tkaiser Posted June 10, 2016 Posted June 10, 2016 (edited) Dear all, we need some help from Banana Pi M2 (not that important), Cubox-i/UDOO and ODROID XU4 users. Please look through this Github issue and also have look how we currently handle IRQ redistribution on various board families (example 1 and example 2) Since irqbalanced on ARM is broken (and if it would work it's often counterproductive) assigning IRQs statically to specific CPU cores increases overall system performance slightly for free. We do this for A20 boards for years (dual core --> sending Ethernet to second CPU core), extended this on H3 boards a few months ago (quad core and somewhat complicated due to the count of different boards exposing different interfaces) and added other board families just recently. Now we need you! In case you are somewhat experienced please get back to us with the output of cat /proc/interrupts (when you're running a more recent Armbian version then output of 'sudo armbianmonitor -u' is preferred!) And in case you're able to do some testing please have a look at the examples above and the Github issue (Amlogic kernels seem to need different procfs calls for example), test yourself and provide code snippets already known to work! Thx in advance! Edited June 10, 2016 by wildcat_paris minor typo (since=>for) 1
wildcat_paris Posted June 10, 2016 Posted June 10, 2016 XU4 gr@odroidxu4:~$ cat /etc/armbian.txt -------------------------------------------------------------------------------- Title: Armbian 5.11 Odroidxu4 Ubuntu trusty default (unofficial) Kernel: Linux 3.10.101 Build date: 14.05.2016 Author: Igor Pecovnik, www.igorpecovnik.com Sources: http://github.com/igorpecovnik Support: http://www.armbian.com -------------------------------------------------------------------------------- gr@odroidxu4:~$ cat /proc/interrupts CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 65: 0 0 0 0 0 0 0 0 GIC 10800000.mdma 66: 0 0 0 0 0 0 0 0 GIC 121a0000.pdma 67: 0 0 0 0 0 0 0 0 GIC 121b0000.pdma 77: 0 0 0 0 0 0 0 0 GIC 13400000.pinctrl 78: 0 0 0 0 0 0 0 0 GIC 14000000.pinctrl 82: 0 0 0 0 0 0 0 0 GIC 14010000.pinctrl 85: 18 0 0 0 0 0 0 0 GIC 12c20000.serial 88: 0 0 0 0 0 0 0 0 GIC 12c60000.i2c 89: 0 0 0 0 0 0 0 0 GIC 12c70000.i2c 92: 0 0 0 0 0 0 0 0 GIC 12ca0000.hsi2c 93: 0 0 0 0 0 0 0 0 GIC 12cb0000.hsi2c 97: 0 0 0 0 0 0 0 0 GIC exynos_tmu 101: 0 0 0 0 0 0 0 0 GIC spi-s3c64xx 103: 1 0 0 0 0 0 0 0 GIC ehci_hcd:usb1, ohci_hcd:usb2 104: 553377 0 0 0 0 0 0 0 GIC xhci-hcd:usb3 105: 54572268 0 0 0 0 0 0 0 GIC xhci-hcd:usb5 106: 0 0 0 0 0 0 0 0 GIC 11800000.mali 107: 13670610 0 0 0 0 0 0 0 GIC dw-mci 109: 4113 0 0 0 0 0 0 0 GIC dw-mci 110: 0 0 0 0 0 0 0 0 GIC 13410000.pinctrl 126: 0 0 0 0 0 0 0 0 GIC drm_mixer 128: 3 0 0 0 0 0 0 0 GIC 11000000.mfc 138: 0 0 0 0 0 0 0 0 GIC 12d10000.adc 142: 0 0 0 0 0 0 0 0 GIC 3880000.adma 146: 0 0 0 0 0 0 0 0 GIC hdmi-cec 149: 1 0 0 0 0 0 0 0 GIC 11800000.mali 152: 42183713 0 0 0 0 0 0 0 GIC mct_tick0 153: 0 23696180 0 0 0 0 0 0 GIC mct_tick1 154: 0 0 23208468 0 0 0 0 0 