ub6yac Posted July 11, 2016 Posted July 11, 2016 Hello.Some facts:1. Boot with image based on legacy kernel cause shutdown after some (less than 10) seconds after power on.2. Boot with image based on vanilla kernel always ok.3. If i try to boot without SD card, than power off Cubie with button, then insert SD and switch on with button - it will boot OK with lagacy kernel!Which logs can help to find the problem? I ought to use legacy kernel - i need internal soundcard and both USB.And I see that it is not my own problem - http://forum.armbian.com/index.php/topic/1593-armbian-cubieboard1a10-desktop-with-legacy-kernel-wont-boot-just-shuts-off-cubieboard/- i think we can help to find the bug.
zador.blood.stained Posted July 11, 2016 Posted July 11, 2016 Which logs can help to find the problem? Logs from serial console may help I ought to use legacy kernel - i need internal soundcard and both USB. USB and internal analog audio are fully supported in mainline.
ub6yac Posted July 11, 2016 Author Posted July 11, 2016 Logs from serial console may help This is the log with boot fail: [Welcome to] minicom 2.7 ПÐÐ ÐМЕТРЫ: I18n Дата компилÑции Jan 1 2014, 10:03:28. Port /dev/ttyUSB0, 02:09:23 Ðажмите CTRL-A Z Ð´Ð»Ñ Ð¿Ð¾Ð»ÑƒÑ‡ÐµÐ½Ð¸Ñ Ð¿Ð¾Ð´Ñказки по клавишам U-Boot SPL 2016.05-armbian (Jun 05 2016 - 17:59:37) DRAM: 1024 MiB CPU: 1008000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2016.05-armbian (Jun 05 2016 - 17:59:37 +0200) Allwinner Technology CPU: Allwinner A10 (SUN4I) Model: Cubietech Cubieboard I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c0b000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2447 bytes read in 182 ms (12.7 KiB/s) ## Executing script at 43100000 0 bytes read in 131 ms (0 Bytes/s) ** File not found /boot/.next ** ** Unrecognized filesystem type ** ** File not found .next ** 43716 bytes read in 336 ms (127 KiB/s) 3531631 bytes read in 417 ms (8.1 MiB/s) 5458664 bytes read in 620 ms (8.4 MiB/s) Kernel image @ 0x48000000 [ 0x000000 - 0x534ae8 ] ## Loading init Ramdisk from Legacy Image at 42000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3531567 Bytes = 3.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Starting kernel ... <6>Booting Linux on physical CPU 0 <6>Initializing cgroup subsys cpuset <6>Initializing cgroup subsys cpu <5>Linux version 3.4.112-sun4i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubu6 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: sun4i <6>Memory Reserved: <6> SYS : 0x43000000 - 0x4300ffff ( 64 kB) <6> LCD : 0x44000000 - 0x44ffffff ( 16 MB) Memory policy: ECC disabled, Data cache writeback <6>sunxi: Allwinner A10 revision C (AW1623/sun4i) detected. <7>On node 0 totalpages: 262144 <7>free_area_init_node: node 0, pgdat c0a470b8, node_mem_map d0000000 <7> DMA zone: 512 pages used for memmap <7> DMA zone: 0 pages reserved <7> DMA zone: 65024 pages, LIFO batch:15 <7> Normal zone: 1008 pages used for memmap <7> Normal zone: 128016 pages, LIFO batch:31 <7> HighMem zone: 528 pages used for memmap <7> HighMem zone: 67056 pages, LIFO batch:15 <7>pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 <7>pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096 <5>Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=e7 <6>PID hash table entries: 4096 (order: 2, 16384 bytes) <6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) <6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) <6>allocated 2097152 bytes of page_cgroup <6>please try 'cgroup_disable=memory' option if you don't want memory cgroups <6>Memory: 1024MB = 1024MB total <5>Memory: 1005228k/1005228k available, 43348k reserved, 270336K highmem <5>Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) lowmem : 0xc0000000 - 0xef800000 ( 760 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc09ac09c (9873 kB) .init : 0xc09ad000 - 0xc09e1000 ( 208 kB) .data : 0xc09e2000 - 0xc0a4f5c8 ( 438 kB) .bss : 0xc0a4f5ec - 0xc0c12800 (1805 kB) <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 <6>NR_IRQS:128 <6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms <6>Console: colour dummy device 80x30 <6>console [tty1] enabled <6>Calibrating delay loop... 1001.88 BogoMIPS (lpj=5009408) <6>pid_max: default: 32768 minimum: 301 <6>Mount-cache hash table entries: 512 <6>Initializing cgroup subsys cpuacct <6>Initializing cgroup subsys memory <6>Initializing cgroup subsys devices <6>Initializing cgroup subsys freezer <6>Initializing cgroup subsys blkio <6>Initializing cgroup subsys perf_event <6>CPU: Testing write buffer coherency: ok <6>hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available <6>Setting up static identity map for 0x40706978 - 0x407069d0 <6>devtmpfs: initialized <6>dummy: <6>NET: Registered protocol family 16 <6>DMA: preallocated 256 KiB pool for atomic coherent allocations <6>hw-breakpoint: debug architecture 0x4 unsupported. <6>Init eGon pin module V2.0 SOFTWINNER DMA Driver, © 2003-2004,2006 Simtec Electronics <6>Initialize DMAC OK <6>bio: create slab at 0 <6>sunxi_gpio driver init ver 1.3 <6>sunxi_gpio_probe can't find script.bin '[gpio_para]' 'gpio_used' <4>gpio-sunxi: probe of gpio-sunxi failed with error -4 <5>SCSI subsystem initialized <7>libata version 3.00 loaded. <6>usbcore: registered new interface driver usbfs <6>usbcore: registered new interface driver hub <6>usbcore: registered new device driver usb <6>Linux media interface: v0.10 <6>Linux video capture interface: v2.00 <6>Advanced Linux Sound Architecture Driver Version 1.0.25. <6>Switching to clocksource aw_64bits_counter <5>FS-Cache: Loaded <6>cfg80211: Calling CRDA to update world regulatory domain <6>CacheFiles: Loaded [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG [sw_hcd0]: usb host driver initialize........ [sw_hcd0]: open_usb_clock [sw_hcd0]: host_init_state = 0 [sw_hcd0]: platform is usb host [sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X) [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IR8 <6>sw_hcd_host0 sw_hcd_host0: sw_hcd host driver <6>sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 <6>hub 1-0:1.0: USB hub found <6>hub 1-0:1.0: 1 port detected wrn: hcd is not enable, need not start hcd [sw_hcd0]: sw_usb_host0_disable start -------sw_hcd0_soft_disconnect--------- is_on = 0, hcd0_set_vbus_cnt = 0 [sw_hcd_host0]: Set USB Power Off wrn: hcd is not enable, need not stop hcd [sw_hcd0]: close_usb_clock [sw_hcd0]: sw_usb_host0_disable end [sw_udc]: udc_init: version 20080411 <6>NET: Registered protocol family 2 <6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes) <6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes) <6>TCP bind hash table entries: 65536 (order: 6, 262144 bytes) <6>TCP: Hash tables configured (established 131072 bind 65536) <6>TCP: reno registered <6>UDP hash table entries: 512 (order: 1, 8192 bytes) <6>UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) <6>NET: Registered protocol family 1 <6>RPC: Registered named UNIX socket transport module. <6>RPC: Registered udp transport module. <6>RPC: Registered tcp transport module. <6>RPC: Registered tcp NFSv4.1 backchannel transport module. <6>Trying to unpack rootfs image as initramfs... <6>Freeing initrd memory: 3448K <6>audit: initializing netlink socket (disabled) <5>type=2000 audit(0.559:1): initialized highmem bounce pool size: 64 pages <5>VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) <6>squashfs: version 4.0 (2009/01/31) Phillip Lougher <5>NFS: Registering the id_resolver key type <6>NTFS driver 2.1.30 [Flags: R/W]. <6>fuse init (API version 7.18) <6>JFS: nTxBlock = 7880, nTxLock = 63042 <6>SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled <6>Btrfs loaded <6>msgmni has been set to 1442 <6>alg: No test for stdrng (krng) <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) <6>io scheduler noop registered <6>io scheduler deadline registered <6>io scheduler cfq registered (default) <6>sunxi disp driver loaded (/dev/disp api 1.0) <6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled <6>[uart]: used uart info.: 0x05 <6>[uart]: serial probe 0 irq 1 mapbase 0x01c28000 <6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 1) is a U6_16550A [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.112-sun4i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro6 [ 0.000000] Memory Reserved: [ 0.000000] SYS : 0x43000000 - 0x4300ffff ( 64 kB) [ 0.000000] LCD : 0x44000000 - 0x44ffffff ( 16 MB) [ 0.000000] sunxi: Allwinner A10 revision C (AW1623/sun4i) detected. [ 0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait 7 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 1005228k/1005228k available, 43348k reserved, 270336K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc09ac09c (9873 kB) [ 0.000000] .init : 0xc09ad000 - 0xc09e1000 ( 208 kB) [ 0.000000] .data : 0xc09e2000 - 0xc0a4f5c8 ( 438 kB) [ 0.000000] .bss : 0xc0a4f5ec - 0xc0c12800 (1805 kB) [ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS:128 [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.008692] Calibrating delay loop... 1001.88 BogoMIPS (lpj=5009408) [ 0.050269] pid_max: default: 32768 minimum: 301 [ 0.053858] Mount-cache hash table entries: 512 [ 0.057691] Initializing cgroup subsys cpuacct [ 0.061020] Initializing cgroup subsys memory [ 0.064440] Initializing cgroup subsys devices [ 0.067865] Initializing cgroup subsys freezer [ 0.071097] Initializing cgroup subsys blkio [ 0.074770] Initializing cgroup subsys perf_event [ 0.078319] CPU: Testing write buffer coherency: ok [ 0.085859] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available [ 0.091413] Setting up static identity map for 0x40706978 - 0x407069d0 [ 0.094241] devtmpfs: initialized [ 0.096828] dummy: [ 0.100400] NET: Registered protocol family 16 [ 0.106857] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.112367] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.115777] Init eGon pin module V2.0 [ 0.123276] Initialize DMAC OK [ 0.130419] bio: create slab at 0 [ 0.133815] sunxi_gpio driver init ver 1.3 [ 0.139882] sunxi_gpio_probe can't find script.bin '[gpio_para]' 'gpio_used' [ 0.144860] gpio-sunxi: probe of gpio-sunxi failed with error -4 [ 0.147870] SCSI subsystem initialized [ 0.155289] usbcore: registered new interface driver usbfs [ 0.159639] usbcore: registered new interface driver hub [ 0.163746] usbcore: registered new device driver usb [ 0.166804] Linux media interface: v0.10 [ 0.170406] Linux video capture interface: v2.00 [ 0.175910] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.181076] Switching to clocksource aw_64bits_counter [ 0.183050] FS-Cache: Loaded [ 0.188457] cfg80211: Calling CRDA to update world regulatory domain [ 0.190629] CacheFiles: Loaded [ 0.257997] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver [ 0.264715] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 [ 0.267898] hub 1-0:1.0: USB hub found [ 0.270799] hub 1-0:1.0: 1 port detected [ 0.304552] NET: Registered protocol family 2 [ 0.316002] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.322798] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.330016] TCP bind hash table entries: 65536 (order: 6, 262144 bytes) [ 0.336057] TCP: Hash tables configured (established 131072 bind 65536) [ 0.338271] TCP: reno registered [ 0.343064] UDP hash table entries: 512 (order: 1, 8192 bytes) [ 0.348322] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) [ 0.351815] NET: Registered protocol family 1 [ 0.356975] RPC: Registered named UNIX socket transport module. [ 0.360648] RPC: Registered udp transport module. [ 0.364311] RPC: Registered tcp transport module. [ 0.369756] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.374252] Trying to unpack rootfs image as initramfs... [ 0.562355] Freeing initrd memory: 3448K [ 0.567652] audit: initializing netlink socket (disabled) [ 0.571355] type=2000 audit(0.559:1): initialized [ 0.584351] VFS: Disk quotas dquot_6.5.2 [ 0.596122] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.600976] NFS: Registering the id_resolver key type [ 0.605088] NTFS driver 2.1.30 [Flags: R/W]. [ 0.608344] fuse init (API version 7.18) [ 0.612740] JFS: nTxBlock = 7880, nTxLock = 63042 [ 0.622476] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled [ 0.625816] Btrfs loaded [ 0.628633] msgmni has been set to 1442 [ 0.635490] alg: No test for stdrng (krng) [ 0.642070] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [ 0.645081] io scheduler noop registered [ 0.648314] io scheduler deadline registered [ 0.652006] io scheduler cfq registered (default) [ 0.656673] sunxi disp driver loaded (/dev/disp api 1.0) [ 0.662147] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.666298] [uart]: used uart info.: 0x05 [ 0.670889] [uart]: serial probe 0 irq 1 mapbase 0x01c28000 [ 0.696894] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 1) is a U6_16550A <6>console [ttyS0] enabled [ 1.278441] console [ttyS0] enabled <6>[uart]: serial probe 2 irq 3 mapbase 0x01c28800 [ 1.286651] [uart]: serial probe 2 irq 3 mapbase 0x01c28800 <6>sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 3) is a U6_16550A [ 1.318159] sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 3) is a U6_16550A <7>G2D: drv_g2d_init <6>G2D: Module initialized.major:250 [ 1.330752] G2D: Module initialized.major:250 <6>brd: module loaded [ 1.341226] brd: module loaded <6>loop: module loaded [ 1.348603] loop: module loaded [NAND] nand driver version: 0x2 0x9 <4>Dev Sunxi softw311 nand: part 1, start 32768, size 32768 [ 1.415934] Dev Sunxi softw311 nand: part 1, start 32768, size 32768 <4>Dev Sunxi softw311 nand: part 2, start 65536, size 32768 [ 1.427657] Dev Sunxi softw311 nand: part 2, start 65536, size 32768 <4>Dev Sunxi softw311 nand: part 3, start 98304, size 65536 [ 1.439334] Dev