq_dt 16384 0 10564 sch_fq_codel 20480 3 10565 usb_f_acm 16384 1 10566 u_serial 20480 3 usb_f_acm 10567 g_serial 16384 0 10568 libcomposite 40960 2 g_serial,usb_f_acm 10569 ip_tables 24576 0 10570 x_tables 20480 1 ip_tables 10571 pwrseq_simple 16384 1 10572 realtek 16384 1 10573 10574 ### Current system health: 10575 10576 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 10577 23:03:59: 1008MHz 0.08 0% 0% 0% 0% 0% 0% 32.6°C 0/4 10578 23:04:00: 1008MHz 0.08 6% 4% 0% 2% 0% 0% 31.6°C 0/4 10579 23:04:00: 1008MHz 0.08 6% 3% 0% 2% 0% 0% 31.7°C 0/4 10580 23:04:01: 1008MHz 0.08 6% 5% 0% 1% 0% 0% 31.6°C 0/4 10581 23:04:01: 1008MHz 0.08 6% 5% 0% 1% 0% 0% 30.6°C 0/4 10582 23:04:04: 1008MHz 0.08 0% 0% 0% 0% 0% 0% 38.0°C 0/4 10583 23:04:05: 1008MHz 0.47 77% 1% 75% 0% 0% 0% 34.5°C 0/4 10584 23:04:05: 1008MHz 0.47 6% 4% 0% 1% 0% 0% 33.4°C 0/4 10585 23:04:06: 1008MHz 0.47 7% 5% 0% 1% 0% 0% 32.7°C 0/4 10586 23:04:06: 1008MHz 0.47 6% 4% 0% 1% 0% 0% 32.4°C 0/4 10587 10588 ### resolv.conf 10589 10590 -rw-r--r-- 1 root root 70 Apr 6 22:06 /etc/resolv.conf 10591 # Generated by NetworkManager 10592 search N17.local 10593 nameserver XXX.XXX.1.1 10594 10595 ### Current sysinfo: 10596 10597 Linux 5.4.28-sunxi (N17.local) 04/11/2020 _armv7l_ (4 CPU) 10598 10599 avg-cpu: %user %nice %system %iowait %steal %idle 10600 0.03 0.00 0.09 0.00 0.00 99.88 10601 10602 Device tps kB_read/s kB_wrtn/s kB_read kB_wrtn 10603 ram0 0.00 0.00 0.00 0 0 10604 ram1 0.00 0.00 0.00 0 0 10605 ram2 0.00 0.00 0.00 0 0 10606 ram3 0.00 0.00 0.00 0 0 10607 mmcblk1 0.00 0.03 0.00 10168 0 10608 mmcblk1p1 0.00 0.00 0.00 852 0 10609 mmcblk1p2 0.00 0.01 0.00 3096 0 10610 mmcblk1p3 0.00 0.02 0.00 4644 0 10611 mmcblk1boot1 0.00 0.00 0.00 216 0 10612 mmcblk1boot0 0.00 0.00 0.00 216 0 10613 mmcblk0 0.01 0.34 0.21 100089 62524 10614 mmcblk0p1 0.01 0.33 0.21 96965 62524 10615 zram0 0.03 0.00 0.11 712 32468 10616 zram1 0.00 0.00 0.00 1196 4 10617 zram2 0.00 0.00 0.00 0 0 10618 10619 procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- 10620 r b swpd free buff cache si so bi bo in cs us sy id wa st 10621 0 0 0 818260 11896 111136 0 0 0 0 26 23 0 0 100 0 0 10622 10623 total used free shared buff/cache available 10624 Mem: 998M 79M 799M 10M 120M 886M 10625 Swap: 499M 0B 499M 10626 10627 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 10628 /dev/zram1 lzo 499.2M 4K 76B 4K 4 [SWAP] 10629 /dev/zram0 50M 17.5M 3.6M 4.1M 4 /var/log 10630 10631 23:04:11 up 3 days, 10:25, 1 user, load average: 0.44, 0.10, 0.03 10632 10633 [ 8.688642] systemd[1]: Reached target Remote File Systems. 10634 [ 8.699992] random: systemd: uninitialized urandom read (16 bytes read) 10635 [ 8.700105] systemd[1]: Reached target Swap. 10636 [ 8.711983] random: systemd: uninitialized urandom read (16 bytes read) 10637 [ 8.712446] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. 10638 [ 8.733922] systemd[1]: Created slice System Slice. 10639 [ 8.749635] systemd[1]: Created slice system-serial-getty.slice. 10640 [ 8.760541] systemd[1]: Listening on fsck to fsckd communication Socket. 