dpSky Posted July 1, 2020 Posted July 1, 2020 I use Armbian_20.05.3_Rockpi-4a_buster_legacy_4.4.213 The armbian kernel version uses 4.4-213 Follow the radxa official installation script: curl -sL https://rock.sh/get-rockpi-penta | sudo -E bash - The output is as follows: Quote root@rockpi-4a:~# curl -sL https://rock.sh/get-rockpi-penta | sudo -E bash - (Reading database ... 56045 files and directories currently installed.) Preparing to unpack /tmp/tmp.pMsOHNj5fC ... Removed /etc/systemd/system/multi-user.target.wants/rockpi-penta.service. Unpacking rockpi-penta (0.10) over (0.10) ... Setting up rockpi-penta (0.10) ... Created symlink /etc/systemd/system/multi-user.target.wants/rockpi-penta.service → /lib/systemd/system/rockpi-penta.service. running install running bdist_egg running egg_info creating Adafruit_SSD1306.egg-info writing Adafruit_SSD1306.egg-info/PKG-INFO writing dependency_links to Adafruit_SSD1306.egg-info/dependency_links.txt writing requirements to Adafruit_SSD1306.egg-info/requires.txt writing top-level names to Adafruit_SSD1306.egg-info/top_level.txt writing manifest file 'Adafruit_SSD1306.egg-info/SOURCES.txt' reading manifest file 'Adafruit_SSD1306.egg-info/SOURCES.txt' writing manifest file 'Adafruit_SSD1306.egg-info/SOURCES.txt' installing library code to build/bdist.linux-aarch64/egg running install_lib running build_py creating build creating build/lib creating build/lib/Adafruit_SSD1306 copying Adafruit_SSD1306/__init__.py -> build/lib/Adafruit_SSD1306 copying Adafruit_SSD1306/SSD1306.py -> build/lib/Adafruit_SSD1306 creating build/bdist.linux-aarch64 creating build/bdist.linux-aarch64/egg creating build/bdist.linux-aarch64/egg/Adafruit_SSD1306 copying build/lib/Adafruit_SSD1306/__init__.py -> build/bdist.linux-aarch64/egg/Adafruit_SSD1306 copying build/lib/Adafruit_SSD1306/SSD1306.py -> build/bdist.linux-aarch64/egg/Adafruit_SSD1306 byte-compiling build/bdist.linux-aarch64/egg/Adafruit_SSD1306/__init__.py to __init__.cpython-37.pyc byte-compiling build/bdist.linux-aarch64/egg/Adafruit_SSD1306/SSD1306.py to SSD1306.cpython-37.pyc creating build/bdist.linux-aarch64/egg/EGG-INFO copying Adafruit_SSD1306.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO copying Adafruit_SSD1306.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO copying Adafruit_SSD1306.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO copying Adafruit_SSD1306.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO copying Adafruit_SSD1306.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO zip_safe flag not set; analyzing archive contents... creating dist creating 'dist/Adafruit_SSD1306-1.6.2-py3.7.egg' and adding 'build/bdist.linux-aarch64/egg' to it removing 'build/bdist.linux-aarch64/egg' (and everything under it) Processing Adafruit_SSD1306-1.6.2-py3.7.egg Removing /usr/local/lib/python3.7/dist-packages/Adafruit_SSD1306-1.6.2-py3.7.egg Copying Adafruit_SSD1306-1.6.2-py3.7.egg to /usr/local/lib/python3.7/dist-packages Adafruit-SSD1306 1.6.2 is already the active version in easy-install.pth Installed /usr/local/lib/python3.7/dist-packages/Adafruit_SSD1306-1.6.2-py3.7.egg Processing dependencies for Adafruit-SSD1306==1.6.2 Searching for Adafruit-GPIO==1.0.5 Best match: Adafruit-GPIO 1.0.5 Processing Adafruit_GPIO-1.0.5-py3.7.egg Adafruit-GPIO 1.0.5 is already the active version in easy-install.pth Using /usr/local/lib/python3.7/dist-packages/Adafruit_GPIO-1.0.5-py3.7.egg Searching for spidev==3.5 Best match: spidev 3.5 Processing spidev-3.5-py3.7-linux-aarch64.egg spidev 3.5 is already the active version in easy-install.pth Using /usr/local/lib/python3.7/dist-packages/spidev-3.5-py3.7-linux-aarch64.egg Searching for Adafruit-PureIO==1.1.5 Best match: Adafruit-PureIO 1.1.5 Processing Adafruit_PureIO-1.1.5-py3.7.egg Adafruit-PureIO 1.1.5 is already the active version in easy-install.pth Using /usr/local/lib/python3.7/dist-packages/Adafruit_PureIO-1.1.5-py3.7.egg