gtj Posted May 4, 2020 Posted May 4, 2020 Hello, I've been trying to install Raspotify on my NeoPlus2. While it seems to be install OK, I can't find my device available in the list of Spotify-connect capable devices. journalctl -u raspotify reports: gtj@nanopineoplus2:~$ journalctl -u raspotify -- Logs begin at Mon 2020-05-04 02:26:25 UTC, end at Mon 2020-05-04 02:43:52 UTC May 04 02:26:32 nanopineoplus2 systemd[1]: Starting Raspotify... May 04 02:26:32 nanopineoplus2 systemd[1]: Started Raspotify. May 04 02:26:32 nanopineoplus2 librespot[963]: [2020-05-04T02:26:32Z INFO libre May 04 02:26:33 nanopineoplus2 librespot[963]: thread 'main' panicked at 'called May 04 02:26:33 nanopineoplus2 librespot[963]: stack backtrace: May 04 02:26:33 nanopineoplus2 librespot[963]: 0: 0x10b13a4 - backtrace::bac May 04 02:26:33 nanopineoplus2 librespot[963]: at /cargo/ May 04 02:26:33 nanopineoplus2 librespot[963]: 1: 0x10b13a4 - backtrace::bac May 04 02:26:33 nanopineoplus2 librespot[963]: at /cargo/ May 04 02:26:33 nanopineoplus2 librespot[963]: 2: 0x10b13a4 - std::sys_commo May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 3: 0x10b13a4 - <std::sys_comm May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 4: 0x10d3ca4 - core::fmt::wri May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 5: 0x10abff0 - std::io::Write May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 6: 0x10b3954 - std::sys_commo May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 7: 0x10b3954 - std::sys_commo May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 8: 0x10b3954 - std::panicking lines 1-23...skipping... -- Logs begin at Mon 2020-05-04 02:26:25 UTC, end at Mon 2020-05-04 02:43:52 UTC. -- May 04 02:26:32 nanopineoplus2 systemd[1]: Starting Raspotify... May 04 02:26:32 nanopineoplus2 systemd[1]: Started Raspotify. May 04 02:26:32 nanopineoplus2 librespot[963]: [2020-05-04T02:26:32Z INFO librespot] librespot (raspotify v0.14.0) 3672214 (2020-01-30). Built on 2020-02-16. May 04 02:26:33 nanopineoplus2 librespot[963]: thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: Os { code: 19, kind: Other, message: "N May 04 02:26:33 nanopineoplus2 librespot[963]: stack backtrace: May 04 02:26:33 nanopineoplus2 librespot[963]: 0: 0x10b13a4 - backtrace::backtrace::libunwind::trace::hb1e9954dcc6e7c1f May 04 02:26:33 nanopineoplus2 librespot[963]: at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.40/src/backtrace/libunw May 04 02:26:33 nanopineoplus2 librespot[963]: 1: 0x10b13a4 - backtrace::backtrace::trace_unsynchronized::h1b198a73034a9734 May 04 02:26:33 nanopineoplus2 librespot[963]: at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.40/src/backtrace/mod.rs May 04 02:26:33 nanopineoplus2 librespot[963]: 2: 0x10b13a4 - std::sys_common::backtrace::_print_fmt::hf691518b63d0b79d May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/sys_common/backtrace.rs:84 May 04 02:26:33 nanopineoplus2 librespot[963]: 3: 0x10b13a4 - <std::sys_common::backtrace::_print::DisplayBacktrace as core::fmt::Display>::fmt::he6a16924 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/sys_common/backtrace.rs:61 May 04 02:26:33 nanopineoplus2 librespot[963]: 4: 0x10d3ca4 - core::fmt::write::hc426988e4c4119a8 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libcore/fmt/mod.rs:1025 May 04 02:26:33 nanopineoplus2 librespot[963]: 5: 0x10abff0 - std::io::Write::write_fmt::h34e90dde595ba7cd May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/io/mod.rs:1426 May 04 02:26:33 nanopineoplus2 librespot[963]: 6: 0x10b3954 - std::sys_common::backtrace::_print::h406863a8800396cd May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/sys_common/backtrace.rs:65 May 04 02:26:33 nanopineoplus2 librespot[963]: 7: 0x10b3954 - std::sys_common::backtrace::print::hec570bc9fdd6a536 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/sys_common/backtrace.rs:50 May 04 02:26:33 nanopineoplus2 librespot[963]: 8: 0x10b3954 - std::panicking::default_hook::{{closure}}::hf187be78db8e291b May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:193 May 04 02:26:33 nanopineoplus2 