On the 20.08.2 Buster release (Kernel 5.8.6) the headphone jack is not currently working.
HDMI audio seems to be supported.
aplay -L returns only the HDMI audio interface. (sun50i-a64-hdmi) but is not showing the headphone interface (should additionally show sun50i-a64-audio as in other working builds)
This is also the case with the current development build (Armbian_20.11.0-trunk.32_Lime-a64_buster_current_5.9.7)
A look at the device tree shows “<stdout>: Warning (unit_address_vs_reg): Node /sound/simple-audio-card,dai-link@0 has a unit name, but no reg property” on the first line of the DTS of sun50i-a64-olinuxino, sun50i-a64-olinuxino-emmc, and sun50i-a64-olinuxino-2Ge8G device tree blobs. Not sure if this is a contributing factor.
The snippet it seems to be complaining about:
simple-audio-card,dai-link@0 {
format = "i2s";
frame-master = <0x11>;
bitclock-master = <0x11>;
mclk-fs = <0x80>;
I did some digging and found this patch from a few years ago: https://www.alsa-project.org/pipermail/alsa-devel/2018-October/141047.html
The only major difference I see between the configuration added by the patch and my current device tree is that hex addresses are specified in place of pointer variables. (i.e. <0x12> vs <&dai>
Going on the advice of several forum posts, I tried adding "overlays=analog-codec" to /boot/armbianEnv.txt to no avail.
I suspect that analog audio needs to be enabled in kernel configuration.
seems to tbe a problem on devices with A64-CPU
We got the "same" problem with Pine64 and the NanoPi A64
Maybe you could get a idea for a solution by checking the attached .dts for the NanoPi A64 in this message?:
