Reducing CPU space and heatsinks
Use the iron leaf to reduce the height, elongation, heat sink
Use the MX-4  thermal compound instead of the patch.
Helps to reduce by 10 degrees
I have purchased Nanopi Neo 3 which is very simular to Nanopi R2S this week and after the installation of Armbian Buster 5.4 noticed overheating. After entering Htop, I found a process completely using the processor. PID 907 is the admin login for it, PID 898 is the root login for it. The command kill -9 898 or kill -9 907 solved the problem of overheating and 100% load. The processor temperature dropped to 66 degrees Celsius.
Perhaps the next step will be the replacement of the installed cooling system with a DIY one.
I hope that my experience will help anybody else.
Good news, update new metal case
25 degree reduction
Not sure if you can order a new metal case only.
Today, NanoPi NEO3 has arrived. I tested it to be very hot.
 85 degree
This is the final solution I ended up with: metal case + old 939 stock cooler.
du046P.jpg .
I was not totally satisfied by the metal case only, probably also because I keep the nanopi in a closed environment with no air circulation. Previously I tried also the heatsink with the small fan, but it's rather noisy and doesn't help a lot if you still use the yellow case.
I am have using a Neo3 for a week now. My idle CPU temperature (reported by htop) is 60°C with a room temperature of around 25°C.
I have the default white case, supposedely with a heat sink inside
Product bought there https://www.aliexpress.com/item/4001260840189.html
I also think this is kinda high, but I understand the lack of fans and small enclosure doesn't help.
That metal case is interesting, a model for the neo3 would be great!
Edited by RedShadow
Following this up with a Nanopi Neo3:
I made a little POC with a 12V CPU fan blowing at the standard white case.
IDLE I went from 60°C to 40°C
And maxed out, I went from 73+°C to 63°C
Definitely a fan should help!
So I ordered a 30x30x10 fan on aliexpress and some JST ZH 1.5 wires to plug it on the Neo3.
Guess I will remove a chunk of the bottom case and set the fan against the heat sink. Will be back in a couple months when I'll have received the goods and set all of this up.
Meanwhile my ghetto 12V CPU fan against the case helps
13 hours ago, Blazerfi said:
@RedShadow Just out of curiosity, how do you plan to mount the fan to the heatsink?
I'm guessing something like that : https://ibb.co/hWFm4jd
Removing the bottom case center while leaving some space around on the sides to make holes for the screws and resting the fan.
And adding some rubber washers to reduce vibrations.
I think I will soon get my little fan order, the package arrived somewhere in my country it seems.
Alright, I have received the fan and stuff to cool my nanopi3.
In the end it looks like this: https://ibb.co/478br6z https://ibb.co/bN4HMhB
Behold my not very round hole. Anyway.
I had to put screws from the inside as mine they are too long and they were touching the passive cooler otherwise. Also not enough space inside to secure them with bolts.
Now the IDLE temp is about 35°C. And a full load is about 53°C. Not bad.
I haven't finished yet though, as I want to put some soft rubber washers to damper vibrations. And then I will secure the screws with bolts and close the case.
I used this little fan there https://www.aliexpress.com/item/32603431500.html and it is quiet enough. I can hear it through the cabinet though, I hear a high pitched noise. But a few meters away and it's gone.
Tried these fans as well https://www.aliexpress.com/item/4000131368383.html and however they are stronger and move more air, they are very loud. Even in the next room I could hear the motor. And, they are actually too strong as the air can't get outta the case fast enough and goes back out through the fan itself. Not good. Not good for my setup anyway.
After seeing your post on this, I decided to do the same with a fan I purchased for the R2S before I got the metal case (which I hope we get for the Neo3).
What is the best way to put a load on this thing?
My fan isn't too loud, bought it on amazon and am currently powering it via the USB2 headers so it is always on.
https://www.amazon.com/gp/product/B07PD1H24F
You can use the JST ZH 1.5mm as well to power on the fan. It's 5V.
Guess it's exactly the same as using the USB2 headers pins.
