I try use image http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&tid=3844
this only one image works HDMI input for HDMI output PC
ffmpeg -f v4l2 -list_formats all -i /dev/video0
[video4linux2,v4l2 @ 0xab89b120] Raw       :     yuyv422 :           YUYV 4:2:2 :
[video4linux2,v4l2 @ 0xab89b120] Raw       :     uyvy422 :           UYVY 4:2:2 :
[video4linux2,v4l2 @ 0xab89b120] Raw       :     yuv422p :     Planar YVU 4:2:2 :
[video4linux2,v4l2 @ 0xab89b120] Raw       : Unsupported :         Y/CbCr 4:2:2 :
[video4linux2,v4l2 @ 0xab89b120] Raw       :     yuv420p :     Planar YUV 4:2:0 :
[video4linux2,v4l2 @ 0xab89b120] Raw       :     yuv420p :     Planar YVU 4:2:0 :
[video4linux2,v4l2 @ 0xab89b120] Raw       :        nv12 :         Y/CbCr 4:2:0 :
[video4linux2,v4l2 @ 0xab89b120] Raw       : Unsupported :         Y/CrCb 4:2:0 :
[video4linux2,v4l2 @ 0xab89b120] Raw       :        gray :      8-bit Greyscale :
[video4linux2,v4l2 @ 0xab89b120] Raw       : Unsupported : 16-bit A/XYUV 4-4-4-4 :
[video4linux2,v4l2 @ 0xab89b120] Raw       : Unsupported :         Y/CbCr 4:4:4 :
[video4linux2,v4l2 @ 0xab89b120] Compressed:       mjpeg :            JFIF JPEG :
[video4linux2,v4l2 @ 0xab89b120] Raw       :    rgb565le :     16-bit RGB 5-6-5 :
[video4linux2,v4l2 @ 0xab89b120] Raw       : bayer_grbg8 : 8-bit Bayer GRGR/BGBG :
also tried images
1. OrangePi_rk3399_ubuntu_bionic_desktop_linux4.4.179_v1.3 from  https://drive.google.com/drive/folders/17t3rWNuvG5i72UgrwfgEuevrEFS9Txo4
2.  Armbian_20.05.4_Orangepi-rk3399_focal_current_5.4.46  from https://dl.armbian.com/orangepi-rk3399/archive/
and try encoding to h264 use preset ultrafast
720p work without h264_rkmpp
ffmpeg -f v4l2 -pix_fmt nv12 -framerate 25 -s 1280x720 -framerate 25 -re -i /dev/video0  -pix_fmt yuv420p -vsync 2  -c:v libx264 -preset ultrafast -profile:v baseline -r 25 -g 50 -sc_threshold 0 -threads 0 -an -bsf:v h264_mp4toannexb -f mpegts "udp://192.168.1.85:10000?pkt_size=1316»
 https://yadi.sk/i/68YnUz6nDLhK6g
1080p after 15 seconds board rebooted
ffmpeg -f v4l2 -pix_fmt nv12 -framerate 25 -s 1920x1080 -framerate 25 -re -i /dev/video0  -pix_fmt yuv420p -vsync 2  -c:v libx264 -preset ultrafast -profile:v baseline -r 25 -g 50 -sc_threshold 0 -threads 0 -an -bsf:v h264_mp4toannexb -f mpegts "udp://192.168.1.85:10000?pkt_size=1316"
Then a try install ffmpeg with h264_rkmpp how I did it from armbian kernel
But from this kernel rockcip_mpp not compiled need kernel headers video/rk_vpu_service
[  5%] Building C object mpp/hal/dummy/CMakeFiles/hal_dummy.dir/hal_dummy_dec_api.c.o
/tmp/rockchip_mpp/mpp/hal/worker/mpp_device/mpp_device.c:24:34: fatal error: video/rk_vpu_service.h: No such file or directory
 #include <video/rk_vpu_service.h>
compilation terminated.