Sunxi softw311 nand: part 3, start 98304, size 65536 <4>Dev Sunxi softw311 nand: part 4, start 163840, size 1048576 [ 1.451263] Dev Sunxi softw311 nand: part 4, start 163840, size 1048576 <4>Dev Sunxi softw311 nand: part 5, start 1212416, size 1048576 [ 1.463538] Dev Sunxi softw311 nand: part 5, start 1212416, size 1048576 <4>Dev Sunxi softw311 nand: part 6, start 2260992, size 32768 [ 1.475726] Dev Sunxi softw311 nand: part 6, start 2260992, size 32768 <4>Dev Sunxi softw311 nand: part 7, start 2293760, size 65536 [ 1.487741] Dev Sunxi softw311 nand: part 7, start 2293760, size 65536 <4>Dev Sunxi softw311 nand: part 8, start 2359296, size 262144 [ 1.499842] Dev Sunxi softw311 nand: part 8, start 2359296, size 262144 <4>Dev Sunxi softw311 nand: part 9, start 2621440, size 5357568 [ 1.512116] Dev Sunxi softw311 nand: part 9, start 2621440, size 5357568 <6> nand: nand1 nand2 nand3 nand4 nand5 nand6 nand7 nand8 nand9 [ 1.524477] nand: nand1 nand2 nand3 nand4 nand5 nand6 nand7 nand8 nand9 [NAND]nand driver, ok. <6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP [ 1.540738] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP <6>ahci: SSS flag set, parallel bus scan disabled [ 1.552215] ahci: SSS flag set, parallel bus scan disabled <6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 1.565118] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode <6>sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc [ 1.580437] sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc <6>scsi0 : sw_ahci_platform [ 1.591574] scsi0 : sw_ahci_platform <6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 56 [ 1.602290] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 56 <6>bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 1.616445] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) <6>Fixed MDIO Bus: probed [ 1.627299] Fixed MDIO Bus: probed <6>sunxi_emac Using mii phy on PortA [ 1.634023] sunxi_emac Using mii phy on PortA <6>sunxi_emac Using MAC from SID: 02:82:01:c2:22:b2[ 1.653033] sunxi_emac Using MAC from SID: 022 [ 1.663471] PPP generic driver version 2.4.2 <6>PPP BSD Compression module registered [ 1.671758] PPP BSD Compression module registered <6>PPP Deflate Compression module registered [ 1.680486] PPP Deflate Compression module registered <6>PPP MPPE Compression module registered [ 1.691534] PPP MPPE Compression module registered <6>NET: Registered protocol family 24 [ 1.699845] NET: Registered protocol family 24 <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.710143] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.721883] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [sw-ehci1]: open clock [sw-ehci1]: Set USB Power ON <6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.759408] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 [ 1.773055] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 <6>sw-ehci sw-ehci.1: irq 39, io mem 0x01c14000 [ 1.784479] sw-ehci sw-ehci.1: irq 39, io mem 0x01c14000 <6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 [ 1.805481] sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 <6>hub 2-0:1.0: USB hub found [ 1.814052] hub 2-0:1.0: USB hub found <6>hub 2-0:1.0: 1 port detected [ 1.820691] hub 2-0:1.0: 1 port detected [sw-ohci1]: open clock <6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 1.853109] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 [ 1.866422] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 <6>sw-ohci sw-ohci.1: irq 64, io mem 0x01c14400 [ 1.877789] sw-ohci sw-ohci.1: irq 64, io mem 0x01c14400 <6>hub 3-0:1.0: USB hub found [ 1.948196] hub 3-0:1.0: USB hub found <6>hub 3-0:1.0: 1 port detected [ 1.954877] hub 3-0:1.0: 1 port detected [sw-ehci2]: open clock <6>ata1: SATA link down (SStatus 0 SControl 300) [ 1.975476] ata1: SATA link down (SStatus 0 SControl 300) [sw-ehci2]: Set USB Power ON <6>sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.000093] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 [ 2.013738] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 <6>sw-ehci sw-ehci.2: irq 40, io mem 0x01c1c000 [ 2.025167] sw-ehci sw-ehci.2: irq 40, io mem 0x01c1c000 <6>sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 [ 2.045475] sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 <6>hub 4-0:1.0: USB hub found [ 2.054078] hub 4-0:1.0: USB hub found <6>hub 4-0:1.0: 1 port detected [ 2.060714] hub 4-0:1.0: 1 port detected [sw-ohci2]: open clock <6>sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 2.093142] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 [ 2.106436] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 <6>sw-ohci sw-ohci.2: irq 65, io mem 0x01c1c400 [ 2.117788] sw-ohci sw-ohci.2: irq 65, io mem 0x01c1c400 <6>hub 5-0:1.0: USB hub found [ 2.188222] hub 5-0:1.0: USB hub found <6>hub 5-0:1.0: 1 port detected [ 2.194892] hub 5-0:1.0: 1 port detected <6>Initializing USB Mass Storage driver... [ 2.202906] Initializing USB Mass Storage driver... <6>usbcore: registered new interface driver usb-storage [ 2.212905] usbcore: registered new interface driver usb-storage <6>USB Mass Storage support registered. [ 2.222499] USB Mass Storage support registered. <6>usbcore: registered new interface driver ums-alauda [ 2.232035] usbcore: registered new interface driver ums-alauda <6>usbcore: registered new interface driver ums-cypress [ 2.242955] usbcore: registered new interface driver ums-cypress <6>usbcore: registered new interface driver ums-datafab [ 2.253961] usbcore: registered new interface driver ums-datafab <6>usbcore: registered new interface driver ums_eneub6250 [ 2.265136] usbcore: registered new interface driver ums_eneub6250 <6>usbcore: registered new interface driver ums-freecom [ 2.276313] usbcore: registered new interface driver ums-freecom <6>usbcore: registered new interface driver ums-isd200 [ 2.287235] usbcore: registered new interface driver ums-isd200 <6>usbcore: registered new interface driver ums-jumpshot [ 2.298304] usbcore: registered new interface driver ums-jumpshot <6>usbcore: registered new interface driver ums-karma [ 2.309230] usbcore: registered new interface driver ums-karma <6>usbcore: registered new interface driver ums-onetouch [ 2.320150] usbcore: registered new interface driver ums-onetouch <6>usbcore: registered new interface driver ums-realtek [ 2.331253] usbcore: registered new interface driver ums-realtek <6>usbcore: registered new interface driver ums-sddr09 [ 2.342171] usbcore: registered new interface driver ums-sddr09 <6>usbcore: registered new interface driver ums-sddr55 [ 2.353001] usbcore: registered new interface driver ums-sddr55 <6>usbcore: registered new interface driver ums-usbat [ 2.363743] usbcore: registered new interface driver ums-usbat <6>mousedev: PS/2 mouse device common for all mice [ 2.374250] mousedev: PS/2 mouse device common for all mice ===========================hv_keypad_init===================== ========HV Inital =================== <3>tkey_fetch_sysconfig_para: tkey_unused. [ 2.392806] tkey_fetch_sysconfig_para: tkey_unused. hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 <3>sunxi-rtc sunxi-rtc: Error: Set LOSC to external failed. [ 2.410602] sunxi-rtc sunxi-rtc: Error: Set LOSC to external failed. <3>sunxi-rtc sunxi-rtc: Warning: RTC time will be wrong! [ 2.422020] sunxi-rtc sunxi-rtc: Warning: RTC time will be wrong! <6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 [ 2.433365] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 <6>i2c /dev entries driver [ 2.441957] i2c /dev entries driver config i2c gpio with gpio_config api <6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected [ 2.454546] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected <6>axp_mfd 0-0034: AXP internal temperature monitoring enabled [ 2.465697] axp_mfd 0-0034: AXP internal temperature monitoring enabled <4>i2c i2c-0: Invalid probe address 0x00 [ 2.476631] i2c i2c-0: Invalid probe address 0x00 <6>I2C: i2c-0: AW16XX I2C adapter [ 2.484414] I2C: i2c-0: AW16XX I2C adapter config i2c gpio with gpio_config api <4>i2c i2c-1: Invalid probe address 0x00 [ 2.495753] i2c i2c-1: Invalid probe address 0x00 <6>I2C: i2c-1: AW16XX I2C adapter [ 2.503505] I2C: i2c-1: AW16XX I2C adapter config i2c gpio with gpio_config api <4>i2c i2c-2: Invalid probe address 0x00 [ 2.514828] i2c i2c-2: Invalid probe address 0x00 <6>I2C: i2c-2: AW16XX I2C adapter [ 2.522581] I2C: i2c-2: AW16XX I2C adapter [cedar dev]: not installed! ve_mem_reserve=0 [tt]----- avs_dev driver load... ---- [tt]----- register iomem ---- [tt]--- avs_dev driver load ok!! ----- [ace_drv] start!!! [ace_drv] init end!!! [pa_drv] start!!! [pa_drv] init end!!! <6>axp20_ldo1: 1300 mV [ 2.551424] axp20_ldo1: 1300 mV <6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV [ 2.559830] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV This is the log of boot from internal flash (with manualy forced shutdown after full start): Добро пожаловать в minicom 2.7 ПÐÐ ÐМЕТРЫ: I18n Дата компилÑции Jan 1 2014, 10:03:28. Port /dev/ttyUSB0, 02:17:12 Ðажмите CTRL-A Z Ð´Ð»Ñ Ð¿Ð¾Ð»ÑƒÑ‡ÐµÐ½Ð¸Ñ Ð¿Ð¾Ð´Ñказки по клавишам HELLO! BOOT0 is starting! boot0 version : 1.5.0 dram size =1024 Succeed in opening nand flash. Succeed in reading Boot1 file head. The size of Boot1 is 0x00056000. The file stored in 0X00000000 of block 2 is perfect. Check is correct. Ready to disable icache. Succeed in loading Boot1. Jump to Boot1. [ 0.178] boot1 version : 1.5.0 [ 0.178] pmu type = 3 [ 0.180] bat vol = 0 [ 0.211] axi:ahb:apb=3:2:2 [ 0.211] set dcdc2=1400, clock=1008 successed [ 0.213] key [ 0.226] no key found [ 0.226] flash init start [ 0.276] flash init finish [ 0.278] fs init ok [ 0.279] fattype FAT16 [ 0.279] fs mount ok [ 0.285] script finish [ 0.286] power finish [ 0.297] BootMain start [ 0.297] 0 [ 0.315] usbdc_vol = 4000, usbdc_cur = 0 [ 0.315] usbpc_vol = 4000, usbpc_cur = 0 [ 0.318] init to usb pc [ 0.321] set pc [ 0.416] power_start=0x00000102 [ 0.416] key value = 0 [ 0.416] recovery key high 6, low 4 [ 0.420] unable to find fastboot_key key_max value [ 0.428] test for multi os boot with display [ 1.040] show pic finish [ 1.040] load kernel start [ 1.061] load kernel successed [ 1.061] start address = 0x4a000000 [ 1.062] power exit detect [ 1.066] usb exit U-Boot 2011.09-rc1-00000-ga044d4f-dirty (Mar 29 2013 - 17:50:25) Cubietech Limited CPU: SUNXI Family Board: CUBIEBOARD DRAM: 1 GiB NAND: 3896 MiB MMC: SUNXI SD/MMC: 0 In: serial Out: serial Err: serial --------fastboot partitions-------- -total partitions:9- -name- -start- -size- bootloader : 1000000 1000000 env : 2000000 1000000 boot : 3000000 2000000 system : 5000000 20000000 data : 25000000 20000000 misc : 45000000 1000000 recovery : 46000000 2000000 cache : 48000000 8000000 UDISK : 50000000 a3800000 ----------------------------------- Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x3000000, size 0x2000000 33554432 bytes read: OK Starting kernel ... [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.0.52+ (build@ubt) (gcc version 4.4.3 (GCC) ) #1 PREEMPT Fri May 10 13 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun4i [ 0.000000] Total Detected Memory: 1024MB (via Allwinner's Hack) [ 0.000000] Memory cut off: [ 0.000000] MALI : 0x5c000000 - 0x5fffffff ( 64 MB) [ 0.000000] Memory Reserved: [ 0.000000] SYS : 0x43000000 - 0x4300ffff ( 64 kB) [ 0.000000] VE : 0x44000000 - 0x48ffffff ( 80 MB) [ 0.000000] G2D : 0x58000000 - 0x58ffffff ( 16 MB) [ 0.000000] LCD : 0x5a000000 - 0x5bffffff ( 32 MB) [ 0.000000] RAMCONSOLE : 0x5be00000 - 0x5bffffff ( 2 MB) [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] BROM Ver: 1100 1100 1623 [ 0.000000] chip-id: A10 (AW1623 revision C) [ 0.000000] On node 0 totalpages: 245248 [ 0.000000] free_area_init_node: node 0, pgdat c07ebb64, node_mem_map c10ef000 [ 0.000000] Normal zone: 1280 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 145664 pages, LIFO batch:31 [ 0.000000] HighMem zone: 768 pages used for memmap [ 0.000000] HighMem zone: 97536 pages, LIFO batch:31 [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243200 [ 0.000000] Kernel command line: console=ttyS0,115200 rw init=/init loglevel=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 446MB 512MB = 958MB total [ 0.000000] Memory: 832512k/832512k available, 150528k reserved, 393216K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB) [ 0.000000] vmalloc : 0xe8800000 - 0xf0000000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe8000000 ( 640 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .init : 0xc0008000 - 0xc0032000 ( 168 kB) [ 0.000000] .text : 0xc0032000 - 0xc07a8908 (7643 kB) [ 0.000000] .data : 0xc07aa000 - 0xc07f3058 ( 293 kB) [ 0.000000] .bss : 0xc07f307c - 0xc09ad720 (1770 kB) [ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS:96 [ 0.000000] timer0: Periodic Mode [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] Calibrating delay loop... 1001.88 BogoMIPS (lpj=5009408) [ 0.040000] pid_max: default: 32768 minimum: 301 [ 0.040000] Mount-cache hash table entries: 512 [ 0.040000] Initializing cgroup subsys cpuacct [ 0.040000] Initializing cgroup subsys devices [ 0.040000] Initializing cgroup subsys freezer [ 0.040000] Initializing cgroup subsys blkio [ 0.040000] CPU: Testing write buffer coherency: ok [ 0.040000] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available [ 0.040000] devtmpfs: initialized [ 0.040000] print_constraints: dummy: [ 0.040000] NET: Registered protocol family 16 [ 0.040000] ram_console: got buffer at 5be00000, size 200000 [ 0.040000] ram_console: no valid data in buffer (sig = 0x00000000) [ 0.040000] console [ram-1] enabled [ 0.040000] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.040000] [ccmu] try to set apb1 parent to sata_pll failed! [ 0.040000] SOFTWINNER DMA Driver, © 2003-2004,2006 Simtec Electronics [ 0.040000] Initialize DMAC OK [ 0.040000] bio: create slab <bio-0> at 0 [ 0.040000] SCSI subsystem initialized [ 0.040000] libata version 3.00 loaded. [ 0.040000] usbcore: registered new interface driver usbfs [ 0.040000] usbcore: registered new interface driver hub [ 0.040000] usbcore: registered new device driver usb [ 0.040000] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.040000] cfg80211: Calling CRDA to update world regulatory domain [ 0.040000] Init eGon pin module V2.0 [ 0.040000] Switching to clocksource aw 64bits couter [ 0.040000] FS-Cache: Loaded [ 0.040000] CacheFiles: Loaded [ 0.050000] Switched to NOHz mode on CPU #0 [ 0.050000] [usb_manager]: CONFIG_USB_SW_SUN4I_USB0_OTG [ 0.050000] [sw_hcd0]: usb host driver initialize........ [ 0.050000] [sw_udc]: udc_init: version 20080411 [ 0.050000] [sw_udc]: usb_vbase = 0xf1c13000 [ 0.050000] [sw_udc]: sram_vbase = 0xf1c00000 [ 0.050000] [sw_udc]: open_usb_clock [ 0.060000] udc->driver is null, udc is need not stop [ 0.060000] NET: Registered protocol family 2 [ 0.060000] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.060000] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.060000] TCP bind hash table entries: 65536 (order: 6, 262144 bytes) [ 0.060000] TCP: Hash tables configured (established 131072 bind 65536) [ 0.060000] TCP reno registered [ 0.060000] UDP hash table entries: 512 (order: 1, 8192 bytes) [ 0.060000] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) [ 0.060000] NET: Registered protocol family 1 [ 0.060000] RPC: Registered named UNIX socket transport module. [ 0.060000] RPC: Registered udp transport module. [ 0.060000] RPC: Registered tcp transport module. [ 0.060000] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.060000] Trying to unpack rootfs image as initramfs... [ 0.130000] Freeing initrd memory: 952K [ 0.130000] [pm]aw_pm_init! [ 0.130000] audit: initializing netlink socket (disabled) [ 0.130000] type=2000 audit(0.129:1): initialized [ 0.130000] highmem bounce pool size: 64 pages [ 0.130000] ashmem: initialized [ 0.140000] VFS: Disk quotas dquot_6.5.2 [ 0.140000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.140000] NTFS driver 2.1.30 [Flags: R/W]. [ 0.140000] fuse init (API version 7.16) [ 0.140000] msgmni has been set to 859 [ 0.150000] alg: No test for stdrng (krng) [ 0.150000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.150000] io scheduler noop registered [ 0.150000] io scheduler deadline registered [ 0.150000] io scheduler cfq registered (default) [ 0.150000] sunxi disp driver loaded (/dev/disp api 1.0) [ 0.150000] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.150000] [uart]: used uart info.: 0x05 [ 0.170000] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 1) is a U6_16550A [ 0.790000] console [ttyS0] enabled [ 0.800000] [uart]: serial probe 0, membase (null) irq 1 mapbase 0x01c28000 [ 0.820000] sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 3) is a U6_16550A [ 0.830000] [uart]: serial probe 2, membase (null) irq 3 mapbase 0x01c28800 [ 0.840000] G2D: drv_g2d_init [ 0.840000] G2D: g2dmem: g2d_start=58000000, g2d_size=1000000 [ 0.850000] G2D: head:d8000000,tail:d9000000 [ 0.850000] G2D: Module initialized.major:251 [ 0.860000] brd: module loaded [ 0.860000] loop: module loaded [ 0.870000] [NAND]nand driver, init. [ 0.870000] cmu_clk is 480 [ 0.870000] nand clk init end [ 0.870000] offset 0xc: 0x6141 [ 0.880000] offset 0x14: 0x8200000b [ 0.880000] [NAND] nand gpio_request [ 0.890000] [NAND] nand driver version: 0x2 0x9 [ 0.890000] nand interrupte register ok [ 0.890000] ret of NFC_ChangMode is 0 [ 0.900000] dma_hdle is 0 [ 0.900000] dma_hdle is 10000008 [ 0.900000] cmu_clk is 480 [ 0.910000] nand clk init end [ 0.910000] offset 0xc: 0x6141 [ 0.910000] offset 0x14: 0x82000007 [ 0.970000] The 0 disk name = DEVICE, class name = NAND, disk start = 0, disk size = 7979008 [ 0.980000] The 1 disk name = bootloader, type = 0, class name = DISK, disk size = 32768 [ 0.990000] The 2 disk name = env, type = 0, class name = DISK, disk size = 32768 [ 0.990000] The 3 disk name = boot, type = 0, class name = DISK, disk size = 65536 [ 1.000000] The 4 disk name = system, type = 0, class name = DISK, disk size = 1048576 [ 1.010000] The 5 disk name = data, type = 1, class name = DISK, disk size = 1048576 [ 1.020000] The 6 disk name = misc, type = 0, class name = DISK, disk size = 32768 [ 1.020000] The 7 disk name = recovery, type = 0, class name = DISK, disk size = 65536 [ 1.030000] The 8 disk name = cache, type = 0, class name = DISK, disk size = 262144 [ 1.040000] The 9 disk name = UDISK, type = 0, class name = DISK, disk size = 5357568 [ 1.050000] The 9 disk size = 5357568 [ 1.050000] part total count = 10 [ 1.060000] nand: unknown partition table [ 1.060000] nanda: [ 1.070000] nandb: unknown partition table [ 1.070000] nandc: unknown partition table [ 1.080000] nandd: unknown partition table [ 1.080000] nande: unknown partition table [ 1.090000] nandf: unknown partition table [ 1.100000] nandg: unknown partition table [ 1.100000] nandh: unknown partition table [ 1.110000] nandi: [ 1.110000] benn: nand probe enter [ 1.110000] [NAND]nand driver, ok. [ 1.120000] hello, sun4i_vibrator init [ 1.120000] sun4i_vibrator_init motor is not used in config [ 1.130000] sun4i gpio driver init [ 1.130000] sun4i_gpio_init script_parser_fetch "gpio_para" "gpio_used" error [ 1.140000] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP [ 1.140000] sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1 [ 1.150000] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 1.160000] sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc [ 1.170000] scsi0 : sw_ahci_platform [ 1.170000] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 56 [ 1.180000] Fixed MDIO Bus: probed [ 1.180000] tun: Universal TUN/TAP device driver, 1.6 [ 1.190000] tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 1.190000] wemac Ethernet Driver, V1.01 in file:/build/cubieboard/openbox/kernel/allwinner/commc [ 1.210000] [EMAC] ahb clk enable [ 1.210000] [EMAC] ahb gate clk: 0x2026141 [ 1.240000] emac MAC isn't valid! [ 1.240000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.250000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.250000] [sw-ehci1]: open clock [ 1.280000] [sw-ehci1]: Set USB Power ON [ 1.280000] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.290000] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 1 [ 1.290000] sw-ehci sw-ehci.1: irq 39, io mem 0xf1c14000 [ 1.320000] sw-ehci sw-ehci.1: USB 0.0 started, EHCI 1.00 [ 1.320000] hub 1-0:1.0: USB hub found [ 1.320000] hub 1-0:1.0: 1 port detected [ 1.330000] [sw-ohci1]: open clock [ 1.350000] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 1.360000] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 2 [ 1.370000] sw-ohci sw-ohci.1: irq 64, io mem 0xf1c14400 [ 1.430000] hub 2-0:1.0: USB hub found [ 1.430000] hub 2-0:1.0: 1 port detected [ 1.440000] [sw-ehci2]: open clock [ 1.460000] [sw-ehci2]: Set USB Power ON [ 1.460000] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.470000] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 3 [ 1.480000] sw-ehci sw-ehci.2: irq 40, io mem 0xf1c1c000 [ 1.500000] sw-ehci sw-ehci.2: USB 0.0 started, EHCI 1.00 [ 1.500000] hub 3-0:1.0: USB hub found [ 1.500000] hub 3-0:1.0: 1 port detected [ 1.510000] [sw-ohci2]: open clock [ 1.530000] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 1.540000] ata1: SATA link down (SStatus 0 SControl 300) [ 1.540000] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 4 [ 1.550000] sw-ohci sw-ohci.2: irq 65, io mem 0xf1c1c400 [ 1.620000] hub 4-0:1.0: USB hub found [ 1.620000] hub 4-0:1.0: 1 port detected [ 1.630000] Initializing USB Mass Storage driver... [ 1.630000] usbcore: registered new interface driver usb-storage [ 1.640000] USB Mass Storage support registered. [ 1.640000] usbcore: registered new interface driver ums-alauda [ 1.650000] usbcore: registered new interface driver ums-cypress [ 1.660000] usbcore: registered new interface driver ums-datafab [ 1.660000] usbcore: registered new interface driver ums_eneub6250 [ 1.670000] usbcore: registered new interface driver ums-freecom [ 1.670000] usbcore: registered new interface driver ums-isd200 [ 1.680000] usbcore: registered new interface driver ums-jumpshot [ 1.690000] usbcore: registered new interface driver ums-karma [ 1.690000] usbcore: registered new interface driver ums-onetouch [ 1.700000] usbcore: registered new interface driver ums-realtek [ 1.700000] usbcore: registered new interface driver ums-sddr09 [ 1.710000] usbcore: registered new interface driver ums-sddr55 [ 1.720000] usbcore: registered new interface driver ums-usbat [ 1.720000] ------print_msc_config----- [ 1.730000] vendor_id = 0x18d1 [ 1.730000] mass_storage_id = 0x1 [ 1.730000] adb_id = 0x2 [ 1.740000] usb_manufacturer_name = USB Developer [ 1.740000] usb_product_name = Android [ 1.750000] usb_serial_number = 20080411 [ 1.750000] msc_vendor_name = USB 2.0 [ 1.750000] msc_product_name = USB Flash Driver [ 1.760000] msc_release = 100 [ 1.760000] luns = 3 [ 1.770000] --------------------------- [ 1.770000] [sw_udc]: [sw_usb_udc]: binding gadget driver 'android_usb' [ 1.780000] [sw_udc]: alloc request: ep(0xc07daaf8, ep0, 64), req(0xe7bdbac0) [ 1.780000] [sw_udc]: sw_udc_pullup, is_on = 0 [ 1.790000] [sw_udc]: usbd_stop_work [ 1.790000] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 1.800000] android_usb gadget: Number of LUNs=3 [ 1.810000] lun0: LUN: removable file: (no medium) [ 1.810000] lun1: LUN: removable file: (no medium) [ 1.820000] lun2: LUN: removable file: (no medium) [ 1.820000] lun name: lun [ 1.820000] lun name: lun1 [ 1.830000] lun name: lun2 [ 1.830000] android_usb gadget: android_usb ready [ 1.830000] mousedev: PS/2 mouse device common for all mice [ 1.840000] [kpad]: sw keypad init [ 1.840000] sw keypad fetch keypad uning configuration failed [ 1.850000] keypad: cannot find using configuration, return without doing anything! [ 1.860000] input: sun4i-keyboard as /devices/virtual/input/input0 [ 1.860000] ==register_early_suspend = [ 1.870000] input: sun4i-ir as /devices/virtual/input/input1 [ 1.870000] IR Initial OK [ 1.870000] ==register_early_suspend = [ 1.880000] ===========================hv_keypad_init===================== [ 1.890000] ========HV Inital =================== [ 1.890000] tkey_fetch_sysconfig_para: tkey_unused. [ 1.890000] hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 [ 1.900000] sunxi RTC version 0.1 [ 1.910000] sunxi-rtc sunxi-rtc: sunxi_rtc_probe tmp_data = 380248073 [ 1.910000] sunxi-rtc sunxi-rtc: sunxi_rtc_gettime [ 1.920000] sunxi-rtc sunxi-rtc: read time 2010-1-1 0:6:59 [ 1.920000] using rtc device, rtc, for alarms [ 1.930000] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 [ 1.940000] i2c /dev entries driver [ 1.940000] !!! base_Addr = 0xe88d4c00 [ 1.940000] config i2c gpio with gpio_config api [ 1.950000] twi0, apb clock = 24000000 [ 1.950000] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected [ 1.960000] i2c i2c-0: Invalid probe address 0x00 [ 1.960000] I2C: i2c-0: AW16XX I2C adapter [ 1.970000] **********start************ [ 1.970000] 0x40 [ 1.970000] 0xf8 [ 1.980000] 0x28 [ 1.980000] 0x0 [ 1.980000] 0x0 [ 1.980000] **********end************ [ 1.980000] !!! base_Addr = 0xe88d6000 [ 1.990000] twi1, apb clock = 24000000 [ 1.990000] i2c i2c-1: Invalid probe address 0x00 [ 2.000000] I2C: i2c-1: AW16XX I2C adapter [ 2.000000] **********start************ [ 2.000000] 0x40 [ 2.010000] 0xf8 [ 2.010000] 0x58 [ 2.010000] 0x0 [ 2.010000] 0x0 [ 2.010000] **********end************ [ 2.020000] !!! base_Addr = 0xe88d8400 [ 2.020000] twi2, apb clock = 24000000 [ 2.030000] i2c i2c-2: Invalid probe address 0x00 [ 2.030000] I2C: i2c-2: AW16XX I2C adapter [ 2.030000] **********start************ [ 2.040000] 0x40 [ 2.040000] 0xf8 [ 2.040000] 0x58 [ 2.040000] 0x0 [ 2.050000] 0x0 [ 2.050000] **********end************ [ 2.050000] Linux video capture interface: v2.00 [ 2.060000] [cedar dev]: install start!!! [ 2.060000] [cedar dev]: install end!!! [ 2.060000] [ace_drv] start!!! [ 2.070000] [ace_drv] init end!!! [ 2.070000] [pa_drv] start!!! [ 2.070000] [pa_drv] init end!!! [ 2.080000] print_constraints: axp20_ldo1: 1300 mV [ 2.080000] print_constraints: axp20_ldo2: 1800 <--> 3300 mV at 3000 mV [ 2.090000] print_constraints: axp20_ldo3: 700 <--> 3500 mV at 2800 mV [ 2.100000] print_constraints: axp20_ldo4: 1250 <--> 3300 mV at 2800 mV [ 2.110000] print_constraints: axp20_buck2: 700 <--> 2275 mV at 1400 mV [ 2.110000] print_constraints: axp20_buck3: 700 <--> 3500 mV at 1250 mV [ 2.120000] print_constraints: axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV [ 2.130000] input: axp20-supplyer as /devices/platform/sun4i-i2c.0/i2c-0/0-0034/axp20-supplyer.22 [ 2.150000] sunxi_wdt: sunxi WatchDog Timer Driver v1.0 [ 2.160000] sunxi_wdt: initialized (timeout=23s, nowayout=0) [ 2.160000] device-mapper: uevent: version 1.0.3 [ 2.170000] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com [ 2.180000] cpuidle: using governor ladder [ 2.180000] cpuidle: using governor menu [ 2.190000] [mmc_pm]: no sdio card used in configuration [ 2.190000] [mmc]: sunximmc_init [ 2.200000] [mmc]: sunxi mmc controller using config : 0x9 [ 2.200000] [mmc]: sunxi-mmc.0: pdev->name: sunxi-mmc, pdev->id: 0 [ 2.210000] [mmc]: mmc 0 power off !! [ 2.210000] [mmc]: mmc0 Probe: base:0xe88e2000 irq:32 dma:0 pdes:0xe7040000, ret 0. [ 2.220000] [mmc]: sunxi-mmc.3: pdev->name: sunxi-mmc, pdev->id: 3 [ 2.220000] [mmc]: mmc 3 power off !! [ 2.230000] [mmc]: mmc3 Probe: base:0xe88e4000 irq:35 dma:0 