ata1: SATA link down (SStatus 0 SControl 300)
I just received my Helios64 system and built it today. The build included 3 drives, a SSD in port 1 and two HHD's on port 2 and 3. After the build, I installed Debian Kernel: 5.8 on an micro SD card. The system booted but only showed the drives in port 2 and 3. I have moved the drive in port 1 to port 4, rebooted and the SSD drive shows up. Also, a HDD in port 1 does not show up: no blue Light on the front panel and not visible in "fdisk -l" .  The output from ' dmesg | grep "ata" ' results in:
[    0.000000] Memory: 3742212K/4061184K available (14460K kernel code, 2114K rwdata, 5920K rodata, 4160K init, 572K bss, 187900K reserved, 131072K cma-reserved)
[    0.017471] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    1.381721] libata version 3.00 loaded.
[    2.753910] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[    3.039365] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 238
[    3.039374] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 239
[    3.039382] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 240
[    3.039390] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 241
[    3.039397] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 242
[    3.351430] ata1: SATA link down (SStatus 0 SControl 300)
[    4.073010] ata1: SATA link down (SStatus 0 SControl 300)
[    4.785020] ata1: SATA link down (SStatus 0 SControl 300)
[    5.501021] ata1: SATA link down (SStatus 0 SControl 300)
[    6.213013] ata1: SATA link down (SStatus 0 SControl 300)
[    6.925015] ata1: SATA link down (SStatus 0 SControl 300)
[    7.637014] ata1: SATA link down (SStatus 0 SControl 300)
[    8.353013] ata1: SATA link down (SStatus 0 SControl 300)
[    9.065013] ata1: SATA link down (SStatus 0 SControl 300)
[    9.777013] ata1: SATA link down (SStatus 0 SControl 300)
[   10.493013] ata1: SATA link down (SStatus 0 SControl 300)
[   11.205013] ata1: SATA link down (SStatus 0 SControl 300)
[   11.917013] ata1: SATA link down (SStatus 0 SControl 300)
[   12.629013] ata1: SATA link down (SStatus 0 SControl 300)
[   13.345013] ata1: SATA link down (SStatus 0 SControl 300)
[   13.360992] ata2: softreset failed (device not ready)
[   14.057013] ata1: SATA link down (SStatus 0 SControl 300)
[   14.769013] ata1: SATA link down (SStatus 0 SControl 300)
[   15.213009] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   15.279535] ata2.00: ATA-9: WDC WD100EFAX-68LHPN0, 83.H0A83, max UDMA/133
[   15.279547] ata2.00: 19532873728 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   15.291821] ata2.00: configured for UDMA/133
[   15.485018] ata1: SATA link down (SStatus 0 SControl 300)
[   15.768996] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   15.775720] ata3.00: ATA-9: WDC WD100EFAX-68LHPN0, 83.H0A83, max UDMA/133
[   15.775731] ata3.00: 19532873728 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   15.788073] ata3.00: configured for UDMA/133
[   16.103595] ata4: SATA link down (SStatus 0 SControl 300)
[   16.197014] ata1: SATA link down (SStatus 0 SControl 300)
[   16.415602] ata5: SATA link down (SStatus 0 SControl 300)
[   16.921041] ata1: SATA link down (SStatus 0 SControl 300)
with the 'ata1: SATA link down (SStatus 0 SControl 300)' message repeating at least every second with a drive on Sata port 1.
I dismantled the system to unplug and replug the Sata port 1 cable but no change.
Any help to resolve my problem is appreciated.
Thanks,
Jim
Edited by TRS-80
put long output inside code block inside spoiler
It could be a faulty HDD harness cable.
Could you try to swap cables connected to SATA port 1 to SATA port 2 on the board. Then check if HDD slot 1 still doesn't work and HDD slot 2 still works.
This way we can confirm it's a wire issue.
On 11/20/2020 at 12:46 PM, TRS-80 said:
You installed Debian?  Or Armbian?
I installed Debian/Armbian 5.8 image from Kobol wiki:  Armbian_20.08.21_Helios64_buster_current_5.8.17.img.xz
I swapped the cables for Sata 1 and Sata 2 ports. The SSD drive was not recognized on either port. So, back to basics. Using a single WD Red 10TB HHD (factory fresh: no portioning, no formatting), I tested each slot.  The WD HHD was recognized on all 5 Sata ports.  So, not a cable problem.  Repeating the process with the Seagate Barracuda SSD 120 drive (factory fresh), the SSD is not visible on ports 1, 2, 3, and 4 but is visible on Sata port 5.  With a 2nd factory fresh Seagate Barracuda SSD 120 drive, I repeated the process. Again only visible on Sata port 5.  Using a old used SanDisk SDSSDXP240G SSD, I repeated the process on port 1 to 4 and it was visible on all ports.