10641 [ 8.772547] systemd[1]: Listening on Journal Socket (/dev/log). 10642 [ 9.047228] g_serial gadget: Gadget Serial v2.4 10643 [ 9.047251] g_serial gadget: g_serial ready 10644 [ 9.180913] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 10645 [ 9.668554] systemd-journald[299]: Received request to flush runtime journal from PID 1 10646 [ 10.260184] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator 10647 [ 10.260220] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) 10648 [ 10.260392] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator 10649 [ 10.260408] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000) 10650 [ 10.260622] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator 10651 [ 10.260639] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000) 10652 [ 10.260926] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator 10653 [ 10.260950] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000) 10654 [ 10.331033] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0 10655 [ 10.488093] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. 10656 [ 10.500889] cedrus 1c0e000.video-codec: Device registered as /dev/video0 10657 [ 10.579370] cdc_ether 4-1:2.0 eth0: register 'cdc_ether' at usb-1c1d000.usb-1, CDC Ethernet Device, d0:37:45:44:8c:04 10658 [ 10.579628] usbcore: registered new interface driver cdc_ether 10659 [ 10.594947] usbcore: registered new interface driver r8152 10660 [ 10.708356] zram: Added device: zram0 10661 [ 10.709699] zram: Added device: zram1 10662 [ 10.710554] zram: Added device: zram2 10663 [ 10.731857] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10664 [ 10.764074] lima 1c40000.gpu: IRQ ppmmu2 not found 10665 [ 10.769039] lima 1c40000.gpu: IRQ ppmmu3 not found 10666 [ 10.773943] lima 1c40000.gpu: gp - mali400 version major 1 minor 1 10667 [ 10.774066] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 10668 [ 10.774127] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 10669 [ 10.774169] lima 1c40000.gpu: IRQ pp2 not found 10670 [ 10.778808] lima 1c40000.gpu: IRQ pp3 not found 10671 [ 10.783468] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus 10672 [ 10.791363] r8152 2-1:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00 10673 [ 10.800592] r8152 2-1:1.0 (unnamed net_device) (uninitialized): Random ether addr 6e:15:02:38:93:e7 10674 [ 10.831179] lima 1c40000.gpu: bus rate = 200000000 10675 [ 10.831199] lima 1c40000.gpu: mod rate = 384000000 10676 [ 10.835320] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 0 10677 [ 10.837711] r8152 2-1:1.0 eth1: v1.10.11 10678 [ 10.847392] zram1: detected capacity change from 0 to 523464704 10679 [ 11.159465] cdc_ether 4-1:2.0 ethext: renamed from eth0 10680 [ 11.266422] r8152 2-1:1.0 bridgeif1: renamed from eth1 10681 [ 11.563092] dwmac-sun8i 1c30000.ethernet bridgeif0: PHY [0.2:07] driver [RTL8211E Gigabit Ethernet] 10682 [ 11.564715] dwmac-sun8i 1c30000.ethernet bridgeif0: No Safety Features support found 10683 [ 11.564734] dwmac-sun8i 1c30000.ethernet bridgeif0: No MAC Management Counters available 10684 [ 11.564747] dwmac-sun8i 1c30000.ethernet bridgeif0: PTP not supported by HW 10685 [ 11.564766] dwmac-sun8i 1c30000.ethernet bridgeif0: configuring for phy/rgmii link mode 10686 [ 11.971902] Adding 511192k swap on /dev/zram1. Priority:5 extents:1 across:511192k SSFS 10687 [ 12.150488] zram0: detected capacity change from 0 to 52428800 10688 [ 12.266235] device bridgeif0 entered promiscuous mode 10689 [ 12.291896] device bridgeif1 entered promiscuous mode 10690 [ 12.446651] br0: Slave A (bridgeif0) is not up; please bring it up to get a fully working HSR network 10691 [ 12.446976] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready 10692 [ 12.496994] random: crng init done 10693 [ 12.497016] random: 7 urandom warning(s) missed due to ratelimiting 10694 [ 12.670378] IPv6: ADDRCONF(NETDEV_CHANGE): bridgeif1: link becomes ready 10695 [ 12.671028] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled 10696 [ 12.673230] r8152 2-1:1.0 bridgeif1: carrier on 10697 [ 12.675782] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled 10698 [ 12.874553] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 10699 [ 12.874606] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 10700 [ 14.648321] dwmac-sun8i 1c30000.ethernet bridgeif0: Link is Up - 100Mbps/Full - flow control off 10701 [ 14.648373] IPv6: ADDRCONF(NETDEV_CHANGE): bridgeif0: link becomes ready 10702 [ 15.880578] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled 10703 [ 16.696122] dwmac-sun8i 1c30000.ethernet bridgeif0: Link is Down 10704 [ 19.768218] dwmac-sun8i 1c30000.ethernet bridgeif0: Link is Up - 100Mbps/Full - flow control rx/tx 10705 [ 35.831768] vcc3v0: disabling 10706 [ 35.831791] vcc5v0: disabling 10707 [ 1063.202413] ------------[ cut here ]------------ 10708 [ 1063.202481] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:448 dev_watchdog+0x213/0x214 10709 [ 1063.202500] NETDEV WATCHDOG: bridgeif1 (r8152): transmit queue 0 timed out 10710 [ 1063.202506] Modules linked in: hsr evdev lima gpu_sched snd_soc_simple_card snd_soc_simple_card_utils zram sun8i_codec_analog sun8i_adda_pr_regmap sun4i_i2s sun4i_gpadc_iio snd_soc_core industrialio snd_pcm_dmaengine snd_pcm r8152 snd_timer snd cdc_ether sun8i_thermal soundcore usbnet sunxi_cedrus(C) v4l2_mem2mem gpio_keys uio_pdrv_genirq uio cpufreq_dt sch_fq_codel usb_f_acm u_serial g_serial libcomposite ip_tables x_tables pwrseq_simple realtek 10711 [ 1063.202605] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G C 5.4.28-sunxi #20.02.7 10712 [ 1063.202610] Hardware name: Allwinner sun8i Family 10713 [ 1063.202640] [<c010da8d>] (unwind_backtrace) from [<c010a0ad>] (show_stack+0x11/0x14) 10714 [ 1063.202661] [<c010a0ad>] (show_stack) from [<c0951bef>] (dump_stack+0x6f/0x7c) 10715 [ 1063.202687] [<c0951bef>] (dump_stack) from [<c011b60b>] (__warn+0xb7/0xb8) 10716 [ 1063.202702] [<c011b60b>] (__warn) from [<c011b8b7>] (warn_slowpath_fmt+0x5f/0x74) 10717 [ 1063.202716] [<c011b8b7>] (warn_slowpath_fmt) from [<c0850083>] (dev_watchdog+0x213/0x214) 10718 [ 1063.202740] [<c0850083>] (dev_watchdog) from [<c017209b>] (call_timer_fn+0x27/0x128) 10719 [ 1063.202752] [<c017209b>] (call_timer_fn) from [<c0172c15>] (run_timer_softirq+0x3f9/0x418) 10720 [ 1063.202763] [<c0172c15>] (run_timer_softirq) from [<c01022f7>] (__do_softirq+0xdf/0x288) 10721 [ 1063.202775] [<c01022f7>] (__do_softirq) from [<c012035f>] (irq_exit+0x7b/0x90) 10722 [ 1063.202792] [<c012035f>] (irq_exit) from [<c016051f>] (__handle_domain_irq+0x47/0x84) 10723 [ 1063.202812] [<c016051f>] (__handle_domain_irq) from [<c05e3c4d>] (gic_handle_irq+0x39/0x6c) 10724 [ 1063.202829] [<c05e3c4d>] (gic_handle_irq) from [<c0101ae5>] (__irq_svc+0x65/0x94) 10725 [ 1063.202841] Exception stack(0xc0f01f20 to 0xc0f01f68) 10726 [ 1063.202855] 1f20: 00000000 0050f000 ef69ff34 c0116341 ffffe000 c0f04f68 c0f04fb0 00000001 10727 [ 1063.202865] 1f40: c0f04f48 00000000 c0ec48f0 c0ff67f6 c0f05028 c0f01f70 c010792f c0107930 10728 [ 1063.202869] 1f60: 400d0033 ffffffff 10729 [ 1063.202886] [<c0101ae5>] (__irq_svc) from [<c0107930>] (arch_cpu_idle+0x28/0x2c) 10730 [ 1063.202900] [<c0107930>] (arch_cpu_idle) from [<c013fa4f>] (do_idle+0x15b/0x1cc) 10731 [ 1063.202912] [<c013fa4f>] (do_idle) from [<c013fcb9>] (cpu_startup_entry+0x19/0x20) 10732 [ 1063.202932] [<c013fcb9>] (cpu_startup_entry) from [<c0e00c6d>] (start_kernel+0x3fb/0x40c) 10733 [ 1063.202948] ---[ end trace 8a7042696d164652 ]--- 10734 [ 1063.202968] r8152 2-1:1.0 bridgeif1: Tx timeout 10735 [ 1064.777084] r8152 2-1:1.0 bridgeif1: Tx status -2 10736 [ 1064.780443] r8152 2-1:1.0 bridgeif1: Tx status -2 10737 [ 1064.783815] r8152 2-1:1.0 bridgeif1: Tx status -2 10738 [ 1064.787064] r8152 2-1:1.0 bridgeif1: Tx status -2 10739 [ 1068.322762] r8152 2-1:1.0 bridgeif1: Tx timeout 10740 [ 1074.211116] r8152 2-1:1.0 bridgeif1: Tx timeout 10741 [ 1079.075375] r8152 2-1:1.0 bridgeif1: Tx timeout 10742 [ 1084.195734] r8152 2-1:1.0 bridgeif1: Tx timeout 10743 [ 1089.315981] r8152 2-1:1.0 bridgeif1: Tx timeout 10744 [ 1095.204340] r8152 2-1:1.0 bridgeif1: Tx timeout 10745 [ 1100.324633] r8152 2-1:1.0 bridgeif1: Tx timeout 10746 [ 1106.212944] r8152 2-1:1.0 bridgeif1: Tx timeout 10747 [ 1111.077223] r8152 2-1:1.0 bridgeif1: Tx timeout 10748 [ 1116.197542] r8152 2-1:1.0 bridgeif1: Tx timeout 10749 [ 1121.317802] r8152 2-1:1.0 bridgeif1: Tx timeout 10750 [ 1127.206158] r8152 2-1:1.0 bridgeif1: Tx timeout 10751 [ 1132.326404] r8152 2-1:1.0 bridgeif1: Tx timeout 10752 [ 1138.214721] r8152 2-1:1.0 bridgeif1: Tx timeout 10753 [ 1143.078976] r8152 2-1:1.0 bridgeif1: Tx timeout 10754 [ 1148.199250] r8152 2-1:1.0 bridgeif1: Tx timeout 10755 [ 1153.319543] r8152 2-1:1.0 bridgeif1: Tx timeout 10756 [ 1159.207853] r8152 2-1:1.0 bridgeif1: Tx timeout 10757 [ 1164.328134] r8152 2-1:1.0 bridgeif1: Tx timeout 10758 [ 1170.216436] r8152 2-1:1.0 bridgeif1: Tx timeout 10759 [ 1175.080678] r8152 2-1:1.0 bridgeif1: Tx timeout 10760 [ 1180.201193] r8152 2-1:1.0 bridgeif1: Tx timeout 10761 [ 1185.321188] r8152 2-1:1.0 bridgeif1: Tx timeout 10762 [ 