bozden Posted October 27, 2020 Posted October 27, 2020 I have several files I want to embed into the compiled image, such as logos, desktop backgrounds, some public keys, scripts etc. I can put them in correct place (e.g. /usr/local/bin) or put it in a directory at root (e.g. /MyAppSetup) and run a script to handle/move them. In the past I was using a private git repo on my server to clone these, but if I'm compiling, I'd like to get rid of this extra layer. I could not find a way to do that. Could someone please advise?
bozden Posted October 27, 2020 Author Posted October 27, 2020 OK, learning... I just recognized customize-image.sh is run in chroot, so direct access to host OS is not possible, maybe there is a variable for host binding which I couldn't find. On the other hand lib.config is run on host. Although it seems to be used for setting variables, it is source'd, so I can run anything there. So, this might work: cp "${SRC}""${MY_PRODUCT_DIR}" "${SDCARD}""${MY_SETUP_DIR}" And in customize-image.sh, I can move files around and do whatever I like with them. Can somebody please confirm? It takes too long to test...
bozden Posted October 27, 2020 Author Posted October 27, 2020 Nope, didn't work... As far as I can understand, at that stage it is not ready yet...
Solution bozden Posted October 28, 2020 Author Solution Posted October 28, 2020 2 hours ago, Werner said: Maybe this help: Thank you Werner, that helps. I had a misconception with the namin. "Userpatch" mixed with kernel pathing, "overlay" with overlayfs. After examining the code I found correct keywords for search and found this: I also recognized from the code that only customize-image.sh is copied to destination and my other files (which I call from it) do not. Now the post you shared comes into play... Thank you again.