So, it seems that there is an issue with Seagate Barracuda SSD 120 drives being only visible on Sata port 5, with the shortest cable length.  But, could I just have 2 bad drives? So, I connected one of the SSDs to a USB bridge to test against my Windows desktop.  I could see the drive so I partitioned and formatted the drive.  Seems to be OK. So I moved the SSD back to the Helios64 (don't remember what port) and it was now visible but in a  degraded 3Gbps link speed. So, I removed the Windows partitions and relabeled and partitioned the drive. Now on Sata port 1, I can see drive with the following messages being generated on boot:
[    3.051038] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 238
[    3.051047] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 239
[    3.051055] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 240
[    3.051063] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 241
[    3.051071] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 242
[    3.525038] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.525282] ata1.00: ATA-10: Seagate BarraCuda 120 SSD ZA1000CM10003, STRSD013, max UDMA/133
[    3.525293] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    3.525909] ata1.00: configured for UDMA/133
[    3.557041] ata1.00: exception Emask 0x0 SAct 0x10 SErr 0x1c00001 action 0x0
[    3.557051] ata1.00: irq_stat 0x0c000000
[    3.557064] ata1: SError: { RecovData Handshk LinkSeq TrStaTrns }
[    3.585013] ata1.00: exception Emask 0x0 SAct 0x80 SErr 0x1c00001 action 0x0
[    3.585021] ata1.00: irq_stat 0x0c000000
[    3.585031] ata1: SError: { RecovData Handshk LinkSeq TrStaTrns }
[    3.843423] ata2: SATA link down (SStatus 0 SControl 300)
[    4.155443] ata3: SATA link down (SStatus 0 SControl 300)
[    4.629032] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.629865] ata4.00: ATA-8: SanDisk SDSSDXP240G, R1311, max UDMA/133
[    4.629876] ata4.00: 468862128 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    4.630718] ata4.00: configured for UDMA/133
[    5.109052] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    5.109303] ata5.00: ATA-10: Seagate BarraCuda 120 SSD ZA1000CM10003, STRSD013, max UDMA/133
[    5.109315] ata5.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    5.109951] ata5.00: configured for UDMA/133
[    5.793226] ata1.00: exception Emask 0x0 SAct 0x4000 SErr 0x1c00001 action 0x0
[    5.793239] ata1.00: irq_stat 0x0c000000
[    5.793252] ata1: SError: { RecovData Handshk LinkSeq TrStaTrns }
[    5.845128] ata1.00: exception Emask 0x0 SAct 0x400 SErr 0x1c00001 action 0x0
[    5.845140] ata1.00: irq_stat 0x08000000
[    5.845153] ata1: SError: { RecovData Handshk LinkSeq TrStaTrns }
[   37.885067] ata1.00: exception Emask 0x0 SAct 0x2080 SErr 0x1c00001 action 0x6 frozen
[   37.885079] ata1.00: irq_stat 0x0c000000
[   37.885091] ata1: SError: { RecovData Handshk LinkSeq TrStaTrns }
[   37.885107] ata1.00: failed command: READ FPDMA QUEUED
[   37.885132] ata1.00: cmd 60/08:38:80:67:70/00:00:74:00:00/40 tag 7 ncq dma 4096 in
[   37.885140] ata1.00: status: { DRDY }
[   37.885159] ata1: hard resetting link
[   38.361025] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   38.361038] ata1.00: link online but device misclassified
[   43.489056] ata1.00: qc timeout (cmd 0xec)
[   43.489076] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[   43.489085] ata1.00: revalidation failed (errno=-5)
[   43.489097] ata1: hard resetting link
[   43.965022] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   43.968192] ata1: illegal qc_active transition (00000000->00000001)
[   43.968218] ata1.00: failed to read native max address (err_mask=0x100)
[   43.968227] ata1.00: HPA support seems broken, skipping HPA handling
[   43.968235] ata1.00: revalidation failed (errno=-5)
[   43.968245] ata1: limiting SATA link speed to 3.0 Gbps
[   49.121036] ata1: hard resetting link
[   49.597020] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[   49.600814] ata1.00: configured for UDMA/133
[   49.600831] ata1.00: device reported invalid CHS sector 0
[   49.601109] ata1: EH complete
At least, the Cuda 120 SSD is being recognized.
One Seagate troubleshooting article indicates:
"The BarraCuda SSD is compliant with the SATA 3.2 specification.  If your computer only supports the SATA 3.1 specification, sometimes the BarraCuda SSD is not detected during startup of your computer.  This should be an intermittent issue, and if you try a few times, the computer should still boot."
Since, the old Sandisk SSD worked on port 1-4, I might try downgrading the Cuda 120 SSD to the 3.1 specs (if I can find the hardware in my collection of bits).
So, some progress. But, with all the drive plugging/unplugging, my Helios64 box has lots of pink plastic shavings from the drive rails.
Jim
Edited by TRS-80
Keep us updated of the result once you manage to downgrade the Barracuda SSD 120 to SATA 3.1 specs. Here the link you are referring to, that might be useful for others :
https://www.seagate.com/sg/en/support/kb/why-does-my-computer-with-a-barracuda-ssd-sometimes-say-no-bootable-device-detected-during-startup/
Unfortunately cannot find such tool for Linux.
