g00d Posted October 24, 2021 Posted October 24, 2021 Hi Steven, thanks for your feedback and thanks again for your suggestion that led me to the right direction. Yeah, the .next file was missing after I did the encryption stuff mentioned here, no clue why. So I wrote everything in detail, maybe the devs can look over it and tell us more and even fix it if there's something to fix. Thanks for the hint about net.ifnames=0 I will try that and report back. I'm happy right now. 0 Quote
pinebook Posted February 10, 2022 Posted February 10, 2022 I've just installed to a Pinebook Pro successfully. Bluetooth is not working, but that's acceptable to me. Details here Thank you so much @MMGenfor the script. 0 Quote
Felix Posted April 28, 2022 Posted April 28, 2022 I have Orange Pi Lite. After running the attached script. But, black screen after reboot on LUKS enabled SD Card. I don't see any prompt asking for password to unlock the root partition. I use the following command to run: sudo ./armbian_rootenc_setup.sh -R -m -F /dev/sda U-Boot 2020.10-armbian (Aug 08 2021 - 16:13:23 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Lite DRAM: 512 MiB MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT… Unable to use mmc 0:1… In: serial@1c28000 Out: serial@1c28000 Err: serial@1c28000 Net: No ethernet found. starting USB… Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c1b000 for devices… 1 USB Device(s) found scanning bus usb@1c1b400 for devices… 2 USB Device(s) found scanning bus usb@1c1c000 for devices… 2 USB Device(s) found scanning bus usb@1c1c400 for devices… 1 USB Device(s) found scanning usb for storage devices… 0 Storage Device(s) found Autoboot in 1 seconds switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1… Found U-Boot script /boot/boot.scr 3964 bytes read in 2 ms (1.9 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 202 bytes read in 2 ms (98.6 KiB/s) 9986940 bytes read in 476 ms (20 MiB/s) 7995296 bytes read in 382 ms (20 MiB/s) Found mainline kernel configuration 31752 bytes read in 11 ms (2.8 MiB/s) 4185 bytes read in 7 ms (583 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 45000000 ## Loading init Ramdisk from Legacy Image at 43300000 … Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 9986876 Bytes = 9.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum … OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 49679000, end 49fff33c … OK Loading Device Tree to 49608000, end 49678fff … OK Starting kernel … 0 Quote
MMGen Posted May 10, 2022 Author Posted May 10, 2022 Updated automated script to support Bullseye and Jammy images, plus minor bugfixes. 0 Quote
MMGen Posted May 10, 2022 Author Posted May 10, 2022 On 4/28/2022 at 4:16 AM, Felix said: I have Orange Pi Lite. After running the attached script. But, black screen after reboot on LUKS enabled SD Card. I don't see any prompt asking for password to unlock the root partition. I use the following command to run: sudo ./armbian_rootenc_setup.sh -R -m -F /dev/sda Are you able to unlock the device via SSH as per the instructions? Can you ping the device at the expected address? Note that the script has been updated, so you might clone or pull the new version from Github and try running it again. 0 Quote
