I am trying to configure "next" with linux-vanilla (4.6.2) and built an Armbian image then booted from SDcard (removing my eMMC)
So far, Samsung OSG provided examples of vanilla kernel
@jobenvil tested 4.6 kernel but compiled on board WITH partition using UUID instead of /dev/mmc
I got 4 cores in the "basic" model (4 little => 4 BIG), network, HDD
issue: mixing uboot 2012.07 and vanilla kernel
it seems /dev/mmcblk0 doesn't exist for uboot 2012 only boot.ini works with root=/dev/mmcblk1p2
to quick fix the problem I put /dev/mmcblk1p2 for root partition in boot.ini
* I know how to manipulate UUID and partition
=> is it possible to put specific UUID on partitions before writing the image with Armbian
[gr@server1404:~/gro_armbian/lib/config/bootscripts] master(+996/-35126)* ± cat boot-odroid-xu4-next.ini
ODROIDXU-UBOOT-CONFIG
# U-Boot Parameters
setenv initrd_high "0xffffffff"
setenv fdt_high "0xffffffff"
# Mac address configuration
setenv macaddr "00:1e:06:61:7a:55
# Basic Ubuntu Setup. Don't touch unless you know what you are doing.
setenv bootrootfs "console=tty1 console=ttySAC2,115200n8 loglevel=1 root=/dev/mmcblk1p2 rootwait ro fsck.repair=yes"
# boot commands
setenv bootcmd "fatload mmc 0:1 0x40008000 zImage; fatload mmc 0:1 0x42000000 uInitrd; fatload mmc 0:1 0x44000000 dtb/exynos5422-odroidxu4.dtb; bootz 0x40008000 0x42000000 0x44000000"
root@odroidxu4:/tmp# blkid
/dev/mmcblk1: PTUUID="000ebbbf" PTTYPE="dos"
/dev/mmcblk1p1: SEC_TYPE="msdos" LABEL="BOOT" UUID="5AD8-0DE7" TYPE="vfat" PARTUUID="000ebbbf-01"
/dev/mmcblk1p2: UUID="7d97d3e2-f4cc-42ae-a2d4-3db000a29d08" TYPE="ext4" PARTUUID="000ebbbf-02"
/dev/sda1: UUID="0bc8e548-b0b8-45cd-9d8d-8b863220a7b4" TYPE="ext4" PARTUUID="e72d222d-01"
root@odroidxu4:/tmp# dmesg
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 4.6.2-odroidxu4-dirty (root@server1404) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #6 SMP PREEMPT Mon Jun 20 00:59:38 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Hardkernel Odroid XU4
[    0.000000] cma: Reserved 64 MiB at 0xba800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Samsung CPU ID: 0xe5422001
[    0.000000] On node 0 totalpages: 514560
[    0.000000] free_area_init_node: node 0, pgdat c0b3f9c0, node_mem_map ef01f000
[    0.000000]   Normal zone: 1536 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 192512 pages, LIFO batch:31
[    0.000000]   HighMem zone: 322048 pages, LIFO batch:31
[    0.000000] Running under secure firmware.
[    0.000000] percpu: Embedded 12 pages/cpu @eef84000 s19392 r8192 d21568 u49152
[    0.000000] pcpu-alloc: s19392 r8192 d21568 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513024
[    0.000000] Kernel command line: console=tty1 console=ttySAC2,115200n8 loglevel=1 root=/dev/mmcblk1p2 rootwait ro fsck.repair=yes smsc95xx.macaddr=00:1e:06:61:7a:55 governor=conservative hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1961368K/2058240K available (6337K kernel code, 258K rwdata, 2132K rodata, 1024K init, 313K bss, 31336K reserved, 65536K cma-reserved, 1222656K highmem)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0945504   (9462 kB)
      .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
      .data : 0xc0b00000 - 0xc0b40a00   ( 259 kB)
       .bss : 0xc0b42000 - 0xc0b907e8   ( 314 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] GIC physical location is 0x10481000
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000000] clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000007] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000962] Console: colour dummy device 80x30
[    0.001126] console [tty1] enabled
[    0.001155] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=120000)
[    0.001176] pid_max: default: 32768 minimum: 301
[    0.001334] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001350] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002236] CPU: Testing write buffer coherency: ok
[    0.002910] CPU0: update cpu_capacity 448
[    0.002928] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
[    0.003109] Setting up static identity map for 0x40100000 - 0x40100058
[    0.003559] ARM CCI driver probed
[    0.003799] Exynos MCPM support installed
[    0.055353] CPU1: update cpu_capacity 448
[    0.055362] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
[    0.075328] CPU2: update cpu_capacity 448
[    0.075336] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
[    0.095328] CPU3: update cpu_capacity 448
[    0.095337] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
[    0.115340] CPU4: update cpu_capacity 1535
[    0.115349] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.135319] CPU5: update cpu_capacity 1535
[    0.135326] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.155342] CPU6: update cpu_capacity 1535
[    0.155349] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.175320] CPU7: update cpu_capacity 1535
[    0.175328] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.175496] Brought up 8 CPUs
[    0.175563] SMP: Total of 8 processors activated (384.00 BogoMIPS).
[    0.175575] CPU: WARNING: CPU(s) started in wrong/inconsistent modes (primary CPU mode 0x1a)
[    0.175585] CPU: This may indicate a broken bootloader or firmware.
[    0.176886] devtmpfs: initialized
[    0.209030] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 3
[    0.210542] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302231375000 ns
[    0.214134] pinctrl core: initialized pinctrl subsystem
[    0.215830] NET: Registered protocol family 16
[    0.218115] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.230007] cpuidle: using governor menu
[    0.267892] exynos-audss-clk 3810000.audss-clock-controller: setup completed
[    0.270293] iommu: Adding device 11000000.codec to group 0
[    0.273823] gpio gpiochip0: (gpy7): added GPIO chardev (254:0)
[    0.274128] gpiochip_setup_dev: registered GPIOs 0 to 7 on device: gpiochip0 (gpy7)
[    0.274171] gpio gpiochip1: (gpx0): added GPIO chardev (254:1)
[    0.274414] gpiochip_setup_dev: registered GPIOs 8 to 15 on device: gpiochip1 (gpx0)
[    0.274452] gpio gpiochip2: (gpx1): added GPIO chardev (254:2)
[    0.274692] gpiochip_setup_dev: registered GPIOs 16 to 23 on device: gpiochip2 (gpx1)
[    0.274730] gpio gpiochip3: (gpx2): added GPIO chardev (254:3)
[    0.275022] gpiochip_setup_dev: registered GPIOs 24 to 31 on device: gpiochip3 (gpx2)
[    0.275062] gpio gpiochip4: (gpx3): added GPIO chardev (254:4)
[    0.275304] gpiochip_setup_dev: registered GPIOs 32 to 39 on device: gpiochip4 (gpx3)
[    0.276662] gpio gpiochip5: (gpc0): added GPIO chardev (254:5)
[    0.276925] gpiochip_setup_dev: registered GPIOs 40 to 47 on device: gpiochip5 (gpc0)
[    0.276963] gpio gpiochip6: (gpc1): added GPIO chardev (254:6)
[    0.277217] gpiochip_setup_dev: registered GPIOs 48 to 55 on device: gpiochip6 (gpc1)
[    0.277264] gpio gpiochip7: (gpc2): added GPIO chardev (254:7)
[    0.277505] gpiochip_setup_dev: registered GPIOs 56 to 62 on device: gpiochip7 (gpc2)
[    0.277541] gpio gpiochip8: (gpc3): added GPIO chardev (254:8)
[    0.277775] gpiochip_setup_dev: registered GPIOs 63 to 66 on device: gpiochip8 (gpc3)
[    0.277812] gpio gpiochip9: (gpc4): added GPIO chardev (254:9)
[    0.278051] gpiochip_setup_dev: registered GPIOs 67 to 68 on device: gpiochip9 (gpc4)
[    0.278088] gpio gpiochip10: (gpd1): added GPIO chardev (254:10)
[    0.278336] gpiochip_setup_dev: registered GPIOs 69 to 76 on device: gpiochip10 (gpd1)
[    0.278374] gpio gpiochip11: (gpy0): added GPIO chardev (254:11)
[    0.278615] gpiochip_setup_dev: registered GPIOs 77 to 82 on device: gpiochip11 (gpy0)
[    0.278651] gpio gpiochip12: (gpy1): added GPIO chardev (254:12)
[    0.278897] gpiochip_setup_dev: registered GPIOs 83 to 86 on device: gpiochip12 (gpy1)
[    0.278934] gpio gpiochip13: (gpy2): added GPIO chardev (254:13)
[    0.279172] gpiochip_setup_dev: registered GPIOs 87 to 92 on device: gpiochip13 (gpy2)
[    0.279208] gpio gpiochip14: (gpy3): added GPIO chardev (254:14)
[    0.279460] gpiochip_setup_dev: registered GPIOs 93 to 100 on device: gpiochip14 (gpy3)
[    0.279505] gpio gpiochip15: (gpy4): added GPIO chardev (254:15)
[    0.279745] gpiochip_setup_dev: registered GPIOs 101 to 108 on device: gpiochip15 (gpy4)
[    0.279781] gpio gpiochip16: (gpy5): added GPIO chardev (254:16)
[    0.280039] gpiochip_setup_dev: registered GPIOs 109 to 116 on device: gpiochip16 (gpy5)
[    0.280077] gpio gpiochip17: (gpy6): added GPIO chardev (254:17)
[    0.280334] gpiochip_setup_dev: registered GPIOs 117 to 124 on device: gpiochip17 (gpy6)
[    0.281371] gpio gpiochip18: (gpe0): added GPIO chardev (254:18)
[    0.281630] gpiochip_setup_dev: registered GPIOs 125 to 132 on device: gpiochip18 (gpe0)
[    0.281668] gpio gpiochip19: (gpe1): added GPIO chardev (254:19)
[    0.281914] gpiochip_setup_dev: registered GPIOs 133 to 134 on device: gpiochip19 (gpe1)
[    0.281952] gpio gpiochip20: (gpf0): added GPIO chardev (254:20)
[    0.282195] gpiochip_setup_dev: registered GPIOs 135 to 140 on device: gpiochip20 (gpf0)
[    0.282247] gpio gpiochip21: (gpf1): added GPIO chardev (254:21)
[    0.282500] gpiochip_setup_dev: registered GPIOs 141 to 148 on device: gpiochip21 (gpf1)
[    0.282538] gpio gpiochip22: (gpg0): added GPIO chardev (254:22)
[    0.282783] gpiochip_setup_dev: registered GPIOs 149 to 156 on device: gpiochip22 (gpg0)
[    0.282821] gpio gpiochip23: (gpg1): added GPIO chardev (254:23)
[    0.283063] gpiochip_setup_dev: registered GPIOs 157 to 164 on device: gpiochip23 (gpg1)
[    0.283101] gpio gpiochip24: (gpg2): added GPIO chardev (254:24)
[    0.283353] gpiochip_setup_dev: registered GPIOs 165 to 166 on device: gpiochip24 (gpg2)
[    0.283391] gpio gpiochip25: (gpj4): added GPIO chardev (254:25)
[    0.283643] gpiochip_setup_dev: registered GPIOs 167 to 170 on device: gpiochip25 (gpj4)
[    0.284601] gpio gpiochip26: (gpa0): added GPIO chardev (254:26)
[    0.284873] gpiochip_setup_dev: registered GPIOs 171 to 178 on device: gpiochip26 (gpa0)
[    0.284911] gpio gpiochip27: (gpa1): added GPIO chardev (254:27)
[    0.285209] gpiochip_setup_dev: registered GPIOs 179 to 184 on device: gpiochip27 (gpa1)
[    0.285247] gpio gpiochip28: (gpa2): added GPIO chardev (254:28)
[    0.285507] gpiochip_setup_dev: registered GPIOs 185 to 192 on device: gpiochip28 (gpa2)
[    0.285545] gpio gpiochip29: (gpb0): added GPIO chardev (254:29)
[    0.285791] gpiochip_setup_dev: registered GPIOs 193 to 197 on device: gpiochip29 (gpb0)
[    0.285828] gpio gpiochip30: (gpb1): added GPIO chardev (254:30)
[    0.286073] gpiochip_setup_dev: registered GPIOs 198 to 202 on device: gpiochip30 (gpb1)
[    0.286109] gpio gpiochip31: (gpb2): added GPIO chardev (254:31)
[    0.286360] gpiochip_setup_dev: registered GPIOs 203 to 206 on device: gpiochip31 (gpb2)
[    0.286397] gpio gpiochip32: (gpb3): added GPIO chardev (254:32)
[    0.286642] gpiochip_setup_dev: registered GPIOs 207 to 214 on device: gpiochip32 (gpb3)
[    0.286678] gpio gpiochip33: (gpb4): added GPIO chardev (254:33)
[    0.286922] gpiochip_setup_dev: registered GPIOs 215 to 216 on device: gpiochip33 (gpb4)
[    0.286959] gpio gpiochip34: (gph0): added GPIO chardev (254:34)
[    0.287244] gpiochip_setup_dev: registered GPIOs 217 to 224 on device: gpiochip34 (gph0)
[    0.288301] gpio gpiochip35: (gpz): added GPIO chardev (254:35)
[    0.288560] gpiochip_setup_dev: registered GPIOs 225 to 231 on device: gpiochip35 (gpz)
[    0.295263] iommu: Adding device 14450000.mixer to group 1
[    0.295836] iommu: Adding device 11c00000.rotator to group 2
[    0.300233] iommu: Adding device 13e00000.video-scaler to group 3
[    0.300790] iommu: Adding device 13e10000.video-scaler to group 4
[    0.301328] iommu: Adding device 11f50000.jpeg to group 5
[    0.301860] iommu: Adding device 11f60000.jpeg to group 6
[    0.302274] EXYNOS5420 PMU initialized
[    0.339532] SCSI subsystem initialized
[    0.340033] usbcore: registered new interface driver usbfs
[    0.340150] usbcore: registered new interface driver hub
[    0.340362] usbcore: registered new device driver usb
[    0.341453] s3c-i2c 12c80000.i2c: slave address 0x00
[    0.341476] s3c-i2c 12c80000.i2c: bus frequency set to 65 KHz
[    0.342186] s3c-i2c 12c80000.i2c: i2c-2: S3C I2C adapter
[    0.343495] Advanced Linux Sound Architecture Driver Initialized.