Yes we ware of such issue, we will fix that in next iteration of the enclosure.
I have the same issue.
dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.8.17-rockchip64 (root@xeon) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025,
GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.08.21 SMP PREEMPT Sat Oct 31 08:22:59 CET 2020
[    0.000000] Machine model: Helios64
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000ecc00000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77db100-0xf77dcfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] On node 0 totalpages: 1015296
[    0.000000]   DMA zone: 4088 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 261632 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 11776 pages used for memmap
[    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s93528 r8192 d29352 u131072
[    0.000000] pcpu-alloc: s93528 r8192 d29352 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=dabb3dbf-8631-4051-a032-c0b97eb285bd rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 uboo
tpart=794023b5-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
[    0.000000] Memory: 3740344K/4061184K available (14460K kernel code, 2114K rwdata, 5920K rodata, 4160K init, 572K bss, 189768K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]     Trampoline variant of Tasks RCU enabled.
[    0.000000]     Rude variant of Tasks RCU enabled.
[    0.000000]     Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @f6d00000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000f6ca0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f6cb0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x674/0x82c with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001441] Console: colour dummy device 80x25
[    0.001459] printk: console [tty1] enabled
[    0.001591] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001606] pid_max: default: 32768 minimum: 301
[    0.001766] LSM: Security Framework initializing
[    0.001805] Yama: becoming mindful.
[    0.001950] AppArmor: AppArmor initialized
[    0.002043] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002072] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005314] rcu: Hierarchical SRCU implementation.
[    0.008185] Platform MSI: interrupt-controller@fee20000 domain created
[    0.008730] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.011147] EFI services will not be available.
[    0.011922] smp: Bringing up secondary CPUs ...
[    0.012943] Detected VIPT I-cache on CPU1
[    0.012994] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.013013] GICv3: CPU1: using allocated LPI pending table @0x00000000f6cc0000
[    0.013073] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.014431] Detected VIPT I-cache on CPU2
[    0.014481] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.014500] GICv3: CPU2: using allocated LPI pending table @0x00000000f6cd0000
[    0.014560] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015958] Detected VIPT I-cache on CPU3
[    0.016008] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.016027] GICv3: CPU3: using allocated LPI pending table @0x00000000f6ce0000
[    0.016087] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.017469] CPU features: detected: EL2 vector hardening
[    0.017479] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.017485] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.017492] Detected PIPT I-cache on CPU4
[    0.017526] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.017540] GICv3: CPU4: using allocated LPI pending table @0x00000000f6cf0000
[    0.017579] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.018761] Detected PIPT I-cache on CPU5
[    0.018799] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.018813] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d80000
[    0.018853] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.019019] smp: Brought up 1 node, 6 CPUs
[    0.019029] SMP: Total of 6 processors activated.
[    0.019039] CPU features: detected: 32-bit EL0 Support
[    0.019048] CPU features: detected: CRC32 instructions
[    0.019056] CPU features: detected: 32-bit EL1 Support
[    0.047089] CPU: All CPU(s) started at EL2
[    0.047154] alternatives: patching kernel code
[    0.050957] devtmpfs: initialized
[    0.065739] Registered cp15_barrier emulation handler
[    0.065760] Registered setend emulation handler
[    0.066571] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.066640] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.069657] xor: measuring software checksum speed
[    0.107998]    8regs     :  2345.000 MB/sec
[    0.148086]    32regs    :  2756.000 MB/sec
[    0.188178]    arm64_neon:  2225.000 MB/sec
[    0.188184] xor: using function: 32regs (2756.000 MB/sec)
[    0.188240] pinctrl core: initialized pinctrl subsystem
[    0.188772] thermal_sys: Registered thermal governor 'fair_share'
[    0.188777] thermal_sys: Registered thermal governor 'bang_bang'
[    0.188783] thermal_sys: Registered thermal governor 'step_wise'
[    0.188789] thermal_sys: Registered thermal governor 'user_space'
[    0.189436] DMI not present or invalid.