LightJolteon Posted May 30, 2022 Posted May 30, 2022 Hello, I've been trying to use the automated script on an Odriod HC4 running Ubuntu Jammy 5.17.5, but it always fails at some point after running APT with some illegal instruction errors. I pasted the output of the script below. I've never really asked for help on one of these forums before and I'm kind of a noob, so if I'm doing something wrong or if more information is needed then let me know. ┌───────────────────────────────────────────────────┐ │ ⣎⣱ ⡀⣀ ⣀⣀ ⣇⡀ ⠄ ⢀⣀ ⣀⡀ ⣏⡉ ⣀⡀ ⢀⣀ ⡀⣀ ⡀⢀ ⣀⡀ ⣰⡀ ⢀⡀ ⢀⣸ │ │ ⠇⠸ ⠏ ⠇⠇⠇ ⠧⠜ ⠇ ⠣⠼ ⠇⠸ ⠧⠤ ⠇⠸ ⠣⠤ ⠏ ⣑⡺ ⡧⠜ ⠘⠤ ⠣⠭ ⠣⠼ │ │ ⣏⡱ ⢀⡀ ⢀⡀ ⣰⡀ ⣏⡉ ⠄ ⡇ ⢀⡀ ⢀⣀ ⡀⢀ ⢀⣀ ⣰⡀ ⢀⡀ ⣀⣀ │ │ ⠇⠱ ⠣⠜ ⠣⠜ ⠘⠤ ⠇ ⠇ ⠣ ⠣⠭ ⠭⠕ ⣑⡺ ⠭⠕ ⠘⠤ ⠣⠭ ⠇⠇⠇ │ │ ⢎⡑ ⢀⡀ ⣰⡀ ⡀⢀ ⣀⡀ │ │ ⠢⠜ ⠣⠭ ⠘⠤ ⠣⠼ ⡧⠜ │ └───────────────────────────────────────────────────┘ For detailed usage information, invoke with the '-h' switch get_armbian_image OK apt_install_host OK close_loopmount OK umount_target OK remove_build_dir OK Will write to target /dev/sda (Mass Storage Device 59.5G) check_sdcard_name_and_params OK create_build_dir OK Enter the IP address of the target machine. Enter 'dhcp' for a dynamic IP or 'none' for no remote SSH unlocking support IP address: 192.168.1.5 Enter the netmask of the target machine, or hit ENTER for the default (255.255.255.0): Enter a boot partition label for the target machine, or hit ENTER for the default (ARMBIAN_BOOT): Enter a device name for the encrypted root filesystem, or hit ENTER for the default (rootfs): Choose a simple disk password for the installation process. Once your encrypted system is up and running, you can change the password using the 'cryptsetup' command. Enter password: 123 Unlock the disk from the serial console. WARNING: enabling this will make it impossible to unlock the disk using the keyboard and monitor, though unlocking via SSH will still work. Enable unlocking via serial console? (y/n): n Unlock the disk via SSH over USB (g_ether). Enable this only if your board supports USB gadget mode, i.e. if it has a USB OTG port. WARNING: enabling this will make it impossible to unlock the disk over the Ethernet interface (eth0). Enable unlocking via SSH over USB? (y/n): n The following user options are in effect: + use local 'authorized_keys' file Armbian image: Armbian_22.05.1_Odroidhc4_jammy_edge_5.17.5.img Target device: /dev/sda (Mass Storage Device 59.5G) Root filesystem device name: /dev/mapper/rootfs Target IP address: 192.168.1.5 Target netmask: 255.255.255.0 Boot partition label: ARMBIAN_BOOT Disk password: 123 Serial console unlocking: no SSH over USB unlocking: no Are these settings correct? (Y/n) y get_authorized_keys OK Copying boot loader (8192 sectors, 4M): 4+0 records in 4+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.421957 s, 9.9 MB/s copy_boot_loader OK partition_sd_card OK Copying files to boot partition: 101,080,678 99% 10.77MB/s 0:00:08 (xfr#145, to-chk=0/152) copy_system_boot OK create_bootpart_label OK Copying system to encrypted root partition: 1,186,326,943 99% 16.16MB/s 0:01:09 (xfr#37888, to-chk=0/47428) copy_system_root OK mount_target OK Host Target ---- ------ distro: jammy jammy kernel: vmlinuz-5.17.5-meson64 vmlinuz-5.17.5-meson64 Unable to copy '/etc/apt/apt.conf.d/*proxy' to target (file does not exist) armbian_rootenc_setup.sh:891: _copy_to_target() failed at command 'false' Host script exiting with error (1) armbian_rootenc_setup.sh:905: copy_etc_files() failed at command 'false' Host script exiting with error (1) copy_etc_files OK copy_etc_files_distro_specific OK edit_initramfs_conf OK edit_initramfs_modules OK copy_authorized_keys OK create_etc_crypttab OK create_fstab OK edit_dropbear_cfg OK netman_manage_usb0 OK ifupdown_config_usb0 OK create_cryptroot_unlock_sh OK edit_armbianEnv OK Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be REMOVED: bash-completion* 0 upgraded, 0 newly installed, 1 to remove and 31 not upgraded. After this operation, 1,499 kB disk space will be freed. (Reading database ... 41456 files and directories currently installed.) Removing bash-completion (1:2.11-5ubuntu1) ... Processing triggers for man-db (2.10.2-1) ... (Reading database ... 40694 files and directories currently installed.) Purging configuration files for bash-completion (1:2.11-5ubuntu1) ... Generating 256 bit ecdsa key, this may take a while... 