pdes:0xe7044000, ret 0. [ 2.240000] usbcore: registered new interface driver usbhid [ 2.240000] usbhid: USB HID core driver [ 2.250000] logger: created 256K log 'log_main' [ 2.250000] logger: created 256K log 'log_events' [ 2.260000] logger: created 256K log 'log_radio' [ 2.260000] logger: created 256K log 'log_system' [ 2.270000] enter sun4i Audio codec!!! [ 2.270000] sun4i audio support initialized [ 2.270000] sun4i Audio codec successfully loaded.. [ 2.280000] asoc: sndhdmi <-> sun4i-hdmiaudio.0 mapping ok [ 2.290000] [sPDIF]sun4i-spdif cannot find any using configuration for controllers, return direc! [ 2.300000] [sPDIF]sndspdif cannot find any using configuration for controllers, return directly! [ 2.300000] [sPDIF]sun4i_sndspdif cannot find any using configuration for controllers, return di! [ 2.310000] [i2S]sun4i-i2s cannot find any using configuration for controllers, return directly! [ 2.320000] [i2S]sndi2s cannot find any using configuration for controllers, return directly! [ 2.330000] [i2S]sun4i_sndi2s cannot find any using configuration for controllers, return direct! [ 2.340000] ALSA device list: [ 2.340000] #0: sun4i-CODEC Audio Codec [ 2.350000] #1: sndhdmi [ 2.350000] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 2.360000] NF_TPROXY: Copyright © 2006-2007 BalaBit IT Ltd. [ 2.360000] IPv4 over IPv4 tunneling driver [ 2.370000] ip_tables: © 2000-2006 Netfilter Core Team [ 2.370000] TCP cubic registered [ 2.380000] Initializing XFRM netlink socket [ 2.380000] NET: Registered protocol family 10 [ 2.390000] ip6_tables: © 2000-2006 Netfilter Core Team [ 2.390000] IPv6 over IPv4 tunneling driver [ 2.400000] NET: Registered protocol family 17 [ 2.400000] NET: Registered protocol family 15 [ 2.410000] Bridge firewalling registered [ 2.410000] 802.1Q VLAN Support v1.8 [ 2.410000] [mmc_pm]: No sdio card, please check your config !! [ 2.420000] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 2.430000] registered taskstats version 1 [ 3.130000] regulator_init_complete: axp20_buck3: incomplete constraints, leaving on [ 3.130000] regulator_init_complete: axp20_buck2: incomplete constraints, leaving on [ 3.140000] regulator_init_complete: axp20_ldo4: incomplete constraints, leaving on [ 3.150000] regulator_init_complete: axp20_ldo3: incomplete constraints, leaving on [ 3.160000] regulator_init_complete: axp20_ldo2: incomplete constraints, leaving on [ 3.170000] ===========================goodix_ts_init===================== [ 3.170000] ctp_fetch_sysconfig_para. [ 3.180000] ctp_fetch_sysconfig_para: ctp_unused. [ 3.180000] goodix_ts_init: err. [ 3.180000] sunxi-rtc sunxi-rtc: sunxi_rtc_gettime [ 3.190000] sunxi-rtc sunxi-rtc: sunxi_rtc_gettime [ 3.190000] sunxi-rtc sunxi-rtc: read time 2010-1-1 0:7:0 [ 3.200000] sunxi-rtc sunxi-rtc: setting system clock to 2010-01-01 00:07:00 UTC (1262304420) [ 3.210000] Freeing init memory: 168K [ 3.270000] init: to sleep 1 seconds. [ 4.270000] init: has waken up. [ 4.270000] Warning: this sunxi disp driver will see significant redesign. [ 4.280000] Applications using /dev/disp directly will break. [ 4.290000] For more information visit: http://linux-sunxi.org/Sunxi_disp_driver [ 4.290000] disp: process 1 (init) has skipped the version handshake. [ 4.300000] init: [william] hdmistatus = 0! [ 4.300000] init: [william] tvstatus = 0! [ 4.310000] disp: process 1 (init) has skipped the version handshake. [ 4.310000] init: width = 1280 [ 4.320000] init: height = 720 [ 4.320000] init: s.st_size = 3686400 [ 4.340000] init: command 'loglevel' r=0 [ 4.350000] init: command 'export' r=0 [ 4.350000] init: command 'export' r=0 [ 4.350000] init: command 'export' r=0 [ 4.360000] init: command 'export' r=0 [ 4.360000] init: command 'export' r=0 [ 4.360000] init: command 'export' r=0 [ 4.370000] init: command 'export' r=0 [ 4.370000] init: command 'export' r=0 [ 4.380000] init: command 'export' r=0 [ 4.380000] init: command 'symlink' r=0 [ 4.380000] init: command 'symlink' r=0 [ 4.390000] init: command 'symlink' r=0 [ 4.390000] init: command 'mkdir' r=0 [ 4.400000] init: command 'mount' r=0 [ 4.400000] init: command 'mkdir' r=0 [ 4.400000] init: command 'mkdir' r=0 [ 4.410000] init: command 'mkdir' r=0 [ 4.410000] init: command 'mkdir' r=0 [ 4.410000] init: command 'mkdir' r=0 [ 4.420000] init: command 'mkdir' r=0 [ 4.420000] init: command 'mkdir' r=0 [ 4.420000] init: command 'mkdir' r=0 [ 4.430000] init: command 'mkdir' r=0 [ 4.430000] init: command 'mount' r=0 [ 4.440000] init: command 'mkdir' r=0 [ 4.440000] init: command 'mount' r=0 [ 4.440000] init: command 'write' r=0 [ 4.450000] init: command 'write' r=-2 [ 4.450000] init: command 'write' r=0 [ 4.450000] init: command 'write' r=0 [ 4.460000] init: command 'write' r=0 [ 4.460000] init: command 'write' r=-2 [ 4.470000] init: command 'write' r=0 [ 4.470000] init: command 'mkdir' r=0 [ 4.470000] init: command 'mount' r=0 [ 4.480000] init: command 'chown' r=0 [ 4.480000] init: command 'chown' r=0 [ 4.480000] init: command 'chmod' r=0 [ 4.490000] init: command 'write' r=-22 [ 4.490000] init: command 'mkdir' r=0 [ 4.500000] init: command 'chown' r=0 [ 4.500000] init: command 'chmod' r=0 [ 4.500000] init: command 'write' r=0 [ 4.510000] init: command 'mkdir' r=0 [ 4.510000] init: command 'chown' r=0 [ 4.510000] init: command 'chmod' r=0 [ 4.520000] init: command 'write' r=0 [ 4.520000] init: command 'chmod' r=0 [ 4.530000] init: processing action 0xd36b00 (fs) [ 4.540000] EXT4-fs (nandd): barriers disabled [ 4.560000] EXT4-fs (nandd): recovery complete [ 4.560000] EXT4-fs (nandd): mounted filesystem with ordered data mode. Opts: barrier=0 [ 4.570000] init: command 'mount' r=0 [ 4.570000] init: command 'wait' r=0 [ 4.590000] EXT4-fs (nande): barriers disabled [ 4.600000] EXT4-fs (nande): recovery complete [ 4.610000] EXT4-fs (nande): mounted filesystem with ordered data mode. Opts: barrier=0 [ 4.620000] init: command 'mount' r=0 [ 4.620000] init: command 'setupfs' r=0 [ 4.620000] init: do_umount: /data [ 4.640000] init: command 'umount' r=0 [ 4.840000] init: command 'exec' r=0 [ 4.950000] EXT4-fs (nande): barriers disabled [ 4.960000] EXT4-fs (nande): mounted filesystem with ordered data mode. Opts: barrier=0,journal_c [ 4.970000] init: command 'exec' r=0 [ 4.990000] EXT4-fs (nandh): barriers disabled [ 5.000000] EXT4-fs (nandh): recovery complete [ 5.010000] EXT4-fs (nandh): mounted filesystem with ordered data mode. Opts: barrier=0 [ 5.010000] init: command 'mount' r=0 [ 5.020000] init: command 'setupfs' r=0 [ 5.020000] init: do_umount: /cache [ 5.040000] init: command 'umount' r=0 [ 5.050000] init: command 'exec' r=0 [ 5.070000] EXT4-fs (nandh): barriers disabled [ 5.070000] EXT4-fs (nandh): mounted filesystem with ordered data mode. Opts: barrier=0,journal_c [ 5.090000] init: command 'exec' r=0 [ 5.090000] init: dont need format /dev/block/nandi [ 5.100000] init: command 'format_userdata' r=1 [ 5.100000] init: command 'export' r=0 [ 5.100000] init: dont need format /dev/block/nandi [ 5.110000] init: command 'format_userdata' r=1 [ 5.110000] init: command 'mkdir' r=0 [ 5.120000] init: command 'mount' r=0 [ 5.120000] init: processing action 0xd31398 (post-fs) [ 5.130000] init: command 'chown' r=0 [ 5.130000] init: command 'chmod' r=0 [ 5.140000] init: command 'chown' r=-2 [ 5.140000] init: command 'chmod' r=-2 [ 5.140000] init: command 'chown' r=0 [ 5.150000] init: command 'chmod' r=0 [ 5.150000] init: command 'chown' r=0 [ 5.160000] init: command 'chmod' r=0 [ 5.160000] init: command 'chown' r=0 [ 5.160000] init: command 'chmod' r=0 [ 5.170000] init: command 'mkdir' r=0 [ 5.170000] init: processing action 0xd31588 (post-fs-data) [ 5.180000] init: command 'chown' r=0 [ 5.180000] init: command 'chmod' r=0 [ 5.310000] init: command 'mkdir' r=0 [ 5.310000] init: command 'copy' r=-1 [ 5.440000] init: command 'chown' r=-2 [ 5.440000] init: command 'chmod' r=-2 [ 5.440000] init: command 'copy' r=-1 [ 5.450000] init: command 'chown' r=-2 [ 5.450000] init: command 'chmod' r=-2 [ 5.450000] init: command 'write' r=-2 [ 5.580000] init: command 'mkdir' r=0 [ 5.700000] init: command 'mkdir' r=0 [ 5.710000] init: command 'mkdir' r=0 [ 5.710000] init: command 'mkdir' r=0 [ 5.710000] init: command 'mkdir' r=0 [ 5.720000] init: command 'mkdir' r=0 [ 5.720000] init: command 'mkdir' r=0 [ 5.720000] init: command 'mkdir' r=0 [ 5.730000] init: command 'mkdir' r=0 [ 5.730000] init: command 'chmod' r=0 [ 5.740000] init: command 'mkdir' r=0 [ 5.740000] init: command 'chown' r=0 [ 5.740000] init: command 'mkdir' r=0 [ 5.750000] init: command 'chmod' r=0 [ 5.750000] init: command 'chmod' r=0 [ 5.760000] init: command 'chmod' r=0 [ 5.760000] init: command 'chmod' r=0 [ 5.760000] init: command 'chmod' r=0 [ 5.870000] init: command 'mkdir' r=0 [ 5.990000] init: command 'mkdir' r=0 [ 5.990000] init: command 'mkdir' r=0 [ 5.990000] init: command 'mkdir' r=0 [ 6.000000] init: command 'mkdir' r=0 [ 6.000000] init: command 'mkdir' r=0 [ 6.010000] init: command 'mkdir' r=0 [ 6.010000] init: command 'mkdir' r=0 [ 6.010000] init: command 'mkdir' r=0 [ 6.020000] init: command 'chown' r=0 [ 6.020000] init: command 'chmod' r=0 [ 6.020000] init: command 'mkdir' r=0 [ 6.030000] init: command 'mkdir' r=0 [ 6.030000] init: command 'chown' r=0 [ 6.040000] init: command 'chmod' r=0 [ 6.040000] init: command 'chown' r=0 [ 6.040000] init: command 'chmod' r=0 [ 6.050000] init: processing action 0xd37278 (property_service_init) [ 6.180000] init: Created socket '/dev/socket/property_service' with mode '666', user '0', group' [ 6.190000] init: command 'property_service_init' r=0 [ 6.200000] init: processing action 0xd372c0 (signal_init) [ 6.200000] init: command 'signal_init' r=0 [ 6.210000] init: processing action 0xd37308 (check_startup) [ 6.210000] init: command 'check_startup' r=0 [ 6.220000] init: processing action 0xd31d78 (boot) [ 6.230000] init: command 'chown' r=0 [ 6.240000] init: command 'chmod' r=0 [ 6.240000] init: command 'ifup' r=0 [ 6.240000] init: command 'hostname' r=0 [ 6.250000] init: command 'domainname' r=0 [ 6.250000] init: command 'setrlimit' r=0 [ 6.260000] init: command 'write' r=0 [ 6.260000] init: command 'write' r=0 [ 6.260000] init: command 'chown' r=0 [ 6.270000] init: command 'chmod' r=0 [ 6.270000] init: command 'chown' r=0 [ 6.280000] init: command 'chmod' r=0 [ 6.280000] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead. [ 6.290000] init: command 'write' r=0 [ 6.290000] init: command 'write' r=0 [ 6.300000] init: command 'write' r=0 [ 6.300000] init: command 'chown' r=-2 [ 6.300000] init: command 'chown' r=-2 [ 6.310000] init: command 'chown' r=-2 [ 6.310000] init: command 'chown' r=-2 [ 6.310000] init: command 'chown' r=-2 [ 6.320000] init: command 'chown' r=0 [ 6.320000] init: command 'chown' r=0 [ 6.330000] init: command 'chown' r=0 [ 6.330000] init: command 'chmod' r=0 [ 6.330000] init: command 'chmod' r=0 [ 6.340000] init: command 'chmod' r=0 [ 6.340000] init: command 'chown' r=0 [ 6.340000] init: command 'chmod' r=0 [ 6.350000] init: command 'chown' r=-2 [ 6.350000] init: command 'chown' r=-2 [ 6.350000] init: command 'chown' r=-2 [ 6.360000] init: command 'chown' r=-2 [ 6.360000] init: command 'chown' r=-2 [ 6.370000] init: command 'chown' r=-2 [ 6.370000] init: command 'chown' r=-2 [ 6.370000] init: command 'chown' r=-2 [ 6.380000] init: command 'chown' r=-2 [ 6.380000] init: command 'chown' r=-2 [ 6.390000] init: command 'chown' r=-2 [ 6.390000] init: command 'chown' r=-2 [ 6.390000] init: command 'chown' r=-2 [ 6.400000] init: command 'chown' r=-2 [ 6.400000] init: command 'chown' r=-2 [ 6.400000] init: command 'chown' r=-2 [ 6.410000] init: command 'chown' r=-2 [ 6.410000] init: command 'chown' r=-2 [ 6.420000] init: command 'chown' r=-2 [ 6.420000] init: command 'chown' r=0 [ 6.420000] init: command 'chown' r=0 [ 6.430000] init: command 'chown' r=0 [ 6.430000] init: command 'chown' r=0 [ 6.430000] init: command 'chown' r=0 [ 6.440000] init: command 'chown' r=0 [ 6.440000] init: command 'chown' r=0 [ 6.440000] init: command 'setprop' r=0 [ 6.450000] init: command 'setprop' r=0 [ 6.450000] init: command 'setprop' r=0 [ 6.460000] init: command 'setprop' r=0 [ 6.460000] init: command 'setprop' r=0 [ 6.460000] init: command 'setprop' r=0 [ 6.470000] init: command 'setprop' r=0 [ 6.470000] init: command 'setprop' r=0 [ 6.480000] init: starting 'console' [ 6.480000] init: starting 'servicemanager' [ 6.480000] init: starting 'vold' [ 6.490000] init: command 'class_start' r=0 [ 6.490000] init: Created socket '/dev/socket/vold' with mode '660', user '0', group '1009' [ 6.500000] init: starting 'netd' [ 6.510000] init: starting 'debuggerd' [ 6.510000] init: starting 'surfaceflinger' [ 6.520000] init: Created socket '/dev/socket/dnsproxyd' with mode '660', user '0', group '3003' [ 6.530000] init: starting 'zygote' [ 6.530000] init: starting 'drm' [ 6.540000] init: Created socket '/dev/socket/zygote' with mode '666', user '0', group '0' [ 6.550000] init: Created socket '/dev/socket/netd' with mode '660', user '0', group '1000' [ 6.550000] init: starting 'media' [ 6.560000] init: starting 'netshare' [ 6.570000] init: starting 'dbus' [ 6.570000] init: starting 'installd' [ 6.570000] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery' [ 6.580000] init: Created socket '/dev/socket/installd' with mode '600', user '1000', group '100' [ 6.590000] init: Created socket '/dev/socket/dbus' with mode '660', user '1002', group '1002' [ 6.600000] init: starting 'keystore' [ 6.610000] init: starting 'u3gmonitor' [ 6.610000] init: Created socket '/dev/socket/keystore' with mode '666', user '0', group '0' [ 6.620000] init: starting 'ril-daemon' [ 6.630000] init: starting 'securefile' [ 6.630000] init: starting 