[    0.190027] NET: Registered protocol family 16
[    0.193160] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.194612] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.195389] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.195490] audit: initializing netlink subsys (disabled)
[    0.195768] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[    0.197019] cpuidle: using governor menu
[    0.197323] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.197534] ASID allocator initialised with 65536 entries
[    0.198877] Serial: AMBA PL011 UART driver
[    0.255088] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.255098] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.255106] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.255113] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.260983] cryptd: max_cpu_qlen set to 1000
[    0.336593] raid6: neonx8   gen()  1666 MB/s
[    0.404746] raid6: neonx8   xor()  1224 MB/s
[    0.472917] raid6: neonx4   gen()  1685 MB/s
[    0.541077] raid6: neonx4   xor()  1261 MB/s
[    0.609237] raid6: neonx2   gen()  1504 MB/s
[    0.677390] raid6: neonx2   xor()  1161 MB/s
[    0.745562] raid6: neonx1   gen()  1180 MB/s
[    0.813711] raid6: neonx1   xor()   945 MB/s
[    0.881907] raid6: int64x8  gen()   993 MB/s
[    0.950042] raid6: int64x8  xor()   580 MB/s
[    1.018198] raid6: int64x4  gen()   988 MB/s
[    1.086357] raid6: int64x4  xor()   591 MB/s
[    1.154511] raid6: int64x2  gen()   927 MB/s
[    1.222676] raid6: int64x2  xor()   524 MB/s
[    1.290843] raid6: int64x1  gen()   730 MB/s
[    1.358994] raid6: int64x1  xor()   390 MB/s
[    1.359000] raid6: using algorithm neonx4 gen() 1685 MB/s
[    1.359005] raid6: .... xor() 1261 MB/s, rmw enabled
[    1.359011] raid6: using neon recovery algorithm
[    1.360416] vcc12v_dcin_bkup: supplied by vcc12v_dcin
[    1.360809] vcc12v_hdd: supplied by vcc12v_dcin_bkup
[    1.374315] vcc5v0_perdev: supplied by vcc12v_dcin_bkup
[    1.374819] vcc5v0_hdd: supplied by vcc12v_dcin_bkup
[    1.375095] pcie_power: supplied by vcc5v0_perdev
[    1.375201] vcc5v0_usb: supplied by vcc5v0_perdev
[    1.375416] vcc5v0_sys: supplied by vcc12v_dcin_bkup
[    1.376165] vcc3v3_sys_s3: supplied by vcc5v0_sys
[    1.376220] vcc0v9_s3: supplied by vcc3v3_sys_s3
[    1.376308] avdd_1v8_s0: supplied by vcc3v3_sys_s3
[    1.376375] vcc3v0_sd: supplied by vcc3v3_sys_s3
[    1.377212] usblan_power: supplied by vcc5v0_usb
[    1.377865] iommu: Default domain type: Translated
[    1.380924] vgaarb: loaded
[    1.381457] SCSI subsystem initialized
[    1.381710] libata version 3.00 loaded.
[    1.381975] usbcore: registered new interface driver usbfs
[    1.382019] usbcore: registered new interface driver hub
[    1.382129] usbcore: registered new device driver usb
[    1.382831] pps_core: LinuxPPS API ver. 1 registered
[    1.382837] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.382852] PTP clock support registered
[    1.383173] EDAC MC: Ver: 3.0.0
[    1.384367] NetLabel: Initializing
[    1.384374] NetLabel:  domain hash size = 128
[    1.384378] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.384440] NetLabel:  unlabeled traffic allowed by default
[    1.384966] clocksource: Switched to clocksource arch_sys_counter
[    1.495917] VFS: Disk quotas dquot_6.6.0
[    1.495993] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.496835] AppArmor: AppArmor Filesystem Enabled
[    1.507073] NET: Registered protocol family 2
[    1.507896] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.508071] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.508599] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    1.509302] TCP: Hash tables configured (established 32768 bind 32768)
[    1.509492] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.509653] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.509998] NET: Registered protocol family 1
[    1.510028] NET: Registered protocol family 44
[    1.510043] PCI: CLS 0 bytes, default 64
[    1.510284] Trying to unpack rootfs image as initramfs...
[    2.662516] Freeing initrd memory: 15628K
[    2.663717] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    2.664167] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    2.664930] kvm [1]: IPA Size Limit: 40bits
[    2.665721] kvm [1]: vgic-v2@fff20000
[    2.665757] kvm [1]: GIC system register CPU interface enabled
[    2.665992] kvm [1]: vgic interrupt IRQ10
[    2.666281] kvm [1]: Hyp mode initialized successfully
[    2.677550] Initialise system trusted keyrings
[    2.677590] Key type blacklist registered
[    2.677787] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    2.683865] zbud: loaded
[    2.685499] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.686388] fuse: init (API version 7.31)
[    2.687741] integrity: Platform Keyring initialized
[    2.752430] Key type asymmetric registered
[    2.752436] Asymmetric key parser 'x509' registered
[    2.752478] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.752704] io scheduler mq-deadline registered
[    2.752710] io scheduler kyber registered
[    2.752841] io scheduler bfq registered
[    2.777811] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.777825] dma-pl330 ff6d0000.dma-controller:     DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    2.779238] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.779250] dma-pl330 ff6e0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.783605] pwm-regulator: supplied by regulator-dummy
[    2.785302] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.788434] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[    2.789494] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[    2.789673] printk: console [ttyS2] enabled
[    2.790980] Serial: AMBA driver
[    2.792501] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.804326] loop: module loaded
[    2.813351] libphy: Fixed MDIO Bus: probed
[    2.813691] tun: Universal TUN/TAP device driver, 1.6
[    2.814854] thunder_xcv, ver 1.0
[    2.814894] thunder_bgx, ver 1.0
[    2.814946] nicpf, ver 1.0
[    2.816149] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.816154] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.816203] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    2.816207] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.816248] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    2.816253] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.816565] sky2: driver version 1.30
[    2.817390] VFIO - User Level meta-driver version: 0.3
[    2.832008] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.832029] ehci-pci: EHCI PCI platform driver