Though I'm wondering if we could somehow control either this USB2 or the JST to maybe control the fan speed!
That'd be neat, like speeding up/powering on the fan according to the CPU temp or CPU usage.
To put the NanoPi under load I'm using `sysbench` to calculate prime numbers with the 4 CPUs
sysbench --test=cpu --threads=4 --cpu-max-prime=100000000 run
And then at the same time I'm hammering my WireGuard on the Nanopi with a 30Gb download or something.
And measure the CPU temp with htop after 15 mins or so.
My results were very similar for a Neo 3 with fan.  ~39c idle and ~54c under load.  I am perfectly content with that.
When I purchased the fan I didn't realize what header I needed and cant force my current plug into the fan header.  USB seems to work just fine for what I need it for right now, at least until someone makes a neat program to adjust fan control speed using one of the other headers.
My R2S in the metal case is running much warmer than I prefer to touch, but it seems stable.
Now that I am thinking about it, it may be time to invest in a few Noctua 40mm fans and slap them on top of my devices for quitter operation and more airflow.
http://wiki.friendlyarm.com/wiki/images/5/59/SCH_NanoPi_R2S_V1.0-1912.pdf
get pwm2 running and you should be done.. iirc it's not the first friendly arm board having this kind of fan control so there should be information here and there.
If it is properly defined in the dt and from a first glance.. It doesn't look like it is that someone is already there long time ago and wrote the pwm fan kernel driver... :lol:
https://elixir.bootlin.com/linux/latest/source/Documentation/devicetree/bindings/hwmon/pwm-fan.txt
well you might need to pack this into a device tree overlay cause I'm sure not everyone wants an annoying fan on his board.
it seems the whole thread is kinda focused on treating symptoms instead of figure out the root case for it. Obviously the board doesn't have much thermal mass due to it's size and I would assume that the USB3 to ethernet phy will also add some additional heat to the system (someone ever checked which other chips 'feel warm' and when - e.g. test if the issue relies when the USB GbE phy gets disabled). Next would IMO then be to test if we have to adjust THS settings for the board or maybe the max frequency we allow it to go (iirc we had this in the past for other boards that we didn't allow them to run at max clock-speeds for various reasons maybe this board is one of them too.
I have a neo3 at home somewhere but didn't even boot it up yet (call me lazy). From a first glance the board looks nicely done but I kinda expected it to be a oven.. given the tiny little case I got with it. Maybe I've a look at it this weekend who knows...
I have a
Yes, I'm starting to look around now for a way to control this.
I'm a Linux n00b,  so bear with me,  I'm gonna confirm below what I understand so far:
- The pins are not exposed to the system for easy manipulation
- Also, the pins addresses and stuff are not the same for each hardware model
- It would pollute the environment if they were set up automatically because not used most of the time
The way to do this is by using the Device Tree. This exposes stuff. But not necessarily everything.
So if we want to expose more stuff (like our PWM pins or USB pins) we have to add these to the DT.
Except that it's not good practice, since the DT gets updated during Kernel update so the changes would be lost.
Instead we have to create an Overlay which would contains only our changes, which will get applied on top of the DT.
Now on my Nanopi Neo3, I have checked the available Overlays as some are provided.
In /boot/dtb/rockship/overlay there are some of them.
The README there describes what each of these does.
In my case (nanopi Neo3), I'm looking to control GPIO2_A6 aka PWM2 from what I can see here.
But, the readme doesn't seem to indicate any available overlay which would expose this.
This link you have given us, chwe, is for us to create our own overlay so we can expose it ourselves.
I understand that once this will be done, we can expect to hit that pin through sysfs. Like with something like /sys/class/pwm/pwmchip0.
Indeed right now I don't have pwmchip0, this folder is empty.
Am I right so far?
Yeah, didn't even think about the causes. From htop I can see the CPU freq and at idle it's about 408mhz. Upon charge, it climbs up to 1.3Ghz.
But it was with these 408mhz that we reached around 50°C idle before setting up our fans. I'm not sure tweaking the max clock speed would change much as with 408mhz it's already very hot
Can't test without the eth disabled as I don't have the debug console and do everything through SSH using eth.
