SATA issue, drive resets: ataX.00: failed command: READ FPDMA QUEUED
@RockBian yeah that is the set. However the seller I ordered from is no longer there. The best offer right now is this https://www.aliexpress.com/item/4000168090307.html
However your error is a different one and I cannot see the reset of the SATA connection but if you FS goes into read-only that may indicate another issue. Did the drive in slot 4 work after all? Cause some people had slot 4/5 resp. 1/2 depending how you count (the two that share power) fail completely.
If you wanna exchange the cables though: the power os from the original harness, I cut of the data connection part using a separation disk on a rotary tool (Dremel like).
Expand
? The problem begins with a READ FPDMA QUEUED error, and ends with a ro filesystem due to an I/O errors. The result may be different (maybe due to no raid/zfs), but the source looks the same to me.
Expand
It worked for 8 months without problems, and now it works fine in slot 3. (Where slot 1 is the farthest from the mobo)
Expand
And solder it on the power connectors of the new cables? Hm. I hoped for a simpler solution.
Expand
Nah, no soldering involved. Just cut of the data part of the connector. It destroys that bit irreversibly, but then you are just left with the power connector and you can plug that on the back of new connector
I took the assembly image from the wiki and used my amazing paint.net skills to draw lines where to cut; just make sure you leave the power connector intact
Expand
It does look like the same issue to me and filesystem does not matter, these SATA errors can present themselves simply by reading the disk. And as a result, filesystem corruption is not unexpected, ZFS does protect us from it though.
But it can’t be discounted that this could be a disk error as well, perhaps it’s nearing its end-of-life. Which  brand / model of disk do you have?
Expand
# smartctl -a /dev/sdb
smartctl 6.6 2017-11-05 r4594 [aarch64-linux-5.10.35-rockchip64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     TOSHIBA HDWD240
Serial Number:    Z9J1S0I9S5HH
LU WWN Device Id: 5 000039 9b560c2c2
Firmware Version: KQ000A
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Jul 26 22:46:35 2021 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(  120) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 502) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   050    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       8060
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       62
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   050    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0032   078   078   000    Old_age   Always       -       8809
 10 Spin_Retry_Count        0x0033   101   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       10
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       1
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       2
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       244
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       18 (Min/Max 12/31)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   253   000    Old_age   Always       -       0
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       0
222 Loaded_Hours            0x0032   099   099   000    Old_age   Always       -       562
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
224 Load_Friction           0x0022   100   100   000    Old_age   Always       -       0
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       803
240 Head_Flying_Hours       0x0001   100   100   001    Pre-fail  Offline      -       0
SMART Error Log Version: 1
ATA Error Count: 3
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	SC = Sector Count Register [HEX]
	SN = Sector Number Register [HEX]
	CL = Cylinder Low Register [HEX]
	CH = Cylinder High Register [HEX]
	DH = Device/Head Register [HEX]
	DC = Device Command Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 3 occurred at disk power-on lifetime: 8764 hours (365 days + 4 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 41 98 28 0e c0 40  Error: UNC at LBA = 0x00c00e28 = 12586536
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 28 98 10 0e c0 40 00  22d+20:33:25.353  READ FPDMA QUEUED
  ef 10 02 00 00 00 a0 00  22d+20:33:25.353  SET FEATURES [Enable SATA feature]
  27 00 00 00 00 00 e0 00  22d+20:33:25.352  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 00 00 00 00 a0 00  22d+20:33:25.352  IDENTIFY DEVICE
  ef 03 45 00 00 00 a0 00  22d+20:33:25.351  SET FEATURES [Set transfer mode]
Error 2 occurred at disk power-on lifetime: 8764 hours (365 days + 4 hours)
  40 41 28 08 0e c0 40  Error: UNC at LBA = 0x00c00e08 = 12586504
  60 30 28 08 0e c0 40 00  22d+20:33:22.242  READ FPDMA QUEUED
  60 08 20 60 0d c1 40 00  22d+20:33:22.241  READ FPDMA QUEUED
  60 08 18 78 0d c1 40 00  22d+20:33:22.240  READ FPDMA QUEUED
  60 08 10 70 0d c1 40 00  22d+20:33:22.239  READ FPDMA QUEUED
  60 08 08 68 0d c1 40 00  22d+20:33:22.238  READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 8764 hours (365 days + 4 hours)
  40 41 28 00 0d c0 40  Error: UNC at LBA = 0x00c00d00 = 12586240
  60 08 28 00 0d c0 40 00  22d+20:32:39.403  READ FPDMA QUEUED
  60 08 20 80 08 c0 40 00  22d+20:32:39.292  READ FPDMA QUEUED
  60 08 18 10 17 01 40 00  22d+20:32:39.291  READ FPDMA QUEUED
  60 08 10 08 17 01 40 00  22d+20:32:39.290  READ FPDMA QUEUED
  60 08 08 f8 16 01 40 00  22d+20:32:39.289  READ FPDMA QUEUED
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
@RockBian hmm, that output look more like there's a problem with the disk itself. At least none of the SATA errors I've experienced have been logged by the disks themselves, but could be difference in manufacturers. I'd recommend running a short and a long scan (via smartctl) on the disk.
