djjerdog Posted August 17, 2020 Posted August 17, 2020 I manged to get the USB OTG headers working on the NEO3 by modifying the NanoPi R2S DTB that it is currently using. 2 changes were needed: - Replaced all usb2 references to usb0 - Changed dr_mode for usb@ff580000 from otg to peripheral Modified DTB file attached if anyone else wants to give this a try or has a need for OTG on the NEO3 rk3328-nanopi-neo3-rev00.dtb 1 Quote
Igor Posted August 17, 2020 Posted August 17, 2020 2 hours ago, djjerdog said: if anyone else Forum is a black hole. If you want that this contribution is not lost, make it way to the build script. As a patch or as an overlay. 0 Quote
Myy Posted August 17, 2020 Posted August 17, 2020 Is it possible to get the patched .dts file at least ? This way, we could create a patch and integrate it to the armbian build tree. 1 Quote
ravenchi Posted January 31, 2022 Posted January 31, 2022 this thread is very important and i hope if can provide more details on how to do it 0 Quote
Lamerjack Posted March 27, 2023 Posted March 27, 2023 @djjerdog can you be more specific with - Replaced all usb2 references to usb0? 0 Quote
Lamerjack Posted June 7, 2023 Posted June 7, 2023 If someone other need a fix. I found this post: at the point 2 there is a working fix! 0 Quote
