Hi all,
First place, sorry if it´s a very basic question, I was searching info and reading topics, but I did not found a solution for my problem.
I`m working with Linux version 5.4.29-sunxi
I´m trying to compile my own char device driver. I noticed that I forgot adding kernel-headers in my build, so I tried to add them via
apt install linux-headers-next-sunxi
After that, I can see a new directory
/usr/src/linux-headers-4.19.62-sunxi
but if I´m not wrong, modules compiled with this headers won´t work in my kernel, cause headers version does not match with my kernel version.
So, could please someone give me a hint about getting correct header version, or if I´m completelly wrong?
Many thanks in advances
Grettings
Mariano
"next" does not exist anymore. It has been replaced with "current".
But regardless you can use armbian-config to install kernel headers
Wow Werner, that was fast!
I´ll try it now, and let you know the result.
Many thanks!!!
Werner, kernel header update worked like a charm. I tried both ways
  • armbian-config -> Software -> Headers_install
  • apt install linux-headers-current-sunxi
So, I´m wondering if there is a way to just install headers that match current target´s kernel version if kernel version is not the last stable.
In my case, after installing headers I had to upgrade kernel to 5.4.35, no problem at all, but I guess sometimes we might want to keep kernel version unchanged.
One more time, thank you very much!
No, we don't have all older matched kernels and headers.
We started to pay attention recently, after headers and DKMS process were improved ... and we are working on to improve CI processes. In case you have know-how and some time, you are welcome to help. We are drowning in work. https://armbian.atlassian.net/projects/AR/issues/AR-214
Hi Igor, thank you very much for your answer.
I understand that you contribute by using time you could spend on other things, and I am completely grateful for that.
I will help if I found something that " know how" from your link
Greetings