[    0.345935] clocksource: Switched to clocksource mct-frc
[    0.368444] NET: Registered protocol family 2
[    0.369325] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.369455] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    0.369834] TCP: Hash tables configured (established 8192 bind 8192)
[    0.370007] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    0.370083] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    0.370450] NET: Registered protocol family 1
[    0.371084] RPC: Registered named UNIX socket transport module.
[    0.371100] RPC: Registered udp transport module.
[    0.371111] RPC: Registered tcp transport module.
[    0.371121] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.371450] Trying to unpack rootfs image as initramfs...
[    0.573475] Freeing initrd memory: 2912K (c2000000 - c22d8000)
[    0.579452] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.580286] workingset: timestamp_bits=28 max_order=19 bucket_order=0
[    0.602465] NFS: Registering the id_resolver key type
[    0.602526] Key type id_resolver registered
[    0.602538] Key type id_legacy registered
[    0.602631] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
[    0.604722] bounce: pool size: 64 pages
[    0.605141] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.605167] io scheduler noop registered
[    0.605186] io scheduler deadline registered
[    0.605572] io scheduler cfq registered (default)
[    0.608472] 12130000.phy supply vbus not found, using dummy regulator
[    0.609825] 12100000.phy supply vbus not found, using dummy regulator
[    0.609931] 12100000.phy supply vbus-boost not found, using dummy regulator
[    0.610520] 12500000.phy supply vbus not found, using dummy regulator
[    0.610598] 12500000.phy supply vbus-boost not found, using dummy regulator
[    0.616098] dma-pl330 3880000.adma: Loaded driver for PL330 DMAC-241330
[    0.616120] dma-pl330 3880000.adma:  DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6
[    0.622020] dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330
[    0.622039] dma-pl330 121a0000.pdma:         DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    0.627922] dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330
[    0.627943] dma-pl330 121b0000.pdma:         DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    0.629628] dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330
[    0.629647] dma-pl330 10800000.mdma:         DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
[    0.751522] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.755070] 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 76, base_baud = 0) is a S3C6400/10
[    0.755777] 12c10000.serial: ttySAC1 at MMIO 0x12c10000 (irq = 77, base_baud = 0) is a S3C6400/10
[    0.756514] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 78, base_baud = 0) is a S3C6400/10
[    0.757375] console [ttySAC2] enabled
[    0.758058] 12c30000.serial: ttySAC3 at MMIO 0x12c30000 (irq = 79, base_baud = 0) is a S3C6400/10
[    0.759723] [drm] Initialized drm 1.1.0 20060810
[    0.762381] exynos-hdmi 14530000.hdmi: GPIO lookup for consumer hpd
[    0.762398] exynos-hdmi 14530000.hdmi: using device tree for GPIO lookup
[    0.762416] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/hdmi@14530000[0]'
[    0.762442] of_get_named_gpiod_flags: parsed 'hpd-gpio' property of node '/hdmi@14530000[0]' - status (0)
[    0.762700] exynos-hdmi 14530000.hdmi: Failed to get supply 'vdd': -517
[    0.762726] [drm:hdmi_probe] *ERROR* failed to get regulators
[    0.762740] [drm:hdmi_probe] *ERROR* hdmi_resources_init failed
[    0.789343] brd: module loaded
[    0.814028] loop: module loaded
[    0.815724] usbcore: registered new interface driver r8152
[    0.815865] usbcore: registered new interface driver asix
[    0.816024] usbcore: registered new interface driver ax88179_178a
[    0.816123] usbcore: registered new interface driver cdc_ether
[    0.816249] usbcore: registered new interface driver smsc75xx
[    0.816378] usbcore: registered new interface driver smsc95xx
[    0.816471] usbcore: registered new interface driver net1080
[    0.816566] usbcore: registered new interface driver cdc_subset
[    0.816669] usbcore: registered new interface driver zaurus
[    0.816833] usbcore: registered new interface driver cdc_ncm
[    0.817988] exynos-dwc3 usb@12000000: no suspend clk specified
[    0.818601] exynos-dwc3 usb@12400000: no suspend clk specified
[    0.819487] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.819507] ehci-exynos: EHCI EXYNOS driver
[    0.819831] of_get_named_gpiod_flags: can't parse 'samsung,vbus-gpio' property of node '/usb@12110000[0]'
[    0.820137] exynos-ehci 12110000.usb: EHCI Host Controller
[    0.820200] exynos-ehci 12110000.usb: new USB bus registered, assigned bus number 1
[    0.820591] exynos-ehci 12110000.usb: irq 130, io mem 0x12110000
[    0.826021] exynos-ehci 12110000.usb: USB 2.0 started, EHCI 1.00
[    0.826328] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.826346] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.826361] usb usb1: Product: EHCI Host Controller
[    0.826375] usb usb1: Manufacturer: Linux 4.6.2-odroidxu4-dirty ehci_hcd
[    0.826389] usb usb1: SerialNumber: 12110000.usb
[    0.827612] hub 1-0:1.0: USB hub found
[    0.827671] hub 1-0:1.0: 3 ports detected
[    0.828818] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.828856] ohci-exynos: OHCI EXYNOS driver
[    0.829371] exynos-ohci 12120000.usb: USB Host Controller
[    0.829425] exynos-ohci 12120000.usb: new USB bus registered, assigned bus number 2
[    0.829638] exynos-ohci 12120000.usb: irq 130, io mem 0x12120000
[    0.885276] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    0.885295] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.885310] usb usb2: Product: USB Host Controller
[    0.885324] usb usb2: Manufacturer: Linux 4.6.2-odroidxu4-dirty ohci_hcd
[    0.885338] usb usb2: SerialNumber: 12120000.usb
[    0.886528] hub 2-0:1.0: USB hub found
[    0.886585] hub 2-0:1.0: 3 ports detected
[    0.888342] usbcore: registered new interface driver usb-storage
[    0.888845] udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers
[    0.889473] mousedev: PS/2 mouse device common for all mice
[    0.891988] i2c /dev entries driver
[    0.913293] vdd_ldo9: ramp_delay not set
[    0.922331] vdd_ldo13: ramp_delay not set
[    0.928081] vdd_ldo15: ramp_delay not set
[    0.937274] vdd_sd: ramp_delay not set
[    0.989463] s5m-rtc s2mps14-rtc: rtc core: registered s5m-rtc as rtc0
[    0.997085] exynos-tmu 10060000.tmu: More trip points than supported by this TMU.
[    0.997106] exynos-tmu 10060000.tmu: 2 trip points should be configured in polling mode.
[    1.002308] s3c2410-wdt 101d0000.watchdog: watchdog inactive, reset disabled, irq disabled
[    1.003263] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.004030] sdhci: Secure Digital Host Controller Interface driver
[    1.004041] sdhci: Copyright(c) Pierre Ossman
[    1.004390] Synopsys Designware Multimedia Card Interface Driver
[    1.005477] dwmmc_exynos 12200000.mmc: IDMAC supports 32-bit address mode.
[    1.005619] dwmmc_exynos 12200000.mmc: Using internal DMA controller.
[    1.005642] dwmmc_exynos 12200000.mmc: Version ID is 250a
[    1.005728] dwmmc_exynos 12200000.mmc: DW MMC controller at irq 83,64 bit host data width,64 deep fifo
[    1.005902] dwmmc_exynos 12200000.mmc: GPIO lookup for consumer cd
[    1.005964] dwmmc_exynos 12200000.mmc: using device tree for GPIO lookup
[    1.005997] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/mmc@12200000[0]' - status (0)
[    1.006033] dwmmc_exynos 12200000.mmc: Got CD GPIO
[    1.006050] dwmmc_exynos 12200000.mmc: GPIO lookup for consumer wp
[    1.006063] dwmmc_exynos 12200000.mmc: using device tree for GPIO lookup
[    1.006078] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@12200000[0]'
[    1.006093] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@12200000[0]'
[    1.006106] dwmmc_exynos 12200000.mmc: using lookup tables for GPIO lookup
[    1.006122] dwmmc_exynos 12200000.mmc: lookup for GPIO wp failed
[    1.006292] platform pwrseq: GPIO lookup for consumer reset
[    1.006306] platform pwrseq: using device tree for GPIO lookup
[    1.006331] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/pwrseq[0]' - status (0)
[    1.006363] dwmmc_exynos 12200000.mmc: allocated mmc-pwrseq
[    1.037398] dwmmc_exynos 12200000.mmc: 1 slots initialized
[    1.037881] dwmmc_exynos 12220000.mmc: IDMAC supports 32-bit address mode.
[    1.037980] dwmmc_exynos 12220000.mmc: Using internal DMA controller.
[    1.038001] dwmmc_exynos 12220000.mmc: Version ID is 250a
[    1.038083] dwmmc_exynos 12220000.mmc: DW MMC controller at irq 84,64 bit host data width,64 deep fifo
[    1.038242] dwmmc_exynos 12220000.mmc: GPIO lookup for consumer cd
[    1.038257] dwmmc_exynos 12220000.mmc: using device tree for GPIO lookup
[    1.038273] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/mmc@12220000[0]'
[    1.038288] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/mmc@12220000[0]'
[    1.038302] dwmmc_exynos 12220000.mmc: using lookup tables for GPIO lookup
[    1.038317] dwmmc_exynos 12220000.mmc: lookup for GPIO cd failed
[    1.038334] dwmmc_exynos 12220000.mmc: GPIO lookup for consumer wp
[    1.038347] dwmmc_exynos 12220000.mmc: using device tree for GPIO lookup
[    1.038361] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@12220000[0]'
[    1.038376] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@12220000[0]'
[    1.038389] dwmmc_exynos 12220000.mmc: using lookup tables for GPIO lookup
[    1.038404] dwmmc_exynos 12220000.mmc: lookup for GPIO wp failed
[    1.066063] dwmmc_exynos 12220000.mmc: 1 slots initialized
[    1.071896] s5p-secss 10830000.sss: s5p-sss driver registered
[    1.073307] usbcore: registered new interface driver usbhid
[    1.073319] usbhid: USB HID core driver
[    1.081248] NET: Registered protocol family 10
[    1.082306] sit: IPv6 over IPv4 tunneling driver
[    1.083341] NET: Registered protocol family 17
[    1.083390] NET: Registered protocol family 15
[    1.083510] Key type dns_resolver registered
[    1.084254] Registering SWP/SWPB emulation handler
[    1.084279] big.LITTLE switcher initializing
[    1.084292] CPU0 paired with CPU7
[    1.084303] CPU1 paired with CPU6
[    1.084314] CPU2 paired with CPU5
[    1.084324] CPU3 paired with CPU4
[    1.084334] GIC ID for CPU 0 cluster 1 is 4
[    1.084345] GIC ID for CPU 1 cluster 1 is 5
[    1.084354] GIC ID for CPU 2 cluster 1 is 6
[    1.084364] GIC ID for CPU 3 cluster 1 is 7
[    1.084373] GIC ID for CPU 0 cluster 0 is 0
[    1.099901] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    1.099997] mmc1: new high speed SDHC card at address 59b4
[    1.100822] mmcblk1: mmc1:59b4       29.8 GiB
[    1.102406]  mmcblk1: p1 p2
[    1.111302] IRQ53 no longer affine to CPU4
[    1.111655] CPU4: shutdown
[    1.141540] GIC ID for CPU 1 cluster 0 is 1
[    1.156309] IRQ54 no longer affine to CPU5
[    1.156607] CPU5: shutdown
[    1.185770] GIC ID for CPU 2 cluster 0 is 2
[    1.201279] IRQ55 no longer affine to CPU6
[    1.201573] CPU6: shutdown
[    1.230138] GIC ID for CPU 3 cluster 0 is 3
[    1.241285] IRQ56 no longer affine to CPU7
[    1.241574] CPU7: shutdown
[    1.270004] big.LITTLE switcher initialized
[    1.272188] exynos-hdmi 14530000.hdmi: GPIO lookup for consumer hpd
[    1.272208] exynos-hdmi 14530000.hdmi: using device tree for GPIO lookup
[    1.272226] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/hdmi@14530000[0]'
[    1.272252] of_get_named_gpiod_flags: parsed 'hpd-gpio' property of node '/hdmi@14530000[0]' - status (0)
[    1.277041] [drm] Exynos DRM: using 14450000.mixer device for DMA mapping operations
[    1.277460] exynos-drm exynos-drm: bound 14450000.mixer (ops mixer_component_ops)
[    1.277826] exynos-drm exynos-drm: bound 14530000.hdmi (ops hdmi_component_ops)
[    1.277842] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.277853] [drm] No driver support for vblank timestamp query.
[    1.277903] [drm] Initialized exynos 1.0.0 20110530 on minor 0
[    1.278871] exynos-dwc3 usb@12000000: no suspend clk specified
[    1.281315] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    1.281371] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3
[    1.281852] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    1.281941] xhci-hcd xhci-hcd.6.auto: irq 135, io mem 0x12000000
[    1.282226] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.282244] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.282259] usb usb3: Product: xHCI Host Controller
[    1.282274] usb usb3: Manufacturer: Linux 4.6.2-odroidxu4-dirty xhci-hcd
[    1.282288] usb usb3: SerialNumber: xhci-hcd.6.auto
[    1.283414] hub 3-0:1.0: USB hub found
[    1.283473] hub 3-0:1.0: 1 port detected
[    1.284185] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    1.284222] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4
[    1.284368] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.284569] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    1.284587] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.284601] usb usb4: Product: xHCI Host Controller
[    1.284615] usb usb4: Manufacturer: Linux 4.6.2-odroidxu4-dirty xhci-hcd
[    1.284629] usb usb4: SerialNumber: xhci-hcd.6.auto
[    1.285736] hub 4-0:1.0: USB hub found
[    1.285789] hub 4-0:1.0: 1 port detected
[    1.287598] exynos-dwc3 usb@12400000: no suspend clk specified
[    1.289885] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    1.289940] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[    1.290405] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    1.290504] xhci-hcd xhci-hcd.9.auto: irq 136, io mem 0x12400000
[    1.290782] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    1.290801] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.290816] usb usb5: Product: xHCI Host Controller
[    1.290830] usb usb5: Manufacturer: Linux 4.6.2-odroidxu4-dirty xhci-hcd
[    1.290844] usb usb5: SerialNumber: xhci-hcd.9.auto
[    1.292050] hub 5-0:1.0: USB hub found
[    1.292108] hub 5-0:1.0: 1 port detected
[    1.292768] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    1.292804] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[    1.292946] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.293159] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    1.293177] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.293192] usb usb6: Product: xHCI Host Controller
[    1.293206] usb usb6: Manufacturer: Linux 4.6.2-odroidxu4-dirty xhci-hcd
[    1.293220] usb usb6: SerialNumber: xhci-hcd.9.auto
[    1.294301] hub 6-0:1.0: USB hub found
[    1.294354] hub 6-0:1.0: 1 port detected
[    1.296034] s3c-rtc 101e0000.rtc: rtc disabled, re-enabling
[    1.296576] s3c-rtc 101e0000.rtc: rtc core: registered s3c as rtc1
[    1.299114] s5m-rtc s2mps14-rtc: setting system clock to 2016-06-19 23:36:23 UTC (1466379383)
[    1.311143] Power domain power-domain@10044120 disable failed
[    1.333840] ALSA device list:
[    1.333863]   No soundcards found.
