hanguofu Posted May 1, 2020 Posted May 1, 2020 I didnot find a driver for MT7668RSN at armbian Armbian_20.02.0-rc1.038_Aml-s9xxx_eoan_current_5.5.0-rc6_desktop_20200205 . There is little info. about this chip on Internet either . But it works at the orignal android with kernel 3.14. Will it be avail. at the coming new armbian release ? Regards ! Guofu Han P.S. if this is not the right place to post it , please help me to move it . Thanks !
Werner Posted May 1, 2020 Posted May 1, 2020 MT7668 is listed in the firmware-misc-nonfree Debian package so I guess it should be there...
Name28 Posted May 14, 2020 Posted May 14, 2020 On 5/1/2020 at 6:53 AM, Werner said: MT7668 is listed in the firmware-misc-nonfree Debian package so I guess it should be there... Expand Hi @Werner, I have TV box A95X F2 (on Amlogic S905X2) with this Wi-Fi module. However, wi-fi does not work. Could you help with that? Is it possible to make it work? "Armbian_20.05.3_Arm-64_buster_current_5.7.0-rc3_desktop_20200502.img.xz" is running from SD card. Thank you. Best regards,
Werner Posted May 14, 2020 Posted May 14, 2020 "not work" is probably the worst possible issue description. armbianmonitor -u
Name28 Posted May 15, 2020 Posted May 15, 2020 On 5/14/2020 at 9:36 AM, Werner said: "not work" is probably the worst possible issue description. armbianmonitor -u Expand Why probably? Below is what I got from armbianmonitor -U Reveal hidden contents 1931 [ 9.203026] axg-sound-card sound: SPDIF IN B <-> ff642680.audio-controller mapping ok 1932 [ 9.203050] axg-sound-card sound: i2s-hifi <-> I2S OUT mapping ok 1933 [ 9.203183] axg-sound-card sound: ASoC: no DMI vendor name! 1934 [ 9.218902] videodev: Linux video capture interface: v2.00 1935 [ 9.233895] Registered IR keymap rc-empty 1936 [ 9.233979] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 1937 [ 9.234101] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 1938 [ 9.234191] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 1939 [ 9.234543] meson-ir ff808000.ir: receiver initialized 1940 [ 9.253269] debugfs: Directory 'ff800280.cec' with parent 'regmap' already present! 1941 [ 9.291364] panfrost ffe40000.gpu: clock rate = 799999987 1942 [ 9.291398] panfrost ffe40000.gpu: supply mali not found, using dummy regulator 1943 [ 9.292837] panfrost ffe40000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0 1944 [ 9.292844] panfrost ffe40000.gpu: features: 00000000,3fde77ff, issues: 00000000,00000400 1945 [ 9.292849] panfrost ffe40000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7 1946 [ 9.292852] panfrost ffe40000.gpu: shader_present=0x1 l2_present=0x1 1947 [ 9.295427] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 1948 [ 9.446486] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 1949 [ 10.677386] zram: Added device: zram0 1950 [ 10.679851] zram: Added device: zram1 1951 [ 10.681164] zram: Added device: zram2 1952 [ 10.726196] zram1: detected capacity change from 0 to 1073741824 1953 [ 10.807605] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.1:08] driver [Meson G12A Internal PHY] (irq=30) 1954 [ 10.822857] meson8b-dwmac ff3f0000.ethernet eth0: No Safety Features support found 1955 [ 10.822876] meson8b-dwmac ff3f0000.ethernet eth0: PTP not supported by HW 1956 [ 10.822892] meson8b-dwmac ff3f0000.ethernet eth0: configuring for phy/rmii link mode 1957 [ 11.802857] Adding 1048572k swap on /dev/zram1. Priority:5 extents:1 across:1048572k SSFS 1958 [ 12.005180] zram0: detected capacity change from 0 to 52428800 1959 [ 13.548148] [drm] kms: can't enable cloning when we probably wanted to. 1960 [ 14.090063] systemd[1]: Started Armbian ZRAM config. 1961 [ 14.101050] systemd[1]: Starting Armbian memory supported logging... 1962 [ 14.167763] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 1963 [ 14.167796] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 1964 [ 16.057796] systemd[1]: Started Armbian memory supported logging. 1965 [ 16.064936] systemd[1]: Starting Journal Service... 1966 [ 16.165896] systemd[1]: Started Journal Service. 1967 [ 16.202396] systemd-journald[741]: Received request to flush runtime journal from PID 1 1968 1969 ### armbian-release: 1970 1971 # PLEASE DO NOT EDIT THIS FILE 1972 BOARD=arm-64 1973 BOARD_NAME="ARM-64" 1974 BOARDFAMILY=arm-64 1975 BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git 1976 BUILD_REPOSITORY_COMMIT=62b8c07-dirty 1977 DISTRIBUTION_CODENAME=buster 1978 DISTRIBUTION_STATUS=supported 1979 VERSION=20.05.3 1980 LINUXFAMILY=arm-64 1981 BRANCH=current 1982 ARCH=arm64 1983 IMAGE_TYPE=user-built 1984 BOARD_TYPE=conf 1985 INITRD_ARCH=arm64 1986 KERNEL_IMAGE_TYPE=Image 1987 1988 ### boot environment: 1989 1990 ODROIDN2-UBOOT-CONFIG 1991 setenv env_addr 0x10400000 1992 setenv kernel_addr 0x11000000 1993 setenv