aliend Posted June 18, 2016 Share Posted June 18, 2016 Hi,I have Cubietrauck and I installed legacy Jessie on SD card and after configuration hostapd for using it as access point only 5 devices were able to connect to my device. After search I’ve added max_num_sta=20 but it didn’t solve my problem.I tried to use other distribution like vanilla Jessie and vanilla trusty server but I had same problem. Here is my hostapd configuration: interface=wlan0driver=nl80211ssid=ssidhw_mode=gchannel=9macaddr_acl=0auth_algs=1ignore_broadcast_ssid=0wpa=2wpa_passphrase=mypasswordwpa_key_mgmt=WPA-PSKwpa_pairwise=CCMPrsn_pairwise=CCMPmax_num_sta=20 How can I change max devices connection? Is this problem relate to the wifi module and how can I fix it? 1 Link to comment Share on other sites More sharing options...
Igor Posted June 18, 2016 Share Posted June 18, 2016 You can't, not with this chip. Limited by firmware. 2 Link to comment Share on other sites More sharing options...
aliend Posted June 18, 2016 Author Share Posted June 18, 2016 You can't, not with this chip. Limited by firmware. I understood something about it , can I change it ? how ? where is firmware sources and compiled firmware location(/path) ? 1 Link to comment Share on other sites More sharing options...
Nagha Posted July 22, 2016 Share Posted July 22, 2016 Wow ! Thanks for the information, I almost spent 10hours looking everywhere in logs and on internet for why my maximum simultaneous connection was 5 ! I'm looking for any workaround, is there any ? (Is changing hardware the only solution ? If yes, which one to choose as a good substitute to cubietruck ?). In the meantime i'll still try to look for more information over the Internet. Many thanks in advance, feel free to just link me interesting URI i'll appreciate any kind of help ! (Even interesting LetMeGoogleThatForYou, just don't know really where to begin with my research) (Oh since it's my first post, i'd like to thanks every participant of Armbian dev/forum ! Saved me lot of time, seriously ! Cubietruck isn't widely documented...or i'm just newbie not finding them) Link to comment Share on other sites More sharing options...