256 SHA256:kcNv1yOFs+xQjuvdzjF23A6r/Qy4BK6dKaLf7A1bK3c /etc/dropbear/initramfs/dropbear_ecdsa_host_key (ECDSA) +---[ECDSA 256]---+ | | | . . . | | = + . | | + = = | | S * * o | | o * o o.| | . + + * +| | .ooO.*E* X | | .o.o*+B.+o*.+| +----[SHA256]-----+ Generating Dropbear ED25519 host key. Please wait. Generating 256 bit ed25519 key, this may take a while... 256 SHA256:M2QMUYkhLLtOLyRZRDUfguhidpEAEp5o6i9WNmBoc1w /etc/dropbear/initramfs/dropbear_ed25519_host_key (ED25519) +--[ED25519 256]--+ |==o+* ==.. | |= =o.E.+. | |+=.oo . + | |=Oo+ o | |Bo=. S | |+ ++ o | | *o.. | | o+ . | |. .o | +----[SHA256]-----+ update-initramfs: deferring update (trigger activated) Dropbear has been added to the initramfs. Don't forget to check your "ip=" kernel bootparameter to match your desired initramfs ip configuration. rmdir: failed to remove '/etc/dropbear-initramfs': Directory not empty ERROR: Couldn't remove directory /etc/dropbear-initramfs Processing triggers for libc-bin (2.35-0ubuntu3) ... Illegal instruction Illegal instruction dpkg: error processing package libc-bin (--configure): installed libc-bin package post-installation script subprocess returned error exit status 132 Processing triggers for man-db (2.10.2-1) ... Processing triggers for initramfs-tools (0.140ubuntu13) ... update-initramfs: Generating /boot/initrd.img-5.17.5-meson64 Illegal instruction Illegal instruction update-initramfs: Converting to u-boot format Errors were encountered while processing: libc-bin E: Sub-process /usr/bin/dpkg returned an error code (1) armbian_rootenc_setup.sh:1149: apt_install_target() failed at command 'apt --yes install $pkgs' Target script exiting with error (100) armbian_rootenc_setup.sh:1213: configure_target() failed at command 'chroot $TARGET_ROOT "./$PROGNAME" $ORIG_OPTS 'in_target'' Host script exiting with error (100) Cleaning up, please wait... close_loopmount OK umount_target OK update_config_vars_file OK remove_build_dir OK 0 Quote
mildparanoia Posted August 6, 2022 Posted August 6, 2022 (edited) Hi, MMGen, thank you for your contribution here. I have a Rock Pi 4A+ and am trying to install Armbian to the eMMC module, fully encrypted. After running your script for /dev/mmcblk1 (the eMMC module) I am getting the following error: armbian_rootenc_setup.sh:841: copy_system_root() failed at command 'cryptsetup luksOpen "/dev/$ROOT_DEVNAME" $ROOTFS_NAME' I tried to unlock it manually but it doesn't work: cryptsetup luksOpen /dev/mmcblk1p2 temp No key available with this passphrase. (Yes I did use the correct key which I entered during the setup script's prompt) Any suggestions on how to fix this? Found the problem; the script isn't creating the encrypted partition correctly. If I make the luks partition manually, the script works. Edited August 6, 2022 by mildparanoia Found solution 0 Quote
MMGen Posted September 5, 2022 Author Posted September 5, 2022 (edited) On 8/6/2022 at 7:07 AM, mildparanoia said: Found the problem; the script isn't creating the encrypted partition correctly. If I make the luks partition manually, the script works. Glad you got it to work. Instead of setting up the LUKS partition manually, erasing everything with the -z option might have solved the problem here. Edited September 5, 2022 by MMGen 0 Quote
MMGen Posted September 5, 2022 Author Posted September 5, 2022 On 5/30/2022 at 9:08 AM, LightJolteon said: Hello, I've been trying to use the automated script on an Odriod HC4 running Ubuntu Jammy 5.17.5, but it always fails at some point after running APT with some illegal instruction errors. I pasted the output of the script below. I've never really asked for help on one of these forums before and I'm kind of a noob, so if I'm doing something wrong or if more information is needed then let me know. Sorry for the extreme delay in replying to your post. Since the errors are coming from APT, this could be a distro-specific problem. Have you tried the Bullseye image? 0 Quote