initrd_addr 0x13000000 1994 setenv dtb_addr 0x1000000 1995 if test "${devtype}" = ""; then setenv devtype "mmc"; fi 1996 load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize} 1997 setenv bootargs ${APPEND} 1998 load ${devtype} ${devnum} ${kernel_addr} ${LINUX} 1999 load ${devtype} ${devnum} ${initrd_addr} ${INITRD} 2000 load ${devtype} ${devnum} ${dtb_addr} ${FDT} 2001 fdt addr ${dtb_addr} 2002 booti ${kernel_addr} ${initrd_addr} ${dtb_addr} 2003 2004 ### lsusb: 2005 2006 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 2007 Bus 001 Device 003: ID 12cf:3003 DEXIN 2008 Bus 001 Device 002: ID 0566:3107 Monterey International Corp. Keyboard 2009 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2010 2011 ### lscpu: 2012 2013 Architecture: aarch64 2014 Byte Order: Little Endian 2015 CPU(s): 4 2016 On-line CPU(s) list: 0-3 2017 Thread(s) per core: 1 2018 Core(s) per socket: 4 2019 Socket(s): 1 2020 Vendor ID: ARM 2021 Model: 4 2022 Model name: Cortex-A53 2023 Stepping: r0p4 2024 CPU max MHz: 1800.0000 2025 CPU min MHz: 100.0000 2026 BogoMIPS: 48.00 2027 L1d cache: unknown size 2028 L1i cache: unknown size 2029 L2 cache: unknown size 2030 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2031 2032 ### cpuinfo: 2033 2034 processor : 0 2035 model name : ARMv8 Processor rev 4 (v8l) 2036 BogoMIPS : 48.00 2037 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2038 CPU implementer : 0x41 2039 CPU architecture: 8 2040 CPU variant : 0x0 2041 CPU part : 0xd03 2042 CPU revision : 4 2043 2044 processor : 1 2045 model name : ARMv8 Processor rev 4 (v8l) 2046 BogoMIPS : 48.00 2047 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2048 CPU implementer : 0x41 2049 CPU architecture: 8 2050 CPU variant : 0x0 2051 CPU part : 0xd03 2052 CPU revision : 4 2053 2054 processor : 2 2055 model name : ARMv8 Processor rev 4 (v8l) 2056 BogoMIPS : 48.00 2057 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2058 CPU implementer : 0x41 2059 CPU architecture: 8 2060 CPU variant : 0x0 2061 CPU part : 0xd03 2062 CPU revision : 4 2063 2064 processor : 3 2065 model name : ARMv8 Processor rev 4 (v8l) 2066 BogoMIPS : 48.00 2067 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2068 CPU implementer : 0x41 2069 CPU architecture: 8 2070 CPU variant : 0x0 2071 CPU part : 0xd03 2072 CPU revision : 4 2073 2074 2075 ### meminfo: 2076 2077 MemTotal: 3365000 kB 2078 MemFree: 3177248 kB 2079 MemAvailable: 3140904 kB 2080 Buffers: 9772 kB 2081 Cached: 51772 kB 2082 SwapCached: 0 kB 2083 Active: 51676 kB 2084 Inactive: 32716 kB 2085 Active(anon): 23252 kB 2086 Inactive(anon): 4540 kB 2087 Active(file): 28424 kB 2088 Inactive(file): 28176 kB 2089 Unevictable: 0 kB 2090 Mlocked: 0 kB 2091 SwapTotal: 1048572 kB 2092 SwapFree: 1048572 kB 2093 Dirty: 2960 kB 2094 Writeback: 248 kB 2095 AnonPages: 23268 kB 2096 Mapped: 19044 kB 2097 Shmem: 4668 kB 2098 KReclaimable: 18764 kB 2099 Slab: 53116 kB 2100 SReclaimable: 18764 kB 2101 SUnreclaim: 34352 kB 2102 KernelStack: 2936 kB 2103 PageTables: 1908 kB 2104 NFS_Unstable: 0 kB 2105 Bounce: 0 kB 2106 WritebackTmp: 0 kB 2107 CommitLimit: 2731072 kB 2108 Committed_AS: 71716 kB 2109 VmallocTotal: 135290159040 kB 2110 VmallocUsed: 21528 kB 2111 VmallocChunk: 0 kB 2112 Percpu: 1264 kB 2113 HardwareCorrupted: 0 kB 2114 AnonHugePages: 2048 kB 2115 ShmemHugePages: 0 kB 2116 ShmemPmdMapped: 0 kB 2117 FileHugePages: 0 kB 2118 FilePmdMapped: 0 kB 2119 CmaTotal: 786432 kB 2120 CmaFree: 774476 kB 2121 HugePages_Total: 0 2122 HugePages_Free: 0 2123 HugePages_Rsvd: 0 2124 HugePages_Surp: 0 2125 Hugepagesize: 2048 kB 2126 Hugetlb: 0 kB 2127 2128 ### virtual memory: 2129 2130 vm.admin_reserve_kbytes = 8192 2131 vm.block_dump = 0 2132 vm.compact_unevictable_allowed = 1 2133 vm.dirty_background_bytes = 0 2134 vm.dirty_background_ratio = 10 2135 vm.dirty_bytes = 0 2136 vm.dirty_expire_centisecs = 3000 2137 vm.dirty_ratio = 20 2138 vm.dirtytime_expire_seconds = 43200 2139 vm.dirty_writeback_centisecs = 500 2140 vm.extfrag_threshold = 500 2141 vm.hugetlb_shm_group = 0 2142 vm.laptop_mode = 0 2143 vm.legacy_va_layout = 0 2144 vm.lowmem_reserve_ratio = 256 256 32 0 2145 vm.max_map_count = 65530 2146 vm.memory_failure_early_kill = 0 2147 vm.memory_failure_recovery = 1 2148 vm.min_free_kbytes = 45056 2149 vm.mmap_min_addr = 4096 2150 vm.mmap_rnd_bits = 18 2151 vm.mmap_rnd_compat_bits = 11 2152 vm.nr_hugepages = 0 2153 vm.nr_overcommit_hugepages = 0 2154 vm.oom_dump_tasks = 1 2155 vm.oom_kill_allocating_task = 0 2156 vm.overcommit_kbytes = 0 2157 vm.overcommit_memory = 0 2158 vm.overcommit_ratio = 50 2159 vm.page-cluster = 0 2160 vm.panic_on_oom = 0 2161 vm.percpu_pagelist_fraction = 0 2162 vm.stat_interval = 1 2163 vm.swappiness = 100 2164 vm.user_reserve_kbytes = 104569 2165 vm.vfs_cache_pressure = 100 2166 