1191.209491] r8152 2-1:1.0 bridgeif1: Tx timeout 10763 [ 1196.329740] r8152 2-1:1.0 bridgeif1: Tx timeout 10764 [ 1202.218054] r8152 2-1:1.0 bridgeif1: Tx timeout 10765 [ 1207.082286] r8152 2-1:1.0 bridgeif1: Tx timeout 10766 [ 1212.202523] r8152 2-1:1.0 bridgeif1: Tx timeout 10767 [ 1217.322777] r8152 2-1:1.0 bridgeif1: Tx timeout 10768 [ 1223.211058] r8152 2-1:1.0 bridgeif1: Tx timeout 10769 [ 1228.331309] r8152 2-1:1.0 bridgeif1: Tx timeout 10770 [ 1234.219597] r8152 2-1:1.0 bridgeif1: Tx timeout 10771 [ 1239.083829] r8152 2-1:1.0 bridgeif1: Tx timeout 10772 [ 1244.204071] r8152 2-1:1.0 bridgeif1: Tx timeout 10773 [ 1249.324313] r8152 2-1:1.0 bridgeif1: Tx timeout 10774 [ 1255.212602] r8152 2-1:1.0 bridgeif1: Tx timeout 10775 [ 1260.332834] r8152 2-1:1.0 bridgeif1: Tx timeout 10776 [ 1266.221110] r8152 2-1:1.0 bridgeif1: Tx timeout 10777 [ 1271.085335] r8152 2-1:1.0 bridgeif1: Tx timeout 10778 [ 1276.205574] r8152 2-1:1.0 bridgeif1: Tx timeout 10779 [ 1281.325815] r8152 2-1:1.0 bridgeif1: Tx timeout 10780 [ 1287.214079] r8152 2-1:1.0 bridgeif1: Tx timeout 10781 [ 1292.334321] r8152 2-1:1.0 bridgeif1: Tx timeout 10782 [ 1298.222578] r8152 2-1:1.0 bridgeif1: Tx timeout 10783 [ 1303.086798] r8152 2-1:1.0 bridgeif1: Tx timeout 10784 [ 1308.207024] r8152 2-1:1.0 bridgeif1: Tx timeout 10785 [ 1313.327255] r8152 2-1:1.0 bridgeif1: Tx timeout 10786 [ 1319.215517] r8152 2-1:1.0 bridgeif1: Tx timeout 10787 [ 1324.335751] r8152 2-1:1.0 bridgeif1: Tx timeout 10788 [ 1330.224002] r8152 2-1:1.0 bridgeif1: Tx timeout 10789 [ 1335.088218] r8152 2-1:1.0 bridgeif1: Tx timeout 10790 [ 1340.208445] r8152 2-1:1.0 bridgeif1: Tx timeout 10791 [ 1345.328670] r8152 2-1:1.0 bridgeif1: Tx timeout 10792 [ 1351.216923] r8152 2-1:1.0 bridgeif1: Tx timeout 10793 [ 1356.337149] r8152 2-1:1.0 bridgeif1: Tx timeout 10794 [ 1362.225400] r8152 2-1:1.0 bridgeif1: Tx timeout 10795 [ 1367.089604] r8152 2-1:1.0 bridgeif1: Tx timeout 10796 [ 1372.209825] r8152 2-1:1.0 bridgeif1: Tx timeout 10797 [ 1377.330044] r8152 2-1:1.0 bridgeif1: Tx timeout 10798 [ 1383.218298] r8152 2-1:1.0 bridgeif1: Tx timeout 10799 [ 1388.338517] r8152 2-1:1.0 bridgeif1: Tx timeout 10800 [ 1394.226765] r8152 2-1:1.0 bridgeif1: Tx timeout 10801 [ 1399.090969] r8152 2-1:1.0 bridgeif1: Tx timeout 10802 [ 1404.211185] r8152 2-1:1.0 bridgeif1: Tx timeout 10803 [ 1409.331406] r8152 2-1:1.0 bridgeif1: Tx timeout 10804 [ 1415.219644] r8152 2-1:1.0 bridgeif1: Tx timeout 10805 [ 1420.339862] r8152 2-1:1.0 bridgeif1: Tx timeout 10806 [ 1426.228097] r8152 2-1:1.0 bridgeif1: Tx timeout 10807 [ 1431.092293] r8152 2-1:1.0 bridgeif1: Tx timeout 10808 [ 1436.212502] r8152 2-1:1.0 bridgeif1: Tx timeout 10809 [ 1441.332714] r8152 2-1:1.0 bridgeif1: Tx timeout 10810 [ 1447.220963] r8152 2-1:1.0 bridgeif1: Tx timeout 10811 [ 1452.341168] r8152 2-1:1.0 bridgeif1: Tx timeout 10812 [ 1458.229403] r8152 2-1:1.0 bridgeif1: Tx timeout 10813 [ 1463.093607] r8152 2-1:1.0 bridgeif1: Tx timeout 10814 [ 1468.213811] r8152 2-1:1.0 bridgeif1: Tx timeout 10815 [ 1473.334015] r8152 2-1:1.0 