DIYprojectz Posted December 10, 2022 Posted December 10, 2022 Dear @MMGen, Thank you for this wonderful guide! Any chance you could include steps necessary to make this guide work with a non-bootable SSD i.e. sitting on a PCIe to SATA controller? Reading the guide, and @Bagel's comments on it, sadly can't figure out. 0 Quote
MMGen Posted December 12, 2022 Author Posted December 12, 2022 @DIYprojectz: It should be possible to put the encrypted root filesystem on a different device than the boot partition, though I've never tried it with an SoC or Armbian. Thanks for the idea. I promise to look into it, but don't expect immediate results as I'm busy with other things at the moment. 1 Quote
dannyboy Posted February 9, 2023 Posted February 9, 2023 (edited) Just want to say thanks! I always intended to report back, but failed. Script worked great for me back in 2021.Mar.02 on PineA64 that has been running perfectly to this day! Two important points that made me charge down this path (1) encrypt everything (2) ability to remote unlock via SSH after reboots. Looking at my notes (i.e. a wrapper script that calls MMGen's script that does all hard work and is thoroughly commented). It took me 4 attempts and what finally worked, was to rebuild all. ... # Destination device name (e.g. SD card in USB reader) dstDevNm=sda export ROOTFS_NAME=somename export IP_ADDRESS=dhcp export BOOTPART_LABEL=somenameboot export DISK_PASSWD=dontlook export UNLOCKING_USERHOST= # Call main script # # [attempt 1] -s use auth keys file, -v verbose, -z wipe all partitions #./armbian_rootenc_setup.sh -svz $dstDevNm # # [attempt 2] Don't wipe all parts. #./armbian_rootenc_setup.sh -sz $dstDevNm # # [attempt 3] only use auth keys #./armbian_rootenc_setup.sh -s $dstDevNm # # [attempt 4] Complete rebuild [THIS WORKED!] ./armbian_rootenc_setup.sh -fFsvz $dstDevNm ... I will be using this again to upgrade my setup, after getting the new version of MMGen's script. Edited February 9, 2023 by dannyboy upd 0 Quote
Tim Makarios Posted February 20, 2023 Posted February 20, 2023 Thank you for the excellent tutorial! Just a little simplification: Instead of using the script in step 9.9, I put command="/usr/bin/cryptroot-unlock" at the start of the line in /etc/dropbear-initramfs/authorized_keys, to force that command when SSHing in using that key. 1 Quote
stamatov Posted March 11, 2023 Posted March 11, 2023 i have issue with rock 5 rock01:armbian:% sudo ./armbian_rootenc_setup.sh -R -m -F /dev/sda ┌───────────────────────────────────────────────────┐ │ ⣎⣱ ⡀⣀ ⣀⣀ ⣇⡀ ⠄ ⢀⣀ ⣀⡀ ⣏⡉ ⣀⡀ ⢀⣀ ⡀⣀ ⡀⢀ ⣀⡀ ⣰⡀ ⢀⡀ ⢀⣸ │ │ ⠇⠸ ⠏ ⠇⠇⠇ ⠧⠜ ⠇ ⠣⠼ ⠇⠸ ⠧⠤ ⠇⠸ ⠣⠤ ⠏ ⣑⡺ ⡧⠜ ⠘⠤ ⠣⠭ ⠣⠼ │ │ ⣏⡱ ⢀⡀ ⢀⡀ ⣰⡀ ⣏⡉ ⠄ ⡇ ⢀⡀ ⢀⣀ ⡀⢀ ⢀⣀ ⣰⡀ ⢀⡀ ⣀⣀ │ │ ⠇⠱ ⠣⠜ ⠣⠜ ⠘⠤ ⠇ ⠇ ⠣ ⠣⠭ ⠭⠕ ⣑⡺ ⠭⠕ ⠘⠤ ⠣⠭ ⠇⠇⠇ │ │ ⢎⡑ ⢀⡀ ⣰⡀ ⡀⢀ ⣀⡀ │ │ ⠢⠜ ⠣⠭ ⠘⠤ ⠣⠼ ⡧⠜ │ └───────────────────────────────────────────────────┘ For detailed usage information, invoke with the '-h' switch get_armbian_image OK apt_install_host OK close_loopmount OK umount_target OK remove_build_dir OK /dev/sda (KINGSTON SNVS1000G 931.5G) doesn’t appear to be an SD card for the following reasons: Device is non-removable Size is > 128GiB Are you sure this is the correct device of your blank SD card? (y/N) n Exiting at user request rock01:armbian:% nano armbian_rootenc_setup.sh rock01:armbian:% sudo ./armbian_rootenc_setup.sh -R -m -F /dev/sda ┌───────────────────────────────────────────────────┐ │ ⣎⣱ ⡀⣀ ⣀⣀ ⣇⡀ ⠄ ⢀⣀ ⣀⡀ ⣏⡉ ⣀⡀ ⢀⣀ ⡀⣀ ⡀⢀ ⣀⡀ ⣰⡀ ⢀⡀ ⢀⣸ │ │ ⠇⠸ ⠏ ⠇⠇⠇ ⠧⠜ ⠇ ⠣⠼ ⠇⠸ ⠧⠤ ⠇⠸ ⠣⠤ ⠏ ⣑⡺ ⡧⠜ ⠘⠤ ⠣⠭ ⠣⠼ │ │ ⣏⡱ ⢀⡀ ⢀⡀ ⣰⡀ ⣏⡉ ⠄ ⡇ ⢀⡀ ⢀⣀ ⡀⢀ ⢀⣀ ⣰⡀ ⢀⡀ ⣀⣀ │ │ ⠇⠱ ⠣⠜ ⠣⠜ ⠘⠤ ⠇ ⠇ ⠣ ⠣⠭ ⠭⠕ ⣑⡺ ⠭⠕ ⠘⠤ ⠣⠭ ⠇⠇⠇ │ │ ⢎⡑ ⢀⡀ ⣰⡀ ⡀⢀ ⣀⡀ │ │ ⠢⠜ ⠣⠭ ⠘⠤ ⠣⠼ ⡧⠜ │ └───────────────────────────────────────────────────┘ For detailed usage information, invoke with the '-h' switch get_armbian_image OK apt_install_host OK close_loopmount OK umount_target OK remove_build_dir OK /dev/sda (KINGSTON SNVS1000G 931.5G) doesn’t appear to be an SD card for the following reasons: Device is non-removable Size is > 128GiB Are you sure this is the correct device of your blank SD card? (y/N) y Will write to target /dev/sda (KINGSTON SNVS1000G 931.5G) check_sdcard_name_and_params OK create_build_dir OK Enter the IP address of the target machine. Enter 'dhcp' for a dynamic IP or 'none' for no remote SSH unlocking support IP address: none Enter a boot partition label for the target machine, or hit ENTER for the default (ARMBIAN_BOOT): Enter a device name for the encrypted root filesystem, or hit ENTER for the default (rootfs): Choose a simple disk password for the installation process. Once your encrypted system is up and running, you can change the password using the 'cryptsetup' command. Enter password: 123 Unlock the disk from the serial console. WARNING: enabling this will make it impossible to unlock the disk using the keyboard and monitor, though unlocking via SSH will still work. Enable unlocking via serial console? (y/n): n Unlock the disk via SSH over USB (g_ether). Enable this only if your board supports USB gadget mode, i.e. if it has a USB OTG port. WARNING: enabling this will make it impossible to unlock the disk over the Ethernet interface (eth0). Enable unlocking via SSH over USB? (y/n): n The following user options are in effect: + force full rebuild + force reformat of encrypted root partition + add all currently loaded modules to initramfs Armbian image: Armbian_22.11.2_Rock-5b_jammy_legacy_5.10.110.img Target device: /dev/sda (KINGSTON SNVS1000G 931.5G) Root filesystem device name: /dev/mapper/rootfs Target IP address: none Boot partition label: ARMBIAN_BOOT Disk password: W3koslad Serial console unlocking: no SSH over USB unlocking: no Are these settings correct? (Y/n) y setup_loopmount OK check_install_state OK All data on /dev/sda (KINGSTON SNVS1000G 931.5G) will be destroyed!!! Are you sure you want to continue? (y/N) y Creating new partition label on /dev/sda create_partition_label OK Copying boot loader (557056 sectors, 272M): 272+0 records in 272+0 records out 285212672 bytes (285 MB, 272 MiB) copied, 1.40963 s, 202 MB/s copy_boot_loader OK partition_sd_card OK Copying files to boot partition: rsync: [sender] change_dir "/home/rock/armbian/armbian_rootenc_build/src/boot" failed: No such file or directory (2) 0 100% 0.00kB/s 0:00:00 (xfr#0, to-chk=0/0) rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1333) [sender=3.2.3] armbian_rootenc_setup.sh:823: copy_system_boot() failed at command 'rsync $RSYNC_VERBOSITY --archive $SRC_ROOT/boot/* $BOOT_ROOT' Host script exiting with error (23) Cleaning up, please wait... close_loopmount OK umount_target OK update_config_vars_file OK remove_build_dir OK rock01:armbian:% ls -la total 2095036 drwxrwxr-x 2 rock rock 4096 Mar 11 15:19 . drwxr-x--- 7 rock rock 4096 Mar 11 15:23 .. -rw-r--r-- 1 root root 2982150144 Mar 11 15:19 Armbian_22.11.2_Rock-5b_jammy_legacy_5.10.110.img -rwxrwxr-x 1 rock rock 39358 Mar 11 15:15 armbian_rootenc_setup.sh 0 Quote
Igor Posted March 19, 2023 Posted March 19, 2023 On 3/11/2023 at 6:10 PM, stamatov said: i have issue with rock 5 Try with something that is close to standards, mainline based (older) rockchip / allwinner, x86, Rpi ... when this is confirmed working there, move on 0 Quote
Vasir Posted September 8, 2023 Posted September 8, 2023 Orangepi5 installed successfully using this process. Did not work on bookworm but worked on Orangepi5_1.1.6_debian_bullseye_server_linux5.10.110 with small modifications. 1 Quote