vm.watermark_boost_factor = 15000 2167 vm.watermark_scale_factor = 10 2168 2169 ### ip addr: 2170 2171 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 2172 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2173 inet XXX.XXX.0.1/8 scope host lo 2174 valid_lft forever preferred_lft forever 2175 inet6 ::1/128 scope host 2176 valid_lft forever preferred_lft forever 2177 2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000 2178 link/ether 02:00:00:3c:1a:01 brd ff:ff:ff:ff:ff:ff 2179 2180 ### partitions: 2181 2182 major minor #blocks name 2183 2184 179 0 15351808 mmcblk0 2185 179 1 524288 mmcblk0p1 2186 179 2 14657616 mmcblk0p2 2187 179 32 61071360 mmcblk1 2188 254 0 51200 zram0 2189 254 1 1048576 zram1 2190 2191 ### df: 2192 2193 udev 1.3G 0 1.3G 0% /dev 2194 tmpfs 329M 4.7M 324M 2% /run 2195 /dev/mmcblk0p2 14G 3.4G 11G 25% / 2196 tmpfs 1.7G 0 1.7G 0% /dev/shm 2197 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 2198 tmpfs 1.7G 0 1.7G 0% /sys/fs/cgroup 2199 tmpfs 1.7G 0 1.7G 0% /tmp 2200 /dev/mmcblk0p1 511M 60M 452M 12% /boot 2201 /dev/zram0 49M 2.9M 43M 7% /var/log 2202 2203 ### lsblk: 2204 2205 NAME FSTYPE SIZE MOUNTPOINT UUID 2206 mmcblk0 14.7G 2207 ├─mmcblk0p1 vfat 512M /boot 32C6-D6F0 2208 └─mmcblk0p2 ext4 14G / 51979543-a283-42d1-b266-13fdadaf7d20 2209 mmcblk1 58.2G 2210 mmcblk1boot0 4M 2211 mmcblk1boot1 4M 2212 zram0 50M /var/log 2213 2214 ### zramctl: 2215 2216 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 2217 /dev/zram1 lzo 1G 4K 81B 12K 4 [SWAP] 2218 /dev/zram0 zstd 50M 132K 696B 36K 4 /var/log 2219 2220 ### mtab: 2221 2222 /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0 2223 /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 2224 /dev/mmcblk0p2 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 2225 /dev/zram0 /var/log ext4 rw,relatime,discard 0 0 2226 2227 ### mmc0:1234 info: 2228 2229 fwrev: 0x2 2230 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SA16G MODALIAS=mmc:block 2231 cid: 02544d5341313647122258026900e100 2232 rca: 0x1234 2233 csd: 400e00325b590000751f7f800a400000 2234 manfid: 0x000002 2235 ocr: 0x00200000 2236 preferred_erase_size: 4194304 2237 type: SD 2238 hwrev: 0x1 2239 date: 01/2014 2240 dsr: 0x404 2241 erase_size: 512 2242 oemid: 0x544d 2243 serial: 0x22580269 2244 ssr: 00000000040000000400900100aa1900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 2245 scr: 0235800301000000 2246 name: SA16G 2247 2248 ### mmc1:0001 info: 2249 2250 fwrev: 0xa200000000000000 2251 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=HCG8a4 MODALIAS=mmc:block 2252 cid: 90014a484347386134a24cf4a88db500 2253 rel_sectors: 0x1 2254 rca: 0x0001 2255 pre_eol_info: 0x01 2256 csd: d02701328f5903ffffffffef8a400000 2257 manfid: 0x000090 2258 ocr: 0x00200000 2259 preferred_erase_size: 4194304 2260 enhanced_area_offset: 18446744073709551594 2261 raw_rpmb_size_mult: 0x20 2262 type: MMC 2263 hwrev: 0x0 2264 date: 11/2018 2265 prv: 0xa2 2266 ffu_capable: 1 2267 dsr: 0x404 2268 erase_size: 524288 2269 life_time: 0x01 0x01 2270 enhanced_area_size: 4294967274 2271 oemid: 0x014a 2272 serial: 0x4cf4a88d 2273 cmdq_en: 0 2274 rev: 0x8 2275 name: HCG8a4 2276 2277 ### Boot system health: 2278 2279 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 2280 20:58:01: 1800MHz 0.37 37% 14% 6% 0% 15% 0% 50.0°C 0/10 2281 20:58:01: 1800MHz 0.90 82% 28% 35% 0% 17% 1% 51.7°C 0/10 2282 20:58:02: 1800MHz 0.90 75% 19% 28% 0% 25% 1% 50.0°C 0/10 2283 20:58:02: 1800MHz 0.90 76% 10% 27% 1% 35% 2% 49.7°C 0/10 2284 20:58:03: 1800MHz 0.90 20% 7% 2% 0% 10% 0% 49.1°C 0/10 2285 2286 ### lsusb: 2287 2288 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 2289 Bus 001 Device 003: ID 12cf:3003 DEXIN 2290 Bus 001 Device 002: ID 0566:3107 Monterey International Corp. Keyboard 2291 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2292 2293 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M 2294 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M 2295 |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M 2296 |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M 2297 |__ Port 2: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M 2298 2299 ### lspci: 2300 2301 2302 ### Installed packages: 2303 2304 ii armbian-buster-desktop 20.05.3 all Armbian desktop for Debian buster 2305 ii armbian-config 20.05.3 all Armbian configuration utility 2306 ii armbian-firmware 20.05.3 all Linux firmware 2307 ii hostapd 3:2.7-99~armbian5.86+1 arm64 IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator 2308 ii htop 2.2.0-3~armbian5.92+1 arm64 interactive processes viewer 2309 ii linux-base 4.6 all Linux image base package 2310 ii linux-buster-root-current-arm-64 20.05.3 arm64 Armbian tweaks for buster on arm-64 (current branch) 2311 ii linux-image-current-arm-64 20.05.3 arm64 Linux kernel, version 