GREAT, thats what I may use in script :).
As one of my OPiPC+ repeatedly hangs, despite heatsinks, but it is in plastic enclosure, so I may suspect overheating.
Now I will add not only date/time but temperature too to a "logfile".
Changed uSD card from Toshiba to Samsung (A1) same. System is not the "old upgraded one" with whitch I had problems, but a clone of working OPi.
Last thing is power, but there is SMPS 5V 3A + UltraCap 1F/5.5V, but who knows, cable is short (10-15cm) but poor quality (more than 1ohm @ 1m).
But a bit strange, other one, w/o heatisinks, shows temp 74950 (I guess it is miliK) but runs (for now) for 8 days w/o problem.
Posted (edited)
Expand
That's 75C, check htop for speed, because it should be throttling down to 1.30Ghz until ~72C
And high temp is not recommended longterm, try cpu max 1.1GHz
Edited by xwiggen
I will install a fan in the case this week (already got it from China). Then log temp/date and see if it hangs. I observed, that while hung, if I do a power cycle, temperature after boot is even 85*C. Then it (slowly) falls to 65-70*C.
But I get temp about 70-75* in OPi3 in metal case, 4 heatsinks (1 "fake" -> a small metal tab on flash, but there is mPCIe connector) and fan. And it works rock-stable.
I am curious, what will it be with OPi4 i plan to buy.
Expand
likely the the pc+ had a temp of 100+ before stopping. what are you running?
the opi3 i do not know, different chip though seems hot also.
Looks it is NOT overheating issue:
System load:   1.82 0.42 0.14   Up time:       0 min
Memory usage:  21 % of 966MB    IP:            192.168.1.100
192.168.2.100 192.168.1.101
192.168.2.101
CPU temp:      80°C
Usage of /:    28% of 30G
[ General system configuration (beta): armbian-config ]
laurent@orangepipcplus:~$ su -
Hasło:
root@orangepipcplus:~# tail ~/self-ping.txt
2020-08-11T01:52+02:00
53637
2020-08-11T01:53+02:00
53637
2020-08-11T01:54+02:00
53273
2020-08-11T01:55+02:00
53515
2020-08-11T01:56+02:00
53758
root@orangepipcplus:~# head ~/self-ping.txt
2020-08-09T19:08+02:00
66715
2020-08-09T19:09+02:00
69137
2020-08-09T19:10+02:00
65020
2020-08-09T19:11+02:00
64778
2020-08-09T19:12+02:00
64293
Login is just after power off/on cycle, CPU is HOT. But this is while OpenHAB2 starting.
But at then last moment it worked it had only ~53.5*C.
What (how) to trace now? Replace SMPS (12V->5V 3A) powering device (& cable)? Remove case (temporairly)? Any ideas else?
192.168.2.101
CPU temp:      80°C
Hasło:
53637
53637
53273
53515
53758
66715
69137
65020
64778
64293
Expand
Load at bootup is <=1.82 (<50% all core utilization), 25C increase within minute  seems very unlikely, what is likely (commit=600 in /etc/fstab) your monitoring script did not sync till the end, i.e. last temps are probably not logged to block device.
Ok, yesterday installed fan (sold on Ali as for "Raspberry Pi 3" but it fits even inside casing), temperature (no real load) even below 40*C. (@ 26*C ambient).
Will look that is to be going on.
"1 liner" to log temperature@date-time launched, so there will be possibility to make a graph of this.
