Hi, Igor. I am trying to compile armbian kernel for N6 Max rk3399 box, based on Armbian/Build: https://github.com/armbian/build
I met the following issues:
1.  The "Current" branch does not boot up the system;
2.  The "Legacy" version of rk3399 for overclock patch https://github.com/armbian/build/tree/master/patch/kernel/rk3399-legacy/overclock-rk3399-to-1.5-2.0.patch cannot be integrated in the debs, and the cpu speed is always A53@1.4GHz/A72@1.8GHz;
3.  The "Legacy" verion of rockchip64 are A53@1.5GHz/A72@2.2GHz, but wifi does not work;
4.  The released debs on apt/armbian,com behave same;
5.  Tried to play with the config files but the problems are not solved yet.
Please help solve the issues.
Wayne
1. Get USB TTL adapter to see what is going on.
2. Seems fine: [ o.k. ] * [l][c] overclock-rk3399-to-1.5-2.0.patch
3. Check data sheet which WiFi chip is used and make sure the driver available/enabled for 4.4 sources.
4. Because they are made from the same sources.
  • Igor locked this topic