5.7.0-rc3-arm-64 2312 ii linux-libc-dev:arm64 4.19.98-1 arm64 Linux support headers for userspace development 2313 ii linux-u-boot-arm-64-current 20.05.3 arm64 Uboot loader 2020.04 2314 2315 ### Loaded modules: 2316 2317 Module Size Used by 2318 fuse 139264 3 2319 rfkill 40960 1 2320 zram 45056 2 2321 nls_ascii 16384 1 2322 joydev 32768 0 2323 meson_vdec 81920 0 2324 v4l2_mem2mem 45056 1 meson_vdec 2325 videobuf2_dma_contig 24576 1 meson_vdec 2326 videobuf2_memops 20480 1 videobuf2_dma_contig 2327 videobuf2_v4l2 36864 2 meson_vdec,v4l2_mem2mem 2328 panfrost 69632 0 2329 crct10dif_ce 20480 1 2330 gpu_sched 36864 1 panfrost 2331 videobuf2_common 65536 3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem 2332 ao_cec_g12a 16384 0 2333 meson_ir 16384 0 2334 rc_core 61440 2 meson_ir 2335 videodev 290816 4 meson_vdec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem 2336 dw_hdmi_cec 16384 0 2337 snd_soc_meson_g12a_tohdmitx 20480 1 2338 snd_soc_meson_axg_spdifout 20480 2 2339 meson_rng 16384 0 2340 mc 65536 4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem 2341 snd_soc_spdif_tx 16384 1 2342 display_connector 20480 0 2343 snd_soc_meson_axg_sound_card 16384 0 2344 ip_tables 32768 0 2345 x_tables 53248 1 ip_tables 2346 ipv6 630784 42 2347 nf_defrag_ipv6 24576 1 ipv6 2348 rtc_meson_vrtc 20480 1 2349 mdio_mux_meson_g12a 16384 0 2350 2351 ### Current system health: 2352 2353 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 2354 21:03:00: --- 0.02 5% 1% 2% 0% 1% 0% 47.0°C 0/10 2355 21:03:00: --- 0.02 5% 2% 0% 1% 0% 0% 46.2°C 0/10 2356 21:03:01: --- 0.02 2% 2% 0% 0% 0% 0% 46.1°C 0/10 2357 21:03:01: --- 0.02 2% 2% 0% 0% 0% 0% 46.1°C 0/10 2358 21:03:01: --- 0.02 3% 2% 0% 0% 0% 0% 46.1°C 0/10 2359 21:03:03: --- 0.10 6% 1% 2% 0% 1% 0% 51.2°C 0/10 2360 21:03:05: --- 0.10 100% 0% 99% 0% 0% 0% 50.6°C 0/10 2361 21:03:05: --- 0.10 39% 1% 37% 0% 0% 0% 47.6°C 0/10 2362 21:03:05: --- 0.10 2% 2% 0% 0% 0% 0% 47.2°C 0/10 2363 21:03:06: --- 0.10 5% 2% 0% 2% 0% 0% 47.0°C 0/10 2364 2365 ### resolv.conf 2366 2367 -rw-rw-r-- 1 root root 19 May 1 19:53 /etc/resolv.conf 2368 nameserver XXX.XXX.0.1 2369 2370 ### Current sysinfo: 2371 2372 Linux 5.7.0-rc3-arm-64 (arm-64) 05/01/2020 _aarch64_ (4 CPU) 2373 2374 avg-cpu: %user %nice %system %iowait %steal %idle 2375 3.19 0.01 1.69 1.75 0.00 93.36 2376 2377 Device tps kB_read/s kB_wrtn/s kB_read kB_wrtn 2378 ram0 0.00 0.00 0.00 0 0 2379 ram1 0.00 0.00 0.00 0 0 2380 ram2 0.00 0.00 0.00 0 0 2381 ram3 0.00 0.00 0.00 0 0 2382 ram4 0.00 0.00 0.00 0 0 2383 ram5 0.00 0.00 0.00 0 0 2384 ram6 0.00 0.00 0.00 0 0 2385 ram7 0.00 0.00 0.00 0 0 2386 ram8 0.00 0.00 0.00 0 0 2387 ram9 0.00 0.00 0.00 0 0 2388 ram10 0.00 0.00 0.00 0 0 2389 ram11 0.00 0.00 0.00 0 0 2390 ram12 0.00 0.00 0.00 0 0 2391 ram13 0.00 0.00 0.00 0 0 2392 ram14 0.00 0.00 0.00 0 0 2393 ram15 0.00 0.00 0.00 0 0 2394 mmcblk0 18.63 706.27 4.24 229510 1377 2395 mmcblk0p1 0.55 21.36 0.00 6941 1 2396 mmcblk0p2 17.62 675.22 4.23 219421 1376 2397 mmcblk1 0.46 9.65 0.00 3136 0 2398 mmcblk1boot1 0.18 0.71 0.00 232 0 2399 mmcblk1boot0 0.18 0.71 0.00 232 0 2400 zram0 3.31 2.24 10.98 728 3568 2401 zram1 0.91 3.62 0.01 1176 4 2402 zram2 0.00 0.00 0.00 0 0 2403 2404 procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- 2405 r b swpd free buff cache si so bi bo in cs us sy id wa st 2406 1 0 0 2705520 18968 238360 0 0 179 4 75 119 3 2 93 2 0 2407 2408 total used free shared buff/cache available 2409 Mem: 3.2Gi 392Mi 2.6Gi 7.0Mi 251Mi 2.7Gi 2410 Swap: 1.0Gi 0B 1.0Gi 2411 2412 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 2413 /dev/zram1 lzo 1G 4K 81B 12K 4 [SWAP] 2414 /dev/zram0 zstd 50M 3.2M 518K 880K 4 /var/log 2415 2416 21:03:06 up 5 min, 1 user, load average: 0.10, 0.16, 0.09 2417 2418 [ 1.938955] Key type cifs.spnego registered 2419 [ 1.938975] Key type cifs.idmap registered 2420 [ 1.938991] ntfs: driver 2.1.32 [Flags: R/W]. 2421 [ 1.939531] JFS: nTxBlock = 8192, nTxLock = 65536 2422 [ 1.943456] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled 2423 [ 1.945060] ocfs2: Registered cluster interface o2cb 2424 [ 1.945214] OCFS2 User DLM kernel interface loaded 2425 [ 1.946609] gfs2: GFS2 installed 2426 [ 1.966550] NET: Registered protocol family 38 2427 [ 1.966582] Key type asymmetric registered 2428 [ 1.966593] Asymmetric key parser 'x509' registered 2429 [ 1.966604] Asymmetric key parser 'pkcs8' registered 2430 [ 1.966672] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) 2431 [ 1.966860] io scheduler mq-deadline registered 2432 [ 1.966873] io scheduler kyber registered 2433 [ 1.967046] io scheduler bfq registered 2434 [ 1.980914] soc soc0: Amlogic Meson G12A (S905X2) Revision 28:b (40:2) Detected 2435 [ 1.982346] pwm-regulator: supplied by regulator-dummy 2436 [ 1.982535] VCC_3V3: supplied by VDDAO_3V3 