Armbianmonitor:
I am using Armbian_20.05.4_Lime-a64_focal_current_5.4.45_desktop.img.xz and I try run glxgears on Olinuxino-A64 with Lima. When I running glxgears I see 117 frames in 5.0 second = 23.313FPS. Also mouse response so slow on desktop. It is understood from here Olinuxino-A64 doing software render. Please correct me if I am wrong. I am new at this job and I have difficulty in fully understanding the problem. Is there a way I can get high FPS in glxgears using Lima? What exactly is problem here? Sorry if I ask silly question. Thanks. Below are some outputs for the board I use.
dmesg | grep "lima" output:
[    8.579828] lima 1c40000.gpu: IRQ ppmmu2 not found
[    8.584705] lima 1c40000.gpu: IRQ ppmmu3 not found
[    8.589554] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
[    8.589626] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
[    8.589670] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[    8.589694] lima 1c40000.gpu: IRQ pp2 not found
[    8.594298] lima 1c40000.gpu: IRQ pp3 not found
[    8.598869] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[    8.606923] lima 1c40000.gpu: bus rate = 200000000
[    8.606932] lima 1c40000.gpu: mod rate = 297000000
[    8.607264] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 0
gpu node on sun50i-a64-olinuxoni.dts:
gpu@1c40000 {
			compatible = "allwinner,sun50i-a64-mali", "arm,mali-400";
			reg = <0x1c40000 0x10000>;
			interrupts = <0x0 0x61 0x4 0x0 0x62 0x4 0x0 0x63 0x4 0x0 0x64 0x4 0x0 0x66 0x4 0x0 0x67 0x4 0x0 0x65 0x4>;
			interrupt-names = "gp", "gpmmu", "pp0", "ppmmu0", "pp1", "ppmmu1", "pmu";
			clocks = <0x2 0x35 0x2 0x72>;
			clock-names = "bus", "core";
			resets = <0x2 0x1f>;
			phandle = <0x83>;
glxinfo:
name of display: :0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_context_flush_control, GLX_ARB_create_context,
    GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
    GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
    GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
    GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
    GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
    GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
    GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_no_error,
    GLX_ARB_create_context_profile, GLX_ARB_fbconfig_float,
    GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_MESA_swap_control,
    GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGIS_multisample,
    GLX_SGI_make_current_read, GLX_SGI_video_sync
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: lima (0x13b5)
    Device: Mali400 (0xffffffff)
    Version: 20.0.8
    Accelerated: yes
    Video memory: 0MB
    Unified memory: yes
    Preferred profile: compat (0x2)
    Max core profile version: 0.0
    Max compat profile version: 2.1
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 2.0
OpenGL vendor string: lima
OpenGL renderer string: Mali400
OpenGL version string: 2.1 Mesa 20.0.8
OpenGL shading language version string: 1.20
OpenGL extensions:
    GL_AMD_shader_trinary_minmax, GL_APPLE_packed_pixels,
    GL_ARB_ES2_compatibility, GL_ARB_clear_buffer_object,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_copy_buffer,
    GL_ARB_debug_output, GL_ARB_depth_texture, GL_ARB_draw_buffers,
    GL_ARB_draw_elements_base_vertex, GL_ARB_explicit_attrib_location,
    GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_fragment_shader, GL_ARB_framebuffer_sRGB,
    GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
    GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
    GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
    GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multisample,
    GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
    GL_ARB_parallel_shader_compile, GL_ARB_pixel_buffer_object,
    GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
    GL_ARB_robustness, GL_ARB_sampler_objects, GL_ARB_separate_shader_objects,
    GL_ARB_shader_objects, GL_ARB_shader_texture_lod,
    GL_ARB_shading_language_100, GL_ARB_shading_language_include,
    GL_ARB_shadow, GL_ARB_sync, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_ARB_texture_cube_map,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_rectangle, GL_ARB_texture_storage, GL_ARB_transpose_matrix,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
    GL_ATI_fragment_shader, GL_ATI_separate_stencil,
    GL_ATI_texture_env_combine3, GL_EXT_EGL_image_storage, GL_EXT_EGL_sync,
    GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_copy_texture, GL_EXT_direct_state_access,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
    GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
    GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture,
    GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
    GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode, GL_EXT_vertex_array,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
    GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
