Graham Posted October 14, 2020 Posted October 14, 2020 Hi, this is a problem that has persisted on my Orange Pi H2+ Board (running Armbian) for quite some time now. At one stage I thought I had resolved the issue, but now since an update to some unrelated software, said software no longer works. I have tracked this back to the locale settings, which, for all intents and purposes, don't exist. I have tried a variety of fixes, such as trying to set Locale using the armbian-config , but Locale remains adamantly blank. I can SSH into the board (which is where I ran the arm config program, as well as the following commands). I tried dpkg-reconfigure locales but I only get told the following: perl: warning: Setting locale failed. perl: warning: Please check that your locale settings: LANGUAGE = (unset), LC_ALL = "en_NZ.utf8", LC_PAPER = "en_NZ.UTF-8", LC_ADDRESS = "en_NZ.UTF-8", LC_MONETARY = "en_NZ.UTF-8", LC_NUMERIC = "en_NZ.UTF-8", LC_TELEPHONE = "en_NZ.UTF-8", LC_IDENTIFICATION = "en_NZ.UTF-8", LC_MEASUREMENT = "en_NZ.UTF-8", LC_TIME = "en_NZ.UTF-8", LC_NAME = "en_NZ.UTF-8", LANG = "en_US.UTF-8" are supported and installed on your system. perl: warning: Falling back to the standard locale ("C"). locale: Cannot set LC_CTYPE to default locale: No such file or directory locale: Cannot set LC_MESSAGES to default locale: No such file or directory locale: Cannot set LC_ALL to default locale: No such file or directory dpkg-query: package 'locales' is not installed and no information is available Use dpkg --info (= dpkg-deb --info) to examine archive files, and dpkg --contents (= dpkg-deb --contents) to list their contents. /usr/sbin/dpkg-reconfigure: locales is not installed Finally, running locale -a I simply end up with the following: locale: Cannot set LC_CTYPE to default locale: No such file or directory locale: Cannot set LC_MESSAGES to default locale: No such file or directory locale: Cannot set LC_COLLATE to default locale: No such file or directory C C.UTF-8 POSIX I have looked at your documentation too, and while I can find information on how to change to an alternative locale, there is no information as to how I go about INSTALLING missing locales. How do I fix this?
Igor Posted October 14, 2020 Posted October 14, 2020 2 hours ago, Graham said: How do I fix this? Try hints from https://www.google.com/search?q=how+to+fix+locales+debian
xwiggen Posted October 15, 2020 Posted October 15, 2020 The locales package is required for locales anything other than C/POSIX, generation is necessary to be able to provide a lot smaller package rather than shipping all locales pregenerated -- i.e. did you install it? (/usr/bin/locale is libc stuff without actual locale data)
Graham Posted October 16, 2020 Author Posted October 16, 2020 On 10/14/2020 at 1:20 PM, Igor said: Try hints from https://www.google.com/search?q=how+to+fix+locales+debian Hi Igor, sorry but that's what I tried already a few days ago. All I appear to find is instructions on how to list the locales that are already installed (and I only see C) but I have not been able to find out how to download/install new locales On 10/15/2020 at 5:15 PM, xwiggen said: The locales package is required for locales anything other than C/POSIX, generation is necessary to be able to provide a lot smaller package rather than shipping all locales pregenerated -- i.e. did you install it? (/usr/bin/locale is libc stuff without actual locale data) I obviously have /usr/bin however the locale directory does not exist. OK, so the fastest way to find a solution is to first make an idiot of yourself, and then the solution pops up... I found this link where a similar question is asked, and followed the advice given in the answer there. When I ran the third command (after running the first two of course), a program popped up in the terminal window, where I was able to install and set my desired locale. Thanks guys for the point in the right direction. I have no idea why I was not able to find this before! https://serverfault.com/questions/301896/how-to-fix-locale-settings-in-debian-squeeze
Dirk_P_Broer Posted February 23, 2022 Posted February 23, 2022 (edited) You can try LC_ALL = C and see if it solves your problems. It appears to be a bug in 32-bit GLIBC for Linux/ARM I have the problem myself when I choose Time zone Amsterdam, Language English and Keyboard US Edited February 23, 2022 by Dirk_P_Broer combination of different locales that creates the problem
c0rnelius Posted February 24, 2022 Posted February 24, 2022 Armv7 and Locales can sometimes be a bitch. Have you tried? sudo apt update; sudo apt install -y locales-all
Dirk_P_Broer Posted March 6, 2022 Posted March 6, 2022 (edited) On 2/24/2022 at 1:01 AM, Cornelius said: Armv7 and Locales can sometimes be a bitch. Have you tried? sudo apt update; sudo apt install -y locales-all I did, found it didn't solve my problems and searched further. That how I came up with LC_ALL = C On a Raspberry Pi 3B the problem went away when I changed 32-bit Raspberry Pi OS for 64-bit Raspberry Pi OS, so changing glibc as well. Edited March 8, 2022 by Dirk_P_Broer 32-bit OS vs 64-bit OS on same board
