Armbianmonitor:
I'm not sure what is the cause and effect here, but what I saw today is weird. OS:
Welcome to Armbian buster with Linux 4.9.219-meson64
Linux odroidn2 4.9.219-meson64 #1 SMP PREEMPT Wed Jun 3 12:42:50 CEST 2020 aarch64 GNU/Linux
Symptom: I recently purchased a Seagate external HDD and wanted to use it with the N2. Started to replicate files from my other server over SFTP, and at the same time I also started Midnight Commander to check on the HDD content. As soon as I wanted to change directory to /mnt/seagate, my console became unresponsive, the SFTP connection failed and there wasn't really any way to unstuck this situation.
Due to other reasons previously I applied quirks on the drive, therefore it is NOT in UAS mode:
Bus 002 Device 006: ID 0bc2:331a Seagate RSS LLC
root@odroidn2:/home/vz# lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
        |__ Port 3: Dev 6, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
(* Other times I managed to "repro" this stuck behavior just by changing directory and executing a fairly simple ls -l from command prompt. I really don't know what's up with the USB storage handling...)
Then I started a new SSH session and executed armbianmonitor -u. There I saw only CPU0 working, the other cores were idling: http://ix.io/2pVH
Alright, somehow I managed to unmount the drive (needed to use the -f switch), then mount again, SFTP reconnected, file transfer started. There is an active transfer even right now, approx. 8MB/s, but still only CPU0 is working:
root@odroidn2:/home/vz# armbianmonitor -n
runtime network statistics: odroidn2
network interface: eth0
[tap 'd' to display column headings]
[tap 'z' to reset counters]
[use <ctrl-c> to exit]
[bps: bits/s, Mbps: megabits/s, pps: packets/s, MB: megabytes]
eth0        rx.stats____________________________________________________________          tx.stats____________________________________________________________
count       bps         Mbps        ư.Mbps        pps         ư.pps         Ʃ.MB          bps         Mbps        ư.Mbps        pps         ư.pps         Ʃ.MB
1           69363392    69.36         69.36       5853          5853          8.26        991072      .99           .99         1827          1827          .11
2           68955424    68.95         69.15       5827          5840          16.48       964480      .96           .97         1776          1801          .23
root@odroidn2:/home/vz# cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3       CPU4       CPU5
 10:          0          0          0          0          0          0     GIC-0  29 Level     arch_timer
 11:    6819558   33868946     983894     427047    2782528     266967     GIC-0  30 Level     arch_timer
 14:          0          0          0          0          0          0     GIC-0  92 Edge      Meson TimerF
 15:          3          0          0          0          0          0     GIC-0 192 Level     ffe40000.bifrost
 16:          0          0          0          0          0          0     GIC-0 193 Level     ffe40000.bifrost
 17:          0          0          0          0          0          0     GIC-0 194 Level     ffe40000.bifrost
 20:          3          0          0          0          0          0     GIC-0 241 Edge
 21:          1          0          0          0          0          0     GIC-0 242 Edge
 22:   62991952          0          0          0          0          0     GIC-0  40 Edge      eth0
 23:    1336993          0          0          0          0          0     GIC-0  62 Level     xhci-hcd:usb1
 24:          1          0          0          0          0          0     GIC-0  48 Level     amlogic_botg_detect
 25:          0          0          0          0          0          0     GIC-0  63 Level     dwc_otg, dwc_otg_pcd
 26:          0          0          0          0          0          0     GIC-0 232 Edge      meson-g12a-saradc
 27:          0          0          0          0          0          0     GIC-0  67 Edge      ff634800.p_tsensor
 28:          0          0          0          0          0          0     GIC-0  68 Edge      ff634c00.d_tsensor
 29:          0          0          0          0          0          0     GIC-0 247 Edge      ffd1d000.i2c
 31:      10078          0          0          0          0          0     GIC-0  71 Edge      ffd1c000.i2c
 33:          0          0          0          0          0          0     GIC-0 225 Edge      meson_uart
 41:          0          0          0          0          0          0     GIC-0  89 Edge      hdmitx