[    2.832068] ehci-platform: EHCI generic platform driver
[    2.832577] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.832593] ohci-pci: OHCI PCI platform driver
[    2.832634] ohci-platform: OHCI generic platform driver
[    2.833883] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.833921] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.834114] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    2.834184] xhci-hcd xhci-hcd.0.auto: irq 226, io mem 0xfe900000
[    2.834607] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    2.834617] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.834625] usb usb1: Product: xHCI Host Controller
[    2.834633] usb usb1: Manufacturer: Linux 5.8.17-rockchip64 xhci-hcd
[    2.834640] usb usb1: SerialNumber: xhci-hcd.0.auto
[    2.835238] hub 1-0:1.0: USB hub found
[    2.835277] hub 1-0:1.0: 1 port detected
[    2.835645] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.835660] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    2.835677] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    2.835754] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.835887] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[    2.835896] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.835904] usb usb2: Product: xHCI Host Controller
[    2.835911] usb usb2: Manufacturer: Linux 5.8.17-rockchip64 xhci-hcd
[    2.835918] usb usb2: SerialNumber: xhci-hcd.0.auto
[    2.836430] hub 2-0:1.0: USB hub found
[    2.836467] hub 2-0:1.0: 1 port detected
[    2.836935] usbcore: registered new interface driver usb-storage
[    2.839765] mousedev: PS/2 mouse device common for all mice
[    2.841212] i2c /dev entries driver
[    2.843938] pca953x 2-0020: using no AI
[    2.850605] rk808 0-001b: chip id: 0x0
[    2.854522] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.854551] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.854645] DCDC_REG1: supplied by vcc5v0_sys
[    2.855792] DCDC_REG2: supplied by vcc5v0_sys
[    2.856412] DCDC_REG3: supplied by vcc5v0_sys
[    2.856735] DCDC_REG4: supplied by vcc5v0_sys
[    2.857390] LDO_REG1: supplied by vcc5v0_sys
[    2.857866] LDO_REG2: supplied by vcc5v0_sys
[    2.858359] LDO_REG3: supplied by vcc5v0_sys
[    2.859835] LDO_REG4: supplied by vcc5v0_sys
[    2.860035] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
[    2.861273] LDO_REG5: supplied by vcc5v0_sys
[    2.861799] LDO_REG6: supplied by vcc5v0_sys
[    2.862985] LDO_REG7: supplied by vcc5v0_sys
[    2.863516] LDO_REG8: supplied by vcc5v0_sys
[    2.864699] SWITCH_REG1: supplied by vcc3v3_sys_s3
[    2.865071] SWITCH_REG2: supplied by vcc3v3_sys_s3
[    2.868921] rk808-rtc rk808-rtc: registered as rtc0
[    2.869490] rk808-rtc rk808-rtc: setting system clock to 2020-11-23T19:32:43 UTC (1606159963)
[    2.871678] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.871719] fan53555-reg: supplied by vcc5v0_sys
[    2.872884] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
[    2.873012] avdd_0v9_s0: supplied by vcc1v8_sys_s3
[    2.875118] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.875152] fan53555-reg: supplied by vcc5v0_sys
[    2.886040] sdhci: Secure Digital Host Controller Interface driver
[    2.886046] sdhci: Copyright(c) Pierre Ossman
[    2.886071] Synopsys Designware Multimedia Card Interface Driver
[    2.887901] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    2.887931] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    2.887946] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    2.888010] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[    2.888290] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    2.901171] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.914544] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.916265] mmc1: CQHCI version 5.10
[    2.921700] random: fast init done
[    2.941624] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.945949] ledtrig-cpu: registered to indicate activity on CPUs
[    2.947248] hid: raw HID events driver (C) Jiri Kosina
[    2.947376] usbcore: registered new interface driver usbhid
[    2.947380] usbhid: USB HID core driver
[    2.953232] drop_monitor: Initializing network drop monitor service
[    2.954040] NET: Registered protocol family 10
[    2.980809] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    2.980915] mmc0: new high speed SDHC card at address aaaa
[    2.982111] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
[    2.984903]  mmcblk0: p1
[    3.010198] mmc1: Command Queue Engine enabled
[    3.010217] mmc1: new HS200 MMC card at address 0001
[    3.010964] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[    3.011211] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[    3.011448] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[    3.011652] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB, chardev (243:0)
[    3.012578] Segment Routing with IPv6
[    3.012694] NET: Registered protocol family 17
[    3.012913] 8021q: 802.1Q VLAN Support v1.8
[    3.013060] Key type dns_resolver registered
[    3.014053] registered taskstats version 1
[    3.014068] Loading compiled-in X.509 certificates
[    3.019827] Loaded X.509 cert 'Build time autogenerated kernel key: 3c30550356ab525d6d7708f95571a45a475bcefb'
[    3.020079] zswap: loaded using pool lzo/zbud
[    3.020612] Key type ._fscrypt registered
[    3.020619] Key type .fscrypt registered
[    3.020625] Key type fscrypt-provisioning registered
[    3.023880] Btrfs loaded, crc32c=crc32c-generic
[    3.050080] Key type encrypted registered
[    3.050108] AppArmor: AppArmor sha1 policy hashing enabled
[    3.168994] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    3.173986] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    3.174035] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    3.174056] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    3.174393] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    3.174404] pci_bus 0000:00: root bus resource [bus 00-1f]
[    3.174413] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    3.174424] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    3.174467] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[    3.174627] pci 0000:00:00.0: supports D1
[    3.174635] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    3.180245] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.180437] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[    3.180558] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    3.180567] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
[    3.180603] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    3.180610] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