'isomountmanager' [ 6.640000] init: Created socket '/dev/socket/rild-debug' with mode '660', user '1001', group '1' [ 6.650000] init: command 'class_start' r=0 [ 6.650000] init: processing action 0xd36e38 (boot) [ 6.660000] init: Created socket '/dev/socket/rild' with mode '660', user '0', group '1001' [ 6.800000] UMP<2>: Inserting UMP device driver. Compiled: May 10 2013, time: 18:12:07 [ 6.810000] UMP<2>: Using OS memory backend, allocation limit: 134217728 [ 6.820000] UMP: UMP device driver loaded [ 6.820000] init: command 'insmod' r=0 [ 7.040000] mali: use config clk_div 4 [ 7.040000] mali: clk_div 4 [ 7.050000] Mali: mali clock set completed, clock is 240000000 Mhz [ 7.060000] mali: use config clk_div 4 [ 7.060000] mali: clk_div 4 [ 7.060000] Mali: mali clock set completed, clock is 240000000 Mhz [ 7.070000] Mali: Mali device driver loaded [ 7.080000] init: command 'insmod' r=0 [ 7.080000] init: processing action 0xd37350 (queue_propety_triggers) [ 7.090000] init: command 'queue_propety_triggers' r=0 [ 7.090000] init: processing action 0xd32780 (nonencrypted) [ 7.100000] init: command 'class_start' r=0 [ 7.100000] init: processing action 0xd32d68 (property:persist.sys.usb.config=*) [ 7.110000] init: command 'setprop' r=0 [ 7.110000] init: processing action 0xd32f38 (property:ro.debuggable=1) [ 7.120000] init: command 'start' r=0 [ 7.120000] init: processing action 0xd35f60 (property:sys.usb.config=mass_storage,adb) [ 7.130000] android_usb: already disabled [ 7.140000] init: command 'write' r=0 [ 7.140000] init: command 'write' r=0 [ 7.140000] init: command 'write' r=0 [ 7.150000] init: command 'write' r=0 [ 7.150000] ep_matches, wrn: endpoint already claimed, ep(0xc07dab38, 0xe7beac00, ep1-bulk) [ 7.160000] adb_bind_config [ 7.160000] ep_matches, wrn: endpoint already claimed, ep(0xc07dab38, 0xe7beac00, ep1-bulk) [ 7.170000] ep_matches, wrn: endpoint already claimed, ep(0xc07dab78, 0xe7beac00, ep2-bulk) [ 7.180000] ep_matches, wrn: endpoint already claimed, ep(0xc07dab38, 0xe7beac00, ep1-bulk) [ 7.190000] ep_matches, wrn: endpoint already claimed, ep(0xc07dab78, 0xe7beac00, ep2-bulk) [ 7.200000] ep_matches, wrn: endpoint already claimed, ep(0xc07dabb8, 0xe7bda800, ep3-bulk) [ 7.210000] [sw_udc]: alloc request: ep(0xc07dabf8, ep4-bulk, 512), req(0xe7264880) [ 7.220000] [sw_udc]: alloc request: ep(0xc07dabb8, ep3-bulk, 512), req(0xe72648c0) [ 7.220000] [sw_udc]: alloc request: ep(0xc07dabb8, ep3-bulk, 512), req(0xe7264900) [ 7.230000] [sw_udc]: alloc request: ep(0xc07dabb8, ep3-bulk, 512), req(0xe7264940) [ 7.240000] [sw_udc]: alloc request: ep(0xc07dabb8, ep3-bulk, 512), req(0xe7264980) [ 7.250000] [sw_udc]: sw_udc_pullup, is_on = 1 [ 7.260000] [sw_udc]: CONFIG_USB_GADGET_DUALSPEED [ 7.260000] [sw_udc]: usbd_start_work [ 7.270000] init: command 'write' r=0 [ 7.270000] init: starting 'adbd' [ 7.270000] init: command 'start' r=0 [ 7.280000] adb_open [ 7.280000] init: command 'setprop' r=0 [ 7.320000] [sw_udc]: IRQ: suspend [ 7.320000] [sw_udc]: ERR: usb speed is unkown [ 8.550000] UMP<2>: New session opened [ 8.780000] disp: process 112 (SurfaceFlinger) has skipped the version handshake. [ 8.920000] disp: process 112 (SurfaceFlinger) has skipped the version handshake. [ 8.930000] init: starting 'bootanim' [ 9.150000] UMP<2>: New session opened [ 15.870000] warning: `zygote' uses 32-bit capabilities (legacy support in use) [ 25.830000] disp: process 149 (er.ServerThread) has skipped the version handshake. [ 25.860000] request_suspend_state: wakeup (3->0) at 25860262159 (2010-01-01 00:07:23.143384495 U) [ 26.120000] wemac wemac.0: WARNING: no IRQ resource flags set. [ 26.290000] wemac wemac.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1 [ 26.390000] acc_open [ 26.390000] acc_release [ 26.600000] init: starting 'dhcpcd_eth' [ 27.910000] RTL871X: sw_usb_enable_hcd: usbc_num = 2 [ 27.910000] RTL871X: rtl8188eu driver version=v4.1.3_5938.20121130 [ 27.960000] RTL871X: build time: May 10 2013 18:12:20 [ 27.960000] usbcore: registered new interface driver rtl8188eu [ 30.800000] UMP<2>: New session opened [ 30.890000] init: processing action 0xd34648 (property:sys.boot_completed=1) [ 30.940000] init: starting 'preinstall' [ 30.940000] init: command 'start' r=0 [ 30.990000] init: waitpid returned pid 424, status = 00000000 [ 30.990000] init: process 'preinstall', pid 424 exited [ 32.080000] UMP<2>: New session opened [ 32.430000] RTL871X: +rtw_drv_halt [ 32.430000] usbcore: deregistering interface driver rtl8188eu [ 32.440000] RTL871X: sw_usb_disable_hcd: usbc_num = 2 [ 32.440000] RTL871X: -rtw_drv_halt [ 32.740000] init: service 'bootanim' is being killed [ 32.750000] init: waitpid returned pid 119, status = 00000009 [ 32.750000] init: process 'bootanim', pid 119 exited [ 32.760000] UMP<2>: Session closed [ 36.580000] eth0: no IPv6 routers present [ 56.890000] init: waitpid returned pid 202, status = 00000100 [ 56.920000] init: process 'dhcpcd_eth', pid 202 exited [ 60.410000] SysRq : Emergency Remount R/O [ 60.420000] EXT4-fs (nandd): re-mounted. Opts: (null) [ 60.440000] EXT4-fs (nande): re-mounted. Opts: (null) [ 60.460000] EXT4-fs (nandh): re-mounted. Opts: (null) [ 60.530000] Emergency Remount complete [ 61.380000] [sw-ohci2]: shutdown start [ 61.390000] [sw-ohci2]: close clock [ 61.390000] [sw-ohci2]: shutdown end [ 61.390000] [sw-ehci2]: shutdown start [ 61.400000] [sw-ehci2]: Set USB Power OFF [ 61.400000] [sw-ehci2]: close clock [ 61.410000] [sw-ehci2]: shutdown end [ 61.410000] [sw-ohci1]: shutdown start [ 61.410000] [sw-ohci1]: close clock [ 61.420000] [sw-ohci1]: shutdown end [ 61.420000] [sw-ehci1]: shutdown start [ 61.420000] [sw-ehci1]: Set USB Power OFF [ 61.430000] [sw-ehci1]: close clock [ 61.430000] [sw-ehci1]: shutdown end [ 61.440000] [NAND]shutdown [ 61.440000] nand try to shutdown 0 time And this is serial boot log when i boot it as described - boot legacy from sd after "boot without sd": Добро пожаловать в minicom 2.7 ПÐÐ ÐМЕТРЫ: I18n Дата компилÑции Jan 1 2014, 10:03:28. Port /dev/ttyUSB0, 02:22:15 Ðажмите CTRL-A Z Ð´Ð»Ñ Ð¿Ð¾Ð»ÑƒÑ‡ÐµÐ½Ð¸Ñ Ð¿Ð¾Ð´Ñказки по клавишам U-Boot SPL 2016.05-armbian (Jun 05 2016 - 17:59:37) DRAM: 1024 MiB CPU: 1008000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2016.05-armbian (Jun 05 2016 - 17:59:37 +0200) Allwinner Technology CPU: Allwinner A10 (SUN4I) Model: Cubietech Cubieboard I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c0b000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2447 bytes read in 182 ms (12.7 KiB/s) ## Executing script at 43100000 0 bytes read in 131 ms (0 Bytes/s) ** File not found /boot/.next ** ** Unrecognized filesystem type ** ** File not found .next ** 43716 bytes read in 336 ms (127 KiB/s) 3531631 bytes read in 417 ms (8.1 MiB/s) 5458664 bytes read in 620 ms (8.4 MiB/s) Kernel image @ 0x48000000 [ 0x000000 - 0x534ae8 ] ## Loading init Ramdisk from Legacy Image at 42000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3531567 Bytes = 3.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Starting kernel ... <6>Booting Linux on physical CPU 0 <6>Initializing cgroup subsys cpuset <6>Initializing cgroup subsys cpu <5>Linux version 3.4.112-sun4i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubu6 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: sun4i <6>Memory Reserved: <6> SYS : 0x43000000 - 0x4300ffff ( 64 kB) <6> LCD : 0x44000000 - 0x44ffffff ( 16 MB) Memory policy: ECC disabled, Data cache writeback <6>sunxi: Allwinner A10 revision C (AW1623/sun4i) detected. <7>On node 0 totalpages: 262144 <7>free_area_init_node: node 0, pgdat c0a470b8, node_mem_map d0000000 <7> DMA zone: 512 pages used for memmap <7> DMA zone: 0 pages reserved <7> DMA zone: 65024 pages, LIFO batch:15 <7> Normal zone: 1008 pages used for memmap <7> Normal zone: 128016 pages, LIFO batch:31 <7> HighMem zone: 528 pages used for memmap <7> HighMem zone: 67056 pages, LIFO batch:15 <7>pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768<c> <7>pcpu-alloc: <c>[0] <c>0 <c> Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096 <5>Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=e7 <6>PID hash table entries: 4096 (order: 2, 16384 bytes) <6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) <6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) <6>allocated 2097152 bytes of page_cgroup <6>please try 'cgroup_disable=memory' option if you don't want memory cgroups <6>Memory: 1024MB = 1024MB total <5>Memory: 1005228k/1005228k available, 43348k reserved, 270336K highmem <5>Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) lowmem : 0xc0000000 - 0xef800000 ( 760 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc09ac09c (9873 kB) .init : 0xc09ad000 - 0xc09e1000 ( 208 kB) .data : 0xc09e2000 - 0xc0a4f5c8 ( 438 kB) .bss : 0xc0a4f5ec - 0xc0c12800 (1805 kB) <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 <6>NR_IRQS:128 <6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms <6>Console: colour dummy device 80x30 <6>console [tty1] enabled <6>Calibrating delay loop... <c>1001.88 BogoMIPS (lpj=5009408) <6>pid_max: default: 32768 minimum: 301 <6>Mount-cache hash table entries: 512 <6>Initializing cgroup subsys cpuacct <6>Initializing cgroup subsys memory <6>Initializing cgroup subsys devices <6>Initializing cgroup subsys freezer <6>Initializing cgroup subsys blkio <6>Initializing cgroup subsys perf_event <6>CPU: Testing write buffer coherency: ok <6>hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available <6>Setting up static identity map for 0x40706978 - 0x407069d0 <6>devtmpfs: initialized <6>dummy: <6>NET: Registered protocol family 16 <6>DMA: preallocated 256 KiB pool for atomic coherent allocations <6>hw-breakpoint: debug architecture 0x4 unsupported. <6>Init eGon pin module V2.0 SOFTWINNER DMA Driver, (c) 2003-2004,2006 Simtec Electronics <6>Initialize DMAC OK <6>bio: create slab <bio-0> at 0 <6>sunxi_gpio driver init ver 1.3 <6>sunxi_gpio_probe can't find script.bin '[gpio_para]' 'gpio_used' <4>gpio-sunxi: probe of gpio-sunxi failed with error -4 <5>SCSI subsystem initialized <7>libata version 3.00 loaded. <6>usbcore: registered new interface driver usbfs <6>usbcore: registered new interface driver hub <6>usbcore: registered new device driver usb <6>Linux media interface: v0.10 <6>Linux video capture interface: v2.00 <6>Advanced Linux Sound Architecture Driver Version 1.0.25. <6>Switching to clocksource aw_64bits_counter <5>FS-Cache: Loaded <6>cfg80211: Calling CRDA to update world regulatory domain <6>CacheFiles: Loaded [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG [sw_hcd0]: usb host driver initialize........ [sw_hcd0]: open_usb_clock [sw_hcd0]: host_init_state = 0 [sw_hcd0]: platform is usb host [sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X) [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IR8 <6>sw_hcd_host0 sw_hcd_host0: sw_hcd host driver <6>sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 <6>hub 1-0:1.0: USB hub found <6>hub 1-0:1.0: 1 port detected wrn: hcd is not enable, need not start hcd [sw_hcd0]: sw_usb_host0_disable start -------sw_hcd0_soft_disconnect--------- is_on = 0, hcd0_set_vbus_cnt = 0 [sw_hcd_host0]: Set USB Power Off wrn: hcd is not enable, need not stop hcd [sw_hcd0]: close_usb_clock [sw_hcd0]: sw_usb_host0_disable end [sw_udc]: udc_init: version 20080411 <6>NET: Registered protocol family 2 <6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes) <6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes) <6>TCP bind hash table entries: 65536 (order: 6, 262144 bytes) <6>TCP: Hash tables configured (established 131072 bind 65536) <6>TCP: reno registered <6>UDP hash table entries: 512 (order: 1, 8192 bytes) <6>UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) <6>NET: Registered protocol family 1 <6>RPC: Registered named UNIX socket transport module. <6>RPC: Registered udp transport module. <6>RPC: Registered tcp transport module. <6>RPC: Registered tcp NFSv4.1 backchannel transport module. <6>Trying to unpack rootfs image as initramfs... <6>Freeing initrd memory: 3448K <6>audit: initializing netlink socket (disabled) <5>type=2000 audit(0.559:1): initialized highmem bounce pool size: 64 pages <5>VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) <6>squashfs: version 4.0 (2009/01/31) Phillip Lougher <5>NFS: Registering the id_resolver key type <6>NTFS driver 2.1.30 [Flags: R/W]. <6>fuse init (API version 7.18) <6>JFS: nTxBlock = 7880, nTxLock = 63042 <6>SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled <6>Btrfs loaded <6>msgmni has been set to 1442 <6>alg: No test for stdrng (krng) <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) <6>io scheduler noop registered <6>io scheduler deadline registered <6>io scheduler cfq registered (default) <6>sunxi disp driver loaded (/dev/disp api 1.0) <6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled <6>[uart]: used uart info.: 0x05 <6>[uart]: serial probe 0 irq 1 mapbase 0x01c28000 <6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 1) is a U6_16550A [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.112-sun4i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro6 [ 0.000000] Memory Reserved: [ 0.000000] SYS : 0x43000000 - 0x4300ffff ( 64 kB) [ 0.000000] LCD : 0x44000000 - 0x44ffffff ( 16 MB) [ 0.000000] sunxi: Allwinner A10 revision C (AW1623/sun4i) detected. [ 0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait 7 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 1005228k/1005228k available, 43348k reserved, 270336K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc09ac09c (9873 kB) [ 0.000000] .init : 0xc09ad000 - 0xc09e1000 ( 208 kB) [ 0.000000] .data : 0xc09e2000 - 0xc0a4f5c8 ( 438 kB) [ 0.000000] .bss : 0xc0a4f5ec - 0xc0c12800 (1805 kB) [ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS:128 [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.008695] Calibrating delay loop... 1001.88 BogoMIPS (lpj=5009408) [ 0.050271] pid_max: default: 32768 minimum: 301 [ 0.053858] Mount-cache hash table entries: 512 [ 0.057686] Initializing cgroup subsys cpuacct [ 0.061013] Initializing cgroup subsys memory [ 0.064431] Initializing cgroup subsys devices [ 0.067854] Initializing cgroup subsys freezer [ 0.071086] Initializing cgroup subsys blkio [ 0.074759] Initializing cgroup subsys perf_event [ 0.078310] CPU: Testing write buffer coherency: ok [ 0.085849] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available [ 0.091404] Setting up static identity map for 0x40706978 - 0x407069d0 [ 0.094234] devtmpfs: initialized [ 0.096825] dummy: [ 0.100400] NET: Registered protocol family 16 [ 0.106859] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.112368] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.115777] Init eGon pin module V2.0 [ 0.123278] Initialize DMAC OK [ 0.130426] bio: create slab <bio-0> at 0 [ 0.133812] sunxi_gpio driver init ver 1.3 [ 0.139879] sunxi_gpio_probe can't find script.bin '[gpio_para]' 'gpio_used' [ 0.144857] gpio-sunxi: probe of gpio-sunxi failed with error -4 [ 0.147867] SCSI subsystem initialized [ 0.155286] usbcore: registered new interface driver usbfs [ 0.159636] usbcore: registered new interface driver hub [ 0.163753] usbcore: registered new device driver usb [ 0.166813] Linux media interface: v0.10 [ 0.170416] Linux video capture interface: v2.00 [ 0.175922] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.181079] Switching to clocksource aw_64bits_counter [ 0.183052] FS-Cache: Loaded [ 0.188452] cfg80211: Calling CRDA to update world regulatory domain [ 0.190623] CacheFiles: Loaded [ 0.257979] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver [ 0.264696] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 [ 0.267879] hub 1-0:1.0: USB hub found [ 0.270780] hub 1-0:1.0: 1 port detected [ 0.304532] NET: Registered protocol family 2 [ 0.315978] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.322770] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.329992] TCP bind hash table entries: 65536 (order: 6, 262144 bytes) [ 0.336033] TCP: Hash tables configured (established 131072 bind 65536) [ 0.338247] TCP: reno registered [ 0.343040] UDP hash table entries: 512 (order: 1, 8192 bytes) [ 0.348298] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) [ 0.351781] NET: Registered protocol family 1 [ 0.356929] RPC: Registered named UNIX socket transport module. [ 0.360601] RPC: Registered udp transport module. [ 0.364265] RPC: Registered tcp transport module. [ 0.369709] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.374210] Trying to unpack rootfs image as initramfs... [ 0.562316] Freeing initrd memory: 3448K [ 0.567614] audit: initializing netlink socket (disabled) [ 0.571318] type=2000 audit(0.559:1): initialized [ 0.584310] VFS: Disk quotas dquot_6.5.2 [ 0.596039] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.600902] NFS: Registering the id_resolver key type [ 0.605025] NTFS driver 2.1.30 [Flags: R/W]. [ 0.608280] fuse init (API version 7.18) [ 0.612679] JFS: nTxBlock = 7880, nTxLock = 63042 [ 0.622412] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled [ 0.625751] Btrfs loaded [ 0.628577] msgmni has been set to 1442 [ 0.635434] alg: No test for stdrng (krng) [ 0.642012] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [ 0.645018] io scheduler noop registered [ 0.648252] io scheduler deadline registered [ 0.651945] io scheduler cfq registered (default) [ 0.656610] sunxi disp driver loaded (/dev/disp api 1.0) [ 0.662085] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.666238] [uart]: used uart info.: 0x05 [ 0.670828] [uart]: serial probe 0 irq 1 mapbase 0x01c28000 [ 0.696828] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 1) is a U6_16550A <6>console [ttyS0] enabled [ 1.278362] console [ttyS0] enabled <6>[uart]: serial probe 2 irq 3 mapbase 0x01c28800 [ 1.286568] [uart]: serial probe 2 irq 3 mapbase 0x01c28800 <6>sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 3) is a U6_16550A [ 1.318072] sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 3) is a U6_16550A <7>G2D: drv_g2d_init <6>G2D: Module initialized.major:250 [ 1.330664] G2D: Module initialized.major:250 <6>brd: module loaded [ 1.341137] brd: module loaded <6>loop: module loaded [ 1.348516] loop: module loaded [NAND] nand driver version: 0x2 0x9 <4>Dev Sunxi softw311 nand: part 1, start 32768, size 32768 [ 4.456357] Dev Sunxi softw311 nand: part 1, start 32768, size 32768 <4>Dev Sunxi softw311 nand: part 2, start 65536, size 32768 [ 4.468091] Dev Sunxi softw311 nand: part 2, start 65536, size 32768 <4>Dev Sunxi softw311 nand: part 3, start 98304, size 65536 [ 4.479767] Dev Sunxi softw311 nand: part 3, start 98304, size 65536 <4>Dev Sunxi softw311 nand: part 4, start 163840, size 1048576 [ 4.491696] Dev Sunxi softw311 nand: part 4, start 163840, size 1048576 <4>Dev Sunxi softw311 nand: part 5, start 1212416, size 1048576 [ 4.503971] Dev Sunxi softw311 nand: part 5, start 1212416, size 1048576 <4>Dev Sunxi softw311 nand: part 6, start 2260992, size 32768 [ 4.516159] Dev Sunxi softw311 nand: part 6, start 2260992, size 32768 <4>Dev Sunxi softw311 nand: part 7, start 2293760, size 65536 [ 4.528173] Dev Sunxi softw311 nand: part 7, start 2293760, size 65536 <4>Dev Sunxi softw311 nand: part 8, start 2359296, size 262144 [ 4.540274] Dev Sunxi softw311 nand: part 8, start 2359296, size 262144 <4>Dev Sunxi softw311 nand: part 9, start 2621440, size 5357568 [ 4.552548] Dev Sunxi softw311 nand: part 9, start 2621440, size 5357568 <6> nand: nand1 nand2 nand3 nand4 nand5 nand6 nand7 nand8 nand9 [ 4.564908] nand: nand1 nand2 nand3 nand4 nand5 nand6 nand7 nand8 nand9 [NAND]nand driver, ok. <6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP [ 4.581163] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP <6>ahci: SSS flag set, parallel bus scan disabled [ 4.592637] ahci: SSS flag set, parallel bus scan disabled <6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 4.605540] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode <6>sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc [ 4.620864] sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc <6>scsi0 : sw_ahci_platform [ 4.632003] scsi0 : sw_ahci_platform <6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 56 [ 4.642721] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 56 <6>bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 4.656877] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) <6>Fixed MDIO Bus: probed [ 4.667727] Fixed MDIO Bus: probed <6>sunxi_emac Using mii phy on PortA [ 4.674516] sunxi_emac Using mii phy on PortA <6>sunxi_emac Using MAC from SID: 02:82:01:c2:22:b2[ 4.693470] sunxi_emac Using MAC from SID: 022 [ 4.703907] PPP generic driver version 2.4.2 <6>PPP BSD Compression module registered [ 4.712208] PPP BSD Compression module registered <6>PPP Deflate Compression module registered [ 4.720939] PPP Deflate Compression module registered <6>PPP MPPE Compression module registered [ 4.731989] PPP MPPE Compression module registered <6>NET: Registered protocol family 24 [ 4.740299] NET: Registered protocol family 24 <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.750603] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 4.762345] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [sw-ehci1]: open clock [sw-ehci1]: Set USB Power ON <6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.799884] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 [ 4.813528] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 <6>sw-ehci sw-ehci.1: irq 39, io mem 0x01c14000 [ 4.824947] sw-ehci sw-ehci.1: irq 39, io mem 0x01c14000 <6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 [ 4.845458] sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 <6>hub 2-0:1.0: USB hub found [ 4.854021] hub 2-0:1.0: USB hub found <6>hub 2-0:1.0: 1 port detected [ 4.860661] hub 2-0:1.0: 1 port detected [sw-ohci1]: open clock <6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 4.893075] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 [ 4.906388] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 <6>sw-ohci sw-ohci.1: irq 64, io mem 0x01c14400 [ 4.917756] sw-ohci sw-ohci.1: irq 64, io mem 0x01c14400 <6>hub 3-0:1.0: USB hub found [ 4.988170] hub 3-0:1.0: USB hub found <6>hub 3-0:1.0: 1 port detected [ 4.994851] hub 3-0:1.0: 1 port detected [sw-ehci2]: open clock <6>ata1: SATA link down (SStatus 0 SControl 300) [ 5.015455] ata1: SATA link down (SStatus 0 SControl 300) [sw-ehci2]: Set USB Power ON <6>sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 5.040074] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 [ 5.053714] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 <6>sw-ehci sw-ehci.2: irq 40, io mem 0x01c1c000 [ 5.065140] sw-ehci sw-ehci.2: irq 40, io mem 0x01c1c000 <6>sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 [ 5.085452] sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 <6>hub 4-0:1.0: USB hub found [ 5.094056] hub 4-0:1.0: USB hub found <6>hub 4-0:1.0: 1 port detected [ 5.100693] hub 4-0:1.0: 1 port detected [sw-ohci2]: open clock <6>sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 5.133115] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 [ 5.146407] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 <6>sw-ohci sw-ohci.2: irq 65, io mem 0x01c1c400 [ 5.157761] sw-ohci sw-ohci.2: irq 65, io mem 0x01c1c400 <6>hub 5-0:1.0: USB hub found [ 5.228199] hub 5-0:1.0: USB hub found <6>hub 5-0:1.0: 1 port detected [ 5.234868] hub 5-0:1.0: 1 port detected <6>Initializing USB Mass Storage driver... [ 5.242885] Initializing USB Mass Storage driver... <6>usbcore: registered new interface driver usb-storage [ 5.252894] usbcore: registered new interface driver usb-storage <6>USB Mass Storage support registered. [ 5.262487] USB Mass Storage support registered. <6>usbcore: registered new interface driver ums-alauda [ 5.272025] usbcore: registered new interface driver ums-alauda <6>usbcore: registered new interface driver ums-cypress [ 5.282947] usbcore: registered new interface driver ums-cypress <6>usbcore: registered new interface driver ums-datafab [ 5.293953] usbcore: registered new interface driver ums-datafab <6>usbcore: registered new interface driver ums_eneub6250 [ 5.305129] usbcore: registered new interface driver ums_eneub6250 <6>usbcore: registered new interface driver ums-freecom [ 5.316307] usbcore: registered new interface driver ums-freecom <6>usbcore: registered new interface driver ums-isd200 [ 5.327229] usbcore: registered new interface driver ums-isd200 <6>usbcore: registered new interface driver ums-jumpshot [ 5.338295] usbcore: registered new interface driver ums-jumpshot <6>usbcore: registered new interface driver ums-karma [ 5.349220] usbcore: registered new interface driver ums-karma <6>usbcore: registered new interface driver ums-onetouch [ 5.360138] usbcore: registered new interface driver ums-onetouch <6>usbcore: registered new interface driver ums-realtek [ 5.371244] usbcore: registered new interface driver ums-realtek <6>usbcore: registered new interface driver ums-sddr09 [ 5.382162] usbcore: registered new interface driver ums-sddr09 <6>usbcore: registered new interface driver ums-sddr55 [ 5.392993] usbcore: registered new interface driver ums-sddr55 <6>usbcore: registered new interface driver ums-usbat [ 5.403727] usbcore: registered new interface driver ums-usbat <6>mousedev: PS/2 mouse device common for all mice [ 5.414234] mousedev: PS/2 mouse device common for all mice ===========================hv_keypad_init===================== ========HV Inital =================== <3>tkey_fetch_sysconfig_para: tkey_unused. [ 5.432786] tkey_fetch_sysconfig_para: tkey_unused. hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 <6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 [ 5.450507] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 <6>i2c /dev entries driver [ 5.459105] i2c /dev entries driver config i2c gpio with gpio_config api <6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected [ 5.471697] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected <6>axp_mfd 0-0034: AXP internal temperature monitoring enabled [ 5.482845] axp_mfd 0-0034: AXP internal temperature monitoring enabled <4>i2c i2c-0: Invalid probe address 0x00 [ 5.493780] i2c i2c-0: Invalid probe address 0x00 <6>I2C: i2c-0: AW16XX I2C adapter [ 5.501561] I2C: i2c-0: AW16XX I2C adapter config i2c gpio with gpio_config api <4>i2c i2c-1: Invalid probe address 0x00 [ 5.512892] i2c i2c-1: Invalid probe address 0x00 <6>I2C: i2c-1: AW16XX I2C adapter [ 5.520670] I2C: i2c-1: AW16XX I2C adapter config i2c gpio with gpio_config api <4>i2c i2c-2: Invalid probe address 0x00 [ 5.531967] i2c i2c-2: Invalid probe address 0x00 <6>I2C: i2c-2: AW16XX I2C adapter [ 5.539743] I2C: i2c-2: AW16XX I2C adapter [cedar dev]: not installed! ve_mem_reserve=0 [tt]----- avs_dev driver load... ---- [tt]----- register iomem ---- [tt]--- avs_dev driver load ok!! ----- [ace_drv] start!!! [ace_drv] init end!!! [pa_drv] start!!! [pa_drv] init end!!! <6>axp20_ldo1: 1300 mV [ 5.568594] axp20_ldo1: 1300 mV <6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV [ 5.576998] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV <6>axp20_ldo3: 700 <--> 3500 mV at 2800 mV [ 5.587322] axp20_ldo3: 700 <--> 3500 mV at 2800 mV <6>axp20_ldo4: 1250 <--> 3300 mV at 2800 mV [ 5.597831] axp20_ldo4: 1250 <--> 3300 mV at 2800 mV <6>axp20_buck2: 700 <--> 2275 mV at 1400 mV [ 