[    1.336852] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
[    1.396753] systemd-udevd[160]: starting version 215
[    1.399502] random: systemd-udevd urandom read with 118 bits of entropy available
[    1.596029] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    1.769019] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610
[    1.769044] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.769059] usb 3-1: Product: USB2.0 Hub
[    1.769074] usb 3-1: Manufacturer: GenesysLogic
[    1.771131] usb 5-1: new high-speed USB device number 3 using xhci-hcd
[    1.797670] hub 3-1:1.0: USB hub found
[    1.798068] hub 3-1:1.0: 2 ports detected
[    1.843177] random: nonblocking pool is initialized
[    1.876191] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    1.893898] usb 4-1: New USB device found, idVendor=05e3, idProduct=0616
[    1.893924] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.893940] usb 4-1: Product: USB3.0 Hub
[    1.893953] usb 4-1: Manufacturer: GenesysLogic
[    1.897687] usb 5-1: New USB device found, idVendor=0bda, idProduct=8153
[    1.897713] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    1.897733] usb 5-1: Product: USB 10/100/1000 LAN
[    1.897747] usb 5-1: Manufacturer: Realtek
[    1.897761] usb 5-1: SerialNumber: 000001000000
[    1.909431] hub 4-1:1.0: USB hub found
[    1.909773] hub 4-1:1.0: 2 ports detected
[    2.044973] usb 5-1: reset high-speed USB device number 3 using xhci-hcd
[    2.181221] usb 4-1.2: new SuperSpeed USB device number 3 using xhci-hcd
[    2.199344] usb 4-1.2: New USB device found, idVendor=05e3, idProduct=0735
[    2.199363] usb 4-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.199379] usb 4-1.2: Product: USB3.0 SATA Bridge
[    2.199393] usb 4-1.2: Manufacturer: USB Storage
[    2.199407] usb 4-1.2: SerialNumber: 0000000000000033
[    2.201395] usb-storage 4-1.2:1.0: USB Mass Storage device detected
[    2.202023] scsi host0: usb-storage 4-1.2:1.0
[    2.205173] r8152 5-1:1.0 eth0: v1.08.3
[    2.391082] usb 4-1.1: new SuperSpeed USB device number 4 using xhci-hcd
[    2.638189] usb 4-1.1: New USB device found, idVendor=2109, idProduct=0812
[    2.638208] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.638223] usb 4-1.1: Product: USB3.0 Hub
[    2.638238] usb 4-1.1: Manufacturer: VIA Labs, Inc.
[    2.644862] hub 4-1.1:1.0: USB hub found
[    2.645092] hub 4-1.1:1.0: 4 ports detected
[    2.706019] usb 3-1.1: new high-speed USB device number 3 using xhci-hcd
[    2.792731] usb 3-1.1: New USB device found, idVendor=2109, idProduct=2812
[    2.792757] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.792772] usb 3-1.1: Product: USB2.0 Hub
[    2.792786] usb 3-1.1: Manufacturer: VIA Labs, Inc.
[    2.821270] hub 3-1.1:1.0: USB hub found
[    2.821528] hub 3-1.1:1.0: 4 ports detected
[    2.879760] EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Opts: (null)
[    3.106005] usb 3-1.1.4: new full-speed USB device number 4 using xhci-hcd
[    3.178976] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    3.179302] systemd[1]: Detected architecture 'arm'.
[    3.202566] systemd[1]: Set hostname to <odroidxu4>.
[    3.203745] usb 3-1.1.4: New USB device found, idVendor=04d8, idProduct=f5fe
[    3.203766] usb 3-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.203781] usb 3-1.1.4: Product: TrueRNG
[    3.203795] usb 3-1.1.4: Manufacturer: ubld.it
[    3.231101] scsi 0:0:0:0: Direct-Access     Genesys  USB3/SATA Bridge 1003 PQ: 0 ANSI: 6
[    3.232641] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    3.561125] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    3.564353] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    3.564825] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.564914] systemd[1]: Expecting device dev-ttySAC2.device...
[    3.576139] systemd[1]: Starting Remote File Systems (Pre).
[    3.591092] systemd[1]: Reached target Remote File Systems (Pre).
[    3.591210] systemd[1]: Starting Encrypted Volumes.
[    3.601096] systemd[1]: Reached target Encrypted Volumes.
[    3.601220] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    3.601560] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.601634] systemd[1]: Starting Paths.
[    3.611089] systemd[1]: Reached target Paths.
[    3.611264] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.611329] systemd[1]: Starting Swap.
[    3.621125] systemd[1]: Reached target Swap.
[    3.621213] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    3.631139] systemd[1]: Starting Root Slice.
[    3.641086] systemd[1]: Created slice Root Slice.
[    3.641172] systemd[1]: Starting User and Session Slice.
[    3.651095] systemd[1]: Created slice User and Session Slice.
[    3.651180] systemd[1]: Starting Delayed Shutdown Socket.
[    3.661093] systemd[1]: Listening on Delayed Shutdown Socket.
[    3.661178] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    3.676090] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.676171] systemd[1]: Starting Journal Socket (/dev/log).
[    3.691086] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.691202] systemd[1]: Starting udev Control Socket.
[    3.701084] systemd[1]: Listening on udev Control Socket.
[    3.701187] systemd[1]: Starting udev Kernel Socket.
[    3.711084] systemd[1]: Listening on udev Kernel Socket.
[    3.711190] systemd[1]: Starting Journal Socket.
[    3.721093] systemd[1]: Listening on Journal Socket.
[    3.721239] systemd[1]: Starting System Slice.
[    3.731093] systemd[1]: Created slice System Slice.
[    3.731218] systemd[1]: Started File System Check on Root Device.
[    3.731282] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    3.746096] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.746179] systemd[1]: Starting system-serial\x2dgetty.slice.
[    3.761086] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    3.761167] systemd[1]: Starting system-getty.slice.
[    3.771089] systemd[1]: Created slice system-getty.slice.
[    3.771288] systemd[1]: Starting Increase datagram queue length...
[    3.806773] systemd[1]: Starting Restore / save the current clock...
[    3.826435] systemd[1]: Mounting Debug File System...
[    3.839539] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    3.859403] systemd[1]: Mounted POSIX Message Queue File System.
[    3.891079] systemd[1]: Started Set Up Additional Binary Formats.
[    3.891244] systemd[1]: Starting udev Coldplug all Devices...
[    3.917694] systemd[1]: Starting Load Kernel Modules...
[    3.934638] systemd[1]: Mounted Huge Pages File System.
[    3.934836] systemd[1]: Starting LSB: Set keymap...
[    3.949504] systemd[1]: Starting Slices.
[    3.961258] systemd[1]: Reached target Slices.
[    3.976165] systemd[1]: Mounted Debug File System.
[    3.991194] systemd[1]: Started Increase datagram queue length.
[    4.011126] systemd[1]: Started Restore / save the current clock.
[    4.031167] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    4.053012] systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE
[    4.081194] systemd[1]: Failed to start Load Kernel Modules.
[    4.081282] systemd[1]: Unit systemd-modules-load.service entered failed state.
[    4.096223] systemd[1]: Started LSB: Set keymap.
[    4.218178] systemd[1]: Starting Apply Kernel Variables...
[    4.252379] systemd[1]: Mounting Configuration File System...
[    4.270706] systemd[1]: Mounted FUSE Control File System.
[    4.271432] systemd[1]: Starting Create Static Device Nodes in /dev...
[    4.289360] systemd[1]: Starting Syslog Socket.
[    4.301305] systemd[1]: Listening on Syslog Socket.
[    4.301477] systemd[1]: Starting Journal Service...
[    4.326435] systemd[1]: Started Journal Service.
[    4.506229] systemd-udevd[269]: starting version 215
[    4.720657] sd 0:0:0:0: [sda] Spinning up disk...
[    5.851023] .ready
[    5.851623] sd 0:0:0:0: [sda] 976773152 512-byte logical blocks: (500 GB/466 GiB)
[    5.852446] sd 0:0:0:0: [sda] Write Protect is off
[    5.852471] sd 0:0:0:0: [sda] Mode Sense: 5f 00 10 08
[    5.853239] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[    5.914061]  sda: sda1
[    5.918599] sd 0:0:0:0: [sda] Attached SCSI disk
[   10.971562] EXT4-fs (mmcblk1p2): re-mounted. Opts: commit=600,errors=remount-ro
[   94.310221] systemd-journald[267]: Received request to flush runtime journal from PID 1
[   94.661542] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   98.525970] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
ok, I have updated /etc/fstab => /dev/mmcblk1p1 and /dev/mmcblk1p2
with the running image and rebooted... that's better
is it easy to update /etc/fstab during image creation? I guess/hope so
ok I am going to sleep :)
console ttySAC2
U-Boot 2012.07 (Jun 20 2016 - 00:59:06) for Exynos5422
CPU: Exynos5422 Rev0.1 [Samsung SOC on SMP Platform Base on ARM CortexA7]
APLL = 800MHz, KPLL = 800MHz
MPLL = 532MHz, BPLL = 825MHz
Board: HardKernel ODROID
DRAM:  2 GiB
WARNING: Caches not enabled
TrustZone Enabled BSP
BL1 version: â/âââ
VDD_KFC: 0x44
LDO19: 0xf2
Checking Boot Mode ... SDMMC
MMC:   S5P_MSHC2: 0, S5P_MSHC0: 1
MMC Device 0: 29.8 GiB
MMC Device 1: [ERROR] response error : 00000006 cmd 8
[ERROR] response error : 00000006 cmd 55
[ERROR] response error : 00000006 cmd 2
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Press quickly 'Enter' twice to stop autoboot:  0
there are pending interrupts 0x00000001
reading boot.ini
8719 bytes read
Loading boot.ini from FAT
Find boot.ini file from FAT/Ext4 Area!!
boot.ini command = setenv initrd_high "0xffffffff"
boot.ini command = setenv fdt_high "0xffffffff"
boot.ini command = setenv macaddr "00:1e:06:61:7a:55
boot.ini command = setenv bootrootfs "console=tty1 console=ttySAC2,115200n8 loglevel=1 root=/dev/mmcblk1p2 rootwait ro fsck.repair=yes"
boot.ini command = setenv bootcmd "fatload mmc 0:1 0x40008000 zImage; fatload mmc 0:1 0x42000000 uInitrd; fatload mmc 0:1 0x44000000 dtb/exynos5422-odroidxu4.dtb; bootz 0x40008000 0x42000000 0x44000000"
boot.ini command = setenv vout "hdmi"
boot.ini command = setenv governor "conservative"
boot.ini command = setenv HPD "true"
boot.ini command = setenv hdmi_tx_amp_lvl  "31"
boot.ini command = setenv hdmi_tx_lvl_ch0      "3"
boot.ini command = setenv hdmi_tx_lvl_ch1      "3"
boot.ini command = setenv hdmi_tx_lvl_ch2      "3"
boot.ini command = setenv hdmi_tx_emp_lvl      "6"
boot.ini command = setenv hdmi_clk_amp_lvl     "31"
boot.ini command = setenv hdmi_tx_res      "0"
boot.ini command = setenv hdmi_phy_control "hdmi_tx_amp_lvl=${hdmi_tx_amp_lvl} hdmi_tx_lvl_ch0=${hdmi_tx_lvl_ch0} hdmi_tx_lvl_ch1=${hdmi_tx_lvl_ch1} hdmi_tx_lvl_ch2=${hdmi_tx_lvl_ch2} hdmi_tx_emp_lvl=${hdmi_tx_emp_lvl} hdmi_clk_amp_lvl=${hdmi_clk_amp_lvl} hdmi_tx_res=${hdmi_tx_res} HPD=${HPD} vout=${vout}"
boot.ini command = setenv bootargs "${bootrootfs} ${videoconfig} smsc95xx.macaddr=${macaddr} governor=${governor} ${hdmi_phy_control}"
boot.ini command = boot
reading zImage
4450808 bytes read
reading uInitrd
2979294 bytes read
reading dtb/exynos5422-odroidxu4.dtb
47808 bytes read
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd
   Data Size:    2979230 Bytes = 2.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
## Flattened Device Tree blob at 44000000
   Booting using the fdt blob at 0x44000000
   Using Device Tree in place at 44000000, end 4400eabf
Starting kernel ...
Loading, please wait...
Begin: Running /scripts/local-premount ... done.
Begin: Will now check root file system ... fsck from util-linux 2.25.2
[/sbin/fsck.ext4 (1) -- /dev/mmcblk1p2] fsck.ext4 -y -C0 /dev/mmcblk1p2
e2fsck 1.42.12 (29-Aug-2014)
/dev/mmcblk1p2: clean, 48589/81920 files, 225056/327424 blocks
done.
done.
Welcome to Debian GNU/Linux 8 (jessie)!
[  OK  ] Reached target Remote File Systems (Pre).
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Swap.
         Expecting device dev-mmcblk1p1.device...
[  OK  ] Created slice Root Slice.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on Delayed Shutdown Socket.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on Journal Socket.
[  OK  ] Created slice System Slice.
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-getty.slice.
         Starting Create list of required static device nodes...rrent kernel...
[  OK  ] Reached target Slices.
[  OK  ] Mounted Debug File System.
[  OK  ] Started Increase datagram queue length.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Create list of required static device nodes ...current kernel.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started LSB: Set keymap.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Configuration File System.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[  OK  ] Started udev Kernel Device Manager.
         Starting Copy rules generated while the root was ro...
         Starting LSB: Tune IDE hard disks...
         Starting LSB: Set preliminary keymap...
[  OK  ] Started Copy rules generated while the root was ro.
[  OK  ] Started LSB: Tune IDE hard disks.
[  OK  ] Found device /dev/ttySAC2.
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[    5.390202] systemd-fsck[314]: fsck.fat 3.0.27 (2014-11-12)
[    5.392130] systemd-fsck[314]: /dev/mmcblk1p1: 71 files, 9437/16343 clusters
[  OK  ] Started File System Check on /dev/mmcblk1p1.
[  OK  ] Started LSB: Set preliminary keymap.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
         Mounting /boot...
[  OK  ] Mounted /tmp.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Mounted /boot.
[  OK  ] Created slice system-ifup.slice.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting LSB: Raise network interfaces....
[  OK  ] Reached target Remote File Systems.
         Starting Trigger Flushing of Journal to Persistent Storage...
         Starting LSB: Prepare console...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Trigger Flushing of Journal to Persistent Storage.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started LSB: Prepare console.
         Starting LSB: Set console font and keymap...
[  OK  ] Started LSB: Raise network interfaces..
         Starting ifup for eth0...
[  OK  ] Started ifup for eth0.
[  OK  ] Reached target Network.
[  OK  ] Reached target Network is Online.
[  OK  ] Started LSB: Set console font and keymap.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Timers.
[  OK  ] Reached target Basic System.
         Starting Entropy daemon using the HAVEGE algorithm...
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
         Starting Regular background program processing daemon...
[  OK  ] Started Regular background program processing daemon.
         Starting OpenBSD Secure Shell server...
[  OK  ] Started OpenBSD Secure Shell server.
         Starting /etc/rc.local Compatibility...
         Starting Login Service...
         Starting LSB: Start NTP daemon...
         Starting LSB: disk temperature monitoring daemon...
         Starting LSB: Armbian gathering hardware information...
         Starting LSB: Start/stop sysstat's sadc...
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
         Starting LSB: Starts LIRC daemon....
         Starting D-Bus System Message Bus...
[  OK  ] Started D-Bus System Message Bus.
         Starting System Logging Service...
         Starting Permit User Sessions...
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started LSB: Start NTP daemon.
[  OK  ] Started LSB: disk temperature monitoring daemon.
[  OK  ] Started LSB: Start/stop sysstat's sadc.
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[  OK  ] Started LSB: Starts LIRC daemon..
[  OK  ] Started Permit User Sessions.
[  OK  ] Started System Logging Service.
         Starting LSB: set CPUFreq kernel parameters...
         Starting Serial Getty on ttySAC2...
[  OK  ] Started Serial Getty on ttySAC2.
         Starting Getty on tty1...
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started LSB: set CPUFreq kernel parameters.
[  OK  ] Started Login Service.
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
[  OK  ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Started LSB: Armbian gathering hardware information.
         Starting LSB: PLEASE BE PATIENT AND DO NOT INTERRUPT...FIRST REBOOT...
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started LSB: PLEASE BE PATIENT AND DO NOT INTERRUPT THE FIRST REBOOT.
[  OK  ] Started Update UTMP about System Runlevel Changes.
Debian GNU/Linux 8 odroidxu4 ttySAC2
Xenial CLI image with 4.6.2
http://www.armbian.com/odroid-xu4/
No idea if it boots. My XU4 is in action ;)
working yes but on SDcard only
after writing the image to SD, /etc/fstab has to be update with mmcblk1
gr@odroidxu4:~$ cat /etc/fstab
/dev/mmcblk1p2 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
/dev/mmcblk1p1 /boot vfat defaults 0 2
tmpfs /tmp tmpfs defaults,nosuid 0 0
I check :)
edit:
or before writing the image, using the loopback recipe
https://github.com/golfromeo-fr/piclone
2/ attach the file to a loopback device (example "/dev/loop0")	sudo losetup /dev/loop0 PicloneSAVE_YYYY_MM_DD.bin3/ use piclone with /dev/loop0 as target4/ detach loop device 	sudo losetup -d /dev/loop05/ you can use md5sum / sha1sum / sha256sum on the file PicloneSAVE_YYYY_MM_DD.bin as usual6/ you can zip the image using 7zip or another compression tool
or better
kpartx on the image file
gr@gr /media/syno/xu4_armbian $ sudo kpartx -av Armbian_5.14_Odroidxu4_Ubuntu_xenial_4.6.2.raw
add map loop1p1 (252:3): 0 65536 linear /dev/loop1 4096
add map loop1p2 (252:4): 0 3078144 linear /dev/loop1 69632
gr@gr /media/syno/xu4_armbian $ sudo mount /dev/mapper/loop1p1 p1
gr@gr /media/syno/xu4_armbian $ sudo mount /dev/mapper/loop1p2 p2
gr@gr /media/syno/xu4_armbian $ sudo umount p1
gr@gr /media/syno/xu4_armbian $ sudo umount p2
gr@gr /media/syno/xu4_armbian $ sudo kpartx -dv Armbian_5.14_Odroidxu4_Ubuntu_xenial_4.6.2.raw
del devmap : loop1p2
del devmap : loop1p1
loop deleted : /dev/loop1
then installing rpimonitor as per https://github.com/XavierBerger/RPi-Monitor-deb/issues/6
wget -O rpimonitor_2.10-1_all.deb https://github.com/XavierBerger/RPi-Monitor-deb/blob/master/repo/rpimonitor_2.10-1_all.deb?raw=true
sudo dpkg -i  rpimonitor_2.10-1_all.deb
sudo apt-get -f install
so I can testing XU4 SoC heating on load
Edited by wildcat_paris
kpartx rpimonitor
@Igor
stuck at first boot... no way to login as root (as usual ;) )with USB-UART and I don't see DHCP request (so no network). let's try keyboard and screen
U-Boot 2012.07 (Jun 21 2016 - 18:19:42) for Exynos5422
DRAM:  2 GiB
BL1 version: â/âââ
VDD_KFC: 0x44
LDO19: 0xf2
In:    serial
Out:   serial
Err:   serial
reading boot.ini
8719 bytes read
reading zImage
4466488 bytes read
reading uInitrd
2819799 bytes read
47808 bytes read
   Image Name:   uInitrd
   Data Size:    2819735 Bytes = 2.7 MiB
Starting kernel ...
starting version 229
Warning: fsck not present, so skipping root file system
done.
Welcome to Ubuntu 16.04 LTS!
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
         Starting Create list of required st... nodes for the current kernel...
         Starting Nameserver information manager...
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Listening on fsck to fsckd communication Socket.
         Starting File System Check on Root Device...
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started File System Check on Root Device.
[  OK  ] Started Nameserver information manager.
[  OK  ] Started File System Check Daemon to report status.
         Mounting /tmp...
         Activating swap /var/swap...
[  OK  ] Activated swap /var/swap.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Flush Journal to Persistent Storage.
         Mounting /boot...
         Starting Raise network interfaces...
         Starting Set console keymap...
[  OK  ] Started Set console keymap.
[  OK  ] Started Raise network interfaces.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily apt activities.
[  OK  ] Started Daily Cleanup of Temporary Directories.
         Starting LSB: Set the CPU Frequency Scaling governor to "ondemand"...
[  OK  ] Started LSB: Set the CPU Frequency Scaling governor to "ondemand".
Ubuntu 16.04 LTS odroidxu4 ttySAC2
odroidxu4 login:
odroidxu4 login: root
Login incorrect
odroidxu4 login:
Password:
Login incorrect
odroidxu4 login:
Login timed out after 60 sec
odroidxu4 login:
You mean it works on SD but id doesn't work on eMMC ?
This shoul have change it ..
if [[ $BOARD == odroidxu4 && $BRANCH == next && -f $CACHEDIR/sdcard/etc/fstab ]] ; then
		sed -e 's/mmcblk0/mmcblk1/g' -i $CACHEDIR/sdcard/etc/fstab
fi
fi
well I had to change the mmcblk0 with mmcblk1 on the image before writing to SDcard
edit: the image I have downloaded from armbian.com (so with your quick fix)
edit2: I don't know if it can work on eMMC at all without UUID
UUID
@Igor,
- the /etc/fstab fix doesn't work
- the main issue so far is Jessie loads the USB3-Ethernet module. Xenial doesn't.
- the network module is built in so ok in dmesg
- issue => dmesg says ethernet interface renamed from eth0 and so no eth0 configured in /etc/network/interfaces !!!
(well also I am stuck with a qwerty keyboard but I know the layout on my azerty layout)
qwerty network
sorry to comment this so late. I can confirm I tried already last week this: xenial + odroidxu4 = not booting properly.  DHCP / Eth0 issue. I think this bug was fixed with jessie, not Xenial. I gave up trying to fix eth0.
network is back
gr@odroidxu4:~$ dmesg  | grep 8152
[    0.754425] usbcore: registered new interface driver r8152
[    2.164556] r8152 5-1:1.0 eth0: v1.08.3
[    2.200154] r8152 5-1:1.0 enx001e06301503: renamed from eth0
I had to change /etc/network/interfaces
gr@odroidxu4:~$ cat /etc/network/interfaces
auto enx001e06301503
iface enx001e06301503 inet dhcp
# Wired adapter #1
##allow-hotplug eth0
##iface eth0 inet dhcp
# Local loopback
auto lo
iface lo inet loopback
the issue with the interface naming enx001e06301503, jessie deals with enx001e06301503, Armbian Xenial doesn't :)
so it is working!
awesome!. I was trying to put statical IP, changing DNS, etc. Something with the interfaces.d/ init scripts should be the problem, but no idea, time and will.
self comment:
"Armbian Xenial" is prefered as Mark Shuttleworth is asking trademark fees for "Ubuntu" name usage for OVH.com hosting (my domain name / DNS provider) some 1-5 M€ / year
Canonical needs funding
http://ubuntuvps.net/canonical-attempting-to-bill-ovh-for-use-of-the-ubuntu-trademark/
@jobenvil
until Armbian team solves the USB-UART no-root login, if you don't have a network connexion, we are stuck seeking for LCD screen and mouse/keyboard :) to achieve the first boot and solve network issues :)
I found something weird:
- 1. You are not using all cores:
### lscpu:
Architecture:          armv7l
Byte Order:            Little Endian
CPU(s):                8
On-line CPU(s) list:   0-3
Off-line CPU(s) list:  4-7           X!
Thread(s) per core:    1
Core(s) per socket:    4
Socket(s):             1             X!
Model name:            ARMv7 Processor rev 3 (v7l)
mine:
root@hiperborea /etc/init.d # lscpu
CPU(s):                8
On-line CPU(s) list:   0-7
Socket(s):             2
CPU max MHz:           1300,0000
CPU min MHz:           200,0000
- 2. Compare your dmesg with mine:
root@hiperborea /etc/init.d # dmesg
[    0.000000] Linux version 4.6.0+ (root@hiperborea) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2.1) ) #1 SMP PREEMPT Mon Jun 13 20:42:30 CEST 2016
[    0.000000] cma: Reserved 128 MiB at 0xb6800000
[    0.000000] free_area_init_node: node 0, pgdat c0b38680, node_mem_map eee24000
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000] percpu: Embedded 12 pages/cpu @eed89000 s20120 r8192 d20840 u49152
[    0.000000] pcpu-alloc: s20120 r8192 d20840 u49152 alloc=12*4096
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 512832
[    0.000000] Kernel command line: console=tty1 console=ttySAC2,115200n8 root=UUID=e139ce78-9841-40fe-8823-96a304a09859 rootwait ro fsck.repair=yes smsc95xx.macaddr=00:1e:06:61:7a:39 governor=ondemand hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi
[    0.000000] Memory: 1889208K/2058240K available (6305K kernel code, 229K rwdata, 1960K rodata, 1024K init, 266K bss, 37960K reserved, 131072K cma-reserved, 1157120K highmem)
                     .text : 0xc0008000 - 0xc09126f8   (9258 kB)
                     .data : 0xc0b00000 - 0xc0b396a0   ( 230 kB)
                      .bss : 0xc0b3b000 - 0xc0b7dae4   ( 267 kB)
[    0.001037] Console: colour dummy device 80x30
[    0.001782] console [tty1] enabled
[    0.001827] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=120000)
[    0.001884] pid_max: default: 32768 minimum: 301
[    0.002067] Security Framework initialized
[    0.002099] Yama: becoming mindful.
[    0.002150] AppArmor: AppArmor disabled by boot time parameter
[    0.002237] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002275] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003439] CPU: Testing write buffer coherency: ok
[    0.004233] CPU0: update cpu_capacity 448
[    0.004276] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
[    0.004485] Setting up static identity map for 0x40100000 - 0x40100058
[    0.005042] ARM CCI driver probed
[    0.005304] Exynos MCPM support installed
[    0.060323] CPU1: update cpu_capacity 448
[    0.060332] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
[    0.080298] CPU2: update cpu_capacity 448
[    0.080306] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
[    0.100296] CPU3: update cpu_capacity 448
[    0.100305] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
[    0.120344] CPU4: update cpu_capacity 1535
[    0.120352] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.140332] CPU5: update cpu_capacity 1535
[    0.140340] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.160332] CPU6: update cpu_capacity 1535
[    0.160339] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.180332] CPU7: update cpu_capacity 1535
[    0.180340] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.180500] Brought up 8 CPUs
[    0.180838] SMP: Total of 8 processors activated (384.00 BogoMIPS).
[    0.180870] CPU: WARNING: CPU(s) started in wrong/inconsistent modes (primary CPU mode 0x1a)
[    0.180913] CPU: This may indicate a broken bootloader or firmware.
[    0.182327] devtmpfs: initialized
[    0.213037] evm: security.SMACK64
[    0.213084] evm: security.SMACK64EXEC
[    0.213111] evm: security.SMACK64TRANSMUTE
[    0.213137] evm: security.SMACK64MMAP
[    0.213162] evm: security.ima
[    0.213187] evm: security.capability
[    0.213822] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 3
[    0.215669] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302231375000 ns
[    0.223374] pinctrl core: initialized pinctrl subsystem
[    0.224104] regulator-dummy: no parameters
[    0.225413] NET: Registered protocol family 16
[    0.227752] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.239984] cpuidle: using governor menu
[    0.241432] exynos-sysmmu 10a60000.sysmmu:: hardware version: 3.2
[    0.242028] exynos-sysmmu 10a70000.sysmmu:: hardware version: 3.2
[    0.242636] exynos-sysmmu 14650000.sysmmu:: hardware version: 3.3
[    0.243328] exynos-sysmmu 13e80000.sysmmu:: hardware version: 3.3
[    0.243941] exynos-sysmmu 13e90000.sysmmu:: hardware version: 3.3
[    0.244541] exynos-sysmmu 12880000.sysmmu:: hardware version: 3.2
[    0.245193] exynos-sysmmu 12890000.sysmmu:: hardware version: 3.2
[    0.245790] exynos-sysmmu 128a0000.sysmmu:: hardware version: 3.2
[    0.246384] exynos-sysmmu 128c0000.sysmmu:: hardware version: 3.2
[    0.246957] exynos-sysmmu 128d0000.sysmmu:: hardware version: 3.2
[    0.247509] exynos-sysmmu 128e0000.sysmmu:: hardware version: 3.2
[    0.248057] exynos-sysmmu 11d40000.sysmmu:: hardware version: 1.0
[    0.248629] exynos-sysmmu 11f10000.sysmmu:: hardware version: 1.2
[    0.249210] exynos-sysmmu 11f20000.sysmmu:: hardware version: 1.2
[    0.249786] exynos-sysmmu 11200000.sysmmu:: hardware version: 2.1
[    0.250426] exynos-sysmmu 11210000.sysmmu:: hardware version: 2.1
[    0.251026] exynos-sysmmu 14640000.sysmmu:: hardware version: 3.3
[    0.251592] exynos-sysmmu 14680000.sysmmu:: hardware version: 3.3
[    0.260226] exynos-audss-clk 3810000.audss-clock-controller:: setup completed
[    0.260672] exynos-sysmmu 11200000.sysmmu:: Enabled
[    0.260712] exynos-sysmmu 11210000.sysmmu:: Enabled
[    0.260730] platform 11000000.codec:: exynos_iommu_attach_device: Attached IOMMU with pgtable 0x6ebec000
[    0.261036] iommu: Adding device 11000000.codec: to group 0
[    0.265161] gpio gpiochip0: (gpy7): added GPIO chardev (254:0)
[    0.265865] gpiochip_setup_dev: registered GPIOs 0 to 7 on device: gpiochip0 (gpy7)
[    0.265912] gpio gpiochip1: (gpx0): added GPIO chardev (254:1)
[    0.266572] gpiochip_setup_dev: registered GPIOs 8 to 15 on device: gpiochip1 (gpx0)
[    0.266623] gpio gpiochip2: (gpx1): added GPIO chardev (254:2)
[    0.267152] gpiochip_setup_dev: registered GPIOs 16 to 23 on device: gpiochip2 (gpx1)
[    0.267191] gpio gpiochip3: (gpx2): added GPIO chardev (254:3)
[    0.267718] gpiochip_setup_dev: registered GPIOs 24 to 31 on device: gpiochip3 (gpx2)
[    0.267757] gpio gpiochip4: (gpx3): added GPIO chardev (254:4)
[    0.268286] gpiochip_setup_dev: registered GPIOs 32 to 39 on device: gpiochip4 (gpx3)
[    0.269729] gpio gpiochip5: (gpc0): added GPIO chardev (254:5)
[    0.270350] gpiochip_setup_dev: registered GPIOs 40 to 47 on device: gpiochip5 (gpc0)
[    0.270391] gpio gpiochip6: (gpc1): added GPIO chardev (254:6)
[    0.270937] gpiochip_setup_dev: registered GPIOs 48 to 55 on device: gpiochip6 (gpc1)
[    0.270975] gpio gpiochip7: (gpc2): added GPIO chardev (254:7)
[    0.271516] gpiochip_setup_dev: registered GPIOs 56 to 62 on device: gpiochip7 (gpc2)
[    0.271555] gpio gpiochip8: (gpc3): added GPIO chardev (254:8)
[    0.272082] gpiochip_setup_dev: registered GPIOs 63 to 66 on device: gpiochip8 (gpc3)
[    0.272120] gpio gpiochip9: (gpc4): added GPIO chardev (254:9)
[    0.272638] gpiochip_setup_dev: registered GPIOs 67 to 68 on device: gpiochip9 (gpc4)
[    0.272677] gpio gpiochip10: (gpd1): added GPIO chardev (254:10)
[    0.273177] gpiochip_setup_dev: registered GPIOs 69 to 76 on device: gpiochip10 (gpd1)
[    0.273214] gpio gpiochip11: (gpy0): added GPIO chardev (254:11)
[    0.273705] gpiochip_setup_dev: registered GPIOs 77 to 82 on device: gpiochip11 (gpy0)
[    0.273742] gpio gpiochip12: (gpy1): added GPIO chardev (254:12)
[    0.274233] gpiochip_setup_dev: registered GPIOs 83 to 86 on device: gpiochip12 (gpy1)
[    0.274271] gpio gpiochip13: (gpy2): added GPIO chardev (254:13)
[    0.274765] gpiochip_setup_dev: registered GPIOs 87 to 92 on device: gpiochip13 (gpy2)
[    0.274813] gpio gpiochip14: (gpy3): added GPIO chardev (254:14)
[    0.275373] gpiochip_setup_dev: registered GPIOs 93 to 100 on device: gpiochip14 (gpy3)
[    0.275420] gpio gpiochip15: (gpy4): added GPIO chardev (254:15)
[    0.275938] gpiochip_setup_dev: registered GPIOs 101 to 108 on device: gpiochip15 (gpy4)
[    0.275976] gpio gpiochip16: (gpy5): added GPIO chardev (254:16)
[    0.276502] gpiochip_setup_dev: registered GPIOs 109 to 116 on device: gpiochip16 (gpy5)
[    0.276540] gpio gpiochip17: (gpy6): added GPIO chardev (254:17)
[    0.277032] gpiochip_setup_dev: registered GPIOs 117 to 124 on device: gpiochip17 (gpy6)
[    0.278158] gpio gpiochip18: (gpe0): added GPIO chardev (254:18)
[    0.278687] gpiochip_setup_dev: registered GPIOs 125 to 132 on device: gpiochip18 (gpe0)
[    0.278724] gpio gpiochip19: (gpe1): added GPIO chardev (254:19)
[    0.279236] gpiochip_setup_dev: registered GPIOs 133 to 134 on device: gpiochip19 (gpe1)
[    0.279273] gpio gpiochip20: (gpf0): added GPIO chardev (254:20)
[    0.279795] gpiochip_setup_dev: registered GPIOs 135 to 140 on device: gpiochip20 (gpf0)
[    0.279834] gpio gpiochip21: (gpf1): added GPIO chardev (254:21)
[    0.280421] gpiochip_setup_dev: registered GPIOs 141 to 148 on device: gpiochip21 (gpf1)
[    0.280462] gpio gpiochip22: (gpg0): added GPIO chardev (254:22)
[    0.280977] gpiochip_setup_dev: registered GPIOs 149 to 156 on device: gpiochip22 (gpg0)
[    0.281016] gpio gpiochip23: (gpg1): added GPIO chardev (254:23)
[    0.281555] gpiochip_setup_dev: registered GPIOs 157 to 164 on device: gpiochip23 (gpg1)
[    0.281595] gpio gpiochip24: (gpg2): added GPIO chardev (254:24)
[    0.282112] gpiochip_setup_dev: registered GPIOs 165 to 166 on device: gpiochip24 (gpg2)
[    0.282151] gpio gpiochip25: (gpj4): added GPIO chardev (254:25)
[    0.282667] gpiochip_setup_dev: registered GPIOs 167 to 170 on device: gpiochip25 (gpj4)
[    0.283756] gpio gpiochip26: (gpa0): added GPIO chardev (254:26)
[    0.284311] gpiochip_setup_dev: registered GPIOs 171 to 178 on device: gpiochip26 (gpa0)
[    0.284351] gpio gpiochip27: (gpa1): added GPIO chardev (254:27)
[    0.284888] gpiochip_setup_dev: registered GPIOs 179 to 184 on device: gpiochip27 (gpa1)
[    0.284926] gpio gpiochip28: (gpa2): added GPIO chardev (254:28)
[    0.285525] gpiochip_setup_dev: registered GPIOs 185 to 192 on device: gpiochip28 (gpa2)
[    0.285578] gpio gpiochip29: (gpb0): added GPIO chardev (254:29)
[    0.286111] gpiochip_setup_dev: registered GPIOs 193 to 197 on device: gpiochip29 (gpb0)
[    0.286151] gpio gpiochip30: (gpb1): added GPIO chardev (254:30)
[    0.286703] gpiochip_setup_dev: registered GPIOs 198 to 202 on device: gpiochip30 (gpb1)
[    0.286742] gpio gpiochip31: (gpb2): added GPIO chardev (254:31)
[    0.287273] gpiochip_setup_dev: registered GPIOs 203 to 206 on device: gpiochip31 (gpb2)
[    0.287311] gpio gpiochip32: (gpb3): added GPIO chardev (254:32)
[    0.287876] gpiochip_setup_dev: registered GPIOs 207 to 214 on device: gpiochip32 (gpb3)
[    0.287916] gpio gpiochip33: (gpb4): added GPIO chardev (254:33)
[    0.288454] gpiochip_setup_dev: registered GPIOs 215 to 216 on device: gpiochip33 (gpb4)
[    0.288492] gpio gpiochip34: (gph0): added GPIO chardev (254:34)
[    0.289018] gpiochip_setup_dev: registered GPIOs 217 to 224 on device: gpiochip34 (gph0)
[    0.290225] gpio gpiochip35: (gpz): added GPIO chardev (254:35)
[    0.290803] gpiochip_setup_dev: registered GPIOs 225 to 231 on device: gpiochip35 (gpz)
[    0.300064] exynos-sysmmu 14650000.sysmmu:: Enabled
[    0.300087] platform 14450000.mixer:: exynos_iommu_attach_device: Attached IOMMU with pgtable 0x6e0c8000
[    0.300354] iommu: Adding device 14450000.mixer: to group 1
[    0.300777] exynos-sysmmu 11d40000.sysmmu:: Enabled
[    0.300796] platform 11c00000.rotator:: exynos_iommu_attach_device: Attached IOMMU with pgtable 0x6e074000
[    0.301054] iommu: Adding device 11c00000.rotator: to group 2
[    0.305044] exynos-sysmmu 13e80000.sysmmu:: Enabled
[    0.305064] platform 13e00000.video-scaler:: exynos_iommu_attach_device: Attached IOMMU with pgtable 0x6e0d8000
[    0.305332] iommu: Adding device 13e00000.video-scaler: to group 3
[    0.305724] exynos-sysmmu 13e90000.sysmmu:: Enabled
[    0.305745] platform 13e10000.video-scaler:: exynos_iommu_attach_device: Attached IOMMU with pgtable 0x6e0dc000
[    0.305989] iommu: Adding device 13e10000.video-scaler: to group 4
[    0.306376] exynos-sysmmu 11f10000.sysmmu:: Enabled
[    0.306395] platform 11f50000.jpeg:: exynos_iommu_attach_device: Attached IOMMU with pgtable 0x6e0e0000
[    0.306645] iommu: Adding device 11f50000.jpeg: to group 5
[    0.307027] exynos-sysmmu 11f20000.sysmmu:: Enabled
[    0.307046] platform 11f60000.jpeg:: exynos_iommu_attach_device: Attached IOMMU with pgtable 0x6e0e4000
[    0.307294] iommu: Adding device 11f60000.jpeg: to group 6
[    0.307805] EXYNOS5420 PMU initialized
[    0.314242] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.314302] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.367422] SCSI subsystem initialized
[    0.368028] usbcore: registered new interface driver usbfs
[    0.368186] usbcore: registered new interface driver hub
[    0.368414] usbcore: registered new device driver usb
[    0.369576] s3c-i2c 12c80000.i2c:: slave address 0x00
[    0.369623] s3c-i2c 12c80000.i2c:: bus frequency set to 65 KHz
[    0.370409] s3c-i2c 12c80000.i2c:: i2c-2: S3C I2C adapter
[    0.370672] media: Linux media interface: v0.10
[    0.370803] Linux video capture interface: v2.00
[    0.373422] NetLabel: Initializing
[    0.373463] NetLabel:  domain hash size = 128
[    0.373490] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.373583] NetLabel:  unlabeled traffic allowed by default
[    0.374317] clocksource: Switched to clocksource mct-frc
[    0.374655] VFS: Disk quotas dquot_6.6.0
[    0.374784] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.401331] NET: Registered protocol family 2
[    0.402320] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.402487] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    0.402882] TCP: Hash tables configured (established 8192 bind 8192)
[    0.403076] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    0.403176] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    0.403576] NET: Registered protocol family 1
[    0.403973] Trying to unpack rootfs image as initramfs...
[    0.970606] Freeing initrd memory: 7600K (c2000000 - c276c000)
[    0.975789] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.976076] audit: initializing netlink subsys (disabled)
[    0.976244] audit: type=2000 audit(0.970:1): initialized
[    0.977414] workingset: timestamp_bits=12 max_order=19 bucket_order=7
[    1.001012] ntfs: driver 2.1.32 [Flags: R/W].