[    3.180645] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    3.180652] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
[    3.180686] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    3.180694] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
[    3.180728] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    3.180735] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
[    3.180770] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    3.180805] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    3.180842] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    3.181181] pci 0000:01:00.0: PME# supported from D3hot
[    3.181394] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    3.186855] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[    3.186885] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[    3.186907] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[    3.186918] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
[    3.186938] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
[    3.186946] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
[    3.186953] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
[    3.186961] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
[    3.186968] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
[    3.186975] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
[    3.186982] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
[    3.186989] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
[    3.186996] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
[    3.187003] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
[    3.187014] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.187027] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[    3.187257] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.187560] pcieport 0000:00:00.0: PME: Signaling with IRQ 237
[    3.187897] pcieport 0000:00:00.0: AER: enabled with IRQ 237
[    3.188232] ahci 0000:01:00.0: version 3.0
[    3.188256] ahci 0000:01:00.0: enabling device (0000 -> 0002)
[    3.188804] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[    3.188904] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
[    3.188917] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    3.192383] scsi host0: ahci
[    3.193018] scsi host1: ahci
[    3.193494] scsi host2: ahci
[    3.193959] scsi host3: ahci
[    3.194474] scsi host4: ahci
[    3.194683] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 238
[    3.194693] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 239
[    3.194702] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 240
[    3.194709] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 241
[    3.194717] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 242
[    3.203440] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.204064] of_cfs_init
[    3.204120] of_cfs_init: OK
[    3.318945] usb 1-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
[    3.318956] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.318965] usb 1-1: Product: USB2.0 Hub
[    3.318973] usb 1-1: Manufacturer: VIA Labs, Inc.
[    3.380010] hub 1-1:1.0: USB hub found
[    3.380182] hub 1-1:1.0: 4 ports detected
[    3.474755] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    3.507628] ata1: SATA link down (SStatus 0 SControl 300)
[    3.596314] usb 2-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
[    3.596325] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.596334] usb 2-1: Product: USB3.0 Hub
[    3.596341] usb 2-1: Manufacturer: VIA Labs, Inc.
[    3.620038] hub 2-1:1.0: USB hub found
[    3.620258] hub 2-1:1.0: 4 ports detected
[    3.819609] ata2: SATA link down (SStatus 0 SControl 300)
[    4.131626] ata3: SATA link down (SStatus 0 SControl 300)
[    4.200993] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
[    4.443428] ata4: SATA link down (SStatus 0 SControl 300)
[    4.755409] ata5: SATA link down (SStatus 0 SControl 300)
[    4.758180] Freeing unused kernel memory: 4160K
[    4.758440] Run /init as init process
[    4.758448]   with arguments:
[    4.758453]     /init
[    4.758458]   with environment:
[    4.758464]     HOME=/
[    4.758469]     TERM=linux
[    4.758474]     ubootpart=794023b5-01
[    4.758479]     cgroup_enable=memory
[    4.758484]     cgroup_memory=1
[    5.021301] usb 2-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[    5.042436] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
[    5.042453] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    5.042464] usb 2-1.4: Product: USB 10/100/1G/2.5G LAN
[    5.042474] usb 2-1.4: Manufacturer: Realtek
[    5.042484] usb 2-1.4: SerialNumber: 000000001
[    5.299845] input: adc-keys as /devices/platform/adc-keys/input/input1
[    5.391039] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[    5.391056] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[    5.391283] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[    5.391463] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    5.391479] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    5.391491] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[    5.391511] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    5.391611] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    5.391620] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    5.398515] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    5.399062] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    5.399081] rk_gmac-dwmac fe300000.ethernet:     DWMAC1000
[    5.399092] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[    5.399102] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[    5.399111] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[    5.399120] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[    5.399129] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[    5.399191] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[    5.399201] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[    5.399211] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    5.531684] libphy: stmmac: probed
[    5.531718] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    5.531735] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    5.722238] async_tx: api initialized (async)
[    6.184582] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    7.202710] systemd[1]: Inserted module 'autofs4'
[    7.267134] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECC
OMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.268049] systemd[1]: Detected architecture arm64.