5.608024] axp20_buck2: 700 <--> 2275 mV at 1400 mV <3>somebody is trying to set dcdc3 range to (1250000, 1250000) uV [ 5.619549] somebody is trying to set dcdc3 range to (1250000, 1250000) uV <3>but we keep dcdc3 = 1250000 uV from the bootloader [ 5.631468] but we keep dcdc3 = 1250000 uV from the bootloader <6>axp20_buck3: 700 <--> 3500 mV at 1250 mV [ 5.641558] axp20_buck3: 700 <--> 3500 mV at 1250 mV <6>axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV [ 5.651440] axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV <6>input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/inpu0 [ 5.666125] input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.20 <4>axp20_ldo2: Failed to create debugfs directory [ 5.694222] axp20_ldo2: Failed to create debugfs directory incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) <6>device-mapper: uevent: version 1.0.3 [ 5.766538] device-mapper: uevent: version 1.0.3 <6>device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 5.778836] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com <6>device-mapper: multipath: version 1.3.2 loaded [ 5.792022] device-mapper: multipath: version 1.3.2 loaded <6>device-mapper: multipath round-robin: version 1.0.0 loaded [ 5.803027] device-mapper: multipath round-robin: version 1.0.0 loaded <6>device-mapper: multipath queue-length: version 0.1.0 loaded [ 5.815132] device-mapper: multipath queue-length: version 0.1.0 loaded <6>device-mapper: multipath service-time: version 0.2.0 loaded [ 5.827321] device-mapper: multipath service-time: version 0.2.0 loaded <6>cpuidle: using governor ladder [ 5.837141] cpuidle: using governor ladder <6>cpuidle: using governor menu [ 5.844133] cpuidle: using governor menu <6>[mmc-msg] sw_mci_init [ 5.850354] [mmc-msg] sw_mci_init <6>[mmc-msg] MMC host used card: 0xb, boot card: 0x0, io_card 8 [ 5.859465] [mmc-msg] MMC host used card: 0xb, boot card: 0x0, io_card 8 <6>[mmc-msg] sdc0 set round clock 400000, src 24000000 [ 5.871389] [mmc-msg] sdc0 set round clock 400000, src 24000000 <6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 5.885521] [mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dB <6>[mmc-msg] sdc0 Probe: base:0xf1c0f000 irq:32 sg_cpu:f05cf000(4fc00000) ret 0. [ 5.902764] [mmc-msg] sdc0 Probe: base:0xf1c0f000 irq:32 sg_cpu:f05cf000(4fc00000) ret 0. <6>[mmc-msg] sdc1 set round clock 400000, src 24000000 [ 5.915901] [mmc-msg] sdc1 set round clock 400000, src 24000000 <6>[mmc-msg] sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 5.929959] [mmc-msg] sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dB <6>[mmc-msg] sdc1 Probe: base:0xf1c10000 irq:33 sg_cpu:f05d1000(4fc01000) ret 0. [ 5.947181] [mmc-msg] sdc1 Probe: base:0xf1c10000 irq:33 sg_cpu:f05d1000(4fc01000) ret 0. <6>[mmc-msg] sdc3 set round clock 400000, src 24000000 [ 5.960312] [mmc-msg] sdc3 set round clock 400000, src 24000000 <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 5.974360] [mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dB <6>[mmc-msg] sdc3 Probe: base:0xf1c12000 irq:35 sg_cpu:f05d3000(4fc02000) ret 0. [ 5.991579] [mmc-msg] sdc3 Probe: base:0xf1c12000 irq:35 sg_cpu:f05d3000(4fc02000) ret 0. <6>sunxi_leds driver init [ 6.002195] sunxi_leds driver init <7>Registered led device: green:ph20:led1 <7>Registered led device: blue:ph21:led2 <6>ledtrig-cpu: registered to indicate activity on CPUs [ 6.018333] ledtrig-cpu: registered to indicate activity on CPUs <6>usbcore: registered new interface driver usbhid [ 6.029347] usbcore: registered new interface driver usbhid <6>usbhid: USB HID core driver [ 6.037732] usbhid: USB HID core driver <6>ashmem: initialized [ 6.044074] ashmem: initialized <6>logger: created 256K log 'log_main' [ 6.050808] logger: created 256K log 'log_main' <6>logger: created 256K log 'log_events' [ 6.059111] logger: created 256K log 'log_events' <6>logger: created 256K log 'log_radio' [ 6.067513] logger: created 256K log 'log_radio' <6>logger: created 256K log 'log_system' [ 6.075895] logger: created 256K log 'log_system' <6>IPv4 over IPv4 tunneling driver [ 6.085468] IPv4 over IPv4 tunneling driver <6>TCP: bic registered [ 6.092210] TCP: bic registered <6>TCP: cubic registered [ 6.097695] TCP: cubic registered <6>TCP: westwood registered [ 6.103537] TCP: westwood registered <6>TCP: highspeed registered [ 6.109741] TCP: highspeed registered <6>TCP: hybla registered [ 6.115684] TCP: hybla registered <6>TCP: htcp registered [ 6.121176] TCP: htcp registered <6>TCP: vegas registered [ 6.126681] TCP: vegas registered <6>TCP: veno registered [ 6.132174] TCP: veno registered <6>TCP: scalable registered [ 6.137940] TCP: scalable registered <6>TCP: lp registered [ 6.143533] TCP: lp registered <6>TCP: yeah registered [ 6.148765] TCP: yeah registered <6>TCP: illinois registered [ 6.154530] TCP: illinois registered <6>Initializing XFRM netlink socket [ 6.161322] Initializing XFRM netlink socket <6>NET: Registered protocol family 10 [ 6.169482] NET: Registered protocol family 10 <6>NET: Registered protocol family 17 [ 6.178196] NET: Registered protocol family 17 <6>NET: Registered protocol family 15 [ 6.186100] NET: Registered protocol family 15 <5>Registering the dns_resolver key type [ 6.194236] Registering the dns_resolver key type <6>VFP support v0.3: [ 6.201104] VFP support v0.3: implementor 41 architecture 3 part 30 variant3 implementor 41 architecture 3 part 30 variant c rev 3 <5>Registering SWP/SWPB emulation handler [ 6.217348] Registering SWP/SWPB emulation handler <4>axp20_buck2: Failed to create debugfs directory [ 6.226701] axp20_buck2: Failed to create debugfs directory <6>registered taskstats version 1 [ 6.236238] registered taskstats version 1 <6>I2C: i2c-3: HDMI I2C adapter [ 6.324890] I2C: i2c-3: HDMI I2C adapter <6>disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0 [ 6.357728] disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0 <6>[mmc-msg] mmc 0 detect change, present 1 [ 6.879956] [mmc-msg] mmc 0 detect change, present 1 <6>[mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.388987] [mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dtB <6>[mmc-msg] sdc0 power on [ 7.423513] [mmc-msg] sdc0 power on [ccmu] set sdc0 reset status to 0 failed! <3>[mmc-err] Failed to release sdc0 reset [ 7.434506] [mmc-err] Failed to release sdc0 reset <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.479404] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR1B <6>[mmc-msg] sdc0 set round clock 400000, src 24000000 [ 7.530927] [mmc-msg] sdc0 set round clock 400000, src 24000000 <3>[mmc-err] smc 0 err, cmd 52, RTO [ 7.616708] [mmc-err] smc 0 err, cmd 52, RTO <3>[mmc-err] smc 0 err, cmd 52, RTO [ 7.625213] [mmc-err] smc 0 err, cmd 52, RTO <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.637914] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR1B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.681764] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR1B <3>[mmc-err] smc 0 err, cmd 5, RTO [ 7.716405] [mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO [ 7.724714] [mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO [ 7.733019] [mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO [ 7.741342] [mmc-err] smc 0 err, cmd 5, RTO <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.754591] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR1B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.789402] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR1B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.836735] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR1B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B [ 7.912178] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25B <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B [ 7.949488] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDRB <6>[mmc-msg] sdc0 set round clock 43636363, src 480000000 [ 7.986224] [mmc-msg] sdc0 set round clock 43636363, src 480000000 <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B [ 8.064548] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDRB <6>mmc0: new high speed SDHC card at address 0007 [ 8.095503] mmc0: new high speed SDHC card at address 0007 <6>mmcblk0: mmc0:0007 SD08G 7.42 GiB [ 8.129673] mmcblk0: mmc0:0007 SD08G 7.42 GiB <6> mmcblk0: p1 [ 8.144259] mmcblk0: p1 <6>Console: switching to colour frame buffer device 240x67 [ 8.181297] Console: switching to colour frame buffer device 240x67 <4>axp20_buck3: incomplete constraints, leaving on [ 8.223888] axp20_buck3: incomplete constraints, leaving on <4>axp20_buck2: incomplete constraints, leaving on [ 8.234372] axp20_buck2: incomplete constraints, leaving on <4>axp20_ldo4: incomplete constraints, leaving on [ 8.244797] axp20_ldo4: incomplete constraints, leaving on <4>axp20_ldo3: incomplete constraints, leaving on [ 8.255098] axp20_ldo3: incomplete constraints, leaving on <4>axp20_ldo2: incomplete constraints, leaving on [ 8.265387] axp20_ldo2: incomplete constraints, leaving on <6>console [netcon0] enabled [ 8.274063] console [netcon0] enabled <6>netconsole: network logging started [ 8.281288] netconsole: network logging started <3>otg_wakelock_init: No USB transceiver found [ 8.290143] otg_wakelock_init: No USB transceiver found <6>ALSA device list: [ 8.297496] ALSA device list: <6> #0: sunxi-CODEC Audio Codec [ 8.303581] #0: sunxi-CODEC Audio Codec <6>Freeing init memory: 208K [ 8.310977] Freeing init memory: 208K <30>systemd-udevd[86]: starting version 215 [ 8.365681] systemd-udevd[86]: starting version 215 <6>EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 11.150534] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) <30>systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTS) [ 11.601241] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT) <30>systemd[1]: Detected architecture 'arm'. [ 11.619623] systemd[1]: Detected architecture 'arm'. <30>systemd[1]: Set hostname to <cubieboard>. [ 11.642896] systemd[1]: Set hostname to <cubieboard>. <28>systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-. [ 12.159388] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Un. <30>systemd[1]: Expecting device dev-ttyS0.device... [ 12.183810] systemd[1]: Expecting device dev-ttyS0.device... <30>systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 12.197408] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. <30>systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 12.212368] systemd[1]: Started Forward Password Requests to Wall Directory Watch. <30>systemd[1]: Starting Remote File Systems (Pre). [ 12.237431] systemd[1]: Starting Remote File Systems (Pre). <30>systemd[1]: Reached target Remote File Systems (Pre). [ 12.280826] systemd[1]: Reached target Remote File Systems (Pre). <30>systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 12.321061] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. <30>systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 12.363408] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. <30>systemd[1]: Starting Paths. [ 12.396360] systemd[1]: Starting Paths. <30>systemd[1]: Reached target Paths. [ 12.474574] systemd[1]: Reached target Paths. <30>systemd[1]: Starting Encrypted Volumes. [ 12.504433] systemd[1]: Starting Encrypted Volumes. <30>systemd[1]: Reached target Encrypted Volumes. [ 12.557751] systemd[1]: Reached target Encrypted Volumes. <30>systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. [ 12.593253] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. <30>systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 12.667610] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount. <30>systemd[1]: Starting Swap. [ 12.702749] systemd[1]: Starting Swap. <30>systemd[1]: Reached target Swap. [ 12.755943] systemd[1]: Reached target Swap. <30>systemd[1]: Starting Root Slice. [ 12.785895] systemd[1]: Starting Root Slice. <30>systemd[1]: Created slice Root Slice. [ 12.839006] systemd[1]: Created slice Root Slice. <30>systemd[1]: Starting User and Session Slice. [ 12.870043] systemd[1]: Starting User and Session Slice. <30>systemd[1]: Created slice User and Session Slice. [ 12.924795] systemd[1]: Created slice User and Session Slice. <30>systemd[1]: Starting Delayed Shutdown Socket. [ 12.966721] systemd[1]: Starting Delayed Shutdown Socket. <30>systemd[1]: Listening on Delayed Shutdown Socket. [ 13.021239] systemd[1]: Listening on Delayed Shutdown Socket. <30>systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 13.054379] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. <30>systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 13.140509] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. <30>systemd[1]: Starting Journal Socket (/dev/log). [ 13.216048] systemd[1]: Starting Journal Socket (/dev/log). <30>systemd[1]: Listening on Journal Socket (/dev/log). [ 13.306951] systemd[1]: Listening on Journal Socket (/dev/log). <30>systemd[1]: Starting udev Control Socket. [ 13.339197] systemd[1]: Starting udev Control Socket. <30>systemd[1]: Listening on udev Control Socket. [ 13.394514] systemd[1]: Listening on udev Control Socket. <30>systemd[1]: Starting udev Kernel Socket. [ 13.426607] systemd[1]: Starting udev Kernel Socket. <30>systemd[1]: Listening on udev Kernel Socket. [ 13.481990] systemd[1]: Listening on udev Kernel Socket. <30>systemd[1]: Starting Journal Socket. [ 13.513678] systemd[1]: Starting Journal Socket. <30>systemd[1]: Listening on Journal Socket. [ 13.579102] systemd[1]: Listening on Journal Socket. <30>systemd[1]: Starting System Slice. [ 13.610517] systemd[1]: Starting System Slice. <30>systemd[1]: Created slice System Slice. [ 13.665498] systemd[1]: Created slice System Slice. <30>systemd[1]: Started File System