Tim Makarios Posted January 15 Posted January 15 I used this tutorial as the basis of my own script, which is heavily adapted for my own needs. It worked for me, getting a bookworm CLI image to run on a Libre Computer Renegade. Although I made lots of changes, I think the only ones necessary for getting it to work on a bookworm image were replacing "etc/dropbear-initramfs" with "etc/dropbear/initramfs" twice in step 9.4, and replacing "etc/dropbear-initramfs/config" with "etc/dropbear/initramfs/dropbear.conf" twice in step 9.7. Perhaps this was the problem @Vasir encountered? 1 Quote
MMGen Posted July 9 Author Posted July 9 (edited) The tutorial and automated script have been updated for Debian bookworm and Ubuntu noble images. Here's a summary of the changes required to make everything work: replace eth0 with end0 replace cryptsetup-bin with cryptsetup replace lsinitramfs /boot/initrd.img* with lsinitramfs /boot/initrd.img-* replace etc/dropbear-initramfs with etc/dropbear/initramfs replace etc/dropbear-initramfs/config with etc/dropbear/initramfs/dropbear.conf before exiting the chroot, execute ssh-keygen -A Edited July 10 by MMGen 1 Quote
DIYprojectz Posted September 18 Posted September 18 (edited) @MMGen Got Rock 5B working by following the guide (keyboard unlock only, without SSH - as desired). Thank you very much! However, at least with the following images: * Armbian_24.8.1_Rock-5b_bookworm_current_6.10.6_cinnamon-backported-mesa_desktop.img.xz * Armbian_24.8.1_Rock-5b_jammy_current_6.10.6_kde-neon-kisak_desktop.img.xz # cat /etc/resolv.conf > etc/resolv.conf does absolutely nothing, have to create the file manually and set desired DNS server there. Edited September 18 by DIYprojectz 1 Quote
MMGen Posted September 27 Author Posted September 27 (edited) @DIYprojectz: Thanks for the feedback and support! First of all, make sure your Internet connection is active as you perform the steps in the tutorial. If it is, you should have a non-empty /etc/resolv.conf file, and the cat command will successfully create a copy of the file's contents in the target. If that doesn't solve the problem, then here are some things you might try: What does `ls -l /etc/resolv.conf` on the host produce? Is the resolv.conf file on the host a symlink? If so, you might try running `systemctl restart resolvconf` and then rechecking the file. If the host is using systemd-resolved for address resolution, try restarting that instead. Edited September 30 by MMGen 0 Quote
MMGen Posted November 14 Author Posted November 14 (edited) The tutorial and automated script have been updated for images that use extlinux.conf to configure the bootloader. In addition, some logic has been added to select the correct network device name (eth0 on some systems, end0 on others). The script has been successfully tested on the Banana Pi F3 with the Ubuntu Noble legacy minimal image. Edited November 14 by MMGen 1 Quote
Igor Posted November 14 Posted November 14 3 hours ago, MMGen said: The tutorial and automated script have been updated for images that use extlinux.conf to configure the bootloader. Great job! Interested for integration into main config tool? https://github.com/armbian/configng Now this tools is properly made. https://docs.armbian.com/User-Guide_Armbian-Software/#adding-example 1 Quote
MMGen Posted November 23 Author Posted November 23 Warning: GPT-partitioned Armbian images are appearing in the wild, and the script and tutorial do not support such images yet. To check whether your image is GPT-partitioned, run /sbin/fdisk -l on the unzipped image file. If you see 'dos' reported as the disklabel type, you're OK, while if you see 'gpt', you're out of luck for now. 0 Quote