bridgeif1: Tx timeout 10816 [ 1479.222255] r8152 2-1:1.0 bridgeif1: Tx timeout 10817 [ 1484.342458] r8152 2-1:1.0 bridgeif1: Tx timeout 10818 [ 1490.230695] r8152 2-1:1.0 bridgeif1: Tx timeout 10819 [ 1495.094882] r8152 2-1:1.0 bridgeif1: Tx timeout 10820 [ 1500.215088] r8152 2-1:1.0 bridgeif1: Tx timeout 10821 [ 1505.335292] r8152 2-1:1.0 bridgeif1: Tx timeout 10822 [ 1511.223529] r8152 2-1:1.0 bridgeif1: Tx timeout 10823 [ 1516.343733] r8152 2-1:1.0 bridgeif1: Tx timeout 10824 [ 1522.231964] r8152 2-1:1.0 bridgeif1: Tx timeout 10825 [ 1527.096153] r8152 2-1:1.0 bridgeif1: Tx timeout 10826 [ 1532.216355] r8152 2-1:1.0 bridgeif1: Tx timeout 10827 [ 1537.336553] r8152 2-1:1.0 bridgeif1: Tx timeout 10828 [ 1543.224791] r8152 2-1:1.0 bridgeif1: Tx timeout 10829 [ 1548.344992] r8152 2-1:1.0 bridgeif1: Tx timeout 10830 [ 1554.233216] r8152 2-1:1.0 bridgeif1: Tx timeout 10831 [ 1559.097401] r8152 2-1:1.0 bridgeif1: Tx timeout 10832 [ 1564.217596] r8152 2-1:1.0 bridgeif1: Tx timeout 10833 [ 1569.337793] r8152 2-1:1.0 bridgeif1: Tx timeout 10834 [ 1575.226025] r8152 2-1:1.0 bridgeif1: Tx timeout 10835 [ 1580.154332] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10836 [ 1580.346228] r8152 2-1:1.0 bridgeif1: Tx timeout 10837 [ 1586.234452] r8152 2-1:1.0 bridgeif1: Tx timeout 10838 [ 1590.794665] usb 2-1: device not accepting address 2, error -110 10839 [ 1590.926658] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10840 [ 1591.098639] r8152 2-1:1.0 bridgeif1: Tx timeout 10841 [ 1591.350662] usb 2-1: device not accepting address 2, error -71 10842 [ 1591.690677] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10843 [ 1596.218831] r8152 2-1:1.0 bridgeif1: Tx timeout 10844 [ 1596.858874] usb 2-1: device descriptor read/64, error -110 10845 [ 1601.339028] r8152 2-1:1.0 bridgeif1: Tx timeout 10846 [ 1607.227257] r8152 2-1:1.0 bridgeif1: Tx timeout 10847 [ 1612.347466] r8152 2-1:1.0 bridgeif1: Tx timeout 10848 [ 1612.479473] usb 2-1: device descriptor read/64, error -110 10849 [ 1612.719486] usb 2-1: reset high-speed USB device number 2 using ehci-platform 10850 [ 1613.067489] usb 2-1: device descriptor read/64, error -71 10851 [ 1618.235679] r8152 2-1:1.0 bridgeif1: Tx timeout 10852 [ 1623.099860] r8152 2-1:1.0 bridgeif1: Tx timeout 10853 [ 1628.220058] r8152 2-1:1.0 bridgeif1: Tx timeout 10854 [ 1628.604091] usb 2-1: device descriptor read/64, error -110 10855 [ 1628.716148] r8152 2-1:1.0 bridgeif1: Get ether addr fail 10856 [ 1628.721491] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled 10857 [ 1628.728148] usb 2-1: USB disconnect, device number 2 10858 [ 1628.736033] device bridgeif1 left promiscuous mode 10859 [ 1629.048173] usb 2-1: new high-speed USB device number 3 using ehci-platform 10860 [ 1639.692512] usb 2-1: device not accepting address 3, error -110 10861 [ 1639.824514] usb 2-1: new high-speed USB device number 4 using ehci-platform 10862 [ 1640.248526] usb 2-1: device not accepting address 4, error -71 10863 [ 1640.254411] usb usb2-port1: attempt power cycle 10864 [ 