2437 [ 1.982605] FLASH_1V8: supplied by VCC_3V3 2438 [ 1.982655] VCC_1V8: supplied by VCC_3V3 2439 [ 1.982705] VDDAO_1V8: supplied by VDDAO_3V3 2440 [ 1.985671] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled 2441 [ 1.987369] Serial: AMBA driver 2442 [ 1.987683] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 14, base_baud = 1500000) is a meson_uart 2443 [ 2.959517] printk: console [ttyAML0] enabled 2444 [ 2.974937] brd: module loaded 2445 [ 2.982002] loop: module loaded 2446 [ 2.986131] libphy: Fixed MDIO Bus: probed 2447 [ 2.987572] VFIO - User Level meta-driver version: 0.3 2448 [ 2.990928] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 2449 [ 2.996182] ehci-pci: EHCI PCI platform driver 2450 [ 3.000602] ehci-platform: EHCI generic platform driver 2451 [ 3.005871] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 2452 [ 3.011875] ohci-pci: OHCI PCI platform driver 2453 [ 3.016296] ohci-platform: OHCI generic platform driver 2454 [ 3.021867] usbcore: registered new interface driver usb-storage 2455 [ 3.027557] mousedev: PS/2 mouse device common for all mice 2456 [ 3.033640] i2c /dev entries driver 2457 [ 3.043055] sdhci: Secure Digital Host Controller Interface driver 2458 [ 3.043598] sdhci: Copyright(c) Pierre Ossman 2459 [ 3.047953] Synopsys Designware Multimedia Card Interface Driver 2460 [ 3.054536] meson-gx-mmc ffe05000.sd: Got CD GPIO 2461 [ 3.093347] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 2462 [ 3.127941] sdhci-pltfm: SDHCI platform and OF driver helper 2463 [ 3.128735] mmc0: new high speed SDHC card at address 1234 2464 [ 3.135921] ledtrig-cpu: registered to indicate activity on CPUs 2465 [ 3.137130] mmcblk0: mmc0:1234 SA16G 14.6 GiB 2466 [ 3.140069] meson-sm: secure-monitor enabled 2467 [ 3.146305] mmcblk0: p1 p2 2468 [ 3.148405] hid: raw HID events driver (C) Jiri Kosina 2469 [ 3.156017] usbcore: registered new interface driver usbhid 2470 [ 3.161405] usbhid: USB HID core driver 2471 [ 3.167526] no UART detected at 0x1 2472 [ 3.171468] NET: Registered protocol family 17 2473 [ 3.173224] Key type dns_resolver registered 2474 [ 3.177665] registered taskstats version 1 2475 [ 3.181332] Loading compiled-in X.509 certificates 2476 [ 3.186158] zswap: loaded using pool lzo/zbud 2477 [ 3.190626] Key type ._fscrypt registered 2478 [ 3.194385] Key type .fscrypt registered 2479 [ 3.198232] Key type fscrypt-provisioning registered 2480 [ 3.203803] Btrfs loaded, crc32c=crc32c-generic 2481 [ 3.228116] Key type encrypted registered 2482 [ 3.240173] mmc1: new HS200 MMC card at address 0001 2483 [ 3.241051] mmcblk1: mmc1:0001 HCG8a4 58.2 GiB 2484 [ 3.244466] mmcblk1boot0: mmc1:0001 HCG8a4 partition 1 4.00 MiB 2485 [ 3.248275] VCC_5V: supplied by 12V 2486 [ 3.250365] mmcblk1boot1: mmc1:0001 HCG8a4 partition 2 4.00 MiB 2487 [ 3.259398] mmcblk1rpmb: mmc1:0001 HCG8a4 partition 3 4.00 MiB, chardev (241:0) 2488 [ 3.312273] meson-drm ff900000.vpu: Queued 3 outputs on vpu 2489 [ 3.312500] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). 2490 [ 3.346835] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 2491 [ 3.351288] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 2492 [ 3.359293] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops) 2493 [ 3.366604] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 2494 [ 3.456961] random: fast init done 2495 [ 3.502339] [drm] kms: can't enable cloning when we probably wanted to. 2496 [ 3.656005] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 2497 [ 3.656030] meson-dw-hdmi ff600000.hdmi-tx: colorspace: YCbCr 4:2:2 2498 [ 3.656049] meson-dw-hdmi ff600000.hdmi-tx: scan mode: Underscan 2499 [ 3.656068] meson-dw-hdmi ff600000.hdmi-tx: colorimetry: ITU709 2500 [ 3.656086] meson-dw-hdmi ff600000.hdmi-tx: picture aspect: 16:9 2501 [ 3.656105] meson-dw-hdmi ff600000.hdmi-tx: active aspect: Same as Picture 2502 [ 3.656122] meson-dw-hdmi ff600000.hdmi-tx: itc: No Data 2503 [ 3.656141] meson-dw-hdmi ff600000.hdmi-tx: extended colorimetry: xvYCC 709 2504 [ 3.656159] meson-dw-hdmi ff600000.hdmi-tx: quantization range: Default 2505 [ 3.656177] meson-dw-hdmi ff600000.hdmi-tx: nups: Unknown Non-uniform Scaling 2506 [ 3.656195] meson-dw-hdmi ff600000.hdmi-tx: video code: 16 2507 [ 3.656213] meson-dw-hdmi ff600000.hdmi-tx: ycc quantization range: Limited 2508 [ 3.656231] meson-dw-hdmi ff600000.hdmi-tx: hdmi content type: Graphics 2509 [ 3.656249] meson-dw-hdmi ff600000.hdmi-tx: pixel repeat: 0 2510 [ 3.656271] meson-dw-hdmi ff600000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 2511 [ 3.656321] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 2512 [ 3.656339] meson-dw-hdmi ff600000.hdmi-tx: vendor: DW 2513 [ 3.656357] meson-dw-hdmi ff600000.hdmi-tx: product: HDMI 2514 [ 3.656377] meson-dw-hdmi ff600000.hdmi-tx: source