GIC mct_tick2 155: 0 0 0 22915935 0 0 0 0 GIC mct_tick3 160: 0 0 0 0 56411289 0 0 0 GIC mct_tick4 161: 0 0 0 0 0 32643942 0 0 GIC mct_tick5 162: 0 0 0 0 0 0 38564153 0 GIC mct_tick6 163: 0 0 0 0 0 0 0 33452062 GIC mct_tick7 201: 0 0 0 0 0 0 0 0 GIC 11f20000.sysmmu 215: 0 0 0 0 0 0 0 0 GIC exynos_tmu 216: 0 0 0 0 0 0 0 0 GIC exynos_tmu 217: 0 0 0 0 0 0 0 0 GIC exynos_tmu 218: 0 0 0 0 0 0 0 0 GIC 12890000.sysmmu 220: 0 0 0 0 0 0 0 0 GIC 128a0000.sysmmu 247: 0 0 0 0 0 0 0 0 GIC exynos_tmu 251: 0 0 0 0 0 0 0 0 GIC 11800000.mali 272: 0 0 0 0 0 0 0 0 COMBINER 13e80000.sysmmu 274: 0 0 0 0 0 0 0 0 COMBINER 13e90000.sysmmu 280: 0 0 0 0 0 0 0 0 COMBINER 14680000.sysmmu 282: 0 0 0 0 0 0 0 0 COMBINER 14640000.sysmmu 290: 0 0 0 0 0 0 0 0 COMBINER 11f10000.sysmmu 306: 0 0 0 0 0 0 0 0 COMBINER 11200000.sysmmu 316: 0 0 0 0 0 0 0 0 COMBINER 14650000.sysmmu 325: 0 0 0 0 0 0 0 0 COMBINER 11210000.sysmmu 404: 0 0 0 0 0 0 0 0 COMBINER drm_fimd 414: 0 0 0 0 0 0 0 0 COMBINER 128e0000.sysmmu 434: 0 0 0 0 0 0 0 0 COMBINER 10a70000.sysmmu 436: 0 0 0 0 0 0 0 0 COMBINER 12880000.sysmmu 438: 0 0 0 0 0 0 0 0 COMBINER 128d0000.sysmmu 443: 13 0 0 0 0 0 0 0 COMBINER mct_comp_irq 453: 0 0 0 0 0 0 0 0 COMBINER 10a60000.sysmmu 474: 0 0 0 0 0 0 0 0 COMBINER 128c0000.sysmmu 512: 0 0 0 0 0 0 0 0 exynos_wkup_irq_chip s2mps11 523: 0 0 0 0 0 0 0 0 s2mps11 rtc-alarm0 529: 0 0 0 0 0 0 0 0 exynos_wkup_irq_chip hdmi 530: 1 0 0 0 0 0 0 0 exynos_wkup_irq_chip dwc3_id 531: 0 0 0 0 0 0 0 0 exynos_wkup_irq_chip dwc3_b_sess 533: 0 0 0 0 0 0 0 0 exynos_wkup_irq_chip gpio-keys: KEY_POWER IPI0: 0 0 0 0 0 0 0 0 CPU wakeup interrupts IPI1: 0 0 0 0 0 0 0 0 Timer broadcast interrupts IPI2: 24246515 23208640 20800956 20595844 23229974 23562283 21574939 21296430 Rescheduling interrupts IPI3: 54 44 40 42 52 56 50 53 Function call interrupts IPI4: 9 19 9 18 121 26 151 14 Single function call interrupts IPI5: 0 0 0 0 0 0 0 0 CPU stop interrupts IPI6: 0 0 0 0 0 0 0 0 CPU backtrace Err: 0 sudo armbianmonitor -u is not very useful http://sprunge.us/WYTL (note: I am managing XU4 fan PWM myself so it outputs a lots of logs)
tkaiser Posted June 10, 2016 Author Posted June 10, 2016 sudo armbianmonitor -u is not very useful http://sprunge.us/WYTL Hmm... can you please replace the contents of /usr/local/bin/armbianmonitor with https://github.com/igorpecovnik/lib/blob/master/scripts/armbianmonitor/armbianmonitor then run the following code (and report back if error messages appear), generate some activity and try again? echo 2 >/proc/irq/$(awk -F":" "/usb2/ {print \$1}" </proc/interrupts | sed 's/\ //g')/smp_affinity echo 4 >/proc/irq/$(awk -F":" "/usb3/ {print \$1}" </proc/interrupts | sed 's/\ //g')/smp_affinity echo 8 >/proc/irq/$(awk -F":" "/usb5/ {print \$1}" </proc/interrupts | sed 's/\ //g')/smp_affinity echo 16 >/proc/irq/$(awk -F":" "/dw-mci/ {print \$1}" </proc/interrupts | sed 's/\ //g' | tail -1)/smp_affinity echo 32 >/proc/irq/$(awk -F":" "/dw-mci/ {print \$1}" </proc/interrupts | sed 's/\ //g' | head -1)/smp_affinity for i in $(awk -F':' '/11800000.mali/{print $1}' /proc/interrupts); do echo 64 >/proc/irq/$i/smp_affinity done (does the XU4 have no Ethernet? Or is this USB?!) EDIT: It's Realtek 8153 USB3 chipset. 1
