When you power on the board, do you have some prompt from boot loader? // with SD card containing Armbian for Orange PI ONE?
  On 6/22/2016 at 4:26 PM, rsegoly said:
Nope, nothing
When I connect Raspberry I see all boot messages
If it's really nothing then connection is wrong or something else that's hardware related (on your side, it's absolutely no problem to use the serial console on any Orange Pi board). But to be honest: Regarding boot messages we just recently changed this and prior to (yet not released) Armbian 5.15 boot messages are sent to HDMI display instead of serial console unless you tweak /boot/boot.cmd (beginning with 5.15 we're using both outputs parallel)
speed is 115200?
I use same connection with Raspberry and it works fine so I do not suspect its wrong connection
  On 6/22/2016 at 5:22 PM, rsegoly said:
speed is 115200?
I use
minicom -D /dev/cu.usbserial -b 115200
with every RPi or any of the countless other SBCs that are lying here around (only exception is Solid-Run's Clearfog since this board contains an own USB-to-UART onboard chip). Not a single problem. Ever. GND <--> GND, TX <--> RX, RX <--> TX, done
http://linux-sunxi.org/Orange_Pi_One#Locating_the_UART
Well I interconnect 2 Pis uart in order to get serial console with 3.3V lines. Cheap and simple. With sometimes curious side effect : power led glowing without power supply on bpiM2+ (powered by uart !) or boot fail on monitoring BPI when bpiM2+ crashed in unknown state during boot ...
N.B. On bpiM2+ tx/rx order is inverted in comparison of RPI or bpiM1.
speed is 115200?
Speed is 15200.
The Raspis have the serial console on the rows of GPIO pins. Orange PI ONE has a separate UART-connector (three pins, no power connection) see link @tkaiser.
I used the serial console regularly from Linux host with
screen /dev/ttyUSB0 115200
I just rechecked with Armbian_5.14 and it looks like there is no login console anymore. Boot messages appear and then the console switches to HDMI.
Leave the host side connected and reboot the OPI. You should see start messages in your terminal window. This would confirm you have a correct
hardware setup. For the needed changes in configuration see @tkaiser's posts above.
  Quote
Huh. There is no console output but login should be possible from serial.
It's possible than we produced a bug ;)
Quick workaround to enable serial console on OPI :
cd /boot
sudo nano boot.cmd
-----------------------------------enable serial console
setenv bootargs "console=tty1 console=ttyS0,115200 root=/dev/mmcblk0p1 ......................
sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
reboot
enjoy !
Orange Pi One serial console works normally.
U-Boot 2016.05-armbian (Jun 23 2016 - 09:03:24 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi One
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2465 bytes read in 172 ms (13.7 KiB/s)
## Executing script at 43100000
gpio: pin PL10 (gpio 298) value is 1
   Warning: value of pin is still 0
gpio: pin PG11 (gpio 203) value is 1
** File not found /boot/.verbose **
** File not found /boot/.next **
** Unrecognized filesystem type **
** File not found .next **
35908 bytes read in 507 ms (68.4 KiB/s)
3136501 bytes read in 3263 ms (938.5 KiB/s)
5011808 bytes read in 5166 ms (947.3 KiB/s)
Kernel image @ 0x48000000 [ 0x000000 - 0x4c7960 ]
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    3136437 Bytes = 3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Using machid 0x1029 from environment
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2004620!
ion_reserve_common: ion reserve: [0x56000000, 0x60000000]!
Ubuntu 16.04 LTS orangepione ttyS0
orangepione login:
Yes, it definitely does. In the cases it did not, wrong connections or missing configuration in boot.cmd were found.