device information: PC General (0x9) 2515 [ 3.988267] Console: switching to colour frame buffer device 240x67 2516 [ 4.139534] meson-drm ff900000.vpu: fb0: mesondrmfb frame buffer device 2517 [ 4.146670] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 2518 [ 4.152648] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 2519 [ 4.158843] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 2520 [ 4.164720] meson8b-dwmac ff3f0000.ethernet: no reset control found 2521 [ 4.171587] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 2522 [ 4.178007] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 2523 [ 4.183177] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 2524 [ 4.190591] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 2525 [ 4.198009] meson8b-dwmac ff3f0000.ethernet: COE Type 2 2526 [ 4.203183] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 2527 [ 4.210170] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 2528 [ 4.216574] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 2529 [ 4.222418] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 2530 [ 4.228196] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 2531 [ 4.236403] libphy: stmmac: probed 2532 [ 4.240300] USB_PWR_EN: supplied by VCC_5V 2533 [ 4.243664] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 2534 [ 4.248727] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 2535 [ 4.256761] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 2536 [ 4.261469] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 2537 [ 4.268672] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 2538 [ 4.276432] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller 2539 [ 4.280954] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 2540 [ 4.288617] xhci-hcd xhci-hcd.3.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 2541 [ 4.297861] xhci-hcd xhci-hcd.3.auto: irq 29, io mem 0xff500000 2542 [ 4.303922] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07 2543 [ 4.311887] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2544 [ 4.319046] usb usb1: Product: xHCI Host Controller 2545 [ 4.323886] usb usb1: Manufacturer: Linux 5.7.0-rc3-arm-64 xhci-hcd 2546 [ 4.323889] usb usb1: SerialNumber: xhci-hcd.3.auto 2547 [ 4.324237] hub 1-0:1.0: USB hub found 2548 [ 4.338632] hub 1-0:1.0: 2 ports detected 2549 [ 4.342805] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller 2550 [ 4.348030] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2 2551 [ 4.355622] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed 2552 [ 4.362117] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 2553 [ 4.370171] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07 2554 [ 4.378302] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2555 [ 4.385458] usb usb2: Product: xHCI Host Controller 2556 [ 4.390286] usb usb2: Manufacturer: Linux 5.7.0-rc3-arm-64 xhci-hcd 2557 [ 4.396497] usb usb2: SerialNumber: xhci-hcd.3.auto 2558 [ 4.401585] hub 2-0:1.0: USB hub found 2559 [ 4.405049] hub 2-0:1.0: 1 port detected 2560 [ 4.411829] printk: console [netcon0] enabled 2561 [ 4.414852] netconsole: network logging started 2562 [ 4.418394] ALSA device list: 2563 [ 4.421382] No soundcards found. 2564 [ 4.426637] Freeing unused kernel memory: 3904K 2565 [ 4.430562] Run /init as init process 2566 [ 4.435146] with arguments: 2567 [ 4.435149] /init 2568 [ 4.435151] with environment: 2569 [ 4.435153] HOME=/ 2570 [ 4.435154] TERM=linux 2571 [ 4.435156] mac=68:1d:ef:18:55:41 2572 [ 4.674856] usb 1-1: new low-speed USB device number 2 using xhci-hcd 2573 [ 4.695002] libphy: mdio_mux: probed 2574 [ 4.698326] libphy: mdio_mux: probed 2575 [ 4.703084] meson-vrtc ff8000a8.rtc: registered as rtc0 2576 [ 4.706252] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4) 2577 [ 4.838000] usb 1-1: New USB device found, idVendor=0566, idProduct=3107, bcdDevice= 4.03 2578 [ 4.843834] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 2579 [ 4.850894] usb 1-1: Product: USB Keyboard 2580 [ 4.854955] usb 1-1: Manufacturer: 2581 [ 4.891110] input: USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1:1.0/0003:0566:3107.0001/input/input0 2582 [ 4.972247] hid-generic 0003:0566:3107.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-xhci-hcd.3.auto-1/input0 2583 [ 4.992196] input: USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1:1.1/0003:0566:3107.0002/input/input1 2584 [ 5.063081] input: USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1:1.1/0003:0566:3107.0002/input/input2 2585 [ 5.078218] hid-generic 0003:0566:3107.