Igor Posted June 10, 2016 Posted June 10, 2016 CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 65: 0 0 0 0 0 0 0 0 GIC 10800000.mdma 66: 0 0 0 0 0 0 0 0 GIC 121a0000.pdma 67: 0 0 0 0 0 0 0 0 GIC 121b0000.pdma 74: 0 0 0 0 0 0 0 0 GIC 101d0000.watchdog 77: 0 0 0 0 0 0 0 0 GIC 13400000.pinctrl 78: 0 0 0 0 0 0 0 0 GIC 14000000.pinctrl 82: 0 0 0 0 0 0 0 0 GIC 14010000.pinctrl 85: 12 0 0 0 0 0 0 0 GIC 12c20000.serial 88: 0 0 0 0 0 0 0 0 GIC 12c60000.i2c 89: 0 0 0 0 0 0 0 0 GIC 12c70000.i2c 92: 0 0 0 0 0 0 0 0 GIC 12ca0000.hsi2c 93: 0 0 0 0 0 0 0 0 GIC 12cb0000.hsi2c 97: 40 0 0 0 0 0 0 0 GIC exynos_tmu 101: 0 0 0 0 0 0 0 0 GIC spi-s3c64xx 103: 1 0 0 0 0 0 0 0 GIC ehci_hcd:usb1, ohci_hcd:usb2 104: 1372 0 0 0 0 0 0 0 GIC xhci-hcd:usb3 105: 69096611 0 0 0 0 0 0 0 GIC xhci-hcd:usb5 106: 0 0 0 0 0 0 0 0 GIC 11800000.mali 107: 200 0 0 0 0 0 0 0 GIC dw-mci 109: 14610251 0 0 0 0 0 0 0 GIC dw-mci 110: 0 0 0 0 0 0 0 0 GIC 13410000.pinctrl 126: 0 0 0 0 0 0 0 0 GIC drm_mixer 128: 3 0 0 0 0 0 0 0 GIC 11000000.mfc 138: 0 0 0 0 0 0 0 0 GIC 12d10000.adc 142: 0 0 0 0 0 0 0 0 GIC 3880000.adma 146: 0 0 0 0 0 0 0 0 GIC hdmi-cec 149: 1 0 0 0 0 0 0 0 GIC 11800000.mali 152: 92561831 0 0 0 0 0 0 0 GIC mct_tick0 153: 0 20595317 0 0 0 0 0 0 GIC mct_tick1 154: 0 0 16052076 0 0 0 0 0 GIC mct_tick2 155: 0 0 0 14994396 0 0 0 0 GIC mct_tick3 160: 0 0 0 0 18023649 0 0 0 GIC mct_tick4 161: 0 0 0 0 0 24953244 0 0 GIC mct_tick5 162: 0 0 0 0 0 0 16258537 0 GIC mct_tick6 163: 0 0 0 0 0 0 0 8673074 GIC mct_tick7 201: 0 0 0 0 0 0 0 0 GIC 11f20000.sysmmu 215: 0 0 0 0 0 0 0 0 GIC exynos_tmu 216: 263 0 0 0 0 0 0 0 GIC exynos_tmu 217: 447 0 0 0 0 0 0 0 GIC exynos_tmu 218: 0 0 0 0 0 0 0 0 GIC 12890000.sysmmu 220: 0 0 0 0 0 0 0 0 GIC 128a0000.sysmmu 247: 0 0 0 0 0 0 0 0 GIC exynos_tmu 251: 0 0 0 0 0 0 0 0 GIC 11800000.mali 272: 0 0 0 0 0 0 0 0 COMBINER 13e80000.sysmmu 274: 0 0 0 0 0 0 0 0 COMBINER 13e90000.sysmmu 280: 0 0 0 0 0 0 0 0 COMBINER 14680000.sysmmu 282: 0 0 0 0 0 0 0 0 COMBINER 14640000.sysmmu 290: 0 0 0 0 0 0 0 0 COMBINER 11f10000.sysmmu 306: 0 0 0 0 0 0 0 0 COMBINER 11200000.sysmmu 316: 0 0 0 0 0 0 0 0 COMBINER 14650000.sysmmu 325: 0 0 0 0 0 0 0 0 COMBINER 11210000.sysmmu 404: 0 0 0 0 0 0 0 0 COMBINER drm_fimd 414: 0 0 0 0 0 0 0 0 COMBINER 128e0000.sysmmu 434: 0 0 0 0 0 0 0 0 COMBINER 10a70000.sysmmu 436: 0 0 0 0 0 0 0 0 COMBINER 12880000.sysmmu 438: 0 0 0 0 0 0 0 0 COMBINER 128d0000.sysmmu 443: 13 0 0 0 0 0 0 0 COMBINER mct_comp_irq 453: 0 0 0 0 0 0 0 0 COMBINER 10a60000.sysmmu 474: 0 0 0 0 0 0 0 0 COMBINER 128c0000.sysmmu 512: 0 0 0 0 0 0 0 0 exynos_wkup_irq_chip s2mps11 523: 0 0 0 0 0 0 0 0 s2mps11 rtc-alarm0 529: 0 0 0 0 0 0 0 0 exynos_wkup_irq_chip hdmi 530: 1 0 0 0 0 0 0 0 exynos_wkup_irq_chip dwc3_id 531: 0 0 0 0 0 0 0 0 exynos_wkup_irq_chip dwc3_b_sess 533: 0 0 0 0 0 0 0 0 exynos_wkup_irq_chip gpio-keys: KEY_POWER IPI0: 0 0 0 0 0 0 0 0 CPU wakeup interrupts IPI1: 0 0 0 0 0 0 0 0 Timer broadcast interrupts IPI2: 17653799 19815007 18618701 17881865 9178030 8393902 5447400 6494852 Rescheduling interrupts IPI3: 489 462 485 447 317 460 340 406 Function call interrupts IPI4: 46 60 51 70 14 44 39 13 Single function call interrupts IPI5: 0 0 0 0 0 0 0 0 CPU stop interrupts IPI6: 0 0 0 0 0 0 0 0 CPU backtrace Err: 0 XU4, big heatsink, no fan http://sprunge.us/DDVC 1
