Like the title says, when I open armbian-config on my brand new NanoPi M4N2 I don't see a "Hardware" entry in the menu... is this expected?
Only reason I wanted to access is to ensure I disable WiFi as I am only using Ethernet.
For the record, I'm powering it with a 5V 4A PoE adapter,  using a Samsung SD-card flashed with Armbian_20.05.7_Nanopim4v2_buster_current_5.4.49.img. I'm using a 256GB Sabrent M.2 NVME SSD as the main disk (configured via armbian-config), so the SSD card is for initial booting only.
FYI, I found that this was due to a missing entry in debian-config-functions so I submitted a PR to add it (here) and this has now been merged so it should be available on the next update of armbian-config!
Thx for the PR.:thumbup:
You can also things like blacklisting the wifi module, using iwconfig wlan0 power off ...