[    1.001725] fuse init (API version 7.24)
[    1.003207] Key type big_key registered
[    1.005072] Key type asymmetric registered
[    1.005104] Asymmetric key parser 'x509' registered
[    1.005204] bounce: pool size: 64 pages
[    1.005604] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    1.005865] io scheduler noop registered
[    1.005896] io scheduler deadline registered
[    1.006272] io scheduler cfq registered (default)
[    1.006775] phy phy-video-phy@10040728:.0: Looking up phy-supply from device tree
[    1.006792] phy phy-video-phy@10040728:.0: Looking up phy-supply property in node /video-phy@10040728 failed
[    1.007451] phy phy-video-phy@10040714:.1: Looking up phy-supply from device tree
[    1.007467] phy phy-video-phy@10040714:.1: Looking up phy-supply property in node /video-phy@10040714 failed
[    1.007695] phy phy-video-phy@10040714:.2: Looking up phy-supply from device tree
[    1.007710] phy phy-video-phy@10040714:.2: Looking up phy-supply property in node /video-phy@10040714 failed
[    1.007923] phy phy-video-phy@10040714:.3: Looking up phy-supply from device tree
[    1.007938] phy phy-video-phy@10040714:.3: Looking up phy-supply property in node /video-phy@10040714 failed
[    1.008155] phy phy-video-phy@10040714:.4: Looking up phy-supply from device tree
[    1.008170] phy phy-video-phy@10040714:.4: Looking up phy-supply property in node /video-phy@10040714 failed
[    1.009266] samsung-usb2-phy 12130000.phy:: Looking up vbus-supply from device tree
[    1.009283] samsung-usb2-phy 12130000.phy:: Looking up vbus-supply property in node /phy@12130000 failed
[    1.009301] 12130000.phy: supply vbus not found, using dummy regulator
[    1.009511] phy phy-12130000.phy:.5: Looking up phy-supply from device tree
[    1.009526] phy phy-12130000.phy:.5: Looking up phy-supply property in node /phy@12130000 failed
[    1.009758] phy phy-12130000.phy:.6: Looking up phy-supply from device tree
[    1.009773] phy phy-12130000.phy:.6: Looking up phy-supply property in node /phy@12130000 failed
[    1.009987] phy phy-12130000.phy:.7: Looking up phy-supply from device tree
[    1.010002] phy phy-12130000.phy:.7: Looking up phy-supply property in node /phy@12130000 failed
[    1.010216] phy phy-12130000.phy:.8: Looking up phy-supply from device tree
[    1.010230] phy phy-12130000.phy:.8: Looking up phy-supply property in node /phy@12130000 failed
[    1.010951] exynos5_usb3drd_phy 12100000.phy:: Looking up vbus-supply from device tree
[    1.010968] exynos5_usb3drd_phy 12100000.phy:: Looking up vbus-supply property in node /phy@12100000 failed
[    1.010983] 12100000.phy: supply vbus not found, using dummy regulator
[    1.011074] exynos5_usb3drd_phy 12100000.phy:: Looking up vbus-boost-supply from device tree
[    1.011089] exynos5_usb3drd_phy 12100000.phy:: Looking up vbus-boost-supply property in node /phy@12100000 failed
[    1.011104] 12100000.phy: supply vbus-boost not found, using dummy regulator
[    1.011200] phy phy-12100000.phy:.9: Looking up phy-supply from device tree
[    1.011214] phy phy-12100000.phy:.9: Looking up phy-supply property in node /phy@12100000 failed
[    1.011435] phy phy-12100000.phy:.10: Looking up phy-supply from device tree
[    1.011450] phy phy-12100000.phy:.10: Looking up phy-supply property in node /phy@12100000 failed
[    1.011792] exynos5_usb3drd_phy 12500000.phy:: Looking up vbus-supply from device tree
[    1.011807] exynos5_usb3drd_phy 12500000.phy:: Looking up vbus-supply property in node /phy@12500000 failed
[    1.011822] 12500000.phy: supply vbus not found, using dummy regulator
[    1.011913] exynos5_usb3drd_phy 12500000.phy:: Looking up vbus-boost-supply from device tree
[    1.011928] exynos5_usb3drd_phy 12500000.phy:: Looking up vbus-boost-supply property in node /phy@12500000 failed
[    1.011942] 12500000.phy: supply vbus-boost not found, using dummy regulator
[    1.012037] phy phy-12500000.phy:.11: Looking up phy-supply from device tree
[    1.012052] phy phy-12500000.phy:.11: Looking up phy-supply property in node /phy@12500000 failed
[    1.012276] phy phy-12500000.phy:.12: Looking up phy-supply from device tree
[    1.012291] phy phy-12500000.phy:.12: Looking up phy-supply property in node /phy@12500000 failed
[    1.018082] dma-pl330 3880000.adma: Loaded driver for PL330 DMAC-241330
[    1.018115] dma-pl330 3880000.adma:  DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6
[    1.025195] dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.025227] dma-pl330 121a0000.pdma:         DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    1.032091] dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.032125] dma-pl330 121b0000.pdma:         DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    1.034077] dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330
[    1.034109] dma-pl330 10800000.mdma:         DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
[    1.172858] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.176350] 12c00000.serial:: ttySAC0 at MMIO 0x12c00000 (irq = 76, base_baud = 0) is a S3C6400/10
[    1.177056] 12c10000.serial:: ttySAC1 at MMIO 0x12c10000 (irq = 77, base_baud = 0) is a S3C6400/10
[    1.177749] 12c20000.serial:: ttySAC2 at MMIO 0x12c20000 (irq = 78, base_baud = 0) is a S3C6400/10
[    2.044553] console [ttySAC2] enabled
[    2.049025] 12c30000.serial:: ttySAC3 at MMIO 0x12c30000 (irq = 79, base_baud = 0) is a S3C6400/10
[    2.059083] [drm] Initialized drm 1.1.0 20060810
[    2.091348] brd: module loaded
[    2.133971] loop: module loaded
[    2.137730] exynos-dwc3 usb@12000000:: no suspend clk specified
[    2.142245] exynos-dwc3 usb@12000000:: Looking up vdd33-supply from device tree
[    2.142954] exynos-dwc3 usb@12400000:: no suspend clk specified
[    2.148127] exynos-dwc3 usb@12400000:: Looking up vdd33-supply from device tree
[    2.148606] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.154638] ehci-exynos: EHCI EXYNOS driver
[    2.159066] of_get_named_gpiod_flags: can't parse 'samsung,vbus-gpio' property of node '/usb@12110000[0]'
[    2.159369] exynos-ehci 12110000.usb:: EHCI Host Controller
[    2.164384] exynos-ehci 12110000.usb:: new USB bus registered, assigned bus number 1
[    2.172401] exynos-ehci 12110000.usb:: irq 130, io mem 0x12110000
[    2.184414] exynos-ehci 12110000.usb:: USB 2.0 started, EHCI 1.00
[    2.189445] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.195846] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.203060] usb usb1: Product: EHCI Host Controller
[    2.207888] usb usb1: Manufacturer: Linux 4.6.0+ ehci_hcd
[    2.213263] usb usb1: SerialNumber: 12110000.usb:
[    2.219348] hub 1-0:1.0: USB hub found
[    2.221695] hub 1-0:1.0: 3 ports detected
[    2.227079] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.231875] ohci-exynos: OHCI EXYNOS driver
[    2.236504] exynos-ohci 12120000.usb:: USB Host Controller
[    2.241505] exynos-ohci 12120000.usb:: new USB bus registered, assigned bus number 2
[    2.249405] exynos-ohci 12120000.usb:: irq 130, io mem 0x12120000
[    2.313656] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.319026] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.327142] usb usb2: Product: USB Host Controller
[    2.330981] usb usb2: Manufacturer: Linux 4.6.0+ ohci_hcd
[    2.336345] usb usb2: SerialNumber: 12120000.usb:
[    2.342261] hub 2-0:1.0: USB hub found
[    2.344801] hub 2-0:1.0: 3 ports detected
[    2.350628] usbcore: registered new interface driver uas
[    2.354724] usbcore: registered new interface driver usb-storage
[    2.361782] i2c /dev entries driver
[    2.369694] vdd_ldo1: 1000 mV
[    2.371059] LDO2: at 1800 mV
[    2.372868] vdd_ldo3: 1800 mV
[    2.374214] LDO4: at 1800 mV
[    2.376063] vdd_ldo5: 1800 mV
[    2.377898] vdd_ldo6: 1000 mV
[    2.379701] vdd_ldo7: 1800 mV
[    2.381510] vdd_ldo8: 1800 mV
[    2.382897] vdd_ldo9: Bringing 3300000uV into 3000000-3000000uV
[    2.390133] vdd_ldo9: 3000 mV
[    2.391964] vdd_ldo10: 1800 mV
[    2.393772] vdd_ldo11: 1000 mV
[    2.395606] vdd_ldo12: 1800 mV
[    2.396943] vdd_ldo13: Bringing 3300000uV into 2800000-2800000uV
[    2.404262] vdd_ldo13: 2800 mV
[    2.405663] LDO14: at 3000 mV
[    2.406987] vdd_ldo15: Bringing 3300000uV into 3100000-3100000uV
[    2.414274] vdd_ldo15: 3100 mV
[    2.416484] vdd_ldo16: 2200 mV
[    2.418296] tsp_avdd: 3300 mV
[    2.419648] LDO18: at 1800 mV
[    2.421031] vdd_sd: Bringing 3300000uV into 2800000-2800000uV
[    2.428091] vdd_sd: 2800 mV
[    2.429452] LDO20: at 1800 mV
[    2.430789] LDO21: at 1800 mV
[    2.432129] LDO22: at 1200 mV
[    2.433458] LDO23: at 1100 mV
[    2.435666] tsp_io: 2800 mV
[    2.437037] LDO25: at 1800 mV
[    2.439188] vdd_ldo26: 3000 mV
[    2.440616] LDO27: at 1000 mV
[    2.442023] LDO28: at 3300 mV
[    2.443366] LDO29: at 1800 mV
[    2.444690] LDO30: at 1800 mV
[    2.445958] LDO31: at 1800 mV
[    2.447236] LDO32: at 1800 mV
[    2.448493] LDO33: at 1800 mV
[    2.449863] LDO34: at 3000 mV
[    2.451183] LDO35: at 1600 mV
[    2.452506] LDO36: at 1800 mV
[    2.453807] LDO37: at 1800 mV
[    2.455184] LDO38: at 2800 mV
[    2.457443] vdd_mif: 800 <--> 1300 mV at 1100 mV
[    2.459736] vdd_arm: 800 <--> 1500 mV at 1000 mV
[    2.462025] vdd_int: 800 <--> 1400 mV at 1000 mV
[    2.464360] vdd_g3d: 800 <--> 1400 mV at 1000 mV
[    2.466633] vdd_mem: 800 <--> 1400 mV at 1200 mV
[    2.468902] vdd_kfc: 800 <--> 1500 mV at 1025 mV
[    2.471191] vdd_1.0v_ldo: 800 <--> 1500 mV at 900 mV
[    2.473475] vdd_1.8v_ldo: 800 <--> 1500 mV at 1225 mV
[    2.475843] vdd_2.8v_ldo: 3000 <--> 3750 mV at 3400 mV
[    2.477987] vdd_vmem: 2850 mV
[    2.486866] s5m-rtc s2mps14-rtc: rtc core: registered s5m-rtc as rtc0
[    2.495535] pwm-fan pwm-fan:: Failed to configure PWM
[    2.499156] pwm-fan: probe of pwm-fan: failed with error -22
[    2.505557] exynos-tmu 10060000.tmu:: Looking up vtmu-supply from device tree
[    2.506396] exynos-tmu 10060000.tmu:: More trip points than supported by this TMU.
[    2.512568] exynos-tmu 10060000.tmu:: 2 trip points should be configured in polling mode.
[    2.520899] exynos-tmu 10064000.tmu:: Looking up vtmu-supply from device tree
[    2.521819] exynos-tmu 10068000.tmu:: Looking up vtmu-supply from device tree
[    2.522756] exynos-tmu 1006c000.tmu:: Looking up vtmu-supply from device tree
[    2.523710] exynos-tmu 100a0000.tmu:: Looking up vtmu-supply from device tree
[    2.526188] s3c2410-wdt 101d0000.watchdog:: watchdog inactive, reset disabled, irq disabled
[    2.534149] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.542211] cpu cpu0: Looking up cpu-supply from device tree
[    2.543187] cpu cpu0: Looking up cpu-supply from device tree
[    2.549482] cpu cpu4: Looking up cpu-supply from device tree
[    2.555956] pwrseq_emmc pwrseq:: GPIO lookup for consumer reset
[    2.555969] pwrseq_emmc pwrseq:: using device tree for GPIO lookup
[    2.555989] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/pwrseq[0]' - status (0)
[    2.556137] sdhci: Secure Digital Host Controller Interface driver
[    2.560888] sdhci: Copyright(c) Pierre Ossman
[    2.565453] Synopsys Designware Multimedia Card Interface Driver
[    2.571948] dwmmc_exynos 12200000.mmc:: IDMAC supports 32-bit address mode.
[    2.578219] dwmmc_exynos 12200000.mmc:: Using internal DMA controller.
[    2.584619] dwmmc_exynos 12200000.mmc:: Version ID is 250a
[    2.590126] dwmmc_exynos 12200000.mmc:: DW MMC controller at irq 83,64 bit host data width,64 deep fifo
[    2.599470] dwmmc_exynos 12200000.mmc:: Looking up vmmc-supply from device tree
[    2.599482] dwmmc_exynos 12200000.mmc:: Looking up vmmc-supply property in node /mmc@12200000 failed
[    2.599550] dwmmc_exynos 12200000.mmc:: Looking up vqmmc-supply from device tree
[    2.599560] dwmmc_exynos 12200000.mmc:: Looking up vqmmc-supply property in node /mmc@12200000 failed
[    2.599614] dwmmc_exynos 12200000.mmc:: GPIO lookup for consumer cd
[    2.599623] dwmmc_exynos 12200000.mmc:: using device tree for GPIO lookup
[    2.599644] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/mmc@12200000[0]' - status (0)
[    2.599665] dwmmc_exynos 12200000.mmc:: Got CD GPIO
[    2.604256] dwmmc_exynos 12200000.mmc:: GPIO lookup for consumer wp
[    2.604265] dwmmc_exynos 12200000.mmc:: using device tree for GPIO lookup
[    2.604275] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@12200000[0]'
[    2.604285] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@12200000[0]'
[    2.604345] dwmmc_exynos 12200000.mmc:: using lookup tables for GPIO lookup
[    2.604357] dwmmc_exynos 12200000.mmc:: lookup for GPIO wp failed
[    2.604424] dwmmc_exynos 12200000.mmc:: allocated mmc-pwrseq
[    2.639645] dwmmc_exynos 12200000.mmc:: 1 slots initialized
[    2.644069] dwmmc_exynos 12220000.mmc:: IDMAC supports 32-bit address mode.