wildcat_paris Posted June 10, 2016 Posted June 10, 2016 (edited) @Tk, the issue with "armbianmonitor -u" when dmesg is too large you only get dmesg in the log so I have rebooted & it is better http://sprunge.us/jTFh note: need to add activity gr@odroidxu4:~$ sudo ./tkActivityTest gr@odroidxu4:~$ sudo armbianmonitor -u /var/log/armhwinfo.log has been uploaded to http://sprunge.us/hNgL http://sprunge.us/hNgL note: I have badly named your script : tkActivityTest => tkChangeIRQCPUaffinity I have done HDD reading (cloudshell NAS uses USB3=>SATA), reading from /dev/TrueRNG (on USB3 port #2), find / for MMC (no USB2, no Mali) gr@odroidxu4:~$ sudo ./tkChangeIRQCPUaffinity 103: 1 0 0 0 0 0 0 0 GIC ehci_hcd:usb1, ohci_hcd:usb2 104: 1650 0 337 0 0 0 0 0 GIC xhci-hcd:usb3 105: 23832 0 0 37163 0 0 0 0 GIC xhci-hcd:usb5 106: 0 0 0 0 0 0 0 0 GIC 11800000.mali 107: 10775 3993 0 0 0 0 0 0 GIC dw-mci 109: 0 0 0 0 0 0 0 0 GIC dw-mci 149: 1 0 0 0 0 0 0 0 GIC 11800000.mali 251: 0 0 0 0 0 0 0 0 GIC 11800000.mali gr@odroidxu4:~$ ls /home2/gr/ kernel/ SAV_odroid_image_20160518.bin SAV_odroid_image_20160518.bin.SD.md5 save_2016_01/ SAV_odroid_image_20160518.bin.md5 gr@odroidxu4:~$ cat /home2/gr/SAV_odroid_image_20160518.bin > /dev/null gr@odroidxu4:~$ sudo ./tkChangeIRQCPUaffinity 103: 1 0 0 0 0 0 0 0 GIC ehci_hcd:usb1, ohci_hcd:usb2 104: 1650 0 1092375 0 0 0 0 0 GIC xhci-hcd:usb3 105: 23832 0 0 210260 0 0 0 0 GIC xhci-hcd:usb5 106: 0 0 0 0 0 0 0 0 GIC 11800000.mali 107: 10775 41906 0 0 0 0 0 0 GIC dw-mci 109: 0 0 0 0 0 0 0 0 GIC dw-mci 149: 1 0 0 0 0 0 0 0 GIC 11800000.mali 251: 0 0 0 0 0 0 0 0 GIC 11800000.mali to compare before reboot gr@odroidxu4:~$ cat /proc/interrupts 103: 1 0 0 0 0 0 0 0 GIC ehci_hcd:usb1, ohci_hcd:usb2 104: 553377 0 0 0 0 0 0 0 GIC xhci-hcd:usb3 105: 54572268 0 0 0 0 0 0 0 GIC xhci-hcd:usb5 106: 0 0 0 0 0 0 0 0 GIC 11800000.mali 107: 13670610 0 0 0 0 0 0 0 GIC dw-mci 109: 4113 0 0 0 0 0 0 0 GIC dw-mci 149: 1 0 0 0 0 0 0 0 GIC 11800000.mali 251: 0 0 0 0 0 0 0 0 GIC 11800000.mali -- so my tkChangeIRQCPUaffinity script gr@odroidxu4:~$ cat tkChangeIRQCPUaffinity #!/bin/bash echo 2 >/proc/irq/$(awk -F":" "/usb2/ {print \$1}" </proc/interrupts | sed 's/\ //g')/smp_affinity echo 4 >/proc/irq/$(awk -F":" "/usb3/ {print \$1}" </proc/interrupts | sed 's/\ //g')/smp_affinity echo 8 >/proc/irq/$(awk -F":" "/usb5/ {print \$1}" </proc/interrupts | sed 's/\ //g')/smp_affinity echo 16 >/proc/irq/$(awk -F":" "/dw-mci/ {print \$1}" </proc/interrupts | sed 's/\ //g' | tail -1)/smp_affinity echo 32 >/proc/irq/$(awk -F":" "/dw-mci/ {print \$1}" </proc/interrupts | sed 's/\ //g' | head -1)/smp_affinity for i in $(awk -F':' '/11800000.mali/{print $1}' /proc/interrupts); do echo 64 >/proc/irq/$i/smp_affinity done cat /proc/interrupts | grep -E "usb|mci|mali" Edited June 10, 2016 by wildcat_paris "added" activity 1