mpp/hal/worker/mpp_device/CMakeFiles/mpp_device.dir/build.make:62: recipe for target 'mpp/hal/worker/mpp_device/CMakeFiles/mpp_device.dir/mpp_device.c.o' failed
make[2]: *** [mpp/hal/worker/mpp_device/CMakeFiles/mpp_device.dir/mpp_device.c.o] Error 1
CMakeFiles/Makefile2:3081: recipe for target 'mpp/hal/worker/mpp_device/CMakeFiles/mpp_device.dir/all' failed
make[1]: *** [mpp/hal/worker/mpp_device/CMakeFiles/mpp_device.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[  5%] Building C object mpp/hal/dummy/CMakeFiles/hal_dummy.dir/hal_dummy_enc_api.c.o
[ 16%] Built target osal
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
Then I try connect my Nikon D5300 to hdmi in
ffmpeg is not responding and board not responding
root@linaro-alip:/home/linaro# ffmpeg -f v4l2 -pix_fmt nv12 -framerate 25 -s 1280x720 -framerate 25 -re -i /dev/video0  -pix_fmt yuv420p -vsync 2  -c:v libx264 -preset ultrafast -profile:v baseline -r 25 -g 50 -sc_threshold 0 -threads 0 -an -bsf:v h264_mp4toannexb -f mpegts "udp://192.168.1.85:10000?pkt_size=1316"
ffmpeg version 3.2.15-0+deb9u1 Copyright (c) 2000-2020 the FFmpeg developers
[video4linux2,v4l2 @ 0xab784270] The driver does not permit changing the time per frame
[video4linux2,v4l2 @ 0xab784270] Time per frame unknown
Input #0, video4linux2,v4l2, from '/dev/video0':
  Duration: N/A, bitrate: N/A
    Stream #0:0: Video: rawvideo (NV12 / 0x3231564E), nv12, 1280x720, 1000k tbr, 1000k tbn, 1000k tbc
[libx264 @ 0xab787250] using cpu capabilities: ARMv6 NEON
[libx264 @ 0xab787250] profile Constrained Baseline, level 3.1
Output #0, mpegts, to 'udp://192.168.1.85:10000?pkt_size=1316':
  Metadata:
    encoder         : Lavf57.56.101
    Stream #0:0: Video: h264 (libx264), yuv420p, 1280x720, q=-1--1, 25 fps, 90k tbn, 25 tbc
    Metadata:
      encoder         : Lavc57.64.101 libx264
    Side data:
      cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Press [q] to stop, [?] for help
frame=    0 fps=0.0 q=0.0 Lsize=       0kB time=00:00:00.00 bitrate=N/A speed=   0x
video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used)
where can i get normal support hdmi-in ?
See
https://medium.com/@poddingue/stream-for-cheap-rk3399-and-ffmpeg-part-i-149f330bd127
https://trac.ffmpeg.org/wiki/Capture/Webcam#Linux
Edited by whitefox
4 hours ago, whitefox said:
also tried images
in user manual writen
Hdmi in only supports receiving input signals of 1080p60, and connects the hdmi output port of other devices to the hdmi in interface of RK3399
maybe at the camera  signal 1080p50
  Metadata:
    Metadata:
    Side data:
Stream mapping:
See
I read carefully user manual and found it
#Dont supports imultaneous HDMI and Screen for HDMI IN Using HDMI IN with HDMI port
CONFIG_VIDEO_TC358749XBG=y
#CONFIG_ROCKCHIP_DW_MIPI_DSI=y
#CONFIG_DRM_PANEL_SIMPLE=y
I did so and went to rebuild kernel image
git clone --depth 1 https://github.com/armbian/build
cd build
./compile.sh
# in dialog menu
# U-boot and kernel packages -> Show a kernel configuration menu before compilation
# then in kernel configuration menu use save config -> edit via vi -> laod config
  ___  ____  _   ____  _  ____________ ___   ___
 / _ \|  _ \(_) |  _ \| |/ /___ /___ // _ \ / _ \
| | | | |_) | | | |_) | ' /  |_ \ |_ \ (_) | (_) |
| |_| |  __/| | |  _ <| . \ ___) |__) \__, |\__, |
 \___/|_|   |_| |_| \_\_|\_\____/____/  /_/   /_/
Welcome to Armbian Focal with Linux 4.4.213-rk3399