1640.904546] usb 2-1: new high-speed USB device number 5 using ehci-platform 10865 [ 1646.268756] usb 2-1: device descriptor read/64, error -110 10866 [ 1661.885363] usb 2-1: device descriptor read/64, error -110 10867 [ 1662.125384] usb 2-1: new high-speed USB device number 6 using ehci-platform 10868 [ 1662.473360] usb 2-1: device descriptor read/64, error -71 10869 [ 1678.013953] usb 2-1: device descriptor read/64, error -110 10870 [ 1678.126003] usb usb2-port1: unable to enumerate USB device 10871 [ 1678.517957] usb 6-1: new full-speed USB device number 2 using ohci-platform 10872 [ 1694.202558] usb 6-1: device descriptor read/64, error -110 10873 [ 1709.819134] usb 6-1: device descriptor read/64, error -110 10874 [ 1710.119160] usb 6-1: new full-speed USB device number 3 using ohci-platform 10875 [ 1725.691731] usb 6-1: device descriptor read/64, error -110 10876 [ 1741.308300] usb 6-1: device descriptor read/64, error -110 10877 [ 1741.420340] usb usb6-port1: attempt power cycle 10878 [ 1741.924322] usb 6-1: new full-speed USB device number 4 using ohci-platform 10879 [ 1752.592714] usb 6-1: device not accepting address 4, error -110 10880 [ 1752.784726] usb 6-1: new full-speed USB device number 5 using ohci-platform 10881 [ 1763.601125] usb 6-1: device not accepting address 5, error -110 10882 [ 1763.607104] usb usb6-port1: unable to enumerate USB device 10883 10884 10885 vm.admin_reserve_kbytes = 8192 10886 vm.block_dump = 0 10887 vm.compact_unevictable_allowed = 1 10888 vm.dirty_background_bytes = 0 10889 vm.dirty_background_ratio = 10 10890 vm.dirty_bytes = 0 10891 vm.dirty_expire_centisecs = 3000 10892 vm.dirty_ratio = 20 10893 vm.dirtytime_expire_seconds = 43200 10894 vm.dirty_writeback_centisecs = 500 10895 vm.extfrag_threshold = 500 10896 vm.highmem_is_dirtyable = 0 10897 vm.laptop_mode = 0 10898 vm.legacy_va_layout = 0 10899 vm.lowmem_reserve_ratio = 32 0 0 10900 vm.max_map_count = 65530 10901 vm.min_free_kbytes = 3465 10902 vm.mmap_min_addr = 32768 10903 vm.mmap_rnd_bits = 8 10904 vm.oom_dump_tasks = 1 10905 vm.oom_kill_allocating_task = 0 10906 vm.overcommit_kbytes = 0 10907 vm.overcommit_memory = 0 10908 vm.overcommit_ratio = 50 10909 vm.page-cluster = 0 10910 vm.panic_on_oom = 0 10911 vm.percpu_pagelist_fraction = 0 10912 vm.stat_interval = 1 10913 vm.swappiness = 100 10914 vm.user_reserve_kbytes = 31523 10915 vm.vfs_cache_pressure = 100 10916 vm.watermark_boost_factor = 15000 10917 vm.watermark_scale_factor = 10 10918 10919 ### interrupts: 10920 CPU0 CPU1 CPU2 CPU3 10921 17: 0 0 0 0 GICv2 50 Level timer@1c20c00 10922 18: 0 0 0 0 GICv2 29 Level arch_timer 10923 19: 893595 920978 13609274 332435 GICv2 30 Level arch_timer 10924 22: 0 0 0 0 GICv2 82 Level 1c02000.dma-controller 10925 24: 307699 0 0 0 GICv2 92 Level sunxi-mmc 10926 25: 461 0 0 0 GICv2 93 Level sunxi-mmc 10927 26: 643 0 0 0 GICv2 94 Level sunxi-mmc 10928 27: 0 0 0 0 GICv2 103 Level musb-hdrc.1.auto 10929 28: 0 0 0 0 GICv2 104 Level ehci_hcd:usb1 10930 29: 0 0 0 0 GICv2 105 Level ohci_hcd:usb5 10931 30: 320521 0 