tkaiser Posted June 10, 2016 Author Posted June 10, 2016 Would be great if you can replace the contents of /etc/init.d/armhwinfo with latest version from Github, then add the IRQ redirection stuff to the XU4 case construct, restart and report back after some activity. And if you've some spare time maybe investigating what's wrong with the dmesg call in armbianmonitor's line 666 -- maybe playing around with '-s, --buffer-size' option helps? 1
wildcat_paris Posted June 10, 2016 Posted June 10, 2016 @Igor my XU4 has very little load https://share.orange.fr/#w5YWIEQilS176d30317a
wildcat_paris Posted June 10, 2016 Posted June 10, 2016 (edited) Would be great if you can replace the contents of /etc/init.d/armhwinfo with latest version from Github, then add the IRQ redirection stuff to the XU4 case construct, restart and report back after some activity. And if you've some spare time maybe investigating what's wrong with the dmesg call in armbianmonitor's line 666 -- maybe playing around with '-s, --buffer-size' option helps? part 1/ updated armhwinfo, added the IRQ redirection in /etc/rc.local and rebooted gr@odroidxu4:~$ sudo ./tkChangeIRQCPUaffinity [sudo] password for gr: 103: 1 0 0 0 0 0 0 0 GIC ehci_hcd:usb1, ohci_hcd:usb2 104: 1419 0 1095945 0 0 0 0 0 GIC xhci-hcd:usb3 105: 1547 0 0 319887 0 0 0 0 GIC xhci-hcd:usb5 106: 0 0 0 0 0 0 0 0 GIC 11800000.mali 107: 9145 54306 0 0 0 0 0 0 GIC dw-mci 109: 0 0 0 0 0 0 0 0 GIC dw-mci 149: 1 0 0 0 0 0 0 0 GIC 11800000.mali 251: 0 0 0 0 0 0 0 0 GIC 11800000.mali part 2/ Let's see what I can do with "dmesg" I guess line 666 of armbianmonitor is not cursed I had an old version of the script and I guess Igor too up-to-date "armbianmonitor -u" is working Edited June 10, 2016 by wildcat_paris dmesg line 666 not cursed
Schwemmlandebene Posted June 12, 2016 Posted June 12, 2016 (edited) Banana Pi M2 PS: I don't use the latest Armbian toolchain. I'm using the .ignore_changes feature. root@m2-bare:~# uname -a Linux m2-bare 4.5.4-sunxi #2 SMP Sat Jun 11 13:05:21 CEST 2016 armv7l GNU/Linux root@m2-bare:~# cat /proc/interrupts CPU0 CPU1 CPU2 CPU3 17: 0 0 0 0 GIC-0 29 Edge arch_timer 18: 11870 265608 31223 36550 GIC-0 30 Edge arch_timer 21: 0 0 0 0 GIC-0 50 Level sun4i_timer0 22: 0 0 0 0 GIC-0 83 Level sun5i_timer0 27: 0 0 0 0 GIC-0 82 Level 1c02000.dma-controller 28: 1653 0 0 0 GIC-0 92 Level sunxi-mmc 29: 8549 0 0 0 GIC-0 94 Level sunxi-mmc 30: 27 0 0 0 GIC-0 104 Level ehci_hcd:usb1 31: 0 0 0 0 GIC-0 105 Level ohci_hcd:usb2 40: 2251 0 0 0 GIC-0 60 Level sun4i-ts 41: 425 0 0 0 GIC-0 32 Level serial 42: 43646 0 0 0 GIC-0 114 Level eth0 48: 0 0 0 0 GIC-0 72 Level 1f00000.rtc 57: 0 0 0 0 sunxi_pio_edge 4 Edge 1c0f000.mmc cd 181: 43 0 0 0 sunxi_pio_level 0 Level brcmf_oob_intr IPI0: 0 0 0 0 CPU wakeup interrupts IPI1: 0 0 0 0 Timer broadcast interrupts IPI2: 3407 15690 13225 7318 Rescheduling interrupts IPI3: 6 8 3 6 Function call interrupts IPI4: 0 0 0 0 CPU stop interrupts IPI5: 0 0 0 0 IRQ work interrupts IPI6: 0 0 0 0 completion interrupts Err: 0 root@m2-bare:~# Edited June 12, 2016 by Schwemmlandebene 1