[    7.294979] systemd[1]: Set hostname to <nas0.fam0.loc>.
[    7.461310] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[    8.051079] random: lvmconfig: uninitialized urandom read (4 bytes read)
[    8.619206] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.st
atd.pid; please update the unit file accordingly.
[    8.656209] systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fanco
ntrol.pid; please update the unit file accordingly.
[    8.761345] random: systemd: uninitialized urandom read (16 bytes read)
[    8.774722] random: systemd: uninitialized urandom read (16 bytes read)
[    8.774785] systemd[1]: Reached target Swap.
[    8.776184] systemd[1]: Listening on Network Service Netlink Socket.
[    8.777218] systemd[1]: Listening on Journal Socket.
[    8.784517] systemd[1]: Mounting Huge Pages File System...
[    8.785899] systemd[1]: Listening on LVM2 poll daemon socket.
[    8.857666] lm75 2-004c: hwmon2: sensor 'lm75'
[    8.978699] RPC: Registered named UNIX socket transport module.
[    8.978705] RPC: Registered udp transport module.
[    8.978710] RPC: Registered tcp transport module.
[    8.978714] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    8.992808] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    9.195202] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    9.411195] systemd-journald[421]: Received request to flush runtime journal from PID 1
[   10.147506] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   10.154504] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[   10.154534] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[   10.155425] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[   10.386057] input: beeper as /devices/platform/beeper/input/input2
[   10.561778] fusb30x: module is from the staging directory, the quality is unknown, you have been warned.
[   10.575148] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_UFP
[   10.604234] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[   10.611056] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   10.611091] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
[   10.611257] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[   10.611285] xhci-hcd xhci-hcd.2.auto: irq 225, io mem 0xfe800000
[   10.611772] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[   10.611778] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.611782] usb usb3: Product: xHCI Host Controller
[   10.611787] usb usb3: Manufacturer: Linux 5.8.17-rockchip64 xhci-hcd
[   10.611791] usb usb3: SerialNumber: xhci-hcd.2.auto
[   10.612272] ehci-platform fe380000.usb: EHCI Host Controller
[   10.612396] hub 3-0:1.0: USB hub found
[   10.612457] hub 3-0:1.0: 1 port detected
[   10.612823] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   10.612838] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4
[   10.612858] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   10.612988] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   10.613161] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[   10.613178] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.613184] usb usb4: Product: xHCI Host Controller
[   10.613189] usb usb4: Manufacturer: Linux 5.8.17-rockchip64 xhci-hcd
[   10.613193] usb usb4: SerialNumber: xhci-hcd.2.auto
[   10.621719] hub 4-0:1.0: USB hub found
[   10.621799] hub 4-0:1.0: 1 port detected
[   10.622284] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[   10.622446] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
[   10.637113] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[   10.637564] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[   10.637573] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.637578] usb usb5: Product: EHCI Host Controller
[   10.637583] usb usb5: Manufacturer: Linux 5.8.17-rockchip64 ehci_hcd
[   10.637587] usb usb5: SerialNumber: fe380000.usb
[   10.638223] hub 5-0:1.0: USB hub found
[   10.638282] hub 5-0:1.0: 1 port detected
[   10.639473] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[   10.639504] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[   10.639662] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
[   10.681337] mc: Linux media interface: v0.10
[   10.702480] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
[   10.702491] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.702496] usb usb6: Product: Generic Platform OHCI controller
[   10.702501] usb usb6: Manufacturer: Linux 5.8.17-rockchip64 ohci_hcd
[   10.702505] usb usb6: SerialNumber: fe3a0000.usb
[   10.703247] hub 6-0:1.0: USB hub found
[   10.703342] hub 6-0:1.0: 1 port detected
[   10.721769] fusb302 4-0022: CC connected in CC1 as UFP
[   10.820234] videodev: Linux video capture interface: v2.00
[   10.832338] random: crng init done
[   10.832350] random: 7 urandom warning(s) missed due to ratelimiting
[   10.998346] rockchip-rga ff680000.rga: HW Version: 0x03.02
[   10.998753] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[   11.018082] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   11.020920] rkvdec ff660000.video-codec: Adding to iommu group 1
[   11.037308] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[   11.041512] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[   11.042377] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
[   11.042588] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
[   11.090994] panfrost ff9a0000.gpu: clock rate = 500000000
[   11.092267] usb 2-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[   11.092368] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   11.092376] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   11.092383] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   11.092389] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   11.104270] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
[   11.236146] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[   11.238119] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[   11.238613] rockchip-vop ff900000.vop: Adding to iommu group 3
[   11.245100] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[   11.245217] [drm] unsupported AFBC format[3231564e]
[   11.247588] r8152 2-1.4:1.0 eth1: v2.13.0 (2020/04/20)
[   11.247595] r8152 2-1.4:1.0 eth1: This product is covered by one or more of the following patents:
                       US6,570,884, US6,115,776, and US6,327,625.
