Hello I have Odroid xu4 with fan mounted on heatsink. I found several tutorials online and I have one problem.
I have  Armbian buster with Linux 5.4.28-odroidxu4
I tried edit temp curve and I did it with nano /etc/rc.local
# Target temperature: 30°C, 50°C, 70°C
TRIP_POINT_0=30000
TRIP_POINT_1=50000
TRIP_POINT_2=70000
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_0_temp
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_0_temp
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_0_temp
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_0_temp
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_1_temp
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_1_temp
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_1_temp
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_1_temp
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_2_temp
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_2_temp
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_2_temp
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_2_temp
This code above is working fine but when I try to edit fan speeds I can't find it
$ echo "0 204 220 240" | sudo tee /sys/devices/platform/pwm-fan/hwmon/hwmon0/fan_speed
when I do ls -l /sys/devices/platform/pwm-fan/hwmon/hwmon0/ there is no fan_speed file
Please can you tell me where is location of file that has attributes to control pwm state so I can do echo from rc.local
Why I want to do that, well I have one idea. When I try edit /sys/devices/platform/pwm-fan/hwmon/hwmon0/pwm1 with nano I try several speed of fan.  Minimun of my fan is 40 but it doesn't start on that speed but is iq quiet and on that speed temp of my CPU is 43C. This is why I edited target temp.  when fan is in stop state 40 in pwm1 doesn't have enough voltage to start fan. But 50 C will activate fan and it will drop to 40 pwm1 and it will keep spining. If it stops, againt 50C activate the fan and so on...
 I only need $ echo "0 40 120 240" | sudo tee /sys/devices/platform/pwm-fan/hwmon/hwmon0/fan_speed to correct place
Thanks.
Reply to:  soerenderfor
I can't reply so I will edit this post I will cut this part of post when system unlock option for reply I get one per day :)
when I do
sudo find /sys -name pwm1 | grep hwmon
I get
I know for that pwm1, I even manualy edited it with nano but some part is constantly being updating this pwm1 and this just replace what ever I try to put in this file.
when I do
cat /sys/devices/platform/pwm-fan/hwmon/hwmon0/pwm1
I get
120
when I change this 120 to 40 after some time it gets updated to 120
Critical is to find location of that pwm or fan_speed file that contains 120 180 240 which is doing editing pwm1 file so I can echo into that file and problem is sloved. I tried everything but I just can't find that file. If I can find that file odroid xu4 will be extra quiet on performance mode with 43C
Edited by tomislav177
You can use: sudo find /sys -name pwm1 | grep hwmon
That command find the fan location, so you can edit your scripts to point to the fan.
Thanks.
This kernel is not yet on the support level of stock 4.14.y ... Modern kernel is always a trade. Good at some features, bad or non-existing others.
You can also use the first script in /etc/rc.local and set them to
# Target temperature: 25°C, 30°C, 65°C
TRIP_POINT_0=25000
TRIP_POINT_1=30000
TRIP_POINT_2=65000
I use these trip points on my XU4 Cloudshell2 - and it works like charm, the fan speeds will then run around 180,.
Hello I was gone for few days. I did some experimets, I was stupid enough for my first install to go with kernel Kernel 5.4.y now I flashed stock kernel 4.14.y and all is working fine. But one BIG drawback of kernel 5.4.y. is samba transfer speed on my home network which was max 48MB/s now with 4.14.y kernel is 98-100MB/s
I use odroid as a home server and this is one big thing to consider if you want to go with experimental kernel. In kernel 4.14 you can control fan because you have file fan_speed.
I managed to control fan by editing
nano /etc/rc.local
TRIP_POINT_0=25000
TRIP_POINT_1=55000
TRIP_POINT_2=70000
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_0_te$
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_0_te$
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_0_te$
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_0_te$
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_1_te$
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_1_te$
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_1_te$
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_1_te$
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_2_te$
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_2_te$
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_2_te$
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_2_te$
# Target fan speed (PWM): 0, 60 180, 240
echo "0 60 180 240" > /sys/devices/platform/pwm-fan/hwmon/hwmon0/fan_speed
Now my odroid is super quiet as home server with 45C in average, I run on it OMV5, in docker (PiHole, transmission, unifi-controller, duckdns and watchtower).
value of 60 is not enough to start odroid fan, but second value of 180 starts the fan and then it continues to spin on 60pwm. This is something that will everyone need to try for himself but quiet is precious. :)
I hope this will help someone like me.
Regards.
nano /etc/rc.local
TRIP_POINT_0=25000
TRIP_POINT_1=55000
TRIP_POINT_2=70000
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_0_temp$
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_0_temp$
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_0_temp$
echo $TRIP_POINT_0 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_0_temp$
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_1_temp$
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_1_temp$
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_1_temp$
echo $TRIP_POINT_1 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_1_temp$
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone0/trip_point_2_temp$
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone1/trip_point_2_temp$
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone2/trip_point_2_temp$
echo $TRIP_POINT_2 > /sys/devices/virtual/thermal/thermal_zone3/trip_point_2_temp$
Regards.
I have one mistake in code that I use in /etc/rc.local this is now correct.
I noticed the same regressions (low samba speed and lack of fan control) with 5.4.28, so I went back to my trusty 4.14.133. Moving data from one USB-drive to another - both connected to the XU4 with 5.4.28 - was almost as slow as samba, 40'ish MB/s. However, reliability with 5.4.28 was fine even when moving huge amounts of data - albeit slowly...
Edited by tbylit
Minor corrections.
