Hi Igor!
I'm running your Image on BananaPi and BananaPro and I want to use the 7" Lemaker LCD...
Image-Version: 3.2 Kernel 3.4.108 Wheezy
How do I switch the script.bin-file?
Do I have to change the symbolic link like:
ln -s /boot/bin/bananapipro.bin /boot/script.bin
In /boot/bin are all script.bin files, but the filesize of the BananaPro BIN-files are identical:
50516 bananapi.bin
50580 bananapilcd7.bin
50612 bananapipro.bin
50612 bananapiprolcd7.bin
The original BIN-files from Lemaker have a different size too:
50972 banana_pi_7lcd.bin
50564 banana_pro_7lcd.bin
Did you make any changes in the BIN-files?
Can I use the BIN-Files from Lemaker?
Thanks.
Steffen
Yes, you only need to re-link to proper one. Same size is nothing unusual since the difference is most likely only LCD enable / disable. 1 / 0
And yes, you can use the one from Lemaker. I got them there and I don't think I made any modifications.
I've tryed to get the 7" Lemaker LCD running with your image v3.2 Kernel 3.4.108 (Wheezy).
What I did is:
rm -f /boot/script.bin
ln -s /boot/bin/bananapiprolcd7.bin /boot/script.bin
After reboot the LCD-Backlight goes on, but there is no output.
I've checked 2 LCDs and 2 BananaPro.
It works with Bananian and Raspian. Can you check it?
Steffen
I have one 7inch LCD from Lemaker around and the last time it was working.
Have you load the driver - add this to /etc/modules
ft5x_ts
Can you check it?
Yes, I'll and put to faq.
That's the one from me... ;-)
The driver is only for the touch, but I get no output on the screen.
Steffen
Oh  :P Nice to meet you again!
I just checked and it's working out of the box. First I used some old 3.4.107 image with link to bananapilcd7.bin since I have normal Banana not PRO ... (try bin from normal Banana. Anyway it should work)
Than I made an upgrade to latest 3.4.108 kernel together with u-boot. Reboot. Again, no problem ... boot output is to LCD.
With default modules on Wheezy:
hci_uart
gpio_sunxi
rfcomm
hidp
sunxi-ir
bonding
spi_sun7i
8021q
a20_tp
Edit:
Made another test with fresh Ubuntu trusty 3.2 with 3.4.108
cd /boot
ln -sf bin/bananapilcd7.bin script.bin
reboot
working.
Hi Igor,
script.bin for BananaPi (bananapilcd7.bin) works, even with BananaPro,
but if I use the BIN-file for BananaPro (bananapiprolcd7.bin) I only get a black LCD with backlight on.
I have tryed the BIN-file from Lemaker. Same problem.
Like I said with Bananian or Raspian there is no problem with BananaPro and Lemaker LCD...
Any idea?
Now I will try an older version of your image...
Thanks.
Steffen
Any idea?
I guess the script file is bad - I just copy it from lemaker Github - but we nail down another bug :) I'll fix this asap.
Just get the latest build 3.4.108 ... some 3.4.107 have stability issues.
Okay Igor, thanks a lot. I will wait for your fix.
Until then I need to use Bananian for my BananaPro.
Steffen