tkaiser Posted June 12, 2016 Author Posted June 12, 2016 Banana Pi M2 PS: I don't use the latest Armbian toolchain. Doesn't matter since it's just about testing out IRQ redistribution. Could you please exchange the contents of /etc/init.d/armhwinfo with this here, reboot and try again (doing some stuff and then checking/posting /proc/interrupts)? Or simply try to execute the statements in the BPi M2 case manually, do some stuff and get back with results (just to ensure that the code works and does something useful since it would be great if we could starting with 5.15 do reasonable IRQ distribution on every board we support). Thx!
Schwemmlandebene Posted June 12, 2016 Posted June 12, 2016 I did - copy armhwinfo - reboot - copy some GB over NFS root@m2-bare:~# cat /boot/.verbose 1465726540 sun6i armv7l 4.5.4-sunxi Linux version 4.5.4-sunxi (root@ubuarm) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #2 SMP Sat Jun 11 13:05:21 CEST 2016 root@m2-bare:~# cat /proc/interrupts CPU0 CPU1 CPU2 CPU3 17: 0 0 0 0 GIC-0 29 Edge arch_timer 18: 53622 41095 142718 94383 GIC-0 30 Edge arch_timer 21: 0 0 0 0 GIC-0 50 Level sun4i_timer0 22: 0 0 0 0 GIC-0 83 Level sun5i_timer0 27: 0 0 0 0 GIC-0 82 Level 1c02000.dma-controller 28: 2095 0 0 0 GIC-0 92 Level sunxi-mmc 29: 8580 0 0 0 GIC-0 94 Level sunxi-mmc 30: 27 0 0 0 GIC-0 104 Level ehci_hcd:usb1 31: 0 0 0 0 GIC-0 105 Level ohci_hcd:usb2 40: 932 0 0 0 GIC-0 60 Level sun4i-ts 41: 423 0 0 0 GIC-0 32 Level serial 42: 30792 257702 0 0 GIC-0 114 Level eth0 48: 0 0 0 0 GIC-0 72 Level 1f00000.rtc 57: 0 0 0 0 sunxi_pio_edge 4 Edge 1c0f000.mmc cd 181: 44 0 0 0 sunxi_pio_level 0 Level brcmf_oob_intr IPI0: 0 0 0 0 CPU wakeup interrupts IPI1: 0 0 0 0 Timer broadcast interrupts IPI2: 43231 21388 45126 41832 Rescheduling interrupts IPI3: 7 5 6 7 Function call interrupts IPI4: 0 0 0 0 CPU stop interrupts IPI5: 0 0 0 0 IRQ work interrupts IPI6: 0 0 0 0 completion interrupts Err: 0 root@m2-bare:~#
tkaiser Posted June 12, 2016 Author Posted June 12, 2016 Thx, seems to work but unfortunately when testing locally I made a mistake that went on pastebin.com too: sun6i) # Banana Pi M2: do network on cpu1, SDIO on cpu2, USB on cpu3 for i in $(awk -F':' '/eth0|brcmf_oob_intr/{print $1}' /proc/interrupts); do echo 2 >/proc/irq/$i/smp_affinity done for i in $(awk -F':' '/sunxi-mmc/{print $1}' lala.txt); do echo 4 >/proc/irq/$i/smp_affinity done for i in $(awk -F':' '/hcd:usb/{print $1}' lala.txt); do echo 8 >/proc/irq/$i/smp_affinity done ;; lala.txt should be replaced with /proc/interrupts then USB and SDIO IRQs should be handled by 3rd and 4th CPU core
Schwemmlandebene Posted June 12, 2016 Posted June 12, 2016 /proc/interrupts or </proc/interrupts? if </proc/interrupts, what about line 232?