    GL_KHR_parallel_shader_compile, GL_KHR_texture_compression_astc_ldr,
    GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_pack_invert,
    GL_MESA_window_pos, GL_NV_blend_square, GL_NV_fog_distance,
    GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
    GL_NV_texture_rectangle, GL_OES_EGL_image, GL_OES_read_format,
    GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
    GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 20.0.8
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
    GL_APPLE_texture_max_level, GL_EXT_blend_minmax,
    GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_discard_framebuffer,
    GL_EXT_draw_buffers, GL_EXT_draw_elements_base_vertex, GL_EXT_frag_depth,
    GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
    GL_EXT_occlusion_query_boolean, GL_EXT_read_format_bgra,
    GL_EXT_separate_shader_objects, GL_EXT_texture_border_clamp,
    GL_EXT_texture_format_BGRA8888, GL_EXT_unpack_subimage,
    GL_KHR_texture_compression_astc_sliced_3d, GL_NV_draw_buffers,
    GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_NV_read_depth,
    GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
    GL_OES_EGL_image_external, GL_OES_EGL_sync,
    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,
    GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint,
    GL_OES_fbo_render_mipmap, GL_OES_get_program_binary, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_required_internalformat,
    GL_OES_rgb8_rgba8, GL_OES_stencil8, GL_OES_surfaceless_context,
    GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_npot,
    GL_OES_vertex_array_object, GL_OES_vertex_half_float
126 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x022 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x29b 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x29c 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x29d 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
150 GLXFBConfigs:
0x0d9 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0da 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0db 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0dc 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
and lsmod output:
snd_soc_hdmi_codec     20480  1
dw_hdmi_cec            16384  0
dw_hdmi_i2s_audio      16384  0
axp20x_adc             20480  0
axp20x_battery         16384  0
axp20x_ac_power        16384  0
snd_soc_spdif_tx       16384  0
snd_soc_simple_card    24576  1
snd_soc_simple_card_utils    20480  1 snd_soc_simple_card
sun50i_codec_analog    28672  0
sun8i_adda_pr_regmap    16384  1 sun50i_codec_analog
sun8i_drm_hdmi         24576  0
zstd                   16384  4
sun4i_gpadc_iio        24576  0
sun8i_codec            28672  0
dw_hdmi                40960  2 sun8i_drm_hdmi,dw_hdmi_i2s_audio
sun4i_i2s              24576  2
lima                   45056  3
cec                    69632  2 dw_hdmi_cec,dw_hdmi
gpu_sched              28672  1 lima
snd_soc_core          176128  7 sun4i_i2s,snd_soc_spdif_tx,snd_soc_hdmi_codec,sun50i_codec_analog,sun8i_codec,snd_soc_simple_card_utils,snd_soc_simple_card
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm               106496  5 sun4i_i2s,snd_soc_hdmi_codec,sun8i_codec,snd_soc_core,snd_pcm_dmaengine
snd_timer              40960  1 snd_pcm
snd                    86016  6 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
soundcore              16384  1 snd
r8723bs               589824  0
cfg80211              356352  1 r8723bs
rfkill                 28672  4 cfg80211
sun4i_drm              20480  7
sun4i_frontend         16384  1 sun4i_drm
sun4i_tcon             32768  1 sun4i_drm
sun8i_mixer            40960  0
sun8i_tcon_top         16384  3 sun8i_drm_hdmi,sun4i_tcon,sun4i_drm
cpufreq_dt             20480  0
zram                   32768  2
sch_fq_codel           20480  6
usb_f_acm              20480  1
u_serial               32768  1 usb_f_acm
g_serial               16384  0
libcomposite           61440  2 g_serial,usb_f_acm
ip_tables              32768  0
x_tables               36864  1 ip_tables
autofs4                49152  2
axp20x_usb_power       16384  0
pinctrl_axp209         16384  0
axp20x_regulator       45056  8
fixed                  20480  2
dwmac_sun8i            28672  0
mdio_mux               16384  1 dwmac_sun8i
Edited by Faruk
As far from what I see it is not software rendered. That would be LLVM.
What you can try is to install mesa from scratch or use oibaf ppa (I had more success on H6 with 1st method though) to get more up to date mesa binaries and/or install a more recent kernel. You can compile a 5.7 kernel package  for sunxi64 using the build script: github.com/armbian/build/
or check nightly builds for trunk kernel packages.
Thank for your reply but Will it be enough just to upgrade the kernel ?
I don't know. Maybe, maybe not. I neither have this board nor access to a similar one to test atm. Dealing with SBCs often is try'n'error. That is the usual business....