I'm now curious as well as to why this is hot idling!
Hi all,
An  update about my experience with the cheap fan I've found in a well know Chinese online market, at that time was the only one I've found and the metal case was not available:
Three months and a half later the fan started to work really noise, is doing the job and the temp is ~ 40ºC without load, but the noise is annoying.
Time to go for the metal case, the question is, with or without fan?
Edited by M.FB
My R2S came in the cute yellow plastic ovencase with the heatsink and fan inside. I need silent operation and FriendlyElec weren't selling the metal case yet. So I bought a metal case without fan from ebay: https://www.ebay.com.au/itm/402314889761
Very happy with it. Totally silent and the heat profile was so good that I stopped my stress/heat/freq tests and put the R2S into active use.  I've just ordered my second NanoPi R2S from FriendlyElec, this time with the metal case. I would add more heatsink, like in the photo above, before a fan.
Am I right so far?
I agree with all that. I found that with the FriendWRT image, that /sys/class/pwm/pwmchip0 existed and is actively used to manage the fan with this script:
https://github.com/friendlyarm/friendlywrt/blob/e1fb88ff29bcf634c875b94a9026565c7780149f/target/linux/rockchip-rk3328/base-files/usr/bin/start-rk3328-pwm-fan.sh
Please let us know if you make any. progress with /sys/class/pwm/pwmchip0 on armbian
I spent too long running heat tests. Once I got my nanopi r2s into a metal heatsink case, I was happy that I had a reasonable operating temperature range for what I plan for this router
Thanks for the feedback @poddmo.
I've asked about the metal case+fan because of the Javin's comment,  I don't really know if we can trust the nice graphs that the Friendlyelec guys posted in his shop, but according to your feedback those graphs can be real.
I think I will try something like the Style A, I will rum some test with and without the fan:
images?q=tbn:ANd9GcTgGpjk4AISL8AA0uFqUBR
If finally I need to go for the Style B, I will spent more in cases and fan than in the SBC itself  :huh:
BR
BR
My second r2s just arrived - I ordered this one from FriendlyElec with the metal case (style B). Looks much more professional than the third party metal heatsink case I got from ebay. It is also lighter and the ports are much more snug. Not enough to prefer one over the other at the end of the day. I installed armbian focal, apt update and then re-ran the cpu stress test. The numbers again match those from the brochure. Style B is guaranteed silent.
I found that since the base of the metal case is flat, putting a couple of chopsticks underneath to allow air flow there also dropped temperature a degree or 2 at idle.
Room temp 23C. I will keep watch as we get into summer and room temp gets much hotter but for now, this case is closed :)
pi@nanopi-r2s:~$ sudo stress -c 4 &
pi@nanopi-r2s:~$ while true ; do echo -n "`date` " ; a=`cat /sys/devices/system/cpu/cpu?/cpufreq/cpuinfo_cur_freq` ; echo -n $a"  ";  cat /sys/class/thermal/thermal_zone0/temp ; sleep 5s ; done
Wed 21 Oct 2020 20:36:02 AEDT 1296000 1296000 1296000 1296000  65384
Wed 21 Oct 2020 20:36:07 AEDT 1296000 1296000 1296000 1296000  64166
Wed 21 Oct 2020 20:36:12 AEDT 1296000 1296000 1296000 1296000  65000
Wed 21 Oct 2020 20:36:17 AEDT 1296000 1296000 1296000 1296000  65769
Wed 21 Oct 2020 23:10:17 AEDT 1296000 1296000 1296000 1296000  69230
Wed 21 Oct 2020 23:10:22 AEDT 1296000 1296000 1296000 1296000  68076
Wed 21 Oct 2020 23:10:27 AEDT 1296000 1296000 1296000 1296000  68461
Wed 21 Oct 2020 23:10:32 AEDT 1296000 1296000 1296000 1296000  68846
Wed 21 Oct 2020 23:10:37 AEDT 408000 408000 408000 408000  55454
Wed 21 Oct 2020 23:10:42 AEDT 408000 408000 408000 408000  54583
Wed 21 Oct 2020 23:10:47 AEDT 408000 408000 408000 408000  53333
Wed 21 Oct 2020 23:26:04 AEDT 408000 408000 408000 408000  44545
Wed 21 Oct 2020 23:26:09 AEDT 408000 408000 408000 408000  46363
Wed 21 Oct 2020 23:26:14 AEDT 408000 408000 408000 408000  46363
Yes, very true, I'm using the original heatsink for the same.