0 0 GICv2 106 Level ehci_hcd:usb2 10932 31: 51 0 0 0 GICv2 107 Level ohci_hcd:usb6 10933 32: 0 0 0 0 GICv2 108 Level ehci_hcd:usb3 10934 33: 0 0 0 0 GICv2 109 Level ohci_hcd:usb7 10935 34: 174 0 9443594 0 GICv2 110 Level ehci_hcd:usb4 10936 35: 0 0 0 0 GICv2 111 Level ohci_hcd:usb8 10937 39: 1714419 0 0 0 GICv2 114 Level bridgeif0 10938 43: 458 0 0 0 GICv2 33 Level ttyS1 10939 44: 0 0 0 0 GICv2 38 Level mv64xxx_i2c 10940 45: 0 0 0 0 GICv2 72 Level 1f00000.rtc 10941 48: 0 0 0 0 GICv2 90 Level 1c0e000.video-codec 10942 49: 0 0 0 0 GICv2 129 Level gp 10943 50: 0 0 0 0 GICv2 130 Level gpmmu 10944 51: 0 0 0 0 GICv2 131 Level pp0 10945 52: 0 0 0 0 GICv2 132 Level ppmmu0 10946 53: 0 0 0 0 GICv2 134 Level pp1 10947 54: 0 0 0 0 GICv2 135 Level ppmmu1 10948 56: 1187613 0 0 0 GICv2 63 Level ths 10949 57: 0 0 0 0 GICv2 152 Level arm-pmu 10950 58: 0 0 0 0 GICv2 153 Level arm-pmu 10951 59: 0 0 0 0 GICv2 154 Level arm-pmu 10952 60: 0 0 0 0 GICv2 155 Level arm-pmu 10953 128: 1 0 0 0 sunxi_pio_edge 3 Edge reset 10954 IPI0: 0 0 0 0 CPU wakeup interrupts 10955 IPI1: 0 0 0 0 Timer broadcast interrupts 10956 IPI2: 170575 327164 258300 614706 Rescheduling interrupts 10957 IPI3: 24 41 21 26 Function call interrupts 10958 IPI4: 0 0 0 0 CPU stop interrupts 10959 IPI5: 117770 41383 1046856 20612 IRQ work interrupts 10960 IPI6: 0 0 0 0 completion interrupts 10961 Err: 0 Please upload the whole output above to an online pasteboard service and provide the URL in the forum where you have been asked for this. 0 Quote
sfx2000 Posted April 19, 2020 Posted April 19, 2020 On 4/13/2020 at 5:56 AM, andersm said: Any ideas if it's a driver or hardware issue? At first glance - this looks like a driver issue... 0 Quote
andersm Posted April 21, 2020 Author Posted April 21, 2020 An update: before building the full system, last year we built a smaller, 8-node system, which I just set up again. This system is still running the "Armbian_5.90_Nanopi-r1_Ubuntu_bionic_next_4.19.57" image, and I can't reproduce the problem with this kernel (4.19.57-sunxi). The size of the network doesn't seem to be a factor, as we encountered the problem with just five nodes. 0 Quote
andersm Posted May 5, 2020 Author Posted May 5, 2020 Here's another oddity: if I run iperf3 between two directly connected NanoPi R1's (from one's LAN to the other's WAN), I get about 94Mbit with kernel 4.19.62 or older, but only about 13Mbit with all newer ones I've tested (including 5.4.35). I'll have to burn fresh images to make sure the results aren't affected by any other configuration changes I've done, but so far this seems consistent and reproducible. 0 Quote
Jean-Marc Posted April 10, 2021 Posted April 10, 2021 Hi, Please could you give us more information about your Linux kernel version and driver used into your test. I am trying to use one Debian 5.10 standard kernel without capabilities to ping one external target connected on WAN port. At the same time, no problems encountered when connected (even with VLAN) on LAN port ? Thanks in advance for your help 0 Quote