[    2.650786] dwmmc_exynos 12220000.mmc:: Using internal DMA controller.
[    2.657213] dwmmc_exynos 12220000.mmc:: Version ID is 250a
[    2.662707] dwmmc_exynos 12220000.mmc:: DW MMC controller at irq 84,64 bit host data width,64 deep fifo
[    2.672054] dwmmc_exynos 12220000.mmc:: Looking up vmmc-supply from device tree
[    2.672066] dwmmc_exynos 12220000.mmc:: Looking up vmmc-supply property in node /mmc@12220000 failed
[    2.672121] dwmmc_exynos 12220000.mmc:: Looking up vqmmc-supply from device tree
[    2.672132] dwmmc_exynos 12220000.mmc:: Looking up vqmmc-supply property in node /mmc@12220000 failed
[    2.672184] dwmmc_exynos 12220000.mmc:: GPIO lookup for consumer cd
[    2.672193] dwmmc_exynos 12220000.mmc:: using device tree for GPIO lookup
[    2.672204] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/mmc@12220000[0]'
[    2.672214] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/mmc@12220000[0]'
[    2.672223] dwmmc_exynos 12220000.mmc:: using lookup tables for GPIO lookup
[    2.672233] dwmmc_exynos 12220000.mmc:: lookup for GPIO cd failed
[    2.672244] dwmmc_exynos 12220000.mmc:: GPIO lookup for consumer wp
[    2.672252] dwmmc_exynos 12220000.mmc:: using device tree for GPIO lookup
[    2.672262] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@12220000[0]'
[    2.672271] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@12220000[0]'
[    2.672280] dwmmc_exynos 12220000.mmc:: using lookup tables for GPIO lookup
[    2.672289] dwmmc_exynos 12220000.mmc:: lookup for GPIO wp failed
[    2.699388] dwmmc_exynos 12220000.mmc:: 1 slots initialized
[    2.704639] s5p-secss 10830000.sss:: s5p-sss driver registered
[    2.710401] usbcore: registered new interface driver usbhid
[    2.714877] usbhid: USB HID core driver
[    2.719957] NET: Registered protocol family 17
[    2.723109] NET: Registered protocol family 15
[    2.728192] Registering SWP/SWPB emulation handler
[    2.733260] registered taskstats version 1
[    2.747654] Key type encrypted registered
[    2.750248] ima: No TPM chip found, activating TPM-bypass!
[    2.755820] evm: HMAC attrs: 0x1
[    2.764708] exynos-dwc3 usb@12000000:: no suspend clk specified
[    2.769156] exynos-dwc3 usb@12000000:: Looking up vdd33-supply from device tree
[    2.769683] exynos-dwc3 usb@12000000:: Looking up vdd10-supply from device tree
[    2.772997] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    2.777096] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3
[    2.784932] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    2.793354] xhci-hcd xhci-hcd.6.auto: irq 134, io mem 0x12000000
[    2.799512] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.806058] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.813258] usb usb3: Product: xHCI Host Controller
[    2.818094] usb usb3: Manufacturer: Linux 4.6.0+ xhci-hcd
[    2.823469] usb usb3: SerialNumber: xhci-hcd.6.auto
[    2.826864] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    2.826953] mmc1: new high speed SDHC card at address aaaa
[    2.827669] mmcblk1: mmc1:aaaa SL08G 7.40 GiB
[    2.829075]  mmcblk1: p1 p2
[    2.851337] hub 3-0:1.0: USB hub found
[    2.854427] hub 3-0:1.0: 1 port detected
[    2.858728] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    2.863782] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4
[    2.871453] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.879553] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    2.886205] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.893403] usb usb4: Product: xHCI Host Controller
[    2.898248] usb usb4: Manufacturer: Linux 4.6.0+ xhci-hcd
[    2.903624] usb usb4: SerialNumber: xhci-hcd.6.auto
[    2.909138] hub 4-0:1.0: USB hub found
[    2.912222] hub 4-0:1.0: 1 port detected
[    2.917084] exynos-dwc3 usb@12400000:: no suspend clk specified
[    2.921996] exynos-dwc3 usb@12400000:: Looking up vdd33-supply from device tree
[    2.922525] exynos-dwc3 usb@12400000:: Looking up vdd10-supply from device tree
[    2.923798] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    2.927846] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[    2.935715] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    2.944151] xhci-hcd xhci-hcd.9.auto: irq 135, io mem 0x12400000
[    2.950227] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.956918] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.964053] usb usb5: Product: xHCI Host Controller
[    2.968897] usb usb5: Manufacturer: Linux 4.6.0+ xhci-hcd
[    2.974273] usb usb5: SerialNumber: xhci-hcd.9.auto
[    2.979804] hub 5-0:1.0: USB hub found
[    2.982850] hub 5-0:1.0: 1 port detected
[    2.987197] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    2.992227] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[    2.999895] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.007998] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    3.014712] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.021851] usb usb6: Product: xHCI Host Controller
[    3.026702] usb usb6: Manufacturer: Linux 4.6.0+ xhci-hcd
[    3.032071] usb usb6: SerialNumber: xhci-hcd.9.auto
[    3.037577] hub 6-0:1.0: USB hub found
[    3.040669] hub 6-0:1.0: 1 port detected
[    3.045732] s3c-rtc 101e0000.rtc:: rtc disabled, re-enabling
[    3.050258] s3c-rtc 101e0000.rtc:: warning: invalid RTC value so initializing it
[    3.057995] s3c-rtc 101e0000.rtc:: rtc core: registered s3c as rtc1
[    3.065297] Power domain power-domain@10044120 disable failed
[    3.069754] s5m-rtc s2mps14-rtc: setting system clock to 2000-01-01 00:00:06 UTC (946684806)
[    3.104477] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
[    3.151565] random: systemd-udevd urandom read with 118 bits of entropy available
[    3.164370] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    3.224469] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    3.247161] usb 4-1: New USB device found, idVendor=05e3, idProduct=0616
[    3.252428] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.259525] usb 4-1: Product: USB3.0 Hub
[    3.263387] usb 4-1: Manufacturer: GenesysLogic
[    3.272716] hub 4-1:1.0: USB hub found
[    3.275309] hub 4-1:1.0: 2 ports detected
[    3.300524] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610
[    3.305786] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.312890] usb 3-1: Product: USB2.0 Hub
[    3.316787] usb 3-1: Manufacturer: GenesysLogic
[    3.352138] hub 3-1:1.0: USB hub found
[    3.354750] hub 3-1:1.0: 2 ports detected
[    3.454437] usb 6-1: new SuperSpeed USB device number 2 using xhci-hcd
[    3.475326] usb 6-1: New USB device found, idVendor=0bda, idProduct=8153
[    3.480604] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    3.487733] usb 6-1: Product: USB 10/100/1000 LAN
[    3.492401] usb 6-1: Manufacturer: Realtek
[    3.496473] usb 6-1: SerialNumber: 000001000000
[    3.769426] random: nonblocking pool is initialized
[    4.064350] raid6: int32x1  gen()   402 MB/s
[    4.149381] raid6: int32x1  xor()   411 MB/s
[    4.234398] raid6: int32x2  gen()   607 MB/s
[    4.319325] raid6: int32x2  xor()   540 MB/s
[    4.404319] raid6: int32x4  gen()   678 MB/s
[    4.489371] raid6: int32x4  xor()   559 MB/s
[    4.574445] raid6: int32x8  gen()   285 MB/s
[    4.659402] raid6: int32x8  xor()   191 MB/s
[    4.662199] raid6: using algorithm int32x4 gen() 678 MB/s
[    4.667596] raid6: .... xor() 559 MB/s, rmw enabled
[    4.672447] raid6: using intx1 recovery algorithm
[    4.678409] xor: measuring software checksum speed
[    4.729329]    arm4regs  :  1535.200 MB/sec
[    4.779356]    8regs     :  1083.200 MB/sec
[    4.829343]    32regs    :  2350.400 MB/sec
[    4.832058] xor: using function: 32regs (2350.400 MB/sec)
[    4.855371] Btrfs loaded, assert=on
[    7.764447] usb 4-1.2: new SuperSpeed USB device number 3 using xhci-hcd
[    7.785658] usb 4-1.2: New USB device found, idVendor=152d, idProduct=3562
[    7.791088] usb 4-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    7.798367] usb 4-1.2: Product: AD TO BE II
[    7.802518] usb 4-1.2: Manufacturer: ADMKIV
[    7.806679] usb 4-1.2: SerialNumber: DB123456789628
[    7.822724] scsi host0: uas
[    7.825526] scsi 0:0:0:0: Direct-Access     ADplus   SuperVer         6302 PQ: 0 ANSI: 6
[    7.865497] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    7.865505] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    7.876807] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    7.882738] sd 0:0:0:0: [sda] Write Protect is off
[    7.886778] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
[    7.887148] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    7.978658]  sda: sda1 sda2
[    7.982428] sd 0:0:0:0: [sda] Attached SCSI disk
[    8.426771] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.871821] systemd[1]: System time before build time, advancing clock.
[    8.974987] NET: Registered protocol family 10
[    9.039104] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    9.056680] systemd[1]: Detected architecture arm.
[    9.085579] systemd[1]: Set hostname to <hiperborea>.
[    9.912138] systemd[1]: Created slice User and Session Slice.
[    9.929638] systemd[1]: Listening on LVM2 metadata daemon socket.
[    9.950250] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.974466] systemd[1]: Reached target Encrypted Volumes.
[    9.989617] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.009735] systemd[1]: Listening on Journal Audit Socket.
[   10.024679] systemd[1]: Listening on Journal Socket.
[   10.039651] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   10.059533] systemd[1]: Listening on udev Kernel Socket.
[   10.074543] systemd[1]: Listening on LVM2 poll daemon socket.
[   10.094517] systemd[1]: Listening on Syslog Socket.
[   10.109668] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.129934] systemd[1]: Created slice System Slice.
[   10.145016] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   10.184634] systemd[1]: Mounting RPC Pipe File System...
[   10.200033] systemd[1]: Created slice system-getty.slice.
[   10.217366] systemd[1]: Starting Journal Service...
[   10.234492] systemd[1]: Reached target Slices.
[   10.252456] systemd[1]: Mounting Debug File System...
[   10.272606] systemd[1]: Starting Nameserver information manager...
[   10.293051] systemd[1]: Mounting POSIX Message Queue File System...
[   10.294698] RPC: Registered named UNIX socket transport module.
[   10.294703] RPC: Registered udp transport module.
[   10.294707] RPC: Registered tcp transport module.
[   10.294711] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.335201] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   10.354684] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.394895] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.411230] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[   10.424545] systemd[1]: Reached target Swap.
[   10.441510] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   10.499945] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   10.528999] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   10.589916] systemd[1]: Starting Load Kernel Modules...
[   10.604688] systemd[1]: Listening on udev Control Socket.
[   10.627094] systemd[1]: Mounted RPC Pipe File System.
[   10.644635] systemd[1]: Mounted POSIX Message Queue File System.
[   10.664509] systemd[1]: Mounted Debug File System.
[   10.679805] systemd[1]: Started Journal Service.
[   11.257762] systemd-journald[1755]: Received request to flush runtime journal from PID 1
[   12.339941] usbcore: registered new interface driver r8152
[   12.428966] usbcore: registered new interface driver cdc_ether
[   12.523976] usb 6-1: reset SuperSpeed USB device number 2 using xhci-hcd
[   12.660714] r8152 6-1:1.0 eth0: v1.08.3
[   26.307526] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Edited by zador.blood.stained
Added spoiler tags
@jobenvil
you forgot to add
for the logs (my firefox nightly / Armbian forum doesn't work when editing too large message :)
ok, the default linux kernel 4.6.2 (from linux.org) create BIG.little  little by default (depending on core load, the core swap from little to BIG), I haven't looked in .config how to configure Hybrid Mode HSM to use little+BIG cores at the same time
I was surprised the 4 core load didn't make the SoC heat over 50°C ;)
so there is none CPU manager neither BIG.little nor HSM configured in .config by default, only the 4 little cores activated
it is not possible to put the other cores online "hotswap"
kernel tuning is needed
root@odroidxu4:/sys/devices/system/cpu# ll
total 0
drwxr-xr-x 14 root root    0 Jun 21 19:55 ./
drwxr-xr-x  6 root root    0 Jun 21 19:55 ../
drwxr-xr-x  5 root root    0 Jun 21 19:55 cpu0/
drwxr-xr-x  5 root root    0 Jun 21 19:55 cpu1/
drwxr-xr-x  5 root root    0 Jun 21 19:55 cpu2/
drwxr-xr-x  5 root root    0 Jun 21 19:55 cpu3/
drwxr-xr-x  4 root root    0 Jun 21 19:59 cpu4/
drwxr-xr-x  4 root root    0 Jun 21 19:55 cpu5/
drwxr-xr-x  4 root root    0 Jun 21 19:55 cpu6/
drwxr-xr-x  4 root root    0 Jun 21 19:55 cpu7/
drwxr-xr-x  2 root root    0 Jun 21 19:55 cpufreq/
drwxr-xr-x  2 root root    0 Jun 21 19:55 cpuidle/
drwxr-xr-x  2 root root    0 Jun 21 19:55 hotplug/
-r--r--r--  1 root root 4096 Jun 21 19:55 isolated
-r--r--r--  1 root root 4096 Jun 21 19:55 kernel_max
-r--r--r--  1 root root 4096 Jun 21 19:55 offline
-r--r--r--  1 root root 4096 Jun 21 19:55 online
-r--r--r--  1 root root 4096 Jun 21 19:55 possible
drwxr-xr-x  2 root root    0 Jun 21 19:55 power/
-r--r--r--  1 root root 4096 Jun 21 19:55 present
-rw-r--r--  1 root root 4096 Jun 21 19:55 uevent
root@odroidxu4:/sys/devices/system/cpu/cpu0# ll
total 0
drwxr-xr-x  5 root root    0 Jun 21 19:55 ./
drwxr-xr-x 14 root root    0 Jun 21 19:55 ../
drwxr-xr-x  2 root root    0 Jun 21 18:43 hotplug/
lrwxrwxrwx  1 root root    0 Jun 21 20:06 of_node -> ../../../../firmware/devicetree/base/cpus/cpu@100/
-rw-r--r--  1 root root 4096 Jun 21 20:06 online
drwxr-xr-x  2 root root    0 Jun 21 18:43 power/
lrwxrwxrwx  1 root root    0 Jun 21 18:42 subsystem -> ../../../../bus/cpu/
drwxr-xr-x  2 root root    0 Jun 21 18:43 topology/
-rw-r--r--  1 root root 4096 Jun 21 18:42 uevent
root@odroidxu4:/sys/devices/system/cpu/cpu0# cat online
1
root@odroidxu4:/sys/devices/system/cpu/cpu0# cd ../cpu4/
root@odroidxu4:/sys/devices/system/cpu/cpu4# cat online
0
root@odroidxu4:/sys/devices/system/cpu/cpu4# echo "1" > online
bash: echo: write error: Operation not permitted
root@odroidxu4:/sys/devices/system/cpu/cpu4# echo 255 > online
bash: echo: write error: Invalid argument
root@odroidxu4:/sys/devices/system/cpu/cpu4# echo 4 > online
root@odroidxu4:/sys/devices/system/cpu/cpu4# echo 0 > online
root@odroidxu4:/sys/devices/system/cpu/cpu4# echo 1 > online
post your .config in pastebin and I will git diff. Theoretically It should not differ to much. I don't remember well which branch/repo I took. My fan runs and runs... and no way to stop it. searching for solution.