 43:          0          0          0          0          0          0     GIC-0 235 Edge      hdmi_aocecb
 45:          0          0          0          0          0          0     GIC-0 178 Edge      ge2d
 46:   17579444          0          0          0          0          0     GIC-0  35 Edge      vsync, osd-vsync
 47:          0          0          0          0          0          0     GIC-0 176 Edge      gdc
 54:   17579444          0          0          0          0          0     GIC-0 121 Edge      rdma
 55:          0          0          0          0          0          0     GIC-0  88 Edge      osd-vsync-viu2
 56:          5          0          0          0          0          0     GIC-0 223 Edge      meson-aml-mmc
 57:       4121          0          0          0          0          0     GIC-0 222 Edge      meson-aml-mmc
 59:          0          0          0          0          0          0     GIC-0  83 Edge      dmc_monitor
 69:          0          0          0          0          0          0     GIC-0  33 Edge      audiolocker
 70:          0          0          0          0          0          0     GIC-0  78 Edge      pre_di
 71:          0          0          0          0          0          0     GIC-0  72 Edge      post_di
 72:        255          0          0          0          0          0     GIC-0 228 Edge      ir-meson
IPI0:  84717127   63361081   17705172   10069318    6700169    4492021       Rescheduling interrupts
IPI1:     27291      52009      49225      28653      26197      24202       Function call interrupts
IPI2:         0          0          0          0          0          0       CPU stop interrupts
IPI3:         0          0          0          0          0          0       Timer broadcast interrupts
IPI4:   1238898      56645     442118     106174    1830596      58141       IRQ work interrupts
IPI5:         0          0          0          0          0          0       CPU wake-up interrupts
Err:          0
How is that possible? eth0 is definitely under load (alright, far away from the gigabit limit, but still), USB is also under load to write the received bytes to the disk... But it really seems like only CPU0 does care.
Basically I'm a Windows guy for a looong time, but this is like unimaginable there, all the CPU cores do work and distribute the load...
Maybe I just don't understand how this should work, but I thought it's better to report. Worst case I'll get educated on Linux. :)
On Linux we have a daemon but it doesn't work properly on ARM. Perhaps now it does ... would need to check. That's why Armbian have this:
https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-hardware-optimization
but it seems it doesn't work.
Hello @Igor thank you for your comment, however I'm afraid I don't follow you: do you say this should work (i.e. all CPU cores handling interrupts) and for some reason buggy with Armbian's N2 distro?
30 minutes ago, vzoltan said:
I don't follow you
Armbian is essentially a build system that makes Linux which is distributed in a Debian / Ubuntu taste.
AFAIK this feature works well on X86 hardware while on ARM it doesn't work at all - is broken (perhaps not anymore - IDK. Need to check). Most distributions are not dealing with hardware functions - they distribute Linux (hw layer) as is under different logo, changed desktop, ... we have covered this feature since early days but everything needs to be maintained to preserve operational state. Maintenance at current levels is already insane expensive and most of users does not even notice that ...
Did you see this problem fixed elsewhere?
The reason is that nobody at Armbian cares any more about such low level stuff. The string 'meson-g12b' (N2's board family) is missing from the case construct in https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-hardware-optimization so what you see is what is to be expected. All IRQ handling on cpu0 therefore being a nice bottleneck.
Some people think irqbalanced would help but at least in the past it was common knowledge that for stuff like storage or networking static IRQ affinity is the way to go.
BTW: You have massive filesystem corruption on the /var/log partition. As for your storage issues a simple web search for 'odroid n2 usb issues' might help.
/var/log is zram and it randomly throws errors, I really had more pressing issues to fix than that one... But thanks for the reminder!
And I really thought that HK did fix the USB issues.
Honestly, purchasing this N2 and investing so much time to make it work was one of the worst decisions in my life, if not the THE worst.