@ShadowDance
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%      8990         -
# 2  Extended offline    Aborted by host               90%      8974         -
# 3  Extended offline    Aborted by host               90%      8945         -
# 4  Short offline       Completed without error       00%      8944         -
It took some time to get the extended offline test completed. Turns out that hdidle aborts it. Anyway, both tests completed without errors, so it seems nothing is wrong with the disk, as the attributes already suggested.
As I can't find a clear description what 'READ FPDMA QUEUED' actually means, I can't say if it's normal that both sides of the SATA bus can detect this error at the same time.
Yesterday I got a mail from my Kobol that a backup failed, 'mount: /mnt/backup: can't read superblock on /dev/sdb1.'. According to smartctl the disk died. So I ordered a new disk, (a WD red), and today I have put it in the Kobol (hotplug is a bless), in the same slot where the Toshiba was located. The backup is running, and so far no problems.
The problem is, I put the old disk in another box, (a Netgear 104 running Debian), and it's perfectly healthy. At the moment I'm stressing it by running a grep on all files on it (around 1TB), but nothing in dmesg.
I used that disk for creating snapshot backups of 2 different sources, one local and one remote, once a week. When looking in dmesg I can see that all backups since beginning this month had a number of 'READ FPDMA QUEUED' errors, followed by a 'hard resetting link', yet all backups succeeded, until yesterday.
I'm wondering if it can be a disk incompatibility problem. But in that case it is strange that it worked without problems for half a year.
That sounds now very much like the SATA issues. Source is still unknown apart from the data cables. I could also imagine (hardware noob here) that it may depend on the drive and power draw and signal quality. So maybe the WD is has a better signal quality.
Posted (edited)
I've bought a molex power cable to use with the new sata cable. But i've not found a sata power cable 8pin(6+2) with the capacitors that came with Helio64.
Do you think that will work?
or It's better to destroy the sata data cable of original cable as @meymarce described?
I'm hoping that this will work. It's sad that we cannot have some spare basic parts of the Helios64
I've bought the following expansion cable to use with the original Helio64 power molex cable 8pin(4+4)
Now my helios64 came back to life =D
I was able to complete rebuild the Raid6 and it's working like a charm.
The problem is that now I have a lot of cables on the case that was difficult to find an arrangement in a way that I was able to close the case with the fans. The @meymarce solution on splitting the cable is better if you are able to do with confidence not to destroy the power cable.:
Thanks!
Edited by manman
Update cables that works
Hi,
I have same problem with WD Red 8to (WDC WD80EFBX-68AZZN0).
In slot 3
Depend of drive, some are more or less sensible
Best configuration without or (with less) error (i test again...) is:
slot 1: WDC WD80EFAX-68KNBN0
slot 2: WDC WD80EFAX-68KNBN0
slot 3: TS256GSSD370S
slot 4: WDC WD80EFBX-68AZZN0
slot 5: WDC WD80EFBX-68AZZN0
harddrive in slot 5 was in slot 3 before and i had:
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       11
in:
Error 11 occurred at disk power-on lifetime: 46 hours (1 days + 22 hours)
Bye.
@meymarce it’s most likely related, and not due to bad disks. All my disks have received a bunch of UDMA_CRC_Error_Count due to the Helios. I’ve since completely stopped using the Helios and put the same disks inside an ASUSTOR. Zero issues.
Basically don’t put WD REDs in a Helios, or be prepared to have a bad time, heh.
Expand
As you can read earlier in this thread I had a Toshiba which after half a year acted up in a Helios, while it run fine in another NAS, It's exchanged by a WD Red which is going strong since then. (But it didn't last six months, so far).
@RockBian it wasn’t my intention to color the issue black and white. My statement was based on that most user accounts have been from users of WD REDs. I personally believe this issue is far more prevalent than made out in this thread. It’s simply that triggering the issue may require time and the right kind of workload. So either people don’t trigger the issue or they may not even notice it unless they’re checking system logs.
I hope your new disks work out for you.
Either way, I never tried any other disks in my Helios and probably never will considering there’s no further development and Armbian used to break seemingly every other day (a while back).
Thanks!
Expand
UPDATE:
Even changing the cables, the disks keep failing over time.
I wasn't able to have my NAS running more than a day or two without a failure on the disks. After buying an APC UPS with
Boost and Trim Automatic Voltage Regulation (AVR), my NAS is now running without any failure over more than a week!
So the problem was the unstable energy in my house. Maybe I'll try to put back the original ones to see if it works.