I have a style-A case on my R2S, and the device idles at ~50c.  It works better if you can slightly shim the fan up away from the case, as their design has the fan blowing directly against a flat metal heatsink with no exit route for the air.
I'd note that that tiny fan is very noisy.
Thanks @devman, them I've selected the wrong option because the fan I'm using right now was really silent until started to make noise, and when is idle the temp is ~ 42c-45c, as the case in on route I'll give a chance.
Edited by M.FB
Hi again,
As @devman noted the fan for the Style A is noisy, and knowing that I cannot expect too much for the price, at least in my case the quality is very very poor, I'm waiting for Friendlyarm to make available a metal case for NEO3, and will order a NEO3 with metal case an the Style B metal case for the RS2.
The fan is noisy but helps (attached logs), testing with "stress -c 4" the temperature rises gradually and does not exceed 82C, maintaining the maximum speed at all times, it drops immediately when there is no load.
Without fan the temperature immediately rises to 83C-85 C and the cpu suffers to maintain the maximum clock speed, although it is not really remarkable, without load it takes a long time to return to normal values and it costs a lot to drop from 50C.
In brief, this option is completely silent and works fine if you made a big square hole on top of the yellow case, but after less than 4 months the fan started to fail and the noise is simply insupportable:
This one also works fine, obviously better with the fan connected, but the quality is poor (for example screws are not long enough to maintain the fan flat)  and the fan is noisy, who knows how many time will be working fine the fan:
Yep, at the end I will spent more in cases and fans that in the SBC :unsure:
BR.
style_A_without_fan.txt style_A_with_fan.txt
I'm pretty sure you don't actually want the fan flat, as there's nowhere for the air to go then.
I ended making some little 2mm bushings and swapping out for longer screws.  I need to source a better fan still.
Hi devman, I've seen your first comment about this, I'm looking for something like this that fits in the micro holes on top of the heatsink but I don't find anything with the required diameter.
BR
The problem is that the holes don't leave enough clearance to rotate those (at least on mine), so I just went with slightly longer screws and washers/bushings
Hi again, as expected (I'm not known for my ability for DIY when I work with small things), after try to make some arrangements in the Style A fan I've broken the fan -_-
I ended putting the R2S behind my old Synology NAS, I took a plastic box and did some holes to pass the NAS cables and use the box as base to put the R2S is just in from of the NAS fan, is this called synergy :D ? . To avoid put the R2S just on top of the plastic I've used the original heat-sink to raise the device a bit.
pic1.png.585ae548edbd73b2165a1f73324f4a4e.pngpic2.png.a9d46f302a66ff87134a82b78345fb79.png
Also I've configured the CPU from Min: 600M/Max: 1.500 to Min:400/Max:1.300 (as FE suggests in the spec sheet), and set the governor mode to conservative, the difference is not too much when the cpu is idle, but after set  the max speed to 1.300 the drop in the temp is noticeable on full load:
Idle: 41-43
With high load: 65-68C.
This crappy setup works for me and is  quiet :), the R2S is running pi.hole, transmission-daemon, minidlna, iperf and sometimes amuled so most of the time the load is low.
The difference between put the R2S behind the Synology fan or not, is about 4-5C when is idle and 8-10 C on full load. Attached the log testing with "stress -c 4".
BR
r2s_temp.log
I solved the problem for the nanopi neo 3
i buy this 3 items
and i control the pwm fan by nodered
and now the temperature is always arround 55°C i summer