librespot[963]: 9: 0x10b35b4 - std::panicking::default_hook::h9634e45fc0d61ba6 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:210 May 04 02:26:33 nanopineoplus2 librespot[963]: 10: 0x10b4030 - std::panicking::rust_panic_with_hook::h35923fdea5783220 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:471 May 04 02:26:33 nanopineoplus2 librespot[963]: 11: 0x10b3c48 - rust_begin_unwind May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:375 May 04 02:26:33 nanopineoplus2 librespot[963]: 12: 0x10cfac0 - core::panicking::panic_fmt::hd74e307162bc16e5 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libcore/panicking.rs:84 May 04 02:26:33 nanopineoplus2 librespot[963]: 13: 0x10cfbac - core::result::unwrap_failed::h36f73057b442c0eb May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libcore/result.rs:1188 May 04 02:26:33 nanopineoplus2 librespot[963]: 14: 0xbeb5e0 - librespot::main::h0ed06a728ac2479f May 04 02:26:33 nanopineoplus2 librespot[963]: 15: 0xbec980 - std::rt::lang_start::{{closure}}::h3ecc962e3fb4564b May 04 02:26:33 nanopineoplus2 librespot[963]: 16: 0x10b3ac4 - std::rt::lang_start_internal::{{closure}}::hc02935a73664ebd0 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/rt.rs:52 May 04 02:26:33 nanopineoplus2 librespot[963]: 17: 0x10b3ac4 - std::panicking::try::do_call::h9ca5184b6b3cc62d May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:292 May 04 02:26:33 nanopineoplus2 librespot[963]: 18: 0x10bb220 - __rust_maybe_catch_panic May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libpanic_unwind/lib.rs:78 May 04 02:26:33 nanopineoplus2 librespot[963]: 19: 0x10b4484 - std::panicking::try::hc53e4a11b02f3299 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:270 May 04 02:26:33 nanopineoplus2 librespot[963]: 20: 0x10b4484 - std::panic::catch_unwind::ha972c7f8a413a94c May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panic.rs:394 May 04 02:26:33 nanopineoplus2 librespot[963]: 21: 0x10b4484 - std::rt::lang_start_internal::hdf6cc497202d2594 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/rt.rs:51 systemctl status raspotify reports: ● raspotify.service - Raspotify Loaded: loaded (/lib/systemd/system/raspotify.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-05-04 02:43:10 UTC; 7min ago Main PID: 2278 (librespot) Tasks: 3 (limit: 1022) Memory: 840.0K CGroup: /system.slice/raspotify.service └─2278 /usr/bin/librespot --name raspotify --backend alsa --bitrate 320 --disable-audio-cache --enable-volume-normalisation --linear-volume --initi May 04 02:43:10 nanopineoplus2 systemd[1]: Starting Raspotify... May 04 02:43:10 nanopineoplus2 systemd[1]: Started Raspotify. May 04 02:43:10 nanopineoplus2 librespot[2278]: [2020-05-04T02:43:10Z INFO librespot] librespot (raspotify v0.14.0) 3672214 (2020-01-30). Built on 2020-02-16 gtj@nanopineoplus2:~$ apt update Reading package lists... Done E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied) E: Unable to lock directory /var/lib/apt/lists/ W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied) W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied) gtj@nanopineoplus2:~$ sudo apt update Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://httpredir.debian.org/debian buster InRelease Get:3 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB] Get:5 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB] Hit:4 https://apt.armbian.com buster InRelease Get:6 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB] Get:7 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB] Get:8 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB] Get:9 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB] Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-04-0201.50.pdiff [860 B] Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-04-0201.50.pdiff [860 B] Get:12 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-04-0201.50.pdiff [265 B] Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-04-0201.50.pdiff [860 B] Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-04-0201.50.pdiff [860 B] Get:12 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-04-0201.50.pdiff [265 B] Get:13 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-04-0201.50.pdiff [264 B] Get:13 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-04-0201.50.pdiff [264 B] Fetched 210 kB in 13s (16.5 kB/s) ^C gtj@nanopineoplus2:~$ Traceback (most recent call last): File "/usr/lib/cnf-update-db", line 26, in <module> col.create(db) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 94, in create self._fill_commands(con) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 132, in _fill_commands self._parse_single_contents_file(con, f, fp.stdout) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 230, in _parse_single_contents_file l.startswith('bin') or l.startswith('sbin')): KeyboardInterrupt and finally systemctl status raspotify reports: ● raspotify.service - Raspotify Loaded: loaded (/lib/systemd/system/raspotify.service; enabled; vendor preset Active: activating (auto-restart) (Result: exit-code) since Mon 2020-05-04 03 Process: 3005 ExecStartPre=/bin/mkdir -m 0755 -p /var/cache/raspotify (code=ex Process: 3006 ExecStartPre=/bin/chown raspotify:raspotify /var/cache/raspotify Process: 3008 ExecStart=/usr/bin/librespot --name ${DEVICE_NAME} $BACKEND_ARGS Main PID: 3008 (code=exited, status=1/FAILURE) May 04 03:05:38 nanopineoplus2 librespot[3008]: uses. May 04 03:05:38 nanopineoplus2 librespot[3008]: --enable-volume-normalis May 04 03:05:38 nanopineoplus2 librespot[3008]: Play all May 04 03:05:38 nanopineoplus2 librespot[3008]: --normalisation-pregain May 04 03:05:38 nanopineoplus2 librespot[3008]: Pregain May 04 03:05:38 nanopineoplus2 librespot[3008]: --linear-volume May 04 03:05:38 nanopineoplus2 librespot[3008]: increase May 04 03:05:38 nanopineoplus2 librespot[3008]: --autoplay autoplay May 04 03:05:38 nanopineoplus2 systemd[1]: raspotify.service: Main process exite May 04 03:05:38 nanopineoplus2 systemd[1]: raspotify.service: Failed with result lines 1-18/18 (END) ● raspotify.service - Raspotify Loaded: loaded (/lib/systemd/system/raspotify.service; enabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Mon 2020-05-04 03:05:38 UTC; 32ms ago Process: 3005 ExecStartPre=/bin/mkdir -m 0755 -p /var/cache/raspotify (code=exited, status=0/SUCCESS) Process: 3006 ExecStartPre=/bin/chown raspotify:raspotify /var/cache/raspotify (code=exited, status=0/SU Process: 3008 ExecStart=/usr/bin/librespot --name ${DEVICE_NAME} $BACKEND_ARGS --bitrate ${BITRATE} $CAC Main PID: 3008 (code=exited, status=1/FAILURE) May 04 03:05:38 nanopineoplus2 librespot[3008]: uses. May 04 03:05:38 nanopineoplus2 librespot[3008]: --enable-volume-normalisation May 04 03:05:38 nanopineoplus2 librespot[3008]: Play all tracks at the same volume May 04 03:05:38 nanopineoplus2 librespot[3008]: --normalisation-pregain PREGAIN May 04 03:05:38 nanopineoplus2 librespot[3008]: Pregain (dB) applied by volume nor May 04 03:05:38 nanopineoplus2 librespot[3008]: --linear-volume May 04 03:05:38 nanopineoplus2 librespot[3008]: increase volume linear instead of May 04 03:05:38 nanopineoplus2 librespot[3008]: --autoplay autoplay similar songs when your m May 04 03:05:38 nanopineoplus2 systemd[1]: raspotify.service: Main process exited, code=exited, status=1/F May 04 03:05:38 nanopineoplus2 systemd[1]: raspotify.service: Failed with result 'exit-code'. Any help with this will be greatly appreciated!
Tido Posted May 4, 2020 Posted May 4, 2020 Your post may need more formatting changes. Tips: use spoiler when adding a long text, use when adding a code, 2 hours ago, gtj said: trying to install Raspotify You don't mention how you did that, or what steps you have taken ? By the way, I just heard about that one: : ncspot – ncurses spotify music client
Igor Posted May 4, 2020 Posted May 4, 2020 4 hours ago, gtj said: Raspotify For debugging application you need to contact Raspotify authors and show them logs - we don't know how this software works. We can help you around Armbian. Does this SW needs active sound card? What is your sound hardware? Is it operational? We only look into those logs: armbianmonitor -u aplay -l