Sorry for the spoiler. I will do this next time.
I was playing around (Kernel 4.7-rc4) with menuconfig and comparing with older kernels where HDMI still worked. In mainline and next releases is not working my monitor, which is not HDMI native. I will receive in the next days a UART adapter and check where it hangs. Actually I use Kernel 4.7. which works somehow better with USB3.
@jobenvil
I have a message in vanilla 4.6 4.7-rc about HDMI
[    0.688642] exynos-hdmi 14530000.hdmi: Failed to get supply 'vdd': -517
[    0.688669] [drm:hdmi_probe] *ERROR* failed to get regulators
[    0.688684] [drm:hdmi_probe] *ERROR* hdmi_resources_init failed
I have tried your .config but I cannot boot the kernel at all.
@Igor, Zador.blood.stain, Tk, & all
I have created a new image (jessie based as ethernet management is not "perfect" in Xenial) from Armbian master, the /etc/fstab isn't updated despite the pushed fix
[    8.811076] systemd-fsck[256]: e2fsck 1.42.12 (29-Aug-2014)
[    8.826013] systemd-fsck[256]: /dev/mmcblk1p2 : propre, 47800/79840 fichiers, 218285/318976 blocs
         Starting Various fixups to make systemd work better on Debian...
         Mounting /tmp...
[  OK  ] Started Various fixups to make systemd work better on Debian.
[ TIME ] Timed out waiting for device dev-mmcblk0p1.device.
[DEPEND] Dependency failed for /boot.
[DEPEND] Dependency failed for Local File Systems.
[DEPEND] Dependency failed for File System Check on /dev/mmcblk0p1.
[  OK  ] Stopped Serial Getty on ttySAC2.
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped getty on tty2-tty6 if dbus and logind are not available.
[  OK  ] Stopped target Graphical Interface.
[  OK  ] Stopped Entropy daemon using the HAVEGE algorithm.
[  OK  ] Stopped target Multi-User System.
[  OK  ] Stopped OpenBSD Secure Shell server.
[  OK  ] Stopped Regular background program processing daemon.
[  OK  ] Stopped /etc/rc.local Compatibility.
[  OK  ] Stopped Login Service.
[  OK  ] Stopped LSB: PLEASE BE PATIENT AND DO NOT INTERRUPT THE FIRST REBOOT.
[  OK  ] Stopped LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Stopped LSB: disk temperature monitoring daemon.
[  OK  ] Stopped LSB: Start/stop sysstat's sadc.
[  OK  ] Stopped LSB: Starts LIRC daemon..
[  OK  ] Stopped LSB: Armbian gathering hardware information.
[  OK  ] Stopped LSB: Start NTP daemon.
[  OK  ] Stopped LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Stopped LSB: set CPUFreq kernel parameters.
[  OK  ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped System Logging Service.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target System Initialization.
[  OK  ] Closed Syslog Socket.
         Starting Emergency Shell...
[  OK  ] Started Emergency Shell.
[  OK  ] Reached target Emergency Mode.
Welcome to emergGive root password for maintenance
(or type Control-D to continue):
root@odroidxu4:~# free
             total       used       free     shared    buffers     cached
Mem:       2030904      61552    1969352       6564       5736      25280
-/+ buffers/cache:      30536    2000368
Swap:            0          0          0
root@odroidxu4:~# ps axf
  PID TTY      STAT   TIME COMMAND
    2 ?        S      0:00 [kthreadd]
    3 ?        S      0:01  \_ [ksoftirqd/0]
    4 ?        S      0:00  \_ [kworker/0:0]
    5 ?        S<     0:00  \_ [kworker/0:0H]
    6 ?        S      0:00  \_ [kworker/u16:0]
    7 ?        S      0:00  \_ [rcu_preempt]
    8 ?        S      0:00  \_ [rcu_sched]
    9 ?        S      0:00  \_ [rcu_bh]
   10 ?        S      0:00  \_ [migration/0]
   11 ?        S      0:00  \_ [watchdog/0]
   12 ?        S      0:00  \_ [cpuhp/0]
   13 ?        S      0:00  \_ [cpuhp/1]
   14 ?        S      0:00  \_ [watchdog/1]
   15 ?        S      0:00  \_ [migration/1]
   16 ?        S      0:00  \_ [ksoftirqd/1]
   18 ?        S<     0:00  \_ [kworker/1:0H]
   19 ?        S      0:00  \_ [cpuhp/2]
   20 ?        S      0:00  \_ [watchdog/2]
   21 ?        S      0:00  \_ [migration/2]
   22 ?        S      0:00  \_ [ksoftirqd/2]
   24 ?        S<     0:00  \_ [kworker/2:0H]
   25 ?        S      0:00  \_ [cpuhp/3]
   26 ?        S      0:00  \_ [watchdog/3]
   27 ?        S      0:00  \_ [migration/3]
   28 ?        S      0:00  \_ [ksoftirqd/3]
   30 ?        S<     0:00  \_ [kworker/3:0H]
   31 ?        S      0:00  \_ [cpuhp/4]
   32 ?        S      0:00  \_ [watchdog/4]
   33 ?        S      0:00  \_ [migration/4]
   34 ?        S      0:00  \_ [ksoftirqd/4]
   35 ?        S      0:00  \_ [kworker/4:0]
   36 ?        S<     0:00  \_ [kworker/4:0H]
   37 ?        S      0:00  \_ [cpuhp/5]
   38 ?        S      0:00  \_ [watchdog/5]
   39 ?        S      0:00  \_ [migration/5]
   40 ?        S      0:00  \_ [ksoftirqd/5]
   41 ?        S      0:00  \_ [kworker/5:0]
   42 ?        S<     0:00  \_ [kworker/5:0H]
   43 ?        S      0:00  \_ [cpuhp/6]
   44 ?        S      0:00  \_ [watchdog/6]
   45 ?        S      0:00  \_ [migration/6]
   46 ?        S      0:00  \_ [ksoftirqd/6]
   47 ?        S      0:00  \_ [kworker/6:0]
   48 ?        S<     0:00  \_ [kworker/6:0H]
   49 ?        S      0:00  \_ [cpuhp/7]
   50 ?        S      0:00  \_ [watchdog/7]
   51 ?        S      0:00  \_ [migration/7]
   52 ?        S      0:00  \_ [ksoftirqd/7]
   53 ?        S      0:00  \_ [kworker/7:0]
   54 ?        S<     0:00  \_ [kworker/7:0H]
   55 ?        S      0:00  \_ [kdevtmpfs]
   56 ?        S<     0:00  \_ [netns]
   57 ?        S      0:00  \_ [kworker/0:1]
   59 ?        S      0:00  \_ [khungtaskd]
   60 ?        S      0:00  \_ [oom_reaper]
   61 ?        S<     0:00  \_ [writeback]
   62 ?        S      0:00  \_ [kcompactd0]
   63 ?        S<     0:00  \_ [crypto]
   64 ?        S<     0:00  \_ [bioset]
   65 ?        S<     0:00  \_ [kblockd]
   66 ?        S<     0:00  \_ [cfg80211]
   67 ?        S<     0:00  \_ [watchdogd]
   68 ?        S<     0:00  \_ [rpciod]
   69 ?        S      0:00  \_ [kswapd0]
   70 ?        S<     0:00  \_ [vmstat]
   71 ?        S<     0:00  \_ [nfsiod]
  115 ?        S<     0:00  \_ [bioset]
  116 ?        S<     0:00  \_ [bioset]
  117 ?        S<     0:00  \_ [bioset]
  118 ?        S<     0:00  \_ [bioset]
  119 ?        S<     0:00  \_ [bioset]
  120 ?        S<     0:00  \_ [bioset]
  121 ?        S<     0:00  \_ [bioset]
  122 ?        S<     0:00  \_ [bioset]
  123 ?        S<     0:00  \_ [bioset]
  124 ?        S<     0:00  \_ [bioset]
  125 ?        S<     0:00  \_ [bioset]
  126 ?        S<     0:00  \_ [bioset]
  127 ?        S<     0:00  \_ [bioset]
  128 ?        S<     0:00  \_ [bioset]
  129 ?        S<     0:00  \_ [bioset]
  130 ?        S<     0:00  \_ [bioset]
  131 ?        S<     0:00  \_ [bioset]
  132 ?        S<     0:00  \_ [bioset]
  133 ?        S<     0:00  \_ [bioset]
  134 ?        S<     0:00  \_ [bioset]
  135 ?        S<     0:00  \_ [bioset]
  136 ?        S<     0:00  \_ [bioset]
  137 ?        S<     0:00  \_ [bioset]
  138 ?        S<     0:00  \_ [bioset]
  139 ?        S      0:00  \_ [irq/132-s2mps11]
  140 ?        S      0:00  \_ [irq/134-1220000]
  141 ?        S<     0:00  \_ [ipv6_addrconf]
  142 ?        S      0:00  \_ [kworker/4:1]
  143 ?        S<     0:00  \_ [kworker/4:1H]
  144 ?        S<     0:00  \_ [bioset]
  145 ?        S      0:00  \_ [mmcqd/1]
  146 ?        S<     0:00  \_ [kworker/5:1H]
  147 ?        S<     0:00  \_ [kworker/6:1H]
  148 ?        S<     0:00  \_ [kworker/7:1H]
  149 ?        S      0:00  \_ [kswitcher_0]
  150 ?        S      0:00  \_ [kswitcher_1]
  151 ?        S      0:00  \_ [kswitcher_2]
  152 ?        S      0:00  \_ [kswitcher_3]
  153 ?        S<     0:00  \_ [deferwq]
  155 ?        S      0:00  \_ [irq/131-hdmi]
  156 ?        S      0:01  \_ [kworker/0:3]
  159 ?        S      0:00  \_ [kworker/1:1]
  180 ?        S      0:00  \_ [kworker/3:1]
  191 ?        S<     0:00  \_ [kworker/0:1H]
  199 ?        S      0:00  \_ [kworker/2:1]
  201 ?        S      0:00  \_ [scsi_eh_0]
  202 ?        S<     0:00  \_ [scsi_tmf_0]
  203 ?        S      0:00  \_ [usb-storage]
  223 ?        S<     0:00  \_ [bioset]
  224 ?        S      0:00  \_ [kworker/u16:2]
  226 ?        S<     0:00  \_ [kworker/3:1H]
  228 ?        S<     0:00  \_ [kworker/2:1H]
  229 ?        S      0:00  \_ [kworker/2:2]
  231 ?        S      0:00  \_ [jbd2/mmcblk1p2-]
  232 ?        S<     0:00  \_ [ext4-rsv-conver]
  257 ?        S<     0:00  \_ [kworker/1:1H]
  266 ?        S      0:00  \_ [kworker/3:2]
  268 ?        S      0:00  \_ [kworker/1:2]
    1 ?        Ss     0:02 /sbin/init
  285 ?        Ss     0:00 /lib/systemd/systemd-journald
  291 ?        Ss     0:00 /lib/systemd/systemd-udevd
  542 ?        Ss     0:00 /bin/sh -c /sbin/sulogin; /bin/systemctl --fail --no-
  543 ?        S      0:00  \_ bash
  621 ?        R+     0:00      \_ ps axf
  599 ?        Ss     0:00 dhclient -v -pf /run/dhclient.eth0.pid -lf /var/lib/d
root@odroidxu4:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:1e:06:30:15:03
          inet adr:192.168.1.15  Bcast:192.168.255.255  Masque:255.255.0.0
          adr inet6: fe80::21e:6ff:fe30:1503/64 Scope:Lien
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:12 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:1000
          RX bytes:1934 (1.8 KiB)  TX bytes:1332 (1.3 KiB)
root@odroidxu4:/home# cat /etc/fstab
/dev/mmcblk0p2 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
/dev/mmcblk0p1 /boot vfat defaults 0 2
root@odroidxu4:/home# sudo nano /etc/fstab
 /dev/mmcblk0 => /dev/mmcblk1 (uboot 2012.07 issue I guess)
@all
I still have the 4 little cores only but it is great... there is no need of fan cooling or heatsink :)
[    1.009593] IRQ53 no longer affine to CPU4
[    1.009916] CPU4: shutdown
[    1.011017]  mmcblk1: p1 p2
[    1.042985] GIC ID for CPU 1 cluster 0 is 1
[    1.064615] IRQ54 no longer affine to CPU5
[    1.064908] CPU5: shutdown
[    1.092452] GIC ID for CPU 2 cluster 0 is 2
[    1.109566] IRQ55 no longer affine to CPU6
[    1.109846] CPU6: shutdown
[    1.137058] GIC ID for CPU 3 cluster 0 is 3
[    1.159539] IRQ56 no longer affine to CPU7
[    1.159825] CPU7: shutdown
[    1.187445] big.LITTLE switcher initialized
The fix is applied before fstab is created, I'll think about the best way to solve this.