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-xhci-hcd.3.auto-1/input1 2586 [ 5.215239] usb 1-2: new low-speed USB device number 3 using xhci-hcd 2587 [ 5.439429] usb 1-2: New USB device found, idVendor=12cf, idProduct=3003, bcdDevice= 1.10 2588 [ 5.509160] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 2589 [ 5.577825] usb 1-2: Product: 2.4GHz Wireless Mouse 2590 [ 5.645084] usb 1-2: Manufacturer: Dexin Corp. sysctl: permission denied on key 'vm.mmap_rnd_bits' sysctl: permission denied on key 'vm.mmap_rnd_compat_bits' sysctl: permission denied on key 'vm.stat_refresh' 2591 [ 5.740345] input: Dexin Corp. 2.4GHz Wireless Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2:1.0/0003:12CF:3003.0003/input/input3 2592 [ 5.768383] hid-generic 0003:12CF:3003.0003: input,hidraw2: USB HID v1.10 Mouse [Dexin Corp. 2.4GHz Wireless Mouse] on usb-xhci-hcd.3.auto-2/input0 2593 [ 6.315435] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback 2594 [ 7.202705] systemd[1]: System time before build time, advancing clock. 2595 [ 7.377583] NET: Registered protocol family 10 2596 [ 7.448524] Segment Routing with IPv6 2597 [ 7.497909] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 2598 [ 7.534687] systemd[1]: Detected architecture arm64. 2599 [ 7.595171] systemd[1]: Set hostname to <arm-64>. 2600 [ 8.214669] random: systemd: uninitialized urandom read (16 bytes read) 2601 [ 8.230286] random: systemd: uninitialized urandom read (16 bytes read) 2602 [ 8.237513] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. 2603 [ 8.251599] random: systemd: uninitialized urandom read (16 bytes read) 2604 [ 8.257710] systemd[1]: Listening on Journal Audit Socket. 2605 [ 8.267864] systemd[1]: Reached target Swap. 2606 [ 8.277625] systemd[1]: Reached target Remote File Systems. 2607 [ 8.287679] systemd[1]: Listening on initctl Compatibility Named Pipe. 2608 [ 8.298760] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 2609 [ 8.310922] systemd[1]: Reached target Local Encrypted Volumes. 2610 [ 8.499410] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro 2611 [ 9.174834] mc: Linux media interface: v0.10 2612 [ 9.200980] axg-sound-card sound: snd-soc-dummy-dai <-> ff6421c0.audio-controller mapping ok 2613 [ 9.201783] axg-sound-card sound: snd-soc-dummy-dai <-> ff642200.audio-controller mapping ok 2614 [ 9.202448] axg-sound-card sound: snd-soc-dummy-dai <-> ff642240.audio-controller mapping ok 2615 [ 9.202988] axg-sound-card sound: I2S IN B <-> TDM Pad mapping ok 2616 [ 9.203003] axg-sound-card sound: snd-soc-dummy-dai <-> TDM Loopback mapping ok 2617 [ 9.203015] axg-sound-card sound: multicodec <-> ff642480.audio-controller mapping ok 2618 [ 9.203026] axg-sound-card sound: SPDIF IN B <-> ff642680.audio-controller mapping ok 2619 [ 9.203050] axg-sound-card sound: i2s-hifi <-> I2S OUT mapping ok 2620 [ 9.203183] axg-sound-card sound: ASoC: no DMI vendor name! 2621 [ 9.218902] videodev: Linux video capture interface: v2.00 2622 [ 9.233895] Registered IR keymap rc-empty 2623 [ 9.233979] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 2624 [ 9.234101] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 2625 [ 9.234191] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 2626 [ 9.234543] meson-ir ff808000.ir: receiver initialized 2627 [ 9.253269] debugfs: Directory 'ff800280.cec' with parent 'regmap' already present! 2628 [ 9.291364] panfrost ffe40000.gpu: clock rate = 799999987 2629 [ 9.291398] panfrost ffe40000.gpu: supply mali not found, using dummy regulator 2630 [ 9.292837] panfrost ffe40000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0 2631 [ 9.292844] panfrost ffe40000.gpu: features: 00000000,3fde77ff, issues: 00000000,00000400 2632 [ 9.292849] panfrost ffe40000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7 2633 [ 9.292852] panfrost ffe40000.gpu: shader_present=0x1 l2_present=0x1 2634 [ 9.295427] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 2635 [ 9.446486] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 2636 [ 10.677386] zram: Added device: zram0 2637 [ 10.679851] zram: Added device: zram1 2638 [ 10.681164] zram: Added device: zram2 2639 [ 10.726196] zram1: detected capacity change from 0 to 1073741824 2640 [ 10.807605] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.1:08] driver [Meson G12A Internal PHY] (irq=30) 2641 [ 10.822857] meson8b-dwmac ff3f0000.ethernet eth0: No Safety Features support found 2642 [ 10.822876] meson8b-dwmac ff3f0000.ethernet eth0: PTP not supported by HW 2643 [ 10.822892] meson8b-dwmac ff3f0000.ethernet eth0: configuring for phy/rmii link mode 2644 [ 11.802857] Adding 1048572k swap on /dev/zram1. Priority:5 extents:1 across:1048572k SSFS 2645 [ 12.005180] zram0: detected capacity change from 0 to 52428800 2646 [ 13.548148] [drm] kms: can't enable cloning when we probably wanted to. 2647 [ 14.090063] systemd[1]: Started Armbian ZRAM config. 2648 [ 14.101050] systemd[1]: Starting Armbian memory supported logging... 