Hi, all:
Today I just upgraded my packages as normal, by using "apt update && apt upgrade",  on my RockPi 4B (legacy kernel), and I saw there was a hostapd package updated. However, after this upgrade, my hostapd won't start anymore now:
Configuration file: /etc/hostapd.conf
wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Using interface wlan0 with hwaddr 6c:21:a2:37:ff:1a and ssid "RockPi-Armbian"
Failed to set beacon parameters
Interface initialization failed
wlan0: interface state COUNTRY_UPDATE->DISABLED
wlan0: AP-DISABLED
wlan0: Unable to setup interface.
wlan0: interface state DISABLED->DISABLED
wlan0: AP-DISABLED
wlan0: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlan0 wasn't started
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
The culprit might be "Failed to set beacon parameters", but not for sure, even if I search on Google and still couldn't figure it out. The following is the output of "sudo armbianmonitor -U":
See here
Not sure if it's a RockPi specific or common issue. If you need more information, just tell me. Thanks.
Edited by darkgeekyang
We have no capacity to test this function on upgrade yet, but at least testing - that we will know it fails - will be probably established by the end of this year.
Who needs more information?
Check support terms https://github.com/armbian/build#support
So I was trying to set up a portable wifi hotspot on my Orange Pi Zero (running Armbian buster with Linux 5.4.34-sunxi).
But whenever I try to enable wifi hotspot on it through armbian-config, it refuses to create a hotspot.
When I looked closely, it tried to probe the nl80211 driver without any error but then it also tried to probe realtek's driver, which is rtl871xdrv according to hostapd.conf in /etc . During its probing, in the corner of the terminal, it said: ioctl[SIOCSIWMODE]: Invalid argument
And as a result, it returned the No compatible driver found error.
I even tried to make NetworkManager ignore it (wlan0) and stop NetworkManager before enabling the hotspot, and start hostapd manually but no positive results.
I'm using the pi's built-in wifi chip - XR819, I'm aware that this wifi chipset isn't greatly supported but before all of this mess, it ran without any hassle. I only encountered this problem after doing an apt upgrade.
And I also tried to downgrade hostapd to an earlier version - 2.7 - but still, nothing.
What can I do to make hostapd working again? Any help would be appreciated!
I also included a screenshot of hostapd when I manually start it.
https://armbian.atlassian.net/browse/AR-245
Planned to look into this in the upcoming months.
Manual way ... All those project are open source, there is a documentation for hostapd and network manager way. Both project are independent from Armbian.
Try using attached hostapd.
hostapd_2.9-99~armbian5.98+1_armhf.deb
Surprisingly, it successfully ran with the config file in /etc, the network showed up in my phone :D
But what I see weird is that despite the correct password I put into my phone, it didn't want to authenticate.
I double checked the password in the config file and the one in my phone, they're the same but it kept telling me it wasn't correct
Maybe I missed something or I didn't set it up correctly.
But thanks for your temporary solution :D
Try armbian-config now. It should work, but AC mode doesn't work. I already waste afternoon ...
Well, suddenly NetworkManager keeps telling rfkill to block the wlan interface (happens on boot and everytime I restart NetworkManager).
But what's weirder is that even after I unblock the interface, it still can't scan for any wifi network. And as a result, the option to create a hotspot in armbian-config isn't available.
However, if I start hostapd manually (an updated version thru apt I just updated yesterday), it will open a hotspot with that config file. But sadly it still doesn't want to authenticate. Welp
I'll make more investigation on this.
Good news :D
Several days ago, I tried armbian-config again to try to create a hotspot. And surprisingly, it worked :DD
The hotspot has been running for days now.
Thanks for your hard work @Igor, I really appreciate it ;)