System load:   0.19 0.14 0.06  	Up time:       1 min
Memory usage:  3 % of 3809MB 	IP:            192.168.1.90
CPU temp:      55°C
Usage of /:    19% of 15G
Last login: Sat Aug  8 18:47:55 2020 from 192.168.1.85
root@orangepi-rk3399:~# v4l2-ctl --list-devices
rkisp10_selfpath (platform:rkisp10-000):
	/dev/video0
	/dev/video1
	/dev/video2
	/dev/video3
root@orangepi-rk3399:~# ffmpeg -f v4l2 -list_formats all -i /dev/video0
ffmpeg version 4.2.4-1ubuntu0.1 Copyright (c) 2000-2020 the FFmpeg developers
  built with gcc 9 (Ubuntu 9.3.0-10ubuntu2)
  configuration: --prefix=/usr --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
  libavutil      56. 31.100 / 56. 31.100
  libavcodec     58. 54.100 / 58. 54.100
  libavformat    58. 29.100 / 58. 29.100
  libavdevice    58.  8.100 / 58.  8.100
  libavfilter     7. 57.100 /  7. 57.100
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  5.100 /  5.  5.100
  libswresample   3.  5.100 /  3.  5.100
  libpostproc    55.  5.100 / 55.  5.100
[video4linux2,v4l2 @ 0x5594189760] Raw       :     yuyv422 :           YUYV 4:2:2 :
[video4linux2,v4l2 @ 0x5594189760] Raw       :     uyvy422 :           UYVY 4:2:2 :
[video4linux2,v4l2 @ 0x5594189760] Raw       :     yuv422p :     Planar YVU 4:2:2 :
[video4linux2,v4l2 @ 0x5594189760] Raw       : Unsupported :         Y/CbCr 4:2:2 :
[video4linux2,v4l2 @ 0x5594189760] Raw       :     yuv420p :     Planar YUV 4:2:0 :
[video4linux2,v4l2 @ 0x5594189760] Raw       :     yuv420p :     Planar YVU 4:2:0 :
[video4linux2,v4l2 @ 0x5594189760] Raw       :        nv12 :         Y/CbCr 4:2:0 :
[video4linux2,v4l2 @ 0x5594189760] Raw       : Unsupported :         Y/CrCb 4:2:0 :
[video4linux2,v4l2 @ 0x5594189760] Raw       :        gray :      8-bit Greyscale :
[video4linux2,v4l2 @ 0x5594189760] Raw       : Unsupported : 16-bit A/XYUV 4-4-4-4 :
[video4linux2,v4l2 @ 0x5594189760] Raw       : Unsupported :         Y/CbCr 4:4:4 :
[video4linux2,v4l2 @ 0x5594189760] Compressed:       mjpeg :            JFIF JPEG :
[video4linux2,v4l2 @ 0x5594189760] Raw       :    rgb565le :     16-bit RGB 5-6-5 :
[video4linux2,v4l2 @ 0x5594189760] Raw       : bayer_grbg8 : 8-bit Bayer GRGR/BGBG :
/dev/video0: Immediate exit requested
Profit !
but it's too early to rejoice ffmpeg and gstreamer  not runing
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device '/dev/video0' failed during initialization
Additional debug info:
gstv4l2object.c(3782): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Call to S_FMT failed for NV12 @ 1920x1080: Bad address
Execution ended after 0:00:00.117020985
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ..
Parsing a group of options: input url /dev/video0.
Applying option hwaccel (use HW accelerated decoding) with argument vaapi.
Applying option f (force format) with argument v4l2.
Applying option pix_fmt (set pixel format) with argument nv12.
Applying option s (set frame size (WxH or abbreviation)) with argument 1920x1080.
Applying option r (set frame rate (Hz value, fraction or abbreviation)) with argument 30.
Successfully parsed a group of options.
Opening an input file: /dev/video0.
[video4linux2,v4l2 @ 0x5595907930] fd:3 capabilities:84200001
[video4linux2,v4l2 @ 0x5595907930] Current input_channel: 0, input_name: tc358749xbg, input_std: 0
/dev/video0: Bad address
  • Igor changed the title to Streaming ffmpeg video from orangepi rk3399 to youtube