Check on Root Device. [ 13.698296] systemd[1]: Started File System Check on Root Device. <30>systemd[1]: Starting system-serial\x2dgetty.slice. [ 13.732012] systemd[1]: Starting system-serial\x2dgetty.slice. <30>systemd[1]: Created slice system-serial\x2dgetty.slice. [ 13.789633] systemd[1]: Created slice system-serial\x2dgetty.slice. <30>systemd[1]: Starting system-getty.slice. [ 13.822502] systemd[1]: Starting system-getty.slice. <30>systemd[1]: Created slice system-getty.slice. [ 13.888017] systemd[1]: Created slice system-getty.slice. <30>systemd[1]: Starting Increase datagram queue length... [ 13.921266] systemd[1]: Starting Increase datagram queue length... <30>systemd[1]: Starting Restore / save the current clock... [ 13.984111] systemd[1]: Starting Restore / save the current clock... <30>systemd[1]: Mounted Huge Pages File System. [ 14.106240] systemd[1]: Mounted Huge Pages File System. <30>systemd[1]: Starting udev Coldplug all Devices... [ 14.145293] systemd[1]: Starting udev Coldplug all Devices... <30>systemd[1]: Started Set Up Additional Binary Formats. [ 14.257299] systemd[1]: Started Set Up Additional Binary Formats. <30>systemd[1]: Mounting POSIX Message Queue File System... [ 14.297321] systemd[1]: Mounting POSIX Message Queue File System... <30>systemd[1]: Mounting Debug File System... [ 14.352237] systemd[1]: Mounting Debug File System... <30>systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 14.391233] systemd[1]: Starting Create list of required static device nodes for the current ker. <30>systemd[1]: Starting Load Kernel Modules... [ 14.439651] systemd[1]: Starting Load Kernel Modules... <30>systemd[1]: Starting LSB: Set keymap... [ 14.470850] systemd[1]: Starting LSB: Set keymap... <30>systemd[1]: Starting Slices. [ 14.517117] systemd[1]: Starting Slices. <6>Bluetooth: Core ver 2.16 <6>NET: Registered protocol family 31 [ 14.550747] Bluetooth: Core ver 2.16 [ 14.554246] NET: Registered protocol family 31 <6>Bluetooth: HCI device and connection manager initialized <6>Bluetooth: HCI socket layer initialized <6>Bluetooth: L2CAP socket layer initialized <6>Bluetooth: SCO socket layer initialized [ 14.583638] Bluetooth: HCI device and connection manager initialized [ 14.587507] Bluetooth: HCI socket layer initialized [ 14.591509] Bluetooth: L2CAP socket layer initialized [ 14.595379] Bluetooth: SCO socket layer initialized <30>systemd[1]: Reached target Slices. [ 14.648373] systemd[1]: Reached target Slices. <6>Bluetooth: HCI UART driver ver 2.2 <6>Bluetooth: HCI H4 protocol initialized [ 14.668115] Bluetooth: HCI UART driver ver 2.2 [ 14.671876] Bluetooth: HCI H4 protocol initialized <6>Bluetooth: HCI BCSP protocol initialized <6>Bluetooth: HCILL protocol initialized <6>Bluetooth: HCIATH3K protocol initialized [ 14.704201] Bluetooth: HCI BCSP protocol initialized [ 14.707882] Bluetooth: HCILL protocol initialized [ 14.711796] Bluetooth: HCIATH3K protocol initialized <30>systemd[1]: Mounted Debug File System. [ 14.751379] systemd[1]: Mounted Debug File System. <6>Bluetooth: RFCOMM TTY layer initialized <6>Bluetooth: RFCOMM socket layer initialized <6>Bluetooth: RFCOMM ver 1.11 [ 14.774949] Bluetooth: RFCOMM TTY layer initialized [ 14.779067] Bluetooth: RFCOMM socket layer initialized [ 14.781770] Bluetooth: RFCOMM ver 1.11 <30>systemd[1]: Mounted POSIX Message Queue File System. [ 14.832800] systemd[1]: Mounted POSIX Message Queue File System. <6>Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 14.854968] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 <30>systemd[1]: Started Increase datagram queue length. [ 14.878743] systemd[1]: Started Increase datagram queue length. <6>input: sunxi-ir as /devices/virtual/input/input1 [ 14.899507] input: sunxi-ir as /devices/virtual/input/input1 IR Initial OK <30>systemd[1]: Started Restore / save the current clock. [ 14.925935] systemd[1]: Started Restore / save the current clock. [spi]: sw spi init !! [spi]: Found 0 spi devices in config files [spi]: boards num modalias max_spd_hz bus_num cs mode <30>systemd[1]: Started Create list of required static device nodes for the current kernel. [ 14.989297] systemd[1]: Started Create list of required static device nodes for the current kern. <4>spi: cannot find any using configuration for all 4 spi controllers, return d! [ 15.014711] spi: cannot find any using configuration for all 4 spi controlle! <30>systemd[1]: Started LSB: Set keymap. [ 15.066141] systemd[1]: Started LSB: Set keymap. <30>systemd[1]: Started Load Kernel Modules. [ 15.095481] systemd[1]: Started Load Kernel Modules. <30>systemd[1]: Started udev Coldplug all Devices. [ 15.120219] systemd[1]: Started udev Coldplug all Devices. <30>systemd[1]: Time has been changed [ 15.142817] systemd[1]: Time has been changed <30>systemd[1]: Mounting FUSE Control File System... [ 15.159242] systemd[1]: Mounting FUSE Control File System... <30>systemd[1]: Starting Apply Kernel Variables... [ 15.186011] systemd[1]: Starting Apply Kernel Variables... <30>systemd[1]: Mounting Configuration File System... [ 15.222076] systemd[1]: Mounting Configuration File System... <30>systemd[1]: Starting Create Static Device Nodes in /dev... [ 15.259125] systemd[1]: Starting Create Static Device Nodes in /dev... <30>systemd[1]: Starting Syslog Socket. [ 15.294736] systemd[1]: Starting Syslog Socket. <30>systemd[1]: Listening on Syslog Socket. [ 15.327125] systemd[1]: Listening on Syslog Socket. <30>systemd[1]: Starting Journal Service... [ 15.343924] systemd[1]: Starting Journal Service... <30>systemd[1]: Started Journal Service. [ 15.395429] systemd[1]: Started Journal Service. <30>systemd-udevd[166]: starting version 215 [ 15.545193] systemd-udevd[166]: starting version 215 <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 23.448947] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro <46>systemd-journald[165]: Received request to flush runtime journal from PID 1 [ 23.770437] systemd-journald[165]: Received request to flush runtime journal from PID 1 <6>sunxi_emac sunxi_emac.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1 [ 24.421977] sunxi_emac sunxi_emac.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1 <7>eth0: no IPv6 routers present Debian GNU/Linux 8 cubieboard ttyS0 cubieboard login: <30>systemd-shutdown[1]: Sending SIGTERM to remaining processes... [ 54.277459] systemd-shutdown[1]: Sending SIGTERM to remaining processes... <46>systemd-journald[165]: Received SIGTERM from PID 1 (systemd-shutdow). [ 54.311178] systemd-journald[165]: Received SIGTERM from PID 1 (systemd-shutdow). <30>systemd-shutdown[1]: Sending SIGKILL to remaining processes... [ 54.343947] systemd-shutdown[1]: Sending SIGKILL to remaining processes... <30>systemd-shutdown[1]: Unmounting file systems. [ 54.372986] systemd-shutdown[1]: Unmounting file systems. <30>systemd-shutdown[1]: Unmounting /sys/kernel/config. [ 54.394660] systemd-shutdown[1]: Unmounting /sys/kernel/config. <30>systemd-shutdown[1]: Unmounting /sys/fs/fuse/connections. [ 54.411528] systemd-shutdown[1]: Unmounting /sys/fs/fuse/connections. <30>systemd-shutdown[1]: Unmounting /sys/kernel/debug. [ 54.435638] systemd-shutdown[1]: Unmounting /sys/kernel/debug. <30>systemd-shutdown[1]: Unmounting /dev/mqueue. [ 54.456137] systemd-shutdown[1]: Unmounting /dev/mqueue. 1
phelum Posted July 12, 2016 Posted July 12, 2016 [ 2.559830] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV This looks like the U-Boot problem I hit a while ago. I have a replacement U-Boot at http://phelum.net/temp/CB1/u-boot-sunxi-with-spl.bin which might help. Cheers, Steven
ub6yac Posted July 12, 2016 Author Posted July 12, 2016 [ 2.559830] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV This looks like the U-Boot problem I hit a while ago. I have a replacement U-Boot at http://phelum.net/temp/CB1/u-boot-sunxi-with-spl.bin which might help. Yes, it looks like you are right. I did dd if=u-boot-sunxi-with-spl.bin of=/dev/sdb bs=1024 seek=8 with your file right after cat Armbian_5.14_Cubieboard_Debian_jessie_3.4.112.raw > /dev/sdb and it can boot now. Thank you.But i do not understand what should i do with this file if i will use FAT boot partition (i will try the same way). Is this situation (with u-boot) a bug? It will be fixed? Thank you.
Igor Posted July 12, 2016 Posted July 12, 2016 Is this situation (with u-boot) a bug? It will be fixed? It's a bug, corrupted settings, ... yes, this kind of problems happens from time to time on different boards, even I did severe manual testing on latest build. Edge functions usually come with limited stability - we are building images with latest stable version of mainline u-boot. It's usually fixed quickly.
walkin-corpse Posted July 23, 2016 Posted July 23, 2016 Well, same problem on my Cubieboard2 with latest legacy images. Green&white points&lines on LCD (HDMI) right after "Starting kernel" and poweroff. Boot with power button as above helps but I hope it will be fixed soon.
phelum Posted July 23, 2016 Posted July 23, 2016 Try my replacement U-Boot at http://phelum.net/temp/CB2/u-boot-sunxi-with-spl.bin and see if this helps. Cheers, Steven
Igor Posted July 24, 2016 Posted July 24, 2016 @phelumI kind of lost track on this. What are you changing in u-boot config?Edit: solved https://github.com/igorpecovnik/lib/commit/85845da4e558109ad779a2623444fad8a9b1a6f6
phelum Posted July 25, 2016 Posted July 25, 2016 (edited) Hi Igor, I built U-Boot from https://github.com/linux-sunxi/u-boot-sunxi.git and selected the sunxi branch and used the standard defconfigs (Cubieboard_config, Cubieboard2_config, and Cubietruck_config). I haven't patched or changed anything. Cheers, Steven Edited July 25, 2016 by phelum
tricolery Posted July 29, 2016 Posted July 29, 2016 Hello! I have a cubieboard 2 and I have the same problem. If I remove the 5VDC cable and wait a little while after inserting it again, my cubieboard 2 shutdown at starting kernel message. If I insert my cubianX sdcard, boot, shutdown the cubieboard2, remove the cubianX sdcard and insert armbian sdcard, my cubieboard2 boots normaly. I tried to use Phelum U-boot, but without success. Can anyone help me? Edit: I'm also using legacy kernel.
zeppa Posted July 29, 2016 Posted July 29, 2016 I have the same problem as everyone here. I have a cubieboard 2 and i'm using armbian 5.14 with legacy kernel. The u-boot provided on this thread did not work, the problem still occur. @Igor, could you please help me? I really liked Armbian and I don't really want to return to my old image. I can help with anything I can to solve this issue.
Igor Posted July 29, 2016 Posted July 29, 2016 The problem is in U-boot. Adding this: CONFIG_CMD_GPIO=y to the uboot configuration solved the problem in Cubieboard 1 ...
zeppa Posted July 29, 2016 Posted July 29, 2016 How do I add this to U-boot? U-boot is that file called cubieboard2.bin (I know how to convert it to .fex if it is needed)? Sorry for the rookie question, I have some experience with linux, but I never seen this u-boot before. Thank you!
Igor Posted July 29, 2016 Posted July 29, 2016 How do I add this to U-boot? U-boot is that file called cubieboard2.bin (I know how to convert it to .fex if it is needed)? Sorry for the rookie question, I have some experience with linux, but I never seen this u-boot before. Thank you! You need to recompile u-boot, preferable with our tools on your PC, to avoid troubles ... http://docs.armbian.com/Developer-Guide_Build-Preparation/ You can try to build on Cubie (theoretical instructions) : git clone git://git.denx.de/u-boot.git -b v2016.07 --depth 1 cd u-boot # edit and add previously mentioned parameter here nano configs/Cubieboard_defconfig make Cubieboard2_config make dd if=u-boot-sunxi-with-spl.bin of=/dev/mmcblk0 bs=1024 seek=8 reboot
zeppa Posted July 29, 2016 Posted July 29, 2016 Seems very easy to do. Thank you, Igor! I'll try to do it today at night. Only one more question, can I compile u-boot using my own cubieboard 2 and dd my sdcard while running armbian or do I need to use my computer? I dont have linux installed on it, but I'll install if needed.
Igor Posted July 29, 2016 Posted July 29, 2016 Yes, you can dd to your sdcard while running. The only problem you might face is u-boot source compiler incompatibility.
tricolery Posted July 29, 2016 Posted July 29, 2016 Thank you Igor! I'll try to compile it today. I will try to use the cubieboard to compile it too, since I also don't have linux on my computer like zeppa. I just need to add the line you mentioned anywhere at configs/Cubieboard_defconfig file.
tricolery Posted July 30, 2016 Posted July 30, 2016 (edited) The board did not boot after compiling uboot either from Igor source and phelum source. I solved it by downgrading uboot to version 5.00 in synaptic package manager. Edit: Nope. Problem still here even with 5.0. Almost giving up Edited July 30, 2016 by tricolery 1
zeppa Posted July 31, 2016 Posted July 31, 2016 Today me and tricolery solved the problem together. (We live near each other and we also bought the cubieboard2 together). We followed the steps described here: https://linux-sunxi.org/U-Bootand managed to solve our problem. We did not change anything, we just downloaded and compiled using the cubieboard2. If anyone here still have this problem and tried everything described here on this topic try these steps: git clone -b sunxi https://github.com/linux-sunxi/u-boot-sunxi.git cd u-boot-sunxi make cubieboard2_config make dd if=u-boot-sunxi-with-spl.bin of=/dev/mmcblk0 bs=1024 seek=8 reboot Dont know if this u-boot-sunxi-with-spl.bin is the newest, but it is working now. (I attached the u-boot here if anyone is interested) u-boot-sunxi-with-spl.zip 1