[   11.247667] usbcore: registered new interface driver r8152
[   11.248594] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[   11.249425] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
[   11.249451] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   11.249542] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   11.250180] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[   11.283938] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   12.257160] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   13.615617] fusb302 4-0022: PD disabled
[   14.241828] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   14.241869] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   14.653827] NFSD: Using UMH upcall client tracking operations.
[   14.653844] NFSD: starting 90-second grace period (net f00000a1)
[  145.441962] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 2204.758840] stmmac: wakeup enable
[ 2636.873680] ata4: SATA link down (SStatus 0 SControl 300)
[ 2637.185406] ata2: SATA link down (SStatus 0 SControl 300)
[ 2637.497283] ata5: SATA link down (SStatus 0 SControl 300)
[ 2637.809415] ata3: SATA link down (SStatus 0 SControl 300)
[ 2638.121377] ata1: SATA link down (SStatus 0 SControl 300)
[ 2947.708710] ata4: SATA link down (SStatus 0 SControl 300)
[ 2948.020809] ata2: SATA link down (SStatus 0 SControl 300)
[ 2948.332687] ata5: SATA link down (SStatus 0 SControl 300)
[ 2948.644816] ata3: SATA link down (SStatus 0 SControl 300)
[ 2948.956815] ata1: SATA link down (SStatus 0 SControl 300)
[ 2973.764232] ata1: SATA link down (SStatus 0 SControl 300)
( I have triggered the rescan with the commnad `echo "- - -" > /sys/class/scsi_host/host0/scan`)
armbian: 20.08.21 fully upgraded (with firmware update)
I also have installed openmediavault.
Edited by TRS-80
move long output into spoiler
A few updates on my testing:
  • As there did not seem to be a cable problem, I swapped the Sata port 1 and 2 cables back to match the wiki build document. Note: the UPS battery is not connected.
  • I did attempt to downgrade the Seagate Barracuda SSD 120 1TB to 3.1 specifications. The downgrade failed on an error so that avenue has been abandoned.
  • I acquired a new Samsung SSD 860  EVO 1 TB hoping that it works better than the Cuda 120 SSD.
  • I retested 5 different drives  on each Sata port.  The drives were
  1.  WD RED 10TB #2 (two Red 10TB drives tested are labeled #2 and #3, just the number on the drive rail)
  2. Samsung SSD 86 EVO - 1 TB
  3. SanDisk Extreme II SSD - 240GB
  4. Seagate Barracuda SSD 120 - 1TB
  5. WD RED 10TB #3
  • For each Sata port, the a single drive was installed with a power on boot to determine whether the drive was visible/recognized after the kernel was started.
    port 1:    recognized:  2, 5                                                           not recognized: 1, 3, 4
    port 2:    recognized:  1, 3                                                           not recognized: 2, 4, 5
    port 3:    recognized:  1, 3                                                           not recognized: 2, 4, 5
    port 4:    recognized:  1*, 2*, 3, 5                                                 not recognized:  4
    port 5:    recognized:  1, 2, 3, 4, 5                                               not recognized:
    * -  very slow boot, many resets, recognized at 3.0Gbps
  • An observation:  during the u-boot process there is a pause just after "Net:   eth0: ethernet@fe300000" and before "scanning bus for devices..." of about 10-12 seconds  With a drive installed in Sata ports 3, 4, 5, front panel LED lights up almost immediately after "Net:   eth0: ethernet@fe300000" is displayed. If the LED is not on, the drive will not be recognized. On Sata port 1 and 2, there is a 10-12 second pause after "Net:   eth0: ethernet@fe300000" is displayed and then the bus scan. I'm assuming this is a staggered power start up, Sata ports 3, 4, 5 and then Sata port 1, 2. Just visually, it seemed more random on port 1 or 2 whether a device has time to complete power up before the bus scan.
  • I'm looking for a 3 drive configuration; a 1 TB SSD  with the two WD RED 10 TB HDD. As the Cuda SSD 120 only seems to be recognized in port 5,  I'll proceed with the Samsung SSD 860 EVO. But what ports? Ports 4 and 5 seem the most reliable so I'm putting the HDDs on these ports. My preference was to have the SSD on port 1 but I did experience a couple of times where the SSD wasn't recognized in this 3 drive configuration. So, I'm testing with the SSD on port 3 and the HDDs on port 4 and 5.  So  far, this is looking to be the best configuration. It's odd that the SSD was not recognized on port 3 during the single drive tests but seems stable with three drives.
Jim
18 hours ago, gprovost said:
@amreo What HDD brand and model are you using ?
4x WD red for nas in the first four bays.
After hours of debugging I have find out that I have inserted the HDDs in the opposite vertically direction.
I have fixed it by removing the HDDs,  re-screwed the HDD Slot connectors and re-inserting the HDDs in the correct direction.
So we can conclude the problem is between the helios64 and the chair.
@JPW Maybe you contact us at support@kobol.io to see if we should send you a new HDD harness.
 Hahhaa good one.