tkaiser Posted June 12, 2016 Author Posted June 12, 2016 /proc/interrupts or </proc/interrupts? if </proc/interrupts, what about line 232? Doesn't really matter since awk either uses stdin or the file argument. Since it works (eth0 on cpu1) in your setup just with /proc/interrupts I would give this a try.
Schwemmlandebene Posted June 12, 2016 Posted June 12, 2016 Ahh, I didn't mind the awk syntax. But bash complains. root@m2-bare:/etc/init.d# /etc/init.d/armhwinfo start [ ok ] Setting noop I/O scheduler for mmcblk0 [ ok ] Starting ARM hardware info: (Linux version 4.5.4-sunxi (root@ubuarm) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #2 SMP Sat Jun 11 13:05:21 CEST 2016) /etc/init.d/armhwinfo: line 233: echo: write error: Input/output error sun6i) # Banana Pi M2: do network on cpu1, SDIO on cpu2, USB on cpu3 for i in $(awk -F':' '/eth0|brcmf_oob_intr/{print $1}' /proc/interrupts); do echo 2 >/proc/irq/$i/smp_affinity done for i in $(awk -F':' '/sunxi-mmc/{print $1}' /proc/interrupts); do echo 4 >/proc/irq/$i/smp_affinity done for i in $(awk -F':' '/hcd:usb/{print $1}' /proc/interrupts); do echo 8 >/proc/irq/$i/smp_affinity done ;;
tkaiser Posted June 12, 2016 Author Posted June 12, 2016 /etc/init.d/armhwinfo: line 233: echo: write error: Input/output error Weird since eth0 has been sent successfully to cpu1 before? Can you please check state of /proc/interrupts now and maybe do the manual call again prefixing everything with /bin/bash -x /etc/init.d/armhwinfo start and upload the whole output on pastebin.com or similar? Thx!
Schwemmlandebene Posted June 12, 2016 Posted June 12, 2016 Hmm, I tried the lala version, too, and that's the output: root@m2-bare:~# journalctl --no-pager | grep armhwinfo Jun 12 14:09:52 m2-bare armhwinfo[645]: [ ok ] Setting noop I/O scheduler for mmcblk0 Jun 12 14:09:52 m2-bare armhwinfo[645]: [ ok ] Starting ARM hardware info: (Linux version 4.5.4-sunxi (root@ubuarm) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #2 SMP Sat Jun 11 13:05:21 CEST 2016) Jun 12 14:09:52 m2-bare armhwinfo[645]: /etc/init.d/armhwinfo: line 233: echo: write error: Input/output error Jun 12 14:09:52 m2-bare armhwinfo[645]: awk: cannot open lala.txt (No such file or directory) Jun 12 14:09:52 m2-bare armhwinfo[645]: awk: cannot open lala.txt (No such file or directory) root@m2-bare:~#
Schwemmlandebene Posted June 12, 2016 Posted June 12, 2016 I don't use postebin, etc. I could post the whole output here. Here is a snippet: + ID='Banana Pi M2' + [[ Sinovoip BPI-M2 == *AMLOGIC* ]] + [[ Sinovoip BPI-M2 == *HummingBoard2* ]] + [[ -f /etc/armbian-release ]] + case ${HARDWARE} in + chmod 644 /etc/logrotate.d/armhwinfo ++ awk -F: '/eth0|brcmf_oob_intr/{print $1}' /proc/interrupts + for i in '$(awk -F'\'':'\'' '\''/eth0|brcmf_oob_intr/{print $1}'\'' /proc/interrupts)' + echo 2 + for i in '$(awk -F'\'':'\'' '\''/eth0|brcmf_oob_intr/{print $1}'\'' /proc/interrupts)' + echo 2 /etc/init.d/armhwinfo: line 233: echo: write error: Input/output error + '[' -f /var/log/armhwinfo.log ']' ++ awk -F: '/sunxi-mmc/{print $1}' /proc/interrupts ++ date + for i in '$(awk -F'\'':'\'' '\''/sunxi-mmc/{print $1}'\'' /proc/interrupts)' + echo 4 + for i in '$(awk -F'\'':'\'' '\''/sunxi-mmc/{print $1}'\'' /proc/interrupts)' + echo 4 + echo -e '\n\n\nSun Jun 12 14:21:33 CEST 2016 sun6i armv7l 4.5.4-sunxi Linux version 4.5.4-sunxi (root@ubuarm) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #2 SMP Sat Jun 11 13:05:21 CEST 2016' ++ awk -F: '/hcd:usb/{print $1}' /proc/interrupts + echo -e '\n### dmesg:\n' + cat /tmp/armhwinfo.OwXgVA + for i in '$(awk -F'\'':'\'' '\''/hcd:usb/{print $1}'\'' /proc/interrupts)' + echo 8 + for i in '$(awk -F'\'':'\'' '\''/hcd:usb/{print $1}'\'' /proc/interrupts)' + echo 8 + echo -e '\n### lsusb:' + '[' -f /boot/.verbose ']' Does armhwinfo do not exit? root@m2-bare:~# cat /proc/interrupts CPU0 CPU1 CPU2 CPU3 17: 0 0 0 0 GIC-0 29 Edge arch_timer 18: 3795 8165 75263 8169 GIC-0 30 Edge arch_timer 21: 0 0 0 0 GIC-0 50 Level sun4i_timer0 22: 0 0 0 0 GIC-0 83 Level sun5i_timer0 27: 0 0 0 0 GIC-0 82 Level 1c02000.dma-controller 28: 625 0 1910 0 GIC-0 92 Level sunxi-mmc 29: 8266 0 0 0 GIC-0 94 Level sunxi-mmc 30: 27 0 0 262 GIC-0 104 Level ehci_hcd:usb1 31: 0 0 0 0 GIC-0 105 Level ohci_hcd:usb2 40: 498 0 0 0 GIC-0 60 Level sun4i-ts 41: 430 0 0 0 GIC-0 32 Level serial 42: 31217 10822 0 0 GIC-0 114 Level eth0 48: 0 0 0 0 GIC-0 72 Level 1f00000.rtc 57: 0 0 0 0 sunxi_pio_edge 4 Edge 1c0f000.mmc cd 181: 44 0 0 0 sunxi_pio_level 0 Level brcmf_oob_intr IPI0: 0 0 0 0 CPU wakeup interrupts IPI1: 0 0 0 0 Timer broadcast interrupts IPI2: 4199 8013 14879 8066 Rescheduling interrupts IPI3: 9 9 6 4 Function call interrupts IPI4: 0 0 0 0 CPU stop interrupts IPI5: 0 0 0 0 IRQ work interrupts IPI6: 0 0 0 0 completion interrupts Err: 0 root@m2-bare:~#
tkaiser Posted June 12, 2016 Author Posted June 12, 2016 Hmm... since the code does what it's supposed to (sending IRQ processing to dedicated CPU cores) I'll simply suffix all the calls with ' 2>/dev/null'. Thx for your help, new settings will then be active starting with Armbian 5.15
Schwemmlandebene Posted June 12, 2016 Posted June 12, 2016 Are you sure? root@m2-bare:~# cat /proc/irq/181/smp_affinity f root@m2-bare:~# cat /proc/irq/42/smp_affinity 2 root@m2-bare:~# cat /proc/irq/31/smp_affinity 8 root@m2-bare:~# cat /proc/irq/30/smp_affinity 8 root@m2-bare:~# cat /proc/irq/29/smp_affinity 4 root@m2-bare:~# cat /proc/irq/28/smp_affinity 4 root@m2-bare:~# echo 2 > /proc/irq/181/smp_affinity -bash: echo: write error: Input/output error root@m2-bare:~#
tkaiser Posted June 12, 2016 Author Posted June 12, 2016 Are you sure? Regarding eth0 I was pretty sure but thanks for confirmation that 118 isn't accessible. Will remove this and commit the stuff for BPi M2 within the next minutes.
Schwemmlandebene Posted June 12, 2016 Posted June 12, 2016 I'm glad to give something back to Armbian. 2
