jgauthier Posted June 20, 2020 Share Posted June 20, 2020 Greetings, I've been building an image for a banana pi m2-zero. I noticed during the build that the following DTS is chosen: sun8i-h3-orangepi-zero-plus2.dt There is a sun8i-h2-plus-bananapi-m2-zero.dts in the same directory, that I think would be more relevant. How can I choose this DTS instead? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 21, 2020 Share Posted June 21, 2020 Um... you mean the built image is using the wrong DTS to boot? 0 Quote Link to comment Share on other sites More sharing options...
jgauthier Posted June 21, 2020 Author Share Posted June 21, 2020 Keep in mind, that I don't know very much about DTS. As my Linux experience is specific to PC hardware and Raspberry Pis. That said, my terminology/understanding my not be accurate. When the kernel (or uboot?) portion of the build takes place a DTS file is chosen. This appears to be sun8i-h3-orangepi-zero-plus2.dt from the compile logs. I would have suspected it to be sun8i-h2-plus-bananapi-m2-zero.dts Since my board is a bananapi m2 zero. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 21, 2020 Share Posted June 21, 2020 I am not sure what the actual issue is. When you build a bootable image for the Bananipi M2 zero does it boot as expected? This SBC is handled as a part of the sunxi family and you might notice that there are many more device tree blobs under /boot/dtb. 0 Quote Link to comment Share on other sites More sharing options...
jgauthier Posted June 22, 2020 Author Share Posted June 22, 2020 19 hours ago, Werner said: I am not sure what the actual issue is. When you build a bootable image for the Bananipi M2 zero does it boot as expected? This SBC is handled as a part of the sunxi family and you might notice that there are many more device tree blobs under /boot/dtb. Ok, it was an understanding issue. Thank you! 0 Quote Link to comment Share on other sites More sharing options...
