orangepi pc doesn't boot after install lvm2 with focal server
jaclopez1978
Hi, I installed the desktop focal version of armbian in orange pi pc. It boots correctly but after install lvm2 and restart, it does not boot. If I don't restart the orangepi the lvm volumes works fine, but after reboot or shutdown it not boot. The steps I made:
Install on sd with ubuntu (restore image directly).
Start the orangepi pc. That's work.
sudo apt-get update
sudo apt-get upgrade
sudo shutdown -r now
Here it works and boot correctly:
sudo apt-get install lvm2
Here dont boot the orange pi:
The log in serial console is:
U-Boot SPL 2020.04-armbian (Jun 15 2020 - 06:08:51 +0200)
DRAM: 1024 MiB
Trying to boot from MMC1
U-Boot 2020.04-armbian (Jun 15 2020 - 06:08:51 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC
DRAM:  1 GiB
MMC:   mmc@1c0f000: 0
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
Bus usb@1c1d000: USB EHCI 1.00
Bus usb@1c1d400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
scanning bus usb@1c1d000 for devices... 1 USB Device(s) found
scanning bus usb@1c1d400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3789 bytes read in 3 ms (1.2 MiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
203 bytes read in 2 ms (98.6 KiB/s)
14522095 bytes read in 691 ms (20 MiB/s)
7163872 bytes read in 342 ms (20 MiB/s)
Found mainline kernel configuration
29475 bytes read in 7 ms (4 MiB/s)
4185 bytes read in 8 ms (510.7 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    14522031 Bytes = 13.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... Bad Data CRC
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
Device 0: unknown device
ethernet@1c30000 Waiting for PHY auto negotiation to complete. done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
*** Unhandled DHCP Option in OFFER/ACK: 125
DHCP client bound to address 192.168.1.130 (1988 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-02-81-3c-da-a3-cb
Retrieving file: pxelinux.cfg/C0A80182
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
Config file not found
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
DHCP client bound to address 192.168.1.130 (2062 ms)
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
DHCP client bound to address 192.168.1.130 (3987 ms)
The only solution I think is install lvm2 when use the disks and purge before shutdown lvm2, with crontab for example. Any help is appreciated.
Thanks a lot and, sorry for my bad english