2649 [ 14.167763] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 2650 [ 14.167796] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 2651 [ 16.057796] systemd[1]: Started Armbian memory supported logging. 2652 [ 16.064936] systemd[1]: Starting Journal Service... 2653 [ 16.165896] systemd[1]: Started Journal Service. 2654 [ 16.202396] systemd-journald[741]: Received request to flush runtime journal from PID 1 2655 [ 16.974024] random: crng init done 2656 [ 16.974032] random: 7 urandom warning(s) missed due to ratelimiting 2657 [ 21.339985] broken atomic modeset userspace detected, disabling atomic 2658 [ 27.444988] hdmi-audio-codec hdmi-audio-codec.1.auto: Not able to map channels to speakers (-22) 2659 [ 27.444996] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: can't set i2s-hifi hw params: -22 2660 [ 27.445002] axg-sound-card sound: ASoC: PRE_PMU: be.dai-link-6-playback event failed: -22 2661 [ 27.533316] fuse: init (API version 7.31) 2662 [ 29.309822] hdmi-audio-codec hdmi-audio-codec.1.auto: Not able to map channels to speakers (-22) 2663 [ 29.309831] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: can't set i2s-hifi hw params: -22 2664 [ 29.309838] axg-sound-card sound: ASoC: PRE_PMU: be.dai-link-6-playback event failed: -22 2665 [ 29.344387] hdmi-audio-codec hdmi-audio-codec.1.auto: Not able to map channels to speakers (-22) 2666 [ 29.344395] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: can't set i2s-hifi hw params: -22 2667 [ 29.344401] axg-sound-card sound: ASoC: PRE_PMU: be.dai-link-6-playback event failed: -22 2668 2669 2670 vm.admin_reserve_kbytes = 8192 2671 vm.block_dump = 0 2672 vm.compact_unevictable_allowed = 1 2673 vm.dirty_background_bytes = 0 2674 vm.dirty_background_ratio = 10 2675 vm.dirty_bytes = 0 2676 vm.dirty_expire_centisecs = 3000 2677 vm.dirty_ratio = 20 2678 vm.dirtytime_expire_seconds = 43200 2679 vm.dirty_writeback_centisecs = 500 2680 vm.extfrag_threshold = 500 2681 vm.hugetlb_shm_group = 0 2682 vm.laptop_mode = 0 2683 vm.legacy_va_layout = 0 2684 vm.lowmem_reserve_ratio = 256 256 32 0 2685 vm.max_map_count = 65530 2686 vm.memory_failure_early_kill = 0 2687 vm.memory_failure_recovery = 1 2688 vm.min_free_kbytes = 45056 2689 vm.mmap_min_addr = 4096 2690 vm.nr_hugepages = 0 2691 vm.nr_overcommit_hugepages = 0 2692 vm.oom_dump_tasks = 1 2693 vm.oom_kill_allocating_task = 0 2694 vm.overcommit_kbytes = 0 2695 vm.overcommit_memory = 0 2696 vm.overcommit_ratio = 50 2697 vm.page-cluster = 0 2698 vm.panic_on_oom = 0 2699 vm.percpu_pagelist_fraction = 0 2700 vm.stat_interval = 1 2701 vm.swappiness = 100 2702 vm.user_reserve_kbytes = 104569 2703 vm.vfs_cache_pressure = 100 2704 vm.watermark_boost_factor = 15000 2705 vm.watermark_scale_factor = 10 2706 2707 ### interrupts: 2708 CPU0 CPU1 CPU2 CPU3 2709 3: 7938 7916 8624 8688 GICv2 30 Level arch_timer 2710 6: 0 0 0 0 GICv2 40 Level eth0 2711 7: 257 0 0 0 GICv2 89 Edge dw_hdmi_top_irq, ff600000.hdmi-tx, dw-hdmi-cec 2712 10: 210 0 0 0 GICv2 184 Edge 2713 13: 0 0 0 0 GICv2 235 Edge ff800280.cec 2714 14: 12 0 0 0 GICv2 225 Edge ttyAML0 2715 15: 0 0 0 0 GICv2 228 Edge ff808000.ir 2716 16: 0 0 0 0 GICv2 76 Edge vdec 2717 17: 0 0 0 0 GICv2 64 Edge esparserirq 2718 18: 1348 0 0 0 GICv2 35 Edge meson 2719 19: 0 0 0 0 GICv2 71 Edge ffd1c000.i2c 2720 20: 0 0 0 0 GICv2 247 Edge ffd1d000.i2c 2721 21: 0 0 0 0 GICv2 53 Edge ffd1f000.i2c 2722 22: 12575 0 0 0 GICv2 222 Edge ffe05000.sd 2723 23: 738 0 0 0 GICv2 223 Edge ffe07000.mmc 2724 24: 0 0 0 0 GICv2 48 Level ffe09000.usb 2725 25: 0 0 0 0 GICv2 194 Level panfrost-job 2726 26: 0 0 0 0 GICv2 193 Level panfrost-mmu 2727 27: 6 0 0 0 GICv2 192 Level panfrost-gpu 2728 28: 0 0 0 0 GICv2 63 Level ff400000.usb, ff400000.usb 2729 29: 1732 0 0 0 GICv2 62 Level xhci-hcd:usb1 2730 30: 0 0 0 0 GICv2 41 Level 0.1:08 2731 IPI0: 10671 13630 12234 9441 Rescheduling interrupts 2732 IPI1: 572 393 487 607 Function call interrupts 2733 IPI2: 0 0 0 0 CPU stop interrupts 2734 IPI3: 0 0 0 0 CPU stop (for crash dump) interrupts 2735 IPI4: 0 0 0 0 Timer broadcast interrupts 2736 IPI5: 738 346 299 392 IRQ work interrupts 2737 IPI6: 0 0 0 0 CPU wake-up interrupts 2738 Err: 0 Please upload the whole output above to an online pasteboard service and provide the URL in the forum where you have been asked for this. name28@arm-64:~$ Thank you for help! Best regards,
Werner Posted May 16, 2020 Posted May 16, 2020 Nope. The output of armbianmonitor -u seems incomplete too.
chewitt Posted June 7, 2020 Posted June 7, 2020 Linux 5.7 has support for MT7668 Bluetooth, but not WiFi, and the Linux 4.9 (Android) driver that can be found in a few places does not compile on recent kernels. I suck at forward porting but might have a look into it as there are a few S905X2/X3 devices with this chip. The firmware was upstreamed to the kernel back in 2018, but no drivers yet.