Finished processing dependencies for Adafruit-SSD1306==1.6.2 Expand I don’t know where the problem is after execution, I still can’t drive it.... It feels like a failure caused by the kernel, it seems that it only supports linux-image-4.4.154-110-rockchip-gcef30e88a9f5 I executed the command to install the kernel: sudo apt-get install linux-4.4-latest Something went wrong. Quote root@rockpi-4a:~# sudo apt-get install linux-4.4-latest Reading package lists... Done Building dependency tree Reading state information... Done linux-4.4-latest is already the newest version (4.4.154-110-rockchip). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 3 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Setting up rockchip-fstab (0.1) ... sed: -e expression #1, char 0: no previous regular expression mount all partitions mount: vfat: mount point does not exist. mount: vfat: mount point does not exist. mount: vfat: mount point does not exist. mount: vfat: mount point does not exist. mount: vfat: mount point does not exist. dpkg: error processing package rockchip-fstab (--configure): installed rockchip-fstab package post-installation script subprocess returned error exit status 32 Setting up linux-image-4.4.154-110-rockchip-gcef30e88a9f5 (4.4.154-110-rockchip) ... update-initramfs: Generating /boot/initrd.img-4.4.154-110-rockchip-gcef30e88a9f5 update-initramfs: Converting to u-boot format Kernel configuration : earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init rootfstype=ext4 rootwait root=PARTUUID=B921B045-1DF0-41C3-AF44-4C6F280D3FAE Creating new extlinux.conf... cp: cannot stat '/usr/lib/linux-image-4.4.213-rockchip64': No such file or directory run-parts: /etc/kernel/postinst.d/zz-update-extlinux exited with return code 1 dpkg: error processing package linux-image-4.4.154-110-rockchip-gcef30e88a9f5 (--configure): installed linux-image-4.4.154-110-rockchip-gcef30e88a9f5 package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of linux-4.4-latest: linux-4.4-latest depends on linux-image-4.4.154-110-rockchip-gcef30e88a9f5; however: Package linux-image-4.4.154-110-rockchip-gcef30e88a9f5 is not configured yet. dpkg: error processing package linux-4.4-latest (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: rockchip-fstab linux-image-4.4.154-110-rockchip-gcef30e88a9f5 linux-4.4-latest E: Sub-process /usr/bin/dpkg returned an error code (1) Expand I just started contacting SBC System and hope I can get help here!!!!!!!!!!!!!!!!!
Igor Posted July 1, 2020 Posted July 1, 2020 On 7/1/2020 at 2:43 AM, dpSky said: and hope I can get help here!!!!!!!!!!!!!!!!! Expand General support terms:https://github.com/armbian/build#support Start here: https://forum.armbian.com/subscriptions/ or fix problems, hire and expert (buy him tools and time) and provide solution https://docs.armbian.com/Process_Contribute/ You have this hardware and presumable more time than we have. This hat should just work OOB but the display and fan. Radxa software support is done in a quick and dirty way and installer will not just work on Armbian. Anyway - IHMO the only interesting (sane) way is to bring this up on a modern 5.4.y / 5.7.y kernel. Investing (100% our) money to support this add-on on Legacy 4.4 kernel is pointless / throwing something we don't have through the window. And if we choose to do anything ... there is a big big pile of requests, people forget to support with any resource.
setq Posted July 3, 2020 Posted July 3, 2020 Hello, dpSky We provide special installation scripts for armbian, please check here https://forum.radxa.com/t/how-to-install-penta-sata-hat-s-software-on-armbian/3752 1
dpSky Posted July 9, 2020 Author Posted July 9, 2020 On 7/3/2020 at 1:31 AM, setq said: 你好, dpSky 我们为armbian提供了特殊的安装脚本,请在此处查看 https://forum.radxa.com/t/how-to-install-penta-sata-hat-s-software-on-armbian/3752 Expand Thank you for everthing
