LostZimbo Posted November 1, 2020 Posted November 1, 2020 Morning All, Around a year and a half ago I found the USB port from my Espressobin V5 had broken off. This has not greatly affected me because the board itself continued to operate perfectly up to the point of merging with the mainline kernel 5.x which it simply will not boot, I am assuming because a new boot script needs to be set for the device as described on the download page ( https://www.armbian.com/espressobin/ ) but of course I am unable to access the U-Boot command without serial communication. I have set the kernel update on hold thus far, but this of course cannot hold forever. Is there anyway to update the boot script without access to serial communication on the device? I still have SSH control and it is booting a 4.19 kernel without a hitch. My Espressobin is currently being used as a subnet: LAN support where required, vpn server, NFS server, 2.4 and 5GHz wifi networks that actually outperform the piece of garbage router that my ISP sent to me. I love it. I would eventually replace it with whichever is newest from Globalscale but for now it is doing what I need, just have to figure out how to update it.
barish Posted November 24, 2020 Posted November 24, 2020 There is no way I know of to change environment parameters or U-Boot of the onboard SPI without UART access (I broke one off myself, it seemed to be very poorly connected to the board at the v5 models). If you compare the contents of the /boot directory: has there changed anything from the version that was running and the one you are trying now? Because, if boot.cmd (boot.scr) and armbianEnv.txt are still the same, the old U-Boot shouldn't have issues booting. Have a look if you can use the old files instead of the ones that come with the new Armbian, maybe that works (actually, boot.scr is the important file, the compiled version of boot.cmd ).
umiddelb Posted November 25, 2020 Posted November 25, 2020 The spi flash memory (with the u-boot environment stored inside) is accessible from the command line. Please check if the corresponding driver is loaded via dmesg. It should look like: [ 1.878826] spi-nor spi0.0: w25q32dw (4096 Kbytes) [ 1.878850] 2 cmdlinepart partitions found on MTD device spi0.0 [ 1.878854] Creating 2 MTD partitions on "spi0.0": [ 1.878870] 0x000000000000-0x0000003f0000 : "uboot" [ 1.888884] 0x0000003f0000-0x000000400000 : "uboot-environment" The partitioning information is passed as a command line parameter to the kernel (last parameter in this case): console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=UUID=c2bdee11-6a88-46c1-8630-b70864d535bb rootfstype=ext4 rootwait loglevel=1 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u mtdparts=spi0.0:4032k(uboot),64k(uboot-environment) You need to install the package u-boot-tools containing the userland tools and you need to configure the correct offsets: uli@ebin:~$ cat /etc/fw_env.config # device name device offset env. size flash sector size number of sectors /dev/mtd1 0x00000000 0x00010000 0x1000 0x10 Then fw_printenv / fw_setenv will help you to modify the u-boot environment: uli@ebin:~$ sudo fw_printenv arch=arm baudrate=115200 board=mvebu_armada-37xx board_name=mvebu_armada-37xx boot_a_script=ext4load ${boot_interface} ${devnum}:1 ${scriptaddr} ${prefix}boot.scr;source ${scriptaddr}; boot_prefixes=/ /boot/ boot_targets=usb sata mmc1 mmc0 bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done bootcmd_mmc0=setenv devnum 0; setenv boot_interface mmc; run scan_dev_for_boot; bootcmd_mmc1=setenv devnum 1; setenv boot_interface mmc; run scan_dev_for_boot; bootcmd_sata=setenv devnum 0; scsi scan; scsi dev 0; setenv boot_interface scsi; run scan_dev_for_boot; bootcmd_usb=setenv devnum 0; usb start;setenv boot_interface usb; run scan_dev_for_boot; bootdelay=2 console=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 cpu=armv8 eth1addr=00:51:82:11:22:01 eth2addr=00:51:82:11:22:02 eth3addr=00:51:82:11:22:03 ethaddr=00:51:82:11:22:00 ethprime=eth0 extra_params=pci=pcie_bus_safe fdt_addr=0x6000000 fdt_addr_r=0x6f00000 fdt_high=0xffffffffffffffff fdt_name=fdt.dtb gatewayip=10.4.50.254 get_images=tftpboot $kernel_addr_r $image_name; tftpboot $fdt_addr_r $fdt_name; run get_ramfs get_ramfs=if test "${ramfs_name}" != "-"; then setenv ramdisk_addr_r 0x8000000; tftpboot $ramdisk_addr_r $ramfs_name; else setenv ramdisk_addr_r -;fi hostname=marvell image_name=Image initrd_addr=0x1100000 initrd_image=uInitrd initrd_size=0x2000000 ipaddr=0.0.0.0 kernel_addr=0x7000000 kernel_addr_r=0x7000000 loadaddr=0x8000000 netdev=eth0 netmask=255.255.255.0 ramdisk_addr_r=0x8000000 ramfs_name=- root=root=/dev/nfs rw rootpath=/srv/nfs/ scan_dev_for_boot=for prefix in ${boot_prefixes}; do echo ${prefix};run boot_a_script; done scriptaddr=0x6d00000 serverip=0.0.0.0 set_bootargs=setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none nfsroot=$serverip:$rootpath,tcp,v3 $extra_params $cpuidle soc=mvebu vendor=Marvell Unfortunately the offsets vary between the different u-boot versions, so you have to find out the correct one for your board. fw_printenv will tell you if the CRC check fails meaning that the chosen offsets do not fit. 1
Pali Posted October 3, 2021 Posted October 3, 2021 On 11/25/2020 at 6:03 AM, umiddelb said: Unfortunately the offsets vary between the different u-boot versions, so you have to find out the correct one for your board. This is fixed in new U-Boot version, which automatically adjust kernel's DTS file to set correct offset ot these partitions.
